Finds auto-tie-points using the descriptor-based matching algorithm. More...
#include <ossimDescriptorSource.h>
Classes | |
| struct | SortFunc |
| ossimDescriptorSource (AtpGenerator *generator) | |
| virtual | ~ossimDescriptorSource () |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 rLevel=0) |
| Derived classes implement their particular tiepoint matching algorithms for the requested tile. More... | |
Public Member Functions inherited from ATP::AtpTileSource | |
| AtpTileSource (AtpGenerator *generator) | |
| virtual | ~AtpTileSource () |
| AtpList & | getTiePoints () |
| This list resets with every getTile() call , so make sure tiepoints from previous getTile() calls are being accumulated. More... | |
| void | filterPoints () |
| void | setTiePoints (ossim::TiePointList &atpList) |
| Used for testing. More... | |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Private Member Functions | |
| ossimDescriptorSource () | |
| ossimDescriptorSource (ossimConnectableObject::ConnectableObjectList &inputSources) | |
Private Attributes | |
| struct ATP::ossimDescriptorSource::SortFunc | sortFunc |
| unsigned int | m_cmpPatchInflation |
Definition at line 23 of file ossimDescriptorSource.h.
| ATP::ossimDescriptorSource::ossimDescriptorSource | ( | AtpGenerator * | generator | ) |
Definition at line 32 of file ossimDescriptorSource.cpp.
Definition at line 38 of file ossimDescriptorSource.cpp.
private |
Definition at line 21 of file ossimDescriptorSource.cpp.
private |
Definition at line 26 of file ossimDescriptorSource.cpp.
References initialize().
It is not clear what the output tile needs to be, since the product of this filter is the list of tiepoints (available through the getTiePoints() method). Recommend simply passing through the corresponding REF image tile.
Implements ATP::AtpTileSource.
Definition at line 69 of file ossimDescriptorSource.cpp.
References ATP::AtpTileSource::allocate(), ossim::JsonParam::asString(), ossim::JsonParam::asUint(), CINFO, ATP::convertToIpl(), CWARN, ossim::JsonConfig::diagnosticLevel(), ossimIrect::expand(), ATP::AtpTileSource::filterPoints(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimConnectableObject::getNumberOfInputs(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), m_cmpPatchInflation, ATP::AtpTileSource::m_generator, ATP::AtpTileSource::m_tiePoints, ATP::AtpTileSource::m_tile, n, OSSIM_EMPTY, ossim::JsonConfig::paramExists(), ossimImageData::setImageRectangle(), sortFunc, ossimString::upcase(), and ossimImageData::write().
Reimplemented from ATP::AtpTileSource.
Definition at line 42 of file ossimDescriptorSource.cpp.
References ossimSensorModel::getNominalPosError(), ATP::AtpTileSource::initialize(), m_cmpPatchInflation, ATP::AtpTileSource::m_generator, ossimDpt::x, and ossimDpt::y.
Referenced by ossimDescriptorSource().
private |
Definition at line 44 of file ossimDescriptorSource.h.
Referenced by getTile(), and initialize().
private |
Referenced by getTile().
