#include <ossimTiffTileSource.h>
Public Types | |
| enum | ReadMethod { UNKNOWN, READ_RGBA_U8_TILE, READ_RGBA_U8_STRIP, READ_RGBA_U8A_STRIP, READ_SCAN_LINE, READ_TILE, READ_U16_STRIP } |
| ossimTiffTileSource () | |
| virtual bool | open (const ossimFilename &image_file) |
| Returns true if the image_file can be opened and is a valid tiff file. More... | |
| bool | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) |
| This open takes a stream and stores/captures the shared pointer on success. More... | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Initializes bandList to the zero based order of output bands. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Returns the number of lines in the image. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Returns the number of samples in the image. More... | |
| virtual ossim_uint32 | getNumberOfDirectories () const |
| Returns the number of image file directories in the tiff image. More... | |
| Returns the number of reduced resolution data sets (rrds). More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | hasR0 () const |
| Returns true if the first directory of the tiff image did not have the reduced resolution file type set. More... | |
| virtual ossim_float64 | getMinPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getMaxPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getNullPixelValue (ossim_uint32 band=0) const |
| void | setApplyColorPaletteFlag (bool flag) |
| bool | getApplyColorPaletteFlag () const |
| bool | isColorMapped () const |
| virtual std::ostream & | print (std::ostream &os) const |
| TIFF * | tiffPtr () |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimTiffTileSource () |
| bool | open () |
| Returns true if no errors initializing object. More... | |
Private Member Functions | |
| void | adjustToStartOfTile (ossimIpt &pt) const |
| Adjust point to even tile boundary. More... | |
| ossim_uint32 | getCurrentTiffRLevel () const |
| If the tiff source has R0 then this returns the current tiff directory that the tiff pointer is pointing to; else, it returns the current directory + 1. More... | |
| ossimString | getReadMethod (ossim_uint32 directory) const |
| bool | loadTile (const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *result) |
| bool | loadFromRgbaU8Tile (const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *result) |
| bool | loadFromRgbaU8Strip (const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *result) |
| bool | loadFromRgbaU8aStrip (const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *result) |
| bool | loadFromU16Strip (const ossimIrect &clip_rect, ossimImageData *result) |
| bool | loadFromScanLine (const ossimIrect &clip_rect, ossimImageData *result) |
| bool | loadFromTile (const ossimIrect &clip_rect, ossimImageData *result) |
| void | setReadMethod () |
| bool | setTiffDirectory (ossim_uint16 directory) |
| Change tiff directory and sets theCurrentDirectory. More... | |
| void | populateLut () |
| void | validateMinMaxNull () |
| validateMinMaxNull Checks min, max and null to make sure they are not equal to the scalar type nan or double nan; sets to default min max if so. More... | |
| bool | isPowerOfTwoDecimation (ossim_uint32 dir) const |
| Checks line/samples of level for power of two decimation from the previous rlevel. More... | |
| void | allocateTile () |
| Allocates theTile. More... | |
| bool | allocateBuffer () |
| Allocates theBuffer. More... | |
Friends | |
| class | TiffStreamAdaptor |
Definition at line 35 of file ossimTiffTileSource.h.
| Enumerator | |
| UNKNOWN | |
| READ_RGBA_U8_TILE | |
| READ_RGBA_U8_STRIP | |
| READ_RGBA_U8A_STRIP | |
| READ_SCAN_LINE | |
| READ_TILE | |
| READ_U16_STRIP | |
Definition at line 39 of file ossimTiffTileSource.h.
| ossimTiffTileSource::ossimTiffTileSource | ( | ) |
Definition at line 68 of file ossimTiffTileSource.cpp.
protectedvirtual |
Definition at line 105 of file ossimTiffTileSource.cpp.
References close().
private |
Assumes 0,0 origin. Shifts in the upper left direction.
Definition at line 1865 of file ossimTiffTileSource.cpp.
References abs, theCurrentDirectory, theImageTileLength, theImageTileWidth, ossimIpt::x, and ossimIpt::y.
Referenced by loadFromRgbaU8Tile(), and loadFromTile().
private |
Definition at line 2604 of file ossimTiffTileSource.cpp.
