#include <ossimDoqqTileSource.h>
| ossimDoqqTileSource () | |
| ossimString | getShortName () const |
| ossimString | getLongName () const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| bool | open (const ossimFilename &filename) |
| bool | open (const ossimGeneralRasterInfo &info) |
| ossimString | acqdate () const |
| Gets a property for matching name. More... | |
| Gets a list of property names available. More... | |
Public Member Functions inherited from ossimGeneralRasterTileSource | |
| ossimGeneralRasterTileSource () | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| Pure virtual open. More... | |
| Override base getXXXXPixValue methods since the null/min/max can be set to something different. More... | |
| Initializes bandList to the zero based order of output bands. More... | |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimDoqqTileSource () |
Protected Member Functions inherited from ossimGeneralRasterTileSource | |
| virtual | ~ossimGeneralRasterTileSource () |
| virtual bool | fillBuffer (const ossimIpt &origin, const ossimIpt &size) |
| Methods return true on succes false on error. More... | |
| virtual bool | fillBIP (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBIL (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBSQ (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBsqMultiFile (const ossimIpt &origin, const ossimIpt &size) |
| virtual ossimKeywordlist | getHdrInfo (ossimFilename hdrFile) |
| virtual ossimKeywordlist | getXmlInfo (ossimFilename xmlFile) |
| bool | initializeHandler () |
Definition at line 17 of file ossimDoqqTileSource.h.
| ossimDoqqTileSource::ossimDoqqTileSource | ( | ) |
Definition at line 25 of file ossimDoqqTileSource.cpp.
protectedvirtual |
Definition at line 30 of file ossimDoqqTileSource.cpp.
References theHeaderInformation.
| ossimString ossimDoqqTileSource::acqdate | ( | ) | const |
The geometry contains full-to-local image transform as well as projection (image-to-world)
Reimplemented from ossimGeneralRasterTileSource.
Definition at line 77 of file ossimDoqqTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::DATUM_KW, ossimRefPtr< T >::get(), ossimImageHandler::initImageParameters(), ossimImageGeometry::loadState(), ossimKeywordNames::METERS_PER_PIXEL_X_KW, ossimKeywordNames::METERS_PER_PIXEL_Y_KW, ossimDoqq::theDatum, ossimDoqq::theEasting, ossimImageHandler::theGeometry, ossimDoqq::theGsd, theHeaderInformation, ossimDoqq::theNorthing, ossimDoqq::theProjection, ossimDoqq::theUtmZone, ossimKeywordNames::TIE_POINT_EASTING_KW, ossimKeywordNames::TIE_POINT_NORTHING_KW, ossimString::trim(), ossimKeywordNames::TYPE_KW, ossimString::upcase(), ossimRefPtr< T >::valid(), ossimDpt::x, ossimDpt::y, and ossimKeywordNames::ZONE_KW.
Definition at line 247 of file ossimDoqqTileSource.cpp.
| name | The name of the property to get. |
Definition at line 171 of file ossimDoqqTileSource.cpp.
References ossimString::c_str(), ossimImageHandler::getProperty(), ossimDoqq::theAcqDay, ossimDoqq::theAcqMonth, ossimDoqq::theAcqYear, theHeaderInformation, and ossimRefPtr< T >::valid().
| propertyNames | The list to push back names to. |
Definition at line 192 of file ossimDoqqTileSource.cpp.
References ossimImageHandler::getPropertyNames().
Definition at line 242 of file ossimDoqqTileSource.cpp.
Definition at line 200 of file ossimDoqqTileSource.cpp.
References ossimDoqq::errorStatus(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimImageHandler::loadState(), ossimGeneralRasterInfo::NONE, ossimGeneralRasterTileSource::open(), OSSIM_BIP, ossimDoqq::OSSIM_OK, OSSIM_UCHAR, theHeaderInformation, ossimDoqq::theHeaderSize, ossimDoqq::theLine, ossimDoqq::theRgb, and ossimDoqq::theSample.
Definition at line 35 of file ossimDoqqTileSource.cpp.
References ossimDoqq::errorStatus(), ossimGeneralRasterInfo::NONE, ossimGeneralRasterTileSource::open(), OSSIM_BIP, ossimDoqq::OSSIM_ERROR, OSSIM_UCHAR, ossimString::push_back(), theAcqDate, ossimDoqq::theAcqDay, ossimDoqq::theAcqMonth, ossimDoqq::theAcqYear, theHeaderInformation, ossimDoqq::theHeaderSize, ossimDoqq::theLine, ossimDoqq::theRgb, and ossimDoqq::theSample.
Definition at line 252 of file ossimDoqqTileSource.cpp.
References ossimGeneralRasterTileSource::open().
protected |
Definition at line 53 of file ossimDoqqTileSource.h.
protected |
Definition at line 52 of file ossimDoqqTileSource.h.
Referenced by getImageGeometry(), getProperty(), loadState(), open(), and ~ossimDoqqTileSource().
