#include <ossimMeanMedianFilter.h>
Public Types | |
| enum | ossimMeanMedianFilterType { OSSIM_MEDIAN = 0, OSSIM_MEDIAN_FILL_NULLS = 1, OSSIM_MEDIAN_NULL_CENTER_ONLY = 2, OSSIM_MEAN = 3, OSSIM_MEAN_FILL_NULLS = 4, OSSIM_MEAN_NULL_CENTER_ONLY = 5 } |
| ossimMeanMedianFilter (ossimObject *owner=NULL) | |
| virtual | ~ossimMeanMedianFilter () |
| void | setWindowSize (ossim_uint32 windowSize) |
| ossim_uint32 | getWindowSize () const |
| void | setAutoGrowRectFlag (bool flag) |
| bool | getAutoGrowRectFlag () const |
| void | setFilterType (ossimMeanMedianFilterType type) |
| void | setFilterType (const ossimString &type) |
| ossimString | getFilterTypeString () const |
| void | getFilterTypeList (std::vector< ossimString > &list) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | applyFilter (ossimRefPtr< ossimImageData > &input) |
| template<class T > | |
| void | applyMean (T dummyVariable, ossimRefPtr< ossimImageData > &inputData) |
| void | applyMeanNullCenterOnly (T dummyVariable, ossimRefPtr< ossimImageData > &inputData) |
| void | applyMedian (T dummyVariable, ossimRefPtr< ossimImageData > &inputData) |
| void | applyMedianNullCenterOnly (T dummyVariable, ossimRefPtr< ossimImageData > &inputData) |
Protected Attributes | |
| ossimRefPtr< ossimImageData > | theTile |
| ossimMeanMedianFilterType | theFilterType |
| ossim_uint32 | theWindowSize |
| bool | theEnableFillNullFlag |
| Used by applyMean and applyMedian for "fill null" modes. More... | |
| bool | theAutoGrowRectFlag |
| If true rectangle is expanded by half filter in each direction if the theFilterType fills nulls. More... | |
Protected Attributes inherited from ossimImageSourceFilter | |
| ossimImageSource * | theInputConnection |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Protected Attributes inherited from ossimListener | |
| bool | theListenerEnableFlag |
class ossimMeanMedianFilter
Allows you to change between a median or mean filter. You can also specify a window size which the median or mean is computed and the center pixel is replaced.
Definition at line 25 of file ossimMeanMedianFilter.h.
Definition at line 29 of file ossimMeanMedianFilter.h.
| ossimMeanMedianFilter::ossimMeanMedianFilter | ( | ossimObject * | owner = NULL | ) |
Definition at line 33 of file ossimMeanMedianFilter.cpp.
References ossimConnectableObject::setDescription().
Definition at line 44 of file ossimMeanMedianFilter.cpp.
protected |
Definition at line 108 of file ossimMeanMedianFilter.cpp.
References applyMean(), applyMeanNullCenterOnly(), applyMedian(), applyMedianNullCenterOnly(), ossimRectilinearDataObject::getScalarType(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_MEAN, OSSIM_MEAN_FILL_NULLS, OSSIM_MEAN_NULL_CENTER_ONLY, OSSIM_MEDIAN, OSSIM_MEDIAN_FILL_NULLS, OSSIM_MEDIAN_NULL_CENTER_ONLY, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, and theFilterType.
Referenced by getTile().
protected |
Definition at line 289 of file ossimMeanMedianFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossim::min(), OSSIM_FULL, status, theEnableFillNullFlag, theTile, theWindowSize, x, and y.
Referenced by applyFilter().
protected |
Definition at line 413 of file ossimMeanMedianFilter.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::loadTile(), ossim::min(), OSSIM_FULL, status, theTile, theWindowSize, x, and y.
protected |
Definition at line 508 of file ossimMeanMedianFilter.cpp.
protected |
Definition at line 628 of file ossimMeanMedianFilter.cpp.
| bool ossimMeanMedianFilter::getAutoGrowRectFlag | ( | ) | const |
Definition at line 879 of file ossimMeanMedianFilter.cpp.
References theAutoGrowRectFlag.