References ossimNotify(), ossimNotifyLevel_WARN, print(), READ_RGBA_U8_STRIP, READ_RGBA_U8_TILE, READ_RGBA_U8A_STRIP, READ_SCAN_LINE, READ_TILE, READ_U16_STRIP, theBytesPerPixel, theCurrentDirectory, theCurrentTileHeight, theImageTileLength, theImageTileWidth, theImageWidth, thePlanarConfig, theReadMethod, theRowsPerStrip, and theSamplesPerPixel.
Referenced by getTile(), and loadTile().
private |
Allocates theTile.
Definition at line 2577 of file ossimTiffTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::getHeight(), getNumberOfOutputBands(), getOutputScalarType(), ossimImageData::getWidth(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theCurrentTileHeight, theCurrentTileWidth, theOutputBandList, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Reimplemented in ossimplugins::ossimTerraSarTiffReader, and ossimplugins::ossimRadarSat2TiffReader.
Definition at line 366 of file ossimTiffTileSource.cpp.
References ossimImageHandler::close(), m_streamAdaptor, theBuffer, theBufferSize, theImageLength, theImageTileLength, theImageTileWidth, theImageWidth, thePhotometric, thePlanarConfig, theReadMethod, theRowsPerStrip, and theTiffPtr.
Referenced by ossimplugins::ossimRadarSat2TiffReader::close(), ossimplugins::ossimTerraSarTiffReader::close(), open(), and ~ossimTiffTileSource().
| bool ossimTiffTileSource::getApplyColorPaletteFlag | ( | ) | const |
Definition at line 2037 of file ossimTiffTileSource.cpp.
References theApplyColorPaletteFlag.
private |
Definition at line 1918 of file ossimTiffTileSource.cpp.
References theCurrentTiffRlevel.
Referenced by getTile(), and loadFromScanLine().
Implements ossimImageHandler.
Definition at line 1972 of file ossimTiffTileSource.cpp.
References isOpen(), theCurrentDirectory, and theImageTileLength.
Referenced by getTileHeight().
Definition at line 1959 of file ossimTiffTileSource.cpp.
References isOpen(), theCurrentDirectory, and theImageTileWidth.
Referenced by getTileWidth().
Reimplemented in ossimplugins::ossimRadarSat2TiffReader, and ossimplugins::ossimTerraSarTiffReader.
Definition at line 2042 of file ossimTiffTileSource.cpp.
Definition at line 2196 of file ossimTiffTileSource.cpp.
References ossimImageHandler::getMaxPixelValue(), ossimImageMetaData::getNumberOfBands(), theMaxSampleValue, and ossimImageHandler::theMetaData.
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 2187 of file ossimTiffTileSource.cpp.
References ossimImageHandler::getMinPixelValue(), ossimImageMetaData::getNumberOfBands(), ossimImageHandler::theMetaData, and theMinSampleValue.
Definition at line 2205 of file ossimTiffTileSource.cpp.
References ossimImageHandler::getNullPixelValue(), ossimImageMetaData::getNumberOfBands(), ossimImageHandler::theMetaData, and theNullSampleValue.
Notes:
Definition at line 1004 of file ossimTiffTileSource.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), theImageDirectoryList, ossimImageHandler::theOverview, theR0isFullRes, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
Referenced by isValidRLevel().
Definition at line 1954 of file ossimTiffTileSource.cpp.
References theNumberOfDirectories.
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 2107 of file ossimTiffTileSource.cpp.
References theSamplesPerPixel.
Referenced by getNumberOfOutputBands().
Definition at line 922 of file ossimTiffTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), isValidRLevel(), theImageDirectoryList, theImageLength, ossimImageHandler::theOverview, theR0isFullRes, ossimImageHandler::theStartingResLevel, theTiffPtr, and ossimRefPtr< T >::valid().
Definition at line 2112 of file ossimTiffTileSource.cpp.
References getNumberOfInputBands(), and theOutputBandList.
Referenced by allocateTile(), and getTile().
Definition at line 965 of file ossimTiffTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), isValidRLevel(), theImageDirectoryList, theImageWidth, ossimImageHandler::theOverview, theR0isFullRes, ossimImageHandler::theStartingResLevel, theTiffPtr, and ossimRefPtr< T >::valid().
Referenced by loadFromScanLine().
Definition at line 2165 of file ossimTiffTileSource.cpp.
References ossimImageSource::getOutputBandList(), and theOutputBandList.
Definition at line 1025 of file ossimTiffTileSource.cpp.
References theScalarType.
Referenced by allocateTile().
Definition at line 2319 of file ossimTiffTileSource.cpp.
