| | ossimScalarRemapper () |
| | ossimScalarRemapper (ossimImageSource *inputSource, ossimScalarType outputScalarType) |
| virtual | ~ossimScalarRemapper () |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| | Returns the output pixel type of the tile source. More...
| virtual ossimString | getOutputScalarTypeString () const |
| | Returns the output pixel type of the tile source as a string. More...
| virtual void | setOutputScalarType (ossimScalarType scalarType) |
| | Sets the output scalar type. More...
| virtual void | setOutputScalarType (ossimString scalarType) |
| virtual void | setPreserveMagnitude (bool value) |
| virtual double | getNullPixelValue (ossim_uint32 band) const |
| | Sets the current resolution level. More...
| | Returns the min pixel of the band. More...
| | Returns the max pixel of the band. More...
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| | Method to save the state of an object to a keyword list. More...
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| | Method to the load (recreate) the state of an object from a keyword list. More...
| | Override base class so that a disableSource event does not reinitialize the object and enable itself. More...
| | ossimImageSourceFilter (ossimObject *owner=NULL) |
| | ossimImageSourceFilter (ossimImageSource *inputSource) |
| | ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) |
| | required to be overriden by derived classes More...
| | ossimImageSource (ossimObject *owner=0) |
| | ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| | Method to get a tile. More...
| | For RTTI support. More...
| | Will return the decimation factor for the given resolution level. More...
| | Will return an array of all decimations for each resolution level. More...
| | Will return the number of resolution levels. More...
| | Returns the number of bands in a tile returned from this TileSource. More...
| | Returns the default processing tile width. More...
| | Returns the default processing tile height. More...
| | This will return the bounding rect of the source. More...
| | Gets the bounding rectangle of the source. More...
| | ordering specifies how the vertices should be arranged. More...
| | Returns the image geometry object associated with this tile source or NULL if not defined. More...
| | Default implementation sets geometry of the first input to the geometry specified. More...
| | Default method to call input's saveImageGeometry. More...
| | ossimSource (ossimObject *owner=0) |
| | ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| virtual | ~ossimSource () |
| | Outputs theErrorStatus as an ossimErrorCode and an ossimString. More...
| | ossimConnectableObject (ossimObject *owner=0) |
| | Base constructor of this object. More...
| | ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
| | All connectable objects will have id's. More...
| | Will allow us to get this object's id. More...
| | Fetches the current owner, most likely a container but not limited to one. More...
| | Permits changing the object's owner. More...
| | will check the direction specified to see if all slots are full. More...
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) |
| | Return a valid index of the input list if the passed in object is found else return -1. More...
| | Return a valid index of the input list if the passed id is found else return -1. More...
| | Return a valid index of the output list if the passed in object is found else return -1. More...
| | Should return the first available index to connect to. More...
| | default implementation is to allow anyone to connect to us. More...
| | Will disconnect the object passed in. More...
| | Will disconnect the object at the given input index and generate a connection event. More...
| | Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More...
| | Will disconnect the object at the given output index and generate a connection event. More...
| | Will disconnect the output object. More...
| | Will disconnect all of the input objects. More...
| | Will disconnect all of the output objects. More...
| | Will try to connect this objects input to the passed in object. More...
| | Will connect the specified input to the passed in object. More...
| | Will try to connect this objects output to the passed in object. More...
| | Will disconnect itself from all inputs and reset to the passed in input list. More...
| | Will disconnect itself from all outputs and reset to the passed in output list. More...
| | Returns the number of input objects. More...
| | Return the number of output objects. More...
| | returns the object at the specified index. More...
| | Will set the number of inputs. More...
| | Will set the number of outputs. More...
| | OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) |
| | OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) |
| | Save the state of all inputs to a keyword list. More...
| | Inserts this object and all of its children and inputs into the container provided. More...
| | Moves the input connection matching id up one in the connection list. More...
| | Moves the input connection matching id down one in the connection list. More...
| | Moves the input connection matching id to the top of the connection list. More...
| | Moves the input connection matching id to the bottom of the connection list. More...
| | We will add a visitor interface for all connectable objects. More...
| | ossimObject () |
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
| | ossimListenerManager () |
| | ossimPropertyInterface () |
| | ossimErrorStatusInterface () |
| bool | hasError () const |
| | ossimConnectableObjectListener () |
| | ProcessEvent. More...
| | ossimListener () |
| void | enableListener () |
| void | disableListener () |
