Contains class declaration for ossimVideoImageSource. More...
#include <ossimVideoImageSource.h>
| virtual bool | setFrameTime (const double &t) |
| Sets the time stamp (in seconds from start of video) for the frame of interest. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Changes the frame to the new index (frame count from start of video). More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Currently assuming all videos are 8-bit RGB. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0)=0 |
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *object) const |
| From ossimConnectableObject base class. Returns true if object is an ossimVideoSource. More... | |
| Video frames have no overviews, only full-res. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimVideoImageSource (ossimVideoSource *video, const double &frame_time_seconds=0) | |
| Constructor used when accessing a common video object (versus instantiating a new video for each frame. More... | |
| ossimVideoImageSource () | |
| Default Constructor. More... | |
| Common initialization code for all construction methods. More... | |
This is the ossimImageSource-derived class representing a single frame in a video stream.
Definition at line 27 of file ossimVideoImageSource.h.
protected |
Definition at line 33 of file ossimVideoImageSource.cpp.
References initialize(), and setFrameTime().
protected |
Definition at line 24 of file ossimVideoImageSource.cpp.
Implements ossimConnectableObject.
Definition at line 189 of file ossimVideoImageSource.cpp.
References PTR_CAST.
Definition at line 198 of file ossimVideoImageSource.cpp.
Definition at line 208 of file ossimVideoImageSource.cpp.
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 173 of file ossimVideoImageSource.cpp.
References ossimVideoGeometry::getImageGeometry(), ossimConnectableObject::getInput(), ossimVideoSource::getVideoGeometry(), m_frameTime, and ossimRefPtr< T >::valid().
inlinevirtual |
Definition at line 43 of file ossimVideoImageSource.h.
inlinevirtual |
Definition at line 42 of file ossimVideoImageSource.h.
inlinevirtual |
Definition at line 58 of file ossimVideoImageSource.h.
inlinevirtual |
Implements ossimImageSource.
Definition at line 46 of file ossimVideoImageSource.h.
This will necessarily change the image geometry. Returns false if frame count is outside of allowable range.
Definition at line 149 of file ossimVideoImageSource.cpp.
References ossimIrect::height(), and m_frameRect.
inlinevirtual |
Definition at line 47 of file ossimVideoImageSource.h.
Definition at line 161 of file ossimVideoImageSource.cpp.
References m_frameRect, and ossimIrect::width().
inlinevirtual |
Definition at line 48 of file ossimVideoImageSource.h.
References OSSIM_UINT8.
pure virtual |
protectedvirtual |
Definition at line 44 of file ossimVideoImageSource.cpp.
References ossimImageDataFactory::create(), ossimVideoSource::frameSize(), ossimConnectableObject::getInput(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_frameRect, m_tile, ossimImageData::setHeight(), and ossimImageData::setWidth().
Referenced by ossimVideoImageSource().
Returns false if frame time is outside of allowable range.
This will necessarily change the image geometry. Returns false if frame time is outside of allowable range.
Definition at line 122 of file ossimVideoImageSource.cpp.
References ossimVideoSource::duration(), ossimConnectableObject::getInput(), m_frameTime, ossimVideoSource::seek(), and ossimVideoSource::SEEK_ABSOLUTE.
protected |
Always (0,0) based.
Definition at line 72 of file ossimVideoImageSource.h.
Referenced by getNumberOfLines(), getNumberOfSamples(), and initialize().
protected |
Definition at line 71 of file ossimVideoImageSource.h.
Referenced by getImageGeometry(), and setFrameTime().
protected |
Definition at line 73 of file ossimVideoImageSource.h.
Referenced by initialize().