References ossimImageHandler::getProperty(), and theApplyColorPaletteFlag.
Definition at line 2337 of file ossimTiffTileSource.cpp.
References ossimImageHandler::getPropertyNames().
private |
Definition at line 1924 of file ossimTiffTileSource.cpp.
References READ_RGBA_U8_STRIP, READ_RGBA_U8_TILE, READ_RGBA_U8A_STRIP, READ_SCAN_LINE, READ_TILE, theReadMethod, and UNKNOWN.
Referenced by print().
Definition at line 2047 of file ossimTiffTileSource.cpp.
Satisfies pure virtual from TileSource class.
Definition at line 110 of file ossimTiffTileSource.cpp.
References allocateTile(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 135 of file ossimTiffTileSource.cpp.
References allocateBuffer(), ossimIrect::clipToRect(), ossimIrect::completely_within(), getCurrentTiffRLevel(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimImageHandler::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::height(), ossimImageData::initialize(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), isValidRLevel(), loadTile(), ossimImageData::makeBlank(), OSSIM_NULL, ossimReferenced::ref(), setTiffDirectory(), status, theCurrentTileHeight, theCurrentTileWidth, theImageDirectoryList, theR0isFullRes, ossimImageHandler::theStartingResLevel, ossimImageData::validate(), and ossimIrect::width().
Definition at line 1997 of file ossimTiffTileSource.cpp.
References ossim::defaultTileSize(), getImageTileHeight(), and ossimIpt::y.
Definition at line 1985 of file ossimTiffTileSource.cpp.
References ossim::defaultTileSize(), getImageTileWidth(), and ossimIpt::x.
| bool ossimTiffTileSource::hasR0 | ( | ) | const |
Definition at line 2182 of file ossimTiffTileSource.cpp.
References theR0isFullRes.
Indicates whether or not the image handler can control output band selection via the setOutputBandList method.
Overrides: ossimImageHandler::isBandSelector
Definition at line 2122 of file ossimTiffTileSource.cpp.
References ossimImageHandler::isBandSelector(), isOpen(), READ_TILE, ossimImageHandler::theOverview, thePlanarConfig, theReadMethod, and ossimRefPtr< T >::valid().
Referenced by saveState(), and setOutputBandList().
| bool ossimTiffTileSource::isColorMapped | ( | ) | const |
Definition at line 2214 of file ossimTiffTileSource.cpp.
References theTiffPtr.
Referenced by setApplyColorPaletteFlag().
Definition at line 2177 of file ossimTiffTileSource.cpp.
Referenced by getImageTileHeight(), getImageTileWidth(), getTile(), isBandSelector(), and open().
private |
Used to weed out thumbnail directories being used as a reduced resolution layer.
Note this shuts off the thumbnail which someone may want to see. We could make this a reader prop if it becomes an issue. drb - 09 Jan. 2012.
| dir | The tiff directory index. |
Definition at line 2558 of file ossimTiffTileSource.cpp.
References theImageLength, and theImageWidth.
Determines if the passed in reslution level is valid.
If this reader is used as an overview the caller should pass in a resLevel relative to the full image.
| resLevel | zero base resolution level. |
Definition at line 1896 of file ossimTiffTileSource.cpp.
References getNumberOfDecimationLevels(), theR0isFullRes, and ossimImageHandler::theStartingResLevel.
Referenced by getNumberOfLines(), getNumberOfSamples(), and getTile().
private |
Definition at line 1630 of file ossimTiffTileSource.cpp.
References ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getWidth(), ossimIrect::lr(), ossimNotify(), ossimNotifyLevel_WARN, theBytesPerPixel, theCurrentDirectory, theRowsPerStrip, theSamplesPerPixel, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
Referenced by loadTile().
private |
Definition at line 1474 of file ossimTiffTileSource.cpp.
References CLOG, ossimIrect::completely_within(), ossimImageData::getBuf(), ossimImageData::getWidth(), ossimIrect::lr(), OSSIM_TIFF_UNPACK_B4, OSSIM_TIFF_UNPACK_G4, OSSIM_TIFF_UNPACK_R4, ossimNotify(), ossimNotifyLevel_WARN, theBuffer, theBufferRect, theBufferRLevel, theBytesPerPixel, theCurrentDirectory, theImageLength, theImageWidth, theRowsPerStrip, theSamplesPerPixel, theTiffPtr, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 1316 of file ossimTiffTileSource.cpp.
