An image mosaic is a simple combiner that will just do a simple mosaic. More...
#include <ossimElevationMosaic.h>
| ossimElevationMosaic () | |
| ossimElevationMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimElevationMosaic () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| template<class T > | |
| ossimRefPtr< ossimImageData > | combine (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| ossimRefPtr< ossimImageData > | combineNorm (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
It just checks NULL pix values until it finds a pixel that is not empty and copies it out to the output. The list will have same size tiles and have the same number of bands.
Definition at line 26 of file ossimElevationMosaic.h.
| ossimElevationMosaic::ossimElevationMosaic | ( | ) |
Definition at line 23 of file ossimElevationMosaic.cpp.
| ossimElevationMosaic::ossimElevationMosaic | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 30 of file ossimElevationMosaic.cpp.
protectedvirtual |
Definition at line 37 of file ossimElevationMosaic.cpp.
protected |
Definition at line 243 of file ossimElevationMosaic.cpp.
References ossimImageDataFactory::create(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and theTile.
Referenced by getTile().
protected |
Definition at line 411 of file ossimElevationMosaic.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageCombiner::getNextNormTile(), ossimImageCombiner::getNextTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, ossimImageCombiner::theLargestNumberOfInputBands, theTile, and ossimRefPtr< T >::valid().
protected |
= srcBandsNullPix[band])
Definition at line 266 of file ossimElevationMosaic.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageCombiner::getNextNormTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, ossimImageCombiner::theLargestNumberOfInputBands, theTile, and ossimRefPtr< T >::valid().
Definition at line 41 of file ossimElevationMosaic.cpp.
References allocate(), combine(), combineNorm(), ossimImageData::getHeight(), ossimImageCombiner::getNextTile(), ossimConnectableObject::getNumberOfInputs(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getWidth(), ossimImageCombiner::hasDifferentInputs(), ossimIrect::height(), ossimImageData::initialize(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT32, OSSIM_SINT8, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_UINT32, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setHeight(), ossimImageData::setOrigin(), ossimImageData::setWidth(), size, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), and ossimIrect::width().
Reimplemented from ossimImageCombiner.
Definition at line 237 of file ossimElevationMosaic.cpp.
References ossimImageCombiner::initialize(), and theTile.
Definition at line 260 of file ossimElevationMosaic.cpp.
References ossimImageCombiner::loadState().
Definition at line 254 of file ossimElevationMosaic.cpp.
References ossimImageCombiner::saveState().
protected |
Definition at line 59 of file ossimElevationMosaic.h.
Referenced by allocate(), combine(), combineNorm(), getTile(), and initialize().
