#include <ossimMaskFilter.h>
Public Types | |
| enum | ossimFileSelectionMaskType { OSSIM_MASK_TYPE_SELECT = 1, OSSIM_MASK_TYPE_INVERT = 2, OSSIM_MASK_TYPE_WEIGHTED = 3, OSSIM_MASK_TYPE_BINARY = 4, OSSIM_MASK_TYPE_BINARY_INVERSE = 5, OSSIM_MASK_TYPE_SELECT_CLAMP_MIN = 6 } |
| Enumeration used to identify what the selection type for this mask is to be used: More... | |
| ossimMaskFilter (ossimObject *owner=NULL) | |
| Default Constructor. More... | |
| void | setMaskSource (ossimImageSource *maskSource) |
| This set method is necessary when this object is being added to an ossimImageChain because ossimImageChain::addLast() performs a disconnect of all the input sources, thus losing the assignments made via constructor accepting source pointers. More... | |
| virtual void | setMaskType (ossimFileSelectionMaskType type) |
| Sets the mask type. More... | |
| virtual void | setMaskType (const ossimString &type) |
| Sets the mask type from string. More... | |
| virtual ossimFileSelectionMaskType | getMaskType () const |
| Returns the current mask algorithm used. More... | |
| virtual ossimString | getMaskTypeString () const |
| Returns the current mask algorithm used as a string. More... | |
| Main entry point for the algorithm. More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *object) const |
| virtual ossimRefPtr< ossimImageData > | executeMaskFilter (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
| Interface to set the mask type. More... | |
| Adds "mask_type" to list. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimMaskFilter () |
| Will delete its owned tile. More... | |
| void | allocate () |
| ossimRefPtr< ossimImageData > | executeMaskFilterSelect (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
| will execute the section algorithm. More... | |
| ossimRefPtr< ossimImageData > | executeMaskFilterInvertSelect (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
| will execute the invert selection algorithm. More... | |
| ossimRefPtr< ossimImageData > | executeMaskFilterWeighted (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
| will execute the weighted algorithm. More... | |
| ossimRefPtr< ossimImageData > | executeMaskFilterBinary (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
| Will execute the binary algorithm. More... | |
| template<class inputT , class maskT > | |
| ossimRefPtr< ossimImageData > | executeMaskFilterSelection (inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
| ossimRefPtr< ossimImageData > | executeMaskFilterInvertSelection (inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
| ossimRefPtr< ossimImageData > | executeMaskFilterWeighted (inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
| ossimRefPtr< ossimImageData > | executeMaskFilterBinarySelection (inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData) |
Protected Attributes | |
| ossimFileSelectionMaskType | theMaskType |
| Member variable that holds the algorithm type to run on the calls to getTile. More... | |
| ossimRefPtr< ossimImageData > | theTile |
| Member used to store the result of the applied algorithm type. More... | |
| ossimRefPtr< ossimImageSource > | theMaskSource |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
class ossimMaskFilter
Requires 2 inputs. The first input is assumed to be the image input and the second input is assumed to be the mask data. It will only use one band of the mask and multi band masks are not supported.
the number of bands, min pix, max pix, null pix ...etc are mapped to the first input.
Keywords: mask_type:
keywords description: This keyword can have the following values: select, select_clamp, invert, weighted, binary, or binary_inverse
example of keywords:mask_type: select
Definition at line 61 of file ossimMaskFilter.h.
Definition at line 89 of file ossimMaskFilter.h.
| ossimMaskFilter::ossimMaskFilter | ( | ossimObject * | owner = NULL | ) |
Definition at line 28 of file ossimMaskFilter.cpp.
protectedvirtual |
protected |
Definition at line 110 of file ossimMaskFilter.cpp.
References ossimImageDataFactory::create(), ossimConnectableObject::getInput(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and theTile.
Referenced by getTile().
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 95 of file ossimMaskFilter.cpp.
References PTR_CAST.
Definition at line 119 of file ossimMaskFilter.cpp.
References ossimImageData::dup(), executeMaskFilterBinary(), executeMaskFilterInvertSelect(), executeMaskFilterSelect(), executeMaskFilterWeighted(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getOrigin(), ossimImageData::getWidth(), ossimImageData::initialize(), ossimImageData::loadTile(), OSSIM_MASK_TYPE_BINARY, OSSIM_MASK_TYPE_BINARY_INVERSE, OSSIM_MASK_TYPE_INVERT, OSSIM_MASK_TYPE_SELECT, OSSIM_MASK_TYPE_SELECT_CLAMP_MIN, OSSIM_MASK_TYPE_WEIGHTED, ossimDataObject::setDataObjectStatus(), ossimImageData::setOrigin(), ossimImageData::setWidthHeight(), theMaskType, and theTile.
protected |
Copies the values in the mask to each tile. Values will be either NULL or MAX pixel value, typically 0 or 255.
Definition at line 379 of file ossimMaskFilter.cpp.