References adjustToStartOfTile(), ossimIrect::lr(), ossimNotify(), ossimNotifyLevel_WARN, theBytesPerPixel, theCurrentDirectory, theImageTileLength, theImageTileWidth, theSamplesPerPixel, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 1082 of file ossimTiffTileSource.cpp.
References ossimIrect::completely_within(), ossimImageData::copyLine(), getCurrentTiffRLevel(), ossimImageHandler::getImageRectangle(), getNumberOfSamples(), ossimImageData::loadTile(), ossimIrect::lr(), OSSIM_BIL, OSSIM_BIP, ossimIrect::set_lry(), ossimIrect::set_uly(), theBuffer, theBufferRect, theBufferRLevel, theBytesPerPixel, theCurrentDirectory, thePlanarConfig, theSamplesPerPixel, theTiffPtr, ossimIrect::ul(), and ossimIpt::y.
private |
Definition at line 1175 of file ossimTiffTileSource.cpp.
References adjustToStartOfTile(), ossimIrect::clipToRect(), ossimIrect::intersects(), ossimImageData::loadTile(), ossimIrect::lr(), OSSIM_BIP, theBuffer, theCurrentDirectory, theImageTileLength, theImageTileWidth, thePlanarConfig, theTiffPtr, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 1770 of file ossimTiffTileSource.cpp.
References ossimIrect::completely_within(), ossimIrect::lr(), status, theBuffer, theBufferRect, theBufferRLevel, theCurrentDirectory, theImageLength, theImageWidth, theRowsPerStrip, theSamplesPerPixel, theTiffPtr, ossimIrect::ul(), and ossimIpt::y.
Definition at line 318 of file ossimTiffTileSource.cpp.
References ossimKeywordNames::BANDS_KW, ossimKeywordlist::findKey(), ossimImageHandler::loadState(), open(), ossimString::size(), ossimString::string(), theApplyColorPaletteFlag, theOutputBandList, ossimString::toBool(), and ossim::toSimpleVector().
Referenced by ossimplugins::ossimRadarSat2TiffReader::loadState(), and ossimplugins::ossimTerraSarTiffReader::loadState().
private |
Definition at line 1030 of file ossimTiffTileSource.cpp.
References allocateBuffer(), loadFromRgbaU8aStrip(), loadFromRgbaU8Strip(), loadFromRgbaU8Tile(), loadFromScanLine(), loadFromTile(), loadFromU16Strip(), ossimNotify(), ossimNotifyLevel_WARN, READ_RGBA_U8_STRIP, READ_RGBA_U8_TILE, READ_RGBA_U8A_STRIP, READ_SCAN_LINE, READ_TILE, READ_U16_STRIP, status, theBuffer, theCurrentDirectory, and theReadMethod.
Definition at line 356 of file ossimTiffTileSource.cpp.
References close(), open(), ossimImageHandler::theImageFile, and theTiffPtr.
Referenced by ossimImageHandlerFactory::open(), ossimQuickbirdRpcModel::parseTiffFile(), and ossimIkonosRpcModel::parseTiffFile().
| bool ossimTiffTileSource::open | ( | std::shared_ptr< ossim::istream > & | str, |
| const std::string & | connectionString | ||
| str | Open stream to image. |
| connectionString | Stored on success as the file name. |
Definition at line 396 of file ossimTiffTileSource.cpp.
References close(), isOpen(), m_streamAdaptor, theImageDirectoryList, ossimImageHandler::theImageFile, and theTiffPtr.
protectedvirtual |
Notes:
Definition at line 901 of file ossimTiffTileSource.cpp.
Referenced by loadState(), ossimplugins::ossimRadarSat2TiffReader::open(), ossimplugins::ossimTerraSarTiffReader::open(), and open().
private |
Definition at line 2378 of file ossimTiffTileSource.cpp.
References OSSIM_UINT16, OSSIM_UINT8, theBitsPerSample, ossimImageHandler::theLut, theTiffPtr, and ossim::toSimpleVector().
Definition at line 2052 of file ossimTiffTileSource.cpp.
References ossimString::c_str(), getReadMethod(), ossimSource::print(), theBitsPerSample, ossimImageHandler::theImageFile, theImageLength, theImageTileLength, theImageTileWidth, theImageWidth, theMaxSampleValue, theMinSampleValue, theNullSampleValue, theNumberOfDirectories, ossimImageHandler::theOverview, thePhotometric, thePlanarConfig, theR0isFullRes, theRowsPerStrip, theSampleFormatUnit, theSamplesPerPixel, theTile, and ossimRefPtr< T >::valid().
