#include <ossimImageCacheTileSource.h>
| ossimImageCacheTileSource () | |
| Default constructor. More... | |
| This method is defined in the base class ossimObject. More... | |
| virtual void | close () |
| Closes this image handler and deletes any allocated data. More... | |
| virtual bool | open () |
| Pure virtual open. More... | |
| Returns a pointer to an ossimImageDataObject given a rectangluar region of interest. More... | |
| This method allows you to query the scalar type of the output data. More... | |
| This method allows you to query the number of input bands. More... | |
| This method allows one to query the number of output bands. More... | |
Public Member Functions inherited from ossimImageCacheBase | |
| ossimImageCacheBase () | |
| Satisfies pure virtual requirement from ImageHandler class. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Method to load the state of an object from a keyword list. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| bool | isOpen () const |
| Determines if its open if there eists a table of contents object. More... | |
Populates the geometry object with image geometry information. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimImageCacheTileSource () |
| Destructor. More... | |
| void | fillTile (const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile) |
| bool | buildFrameEntryArray (ossimFilename imageFile) |
Protected Member Functions inherited from ossimImageCacheBase | |
| virtual | ~ossimImageCacheBase () |
| void | setActualImageRect () |
| Will shift the rect and clamp it so not to go outside the -180 to 180 degree range. More... | |
| void | checkLongitude (ossim_float64 &leftLon, const ossim_float64 &rightLon) const |
| Method to test for 180.0 <–> 180.00 and set leftLon to -180 if both left and right are 180.0 degrees. More... | |
| vector< ossimFrameEntryData > | getIntersectingEntries (const ossimIrect &rect) |
| It is important to note that each frame is organized into an easting northing type orientation. More... | |
| void | deleteAll () |
| bool | buildFrameEntryArray (ossimFilename imageFile, ossim_uint32 frameWidth, ossim_uint32 frameHeight) |
Definition at line 18 of file ossimImageCacheTileSource.h.
| ossimImageCacheTileSource::ossimImageCacheTileSource | ( | ) |
Initializes all internal attributes to a default state.
Definition at line 44 of file ossimImageCacheTileSource.cpp.
protectedvirtual |
Destructor.
Will return allocated memory back to the heap.
Definition at line 55 of file ossimImageCacheTileSource.cpp.
protected |
Definition at line 127 of file ossimImageCacheTileSource.cpp.
Reimplemented from ossimImageCacheBase.
Definition at line 75 of file ossimImageCacheTileSource.cpp.
protected |
| tileRect | Region to fill. |
| framesInvolved | All intersecting frames used to render the region. |
Definition at line 262 of file ossimImageCacheTileSource.cpp.
References ossimIrect::clipToRect(), ossimImageData::dup(), ossimImageData::getBuf(), ossimIrect::height(), ossimImageHandlerRegistry::instance(), ossimImageData::loadTile(), ossimImageData::makeBlank(), ossimImageHandlerRegistry::open(), ossimImageHandler::open(), OSSIM_BSQ, ossimFilterResampler::resample(), ossimImageData::setImageRectangle(), ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
This class overrides the default implementation to return its own long name.
Definition at line 69 of file ossimImageCacheTileSource.cpp.
Definition at line 403 of file ossimImageCacheTileSource.cpp.
References ossimImageHandler::getMaxPixelValue(), and ossim::isnan().
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 394 of file ossimImageCacheTileSource.cpp.
References ossimImageHandler::getMinPixelValue(), and ossim::isnan().
Definition at line 412 of file ossimImageCacheTileSource.cpp.
References ossimImageHandler::getNullPixelValue(), and ossim::isnan().
If an image is band selectable this will allow one to select the bands you wish to read in. This indicates that the number of input bands might not match the number of output bands.
Definition at line 421 of file ossimImageCacheTileSource.cpp.
This might not be the same as the n umber of input bands.
Definition at line 430 of file ossimImageCacheTileSource.cpp.
This is simply the data type, i.e. whether its OSSIM_FLOAT, OSSIM_DOUBLE, OSSIM_UCHAR, ... etc. This means that if there are bands of different scalar types from a single image then they must be casted to the highest precision type.
Definition at line 385 of file ossimImageCacheTileSource.cpp.
References OSSIM_UCHAR.
This class overrides the default implementation to return its own short name.
Definition at line 64 of file ossimImageCacheTileSource.cpp.
| rect | The region of interest to return. |
| resLevel | From which resolution set are we querying (default is 0 full res). |
Definition at line 186 of file ossimImageCacheTileSource.cpp.
References OSSIM_NULL, and ossimImageData::setImageRectangle().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 206 of file ossimImageCacheTileSource.cpp.
References ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), ossimIrect::intersects(), ossimImageData::makeBlank(), status, and ossimImageData::validate().
Pure virtual open.
Derived classes must implement.
Implements ossimImageCacheBase.
Definition at line 80 of file ossimImageCacheTileSource.cpp.
protected |
Definition at line 146 of file ossimImageCacheTileSource.h.
protected |
Definition at line 148 of file ossimImageCacheTileSource.h.
protected |
Definition at line 147 of file ossimImageCacheTileSource.h.
protected |
Definition at line 149 of file ossimImageCacheTileSource.h.
protected |
This is the actual data returned from a getTile request.
Definition at line 144 of file ossimImageCacheTileSource.h.
