#include <ossimNBandToIndexFilter.h>
| ossimNBandToIndexFilter () | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
| void | setLut (ossimNBandLutDataObject &lut) |
| void | setLut (const ossimFilename &file) |
| Will set the property whose name matches the argument "property->getName()". More... | |
| Pushes this's names onto the list of property names. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimNBandToIndexFilter () |
| void | allocate () |
| virtual ossimRefPtr< ossimImageData > | convertInputTile (ossimImageData *inputTile) |
| template<class T > | |
| ossimRefPtr< ossimImageData > | convertOutputTileTemplate (T inputDummy, ossimImageData *inputTile) |
| template<class T1 , class T2 > | |
| ossimRefPtr< ossimImageData > | convertInputTileToOutputTemplate (T1 inputDummy, T2 outputDummy, ossimImageData *inputTile) |
It will map the input data to an 8-bit index table. The table
Example keyword list:
type: ossimNBandToIndexFilter
If you want to load from a file then just do:
lut.filename: <full path="" to="" lut="" file>="">
If you have the lut table in line then it must look like this:
lut.entry0: 204 102 1 lut.entry1: 255 204 153 lut.entry2: 51 204 204 lut.number_of_entries: 3 lut.type: ossimNBandLutDataObject
Definition at line 43 of file ossimNBandToIndexFilter.h.
| ossimNBandToIndexFilter::ossimNBandToIndexFilter | ( | ) |
Initializes the min value to 0 and the max value to 4000.
Definition at line 28 of file ossimNBandToIndexFilter.cpp.
protectedvirtual |
Definition at line 36 of file ossimNBandToIndexFilter.cpp.
protected |
Definition at line 85 of file ossimNBandToIndexFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), isSourceEnabled(), ossimImageSourceFilter::theInputConnection, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
protectedvirtual |
Definition at line 137 of file ossimNBandToIndexFilter.cpp.
References convertOutputTileTemplate(), getOutputScalarType(), OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
protected |
Definition at line 215 of file ossimNBandToIndexFilter.cpp.
References ossimNBandLutDataObject::findIndex(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimNBandLutDataObject::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::isNull(), ossim::min(), OSSIM_FULL, OSSIM_PARTIAL, ossimDataObject::setDataObjectStatus(), theKeepQuantizedValueFlag, theLut, theTile, and ossimImageData::validate().
Referenced by convertOutputTileTemplate().
protected |
Definition at line 169 of file ossimNBandToIndexFilter.cpp.
References convertInputTileToOutputTemplate(), ossimRectilinearDataObject::getScalarType(), OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
Referenced by convertInputTile().
Definition at line 99 of file ossimNBandToIndexFilter.cpp.
References ossimSource::disableSource(), and theTile.
Definition at line 497 of file ossimNBandToIndexFilter.cpp.
References ossimImageSource::getMaxPixelValue(), isSourceEnabled(), and theMaxValues.
Definition at line 472 of file ossimNBandToIndexFilter.cpp.
References ossimImageSource::getMinPixelValue(), isSourceEnabled(), and theMinValues.
Definition at line 459 of file ossimNBandToIndexFilter.cpp.
References ossimNBandLutDataObject::getNullPixelIndex(), ossimImageSource::getNullPixelValue(), isSourceEnabled(), and theLut.
Definition at line 410 of file ossimNBandToIndexFilter.cpp.
References ossimNBandLutDataObject::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), isSourceEnabled(), theKeepQuantizedValueFlag, theLut, and ossimRefPtr< T >::valid().
Definition at line 430 of file ossimNBandToIndexFilter.cpp.
References ossimNBandLutDataObject::getNumberOfEntries(), ossimImageSource::getOutputScalarType(), isSourceEnabled(), OSSIM_UCHAR, OSSIM_UINT16, OSSIM_UINT32, and theLut.
| name | Name of property to return. |
Definition at line 539 of file ossimNBandToIndexFilter.cpp.