Referenced by allocateBuffer().
Definition at line 285 of file ossimTiffTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::BANDS_KW, isBandSelector(), ossimImageHandler::isIdentityBandList(), ossimImageHandler::saveState(), theApplyColorPaletteFlag, theOutputBandList, and ossim::toSimpleStringList().
Referenced by ossimplugins::ossimRadarSat2TiffReader::saveState(), and ossimplugins::ossimTerraSarTiffReader::saveState().
| void ossimTiffTileSource::setApplyColorPaletteFlag | ( | bool | flag | ) |
Definition at line 2009 of file ossimTiffTileSource.cpp.
References isColorMapped(), setReadMethod(), theApplyColorPaletteFlag, theBuffer, thePhotometric, theSamplesPerPixel, and theTile.
Referenced by setProperty().
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled.
Overrides: ossimImageHandler::setOutputBandList
Definition at line 2146 of file ossimTiffTileSource.cpp.
References ossimImageData::getNumberOfBands(), isBandSelector(), ossimImageHandler::setOutputBandList(), theOutputBandList, theTile, and ossimRefPtr< T >::valid().
Definition at line 2302 of file ossimTiffTileSource.cpp.
References ossimProperty::getName(), setApplyColorPaletteFlag(), ossimImageHandler::setProperty(), ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
private |
Definition at line 2228 of file ossimTiffTileSource.cpp.
References ossim::COMPRESSION_NONE, READ_RGBA_U8_STRIP, READ_RGBA_U8_TILE, READ_RGBA_U8A_STRIP, READ_SCAN_LINE, READ_TILE, READ_U16_STRIP, theBitsPerSample, theCompressionType, theNumberOfDirectories, thePhotometric, thePlanarConfig, theReadMethod, theRowsPerStrip, theSamplesPerPixel, and UNKNOWN.
private |
Definition at line 2344 of file ossimTiffTileSource.cpp.
References status, theCurrentDirectory, theCurrentTiffRlevel, and theTiffPtr.
inline |
Definition at line 222 of file ossimTiffTileSource.h.
Referenced by ossimTiffProjectionFactory::createProjection().
private |
Definition at line 2436 of file ossimTiffTileSource.cpp.
References ossimString::c_str(), ossim::defaultMax(), ossim::defaultMin(), ossim::defaultNull(), ossim::isnan(), OSSIM_FLOAT32, ossimKeywordlist::parseStream(), ossimTiffInfo::print(), ossimImageHandler::theImageFile, theMaxSampleValue, theMinSampleValue, theNullSampleValue, and theScalarType.
friend |
Definition at line 38 of file ossimTiffTileSource.h.
private |
Definition at line 378 of file ossimTiffTileSource.h.
private |
Definition at line 362 of file ossimTiffTileSource.h.
Referenced by getApplyColorPaletteFlag(), getProperty(), loadState(), saveState(), and setApplyColorPaletteFlag().
private |
Definition at line 350 of file ossimTiffTileSource.h.
Referenced by populateLut(), print(), and setReadMethod().
private |
Definition at line 342 of file ossimTiffTileSource.h.
Referenced by close(), loadFromRgbaU8Strip(), loadFromScanLine(), loadFromTile(), loadFromU16Strip(), loadTile(), and setApplyColorPaletteFlag().
private |
Definition at line 344 of file ossimTiffTileSource.h.
Referenced by loadFromRgbaU8Strip(), loadFromScanLine(), and loadFromU16Strip().
private |
Definition at line 345 of file ossimTiffTileSource.h.
private |
Definition at line 343 of file ossimTiffTileSource.h.
Referenced by close().
private |
Definition at line 360 of file ossimTiffTileSource.h.
Referenced by allocateBuffer(), loadFromRgbaU8aStrip(), loadFromRgbaU8Strip(), loadFromRgbaU8Tile(), and loadFromScanLine().
private |
Definition at line 376 of file ossimTiffTileSource.h.
Referenced by setReadMethod().
private |
Definition at line 358 of file ossimTiffTileSource.h.