Definition at line 904 of file ossimMeanMedianFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimIrect::hasNans(), ossimIrect::lr(), OSSIM_MEAN_FILL_NULLS, OSSIM_MEAN_NULL_CENTER_ONLY, OSSIM_MEDIAN_FILL_NULLS, OSSIM_MEDIAN_NULL_CENTER_ONLY, ossimIrect::set_lr(), ossimIrect::set_ul(), theAutoGrowRectFlag, theFilterType, theWindowSize, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
| void ossimMeanMedianFilter::getFilterTypeList | ( | std::vector< ossimString > & | list | ) | const |
Definition at line 891 of file ossimMeanMedianFilter.cpp.
References OSSIM_MEAN_NULL_CENTER_ONLY.
Referenced by getFilterTypeString(), and setFilterType().
| ossimString ossimMeanMedianFilter::getFilterTypeString | ( | ) | const |
Definition at line 884 of file ossimMeanMedianFilter.cpp.
References getFilterTypeList(), and theFilterType.
Definition at line 750 of file ossimMeanMedianFilter.cpp.
Definition at line 786 of file ossimMeanMedianFilter.cpp.
Definition at line 48 of file ossimMeanMedianFilter.cpp.
References applyFilter(), ossimImageData::dup(), ossimImageSource::getTile(), getWindowSize(), ossimSource::isSourceEnabled(), ossimIrect::lr(), ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), ossimImageData::setImageRectangleAndBands(), theEnableFillNullFlag, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
| ossim_uint32 ossimMeanMedianFilter::getWindowSize | ( | ) | const |
Definition at line 96 of file ossimMeanMedianFilter.cpp.
References theWindowSize.
Definition at line 101 of file ossimMeanMedianFilter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
Definition at line 815 of file ossimMeanMedianFilter.cpp.
References ossimKeywordlist::find().
Definition at line 796 of file ossimMeanMedianFilter.cpp.
References ossimKeywordlist::add().
| void ossimMeanMedianFilter::setAutoGrowRectFlag | ( | bool | flag | ) |
| flag | Set "theAutoGrowRectFlag". This only affects filter types that set nulls. Will have a growing affect on the edges. |
Definition at line 874 of file ossimMeanMedianFilter.cpp.
| void ossimMeanMedianFilter::setFilterType | ( | ossimMeanMedianFilterType | type | ) |
Definition at line 842 of file ossimMeanMedianFilter.cpp.
References theFilterType.
| void ossimMeanMedianFilter::setFilterType | ( | const ossimString & | type | ) |
Definition at line 847 of file ossimMeanMedianFilter.cpp.
References ossimString::downcase(), getFilterTypeList(), OSSIM_MEAN_FILL_NULLS, OSSIM_MEDIAN_FILL_NULLS, theEnableFillNullFlag, and theFilterType.
Definition at line 720 of file ossimMeanMedianFilter.cpp.
References ossimRefPtr< T >::valid().
| void ossimMeanMedianFilter::setWindowSize | ( | ossim_uint32 | windowSize | ) |
Definition at line 91 of file ossimMeanMedianFilter.cpp.
protected |
Definition at line 109 of file ossimMeanMedianFilter.h.
Referenced by getAutoGrowRectFlag(), getBoundingRect(), and setAutoGrowRectFlag().
protected |
Definition at line 103 of file ossimMeanMedianFilter.h.
Referenced by applyMean(), applyMedian(), getTile(), and setFilterType().
protected |
Definition at line 99 of file ossimMeanMedianFilter.h.
Referenced by applyFilter(), getBoundingRect(), getFilterTypeString(), and setFilterType().
protected |
Definition at line 98 of file ossimMeanMedianFilter.h.
Referenced by applyMean(), applyMeanNullCenterOnly(), applyMedian(), applyMedianNullCenterOnly(), getTile(), and initialize().
protected |
Definition at line 100 of file ossimMeanMedianFilter.h.
Referenced by applyMean(), applyMeanNullCenterOnly(), applyMedian(), applyMedianNullCenterOnly(), getBoundingRect(), getWindowSize(), and setWindowSize().