References ossimKeywordNames::FILENAME_KW, ossimFilenameProperty::ossimFilenamePropertyIoType_INPUT, and theLutFilename.
| propertyNames | array to add this's property names to. |
Definition at line 559 of file ossimNBandToIndexFilter.cpp.
References ossimKeywordNames::FILENAME_KW, and ossimImageSourceFilter::getPropertyNames().
Definition at line 105 of file ossimNBandToIndexFilter.cpp.
References allocate(), convertInputTile(), ossimRefPtr< T >::get(), ossimImageSource::getTile(), isSourceEnabled(), ossimImageData::makeBlank(), OSSIM_FULL, ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, theTile, and ossimRefPtr< T >::valid().
Definition at line 40 of file ossimNBandToIndexFilter.cpp.
References ossimNBandLutDataObject::getMinMax(), ossimNBandLutDataObject::getNullPixelIndex(), ossimImageSource::getNullPixelValue(), ossimNBandLutDataObject::getNumberOfBands(), ossimNBandLutDataObject::getNumberOfEntries(), ossimImageSourceFilter::initialize(), theKeepQuantizedValueFlag, theLut, theMaxValues, theMinValues, theNullValues, theTile, and ossimRefPtr< T >::valid().
Definition at line 387 of file ossimNBandToIndexFilter.cpp.
References ossimNBandLutDataObject::getNumberOfEntries(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), OSSIM_FLOAT32, OSSIM_FLOAT64, ossimImageSourceFilter::theInputConnection, theLut, and ossimRefPtr< T >::valid().
Referenced by allocate(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfOutputBands(), getOutputScalarType(), and getTile().
Loads the state of this object.
Definition at line 368 of file ossimNBandToIndexFilter.cpp.
References ossimString::c_str(), ossimKeywordlist::find(), ossimNBandLutDataObject::loadState(), theLut, and ossimRefPtr< T >::valid().
Saves the state of this object.
Definition at line 349 of file ossimNBandToIndexFilter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimNBandLutDataObject::saveState(), theLut, and ossimRefPtr< T >::valid().
| void ossimNBandToIndexFilter::setLut | ( | ossimNBandLutDataObject & | lut | ) |
Definition at line 454 of file ossimNBandToIndexFilter.cpp.
References theLut.
| void ossimNBandToIndexFilter::setLut | ( | const ossimFilename & | file | ) |
| property | Object containing property to set. |
Definition at line 518 of file ossimNBandToIndexFilter.cpp.
References ossimKeywordlist::addFile(), ossimKeywordNames::FILENAME_KW, ossimProperty::getName(), ossimNBandLutDataObject::loadState(), theLut, and ossimProperty::valueToString().
protected |
Definition at line 122 of file ossimNBandToIndexFilter.h.
Referenced by convertInputTileToOutputTemplate(), getNumberOfOutputBands(), and initialize().
protected |
Definition at line 119 of file ossimNBandToIndexFilter.h.
Referenced by convertInputTileToOutputTemplate(), getNullPixelValue(), getNumberOfOutputBands(), getOutputScalarType(), initialize(), isSourceEnabled(), loadState(), saveState(), setLut(), and setProperty().
protected |
Definition at line 121 of file ossimNBandToIndexFilter.h.
Referenced by getProperty().
protected |
Definition at line 124 of file ossimNBandToIndexFilter.h.
Referenced by getMaxPixelValue(), and initialize().
protected |
Definition at line 123 of file ossimNBandToIndexFilter.h.
Referenced by getMinPixelValue(), and initialize().
protected |
Definition at line 125 of file ossimNBandToIndexFilter.h.
Referenced by initialize().
protected |
Definition at line 120 of file ossimNBandToIndexFilter.h.
Referenced by allocate(), convertInputTile(), convertInputTileToOutputTemplate(), convertOutputTileTemplate(), disableSource(), getTile(), and initialize().