References executeMaskFilterBinarySelection(), ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
Referenced by executeMaskFilter().
protected |
Definition at line 668 of file ossimMaskFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), OSSIM_MASK_TYPE_BINARY_INVERSE, theMaskType, theTile, and ossimImageData::validate().
Referenced by executeMaskFilterBinary().
protected |
everywhere the mask is 0 it copies the input data to the output else it outputs null.
Definition at line 243 of file ossimMaskFilter.cpp.
References executeMaskFilterInvertSelection(), ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
protected |
Definition at line 524 of file ossimMaskFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, theTile, and ossimImageData::validate().
Referenced by executeMaskFilterInvertSelect().
protected |
everywhere the mask is not 0 it copies the input data to the output and everywhere the input is null it writes a null pixel to the output.
Definition at line 174 of file ossimMaskFilter.cpp.
References executeMaskFilterSelection(), ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
protected |
Definition at line 448 of file ossimMaskFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_MASK_TYPE_SELECT, OSSIM_NULL, theMaskType, theTile, and ossimImageData::validate().
Referenced by executeMaskFilterSelect().
protected |
It normalizes the mask value to be between 0 and 1 and multiplies the input data by that value and outputs it.
Definition at line 311 of file ossimMaskFilter.cpp.
References ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
protected |
Definition at line 588 of file ossimMaskFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, OSSIM_PARTIAL, theTile, and ossimImageData::validate().
Definition at line 751 of file ossimMaskFilter.cpp.
References theMaskType.
Definition at line 756 of file ossimMaskFilter.cpp.
References OSSIM_MASK_TYPE_BINARY, OSSIM_MASK_TYPE_BINARY_INVERSE, OSSIM_MASK_TYPE_INVERT, OSSIM_MASK_TYPE_SELECT, OSSIM_MASK_TYPE_SELECT_CLAMP_MIN, OSSIM_MASK_TYPE_WEIGHTED, and theMaskType.
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 871 of file ossimMaskFilter.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getNumberOfInputBands(), and PTR_CAST.
Definition at line 841 of file ossimMaskFilter.cpp.
Definition at line 865 of file ossimMaskFilter.cpp.
References ossimImageSource::getPropertyNames().
| rect |
Definition at line 46 of file ossimMaskFilter.cpp.
References allocate(), executeMaskFilter(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimImageSource::getTile(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), OSSIM_NULL, PTR_CAST, ossimImageData::setImageRectangle(), ossimImageData::setOrigin(), theMaskSource, theTile, ossimIrect::ul(), and ossimRefPtr< T >::valid().
Referenced by ossimOverviewSequencer::getNextTile().
Definition at line 101 of file ossimMaskFilter.cpp.
References ossimConnectableObject::getInput(), and theTile.
Definition at line 797 of file ossimMaskFilter.cpp.
References ossimKeywordlist::find(), ossimImageSource::loadState(), ossimConnectableObject::setNumberOfInputs(), ossimConnectableObject::theInputListIsFixedFlag, and ossimConnectableObject::theOutputListIsFixedFlag.
Definition at line 815 of file ossimMaskFilter.cpp.
References ossimKeywordlist::add().
| void ossimMaskFilter::setMaskSource | ( | ossimImageSource * | maskSource | ) |
If the intent is to insert this object in place of the image handler in a chain, First remove the handler from the chain, then add a default-constructed mask filter object, then call this method to assign the inputs.
Definition at line 41 of file ossimMaskFilter.cpp.
References theMaskSource.
Sets the mask type.
| type | The mask algorithm type to be used. see ossimFileSelectionMaskType |
Definition at line 712 of file ossimMaskFilter.cpp.
Valid strings are: "select", "invert" and "weighted".
| type | The mask algorithm type to be used. |
Definition at line 717 of file ossimMaskFilter.cpp.
References ossimString::downcase(), OSSIM_MASK_TYPE_BINARY, OSSIM_MASK_TYPE_BINARY_INVERSE, OSSIM_MASK_TYPE_INVERT, OSSIM_MASK_TYPE_SELECT, OSSIM_MASK_TYPE_SELECT_CLAMP_MIN, OSSIM_MASK_TYPE_WEIGHTED, and theMaskType.
Definition at line 826 of file ossimMaskFilter.cpp.
References ossimProperty::getName(), and ossimRefPtr< T >::valid().
protected |
Definition at line 261 of file ossimMaskFilter.h.
Referenced by getTile(), and setMaskSource().
protected |
Definition at line 254 of file ossimMaskFilter.h.
Referenced by executeMaskFilter(), executeMaskFilterBinarySelection(), executeMaskFilterSelection(), getMaskType(), getMaskTypeString(), and setMaskType().
protected |
This is returned from the call to getTile.
Definition at line 260 of file ossimMaskFilter.h.
Referenced by allocate(), executeMaskFilter(), executeMaskFilterBinary(), executeMaskFilterBinarySelection(), executeMaskFilterInvertSelect(), executeMaskFilterInvertSelection(), executeMaskFilterSelect(), executeMaskFilterSelection(), executeMaskFilterWeighted(), getTile(), and initialize().