Referenced by adjustToStartOfTile(), allocateBuffer(), getImageTileHeight(), getImageTileWidth(), loadFromRgbaU8aStrip(), loadFromRgbaU8Strip(), loadFromRgbaU8Tile(), loadFromScanLine(), loadFromTile(), loadFromU16Strip(), loadTile(), and setTiffDirectory().
private |
Definition at line 375 of file ossimTiffTileSource.h.
Referenced by getCurrentTiffRLevel(), and setTiffDirectory().
private |
Definition at line 347 of file ossimTiffTileSource.h.
Referenced by allocateBuffer(), allocateTile(), and getTile().
private |
Definition at line 346 of file ossimTiffTileSource.h.
private |
Definition at line 373 of file ossimTiffTileSource.h.
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), getTile(), and open().
private |
Definition at line 366 of file ossimTiffTileSource.h.
Referenced by close(), getNumberOfLines(), isPowerOfTwoDecimation(), loadFromRgbaU8Strip(), loadFromU16Strip(), and print().
private |
Definition at line 372 of file ossimTiffTileSource.h.
Referenced by adjustToStartOfTile(), allocateBuffer(), close(), getImageTileHeight(), loadFromRgbaU8Tile(), loadFromTile(), and print().
private |
Definition at line 371 of file ossimTiffTileSource.h.
Referenced by adjustToStartOfTile(), allocateBuffer(), close(), getImageTileWidth(), loadFromRgbaU8Tile(), loadFromTile(), and print().
private |
Definition at line 365 of file ossimTiffTileSource.h.
Referenced by allocateBuffer(), close(), getNumberOfSamples(), isPowerOfTwoDecimation(), loadFromRgbaU8Strip(), loadFromU16Strip(), and print().
private |
Definition at line 353 of file ossimTiffTileSource.h.
Referenced by getMaxPixelValue(), print(), and validateMinMaxNull().
private |
Definition at line 354 of file ossimTiffTileSource.h.
Referenced by getMinPixelValue(), print(), and validateMinMaxNull().
private |
Definition at line 355 of file ossimTiffTileSource.h.
Referenced by getNullPixelValue(), print(), and validateMinMaxNull().
private |
Definition at line 357 of file ossimTiffTileSource.h.
Referenced by getNumberOfDirectories(), print(), and setReadMethod().
private |
Definition at line 377 of file ossimTiffTileSource.h.
Referenced by allocateTile(), getNumberOfOutputBands(), getOutputBandList(), loadState(), saveState(), and setOutputBandList().
private |
Definition at line 369 of file ossimTiffTileSource.h.
Referenced by close(), print(), setApplyColorPaletteFlag(), and setReadMethod().
private |
Definition at line 368 of file ossimTiffTileSource.h.
Referenced by allocateBuffer(), close(), isBandSelector(), loadFromScanLine(), loadFromTile(), print(), and setReadMethod().
private |
Definition at line 359 of file ossimTiffTileSource.h.
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), getTile(), hasR0(), isValidRLevel(), and print().
private |
Definition at line 367 of file ossimTiffTileSource.h.
Referenced by allocateBuffer(), close(), getReadMethod(), isBandSelector(), loadTile(), and setReadMethod().
private |
Definition at line 370 of file ossimTiffTileSource.h.
Referenced by allocateBuffer(), close(), loadFromRgbaU8aStrip(), loadFromRgbaU8Strip(), loadFromU16Strip(), print(), and setReadMethod().
private |
Definition at line 351 of file ossimTiffTileSource.h.
private |
Definition at line 349 of file ossimTiffTileSource.h.
Referenced by allocateBuffer(), getNumberOfInputBands(), loadFromRgbaU8aStrip(), loadFromRgbaU8Strip(), loadFromRgbaU8Tile(), loadFromScanLine(), loadFromU16Strip(), print(), setApplyColorPaletteFlag(), and setReadMethod().
private |
Definition at line 361 of file ossimTiffTileSource.h.
Referenced by getOutputScalarType(), and validateMinMaxNull().
protected |
Definition at line 252 of file ossimTiffTileSource.h.
Referenced by close(), getNumberOfLines(), getNumberOfSamples(), isColorMapped(), isOpen(), loadFromRgbaU8Strip(), loadFromScanLine(), loadFromTile(), loadFromU16Strip(), open(), populateLut(), and setTiffDirectory().
private |
Definition at line 340 of file ossimTiffTileSource.h.
Referenced by allocateTile(), getTile(), print(), setApplyColorPaletteFlag(), and setOutputBandList().
