#include <ossimGdalOgrVectorAnnotation.h>
| ossimGdalOgrVectorAnnotation (ossimImageSource *inputSource=0) | |
| virtual | ~ossimGdalOgrVectorAnnotation () |
| virtual bool | open () |
| virtual bool | open (const ossimFilename &file) |
| virtual void | close () |
| virtual ossimFilename | getFilename () const |
| virtual bool | setView (ossimObject *baseObject) |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
| virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () const |
| virtual void | computeBoundingRect () |
| virtual void | drawAnnotations (ossimRefPtr< ossimImageData > tile) |
| virtual void | setBrushColor (const ossimRgbVector &brushColor) |
| virtual void | setPenColor (const ossimRgbVector &penColor) |
| virtual ossimRgbVector | getPenColor () const |
| virtual ossimRgbVector | getBrushColor () const |
| virtual double | getPointRadius () const |
| virtual void | setPointRadius (double r) |
| virtual bool | getFillFlag () const |
| virtual void | setFillFlag (bool flag) |
| virtual void | setThickness (ossim_int32 thickness) |
| virtual ossim_int32 | getThickness () const |
| std::multimap< long, ossimAnnotationObject * > | getFeatureTable () |
| void | setQuery (const ossimString &query) |
| void | setGeometryBuffer (ossim_float64 distance, ossimUnitType type) |
| void | initializeBoundingRec (vector< ossimGpt > points) |
| bool | setCurrentEntry (ossim_uint32 entryIdx) |
Public Member Functions inherited from ossimAnnotationSource | |
| ossimAnnotationSource (ossimImageSource *inputSource=0) | |
| virtual | ~ossimAnnotationSource () |
| virtual void | setNumberOfBands (ossim_uint32 bands) |
| virtual bool | addObject (ossimAnnotationObject *anObject) |
| virtual bool | deleteObject (ossimAnnotationObject *anObject) |
| AnnotationObjectListType | pickObjects (const ossimDpt &imagePoint) |
| AnnotationObjectListType | pickObjects (const ossimDrect &imageRect) |
| const AnnotationObjectListType & | getObjectList () const |
| AnnotationObjectListType & | getObjectList () |
| void | deleteAll () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimViewInterface | |
| ossimViewInterface () | |
| ossimViewInterface (ossimObject *base) | |
| virtual | ~ossimViewInterface () |
| virtual void | refreshView () |
| ossimObject * | getBaseObject () |
| void | computeDefaultView () |
| void | transformObjectsFromView () |
| Uses theViewProjection. More... | |
| void | loadPoint (long id, OGRPoint *point, ossimMapProjection *mapProj) |
| void | loadMultiPoint (long id, OGRMultiPoint *multiPoint, ossimMapProjection *mapProj) |
| void | loadMultiPolygon (long id, OGRMultiPolygon *multiPolygon, ossimMapProjection *mapProj) |
| void | loadPolygon (long id, OGRPolygon *polygon, ossimMapProjection *mapProj) |
| void | loadLineString (long id, OGRLineString *lineString, ossimMapProjection *mapProj) |
| void | loadMultiLineString (long id, OGRMultiLineString *multiLineString, ossimMapProjection *mapProj) |
| void | getFeatures (std::list< long > &result, const ossimIrect &rect) |
| void | getFeature (vector< ossimAnnotationObject *> &featureList, long id) |
| ossimProjection * | createProjFromReference (OGRSpatialReference *reference) const |
| void | initializeTables () |
| void | deleteTables () |
| void | updateAnnotationSettings () |
| void | loadExternalGeometryFile () |
| Will set theViewProjection if geometry file is present with projection. More... | |
| void | loadExternalImageGeometryFromXml () |
| Will set theViewProjection if xml file is present with projection. More... | |
| void | loadOmdFile () |
| Looks for "file.omd" and loads pen, brush and point settings if present. More... | |
| void | getDefaults () |
| Will set thePenColor and theBrushColor if keyword found in preferences. More... | |
| void | verifyViewParams () |
| Checks for nan scale and tie point. More... | |
Protected Member Functions inherited from ossimAnnotationSource | |
| void | allocate (const ossimIrect &rect) |
| void | destroy () |
| ossimAnnotationSource (const ossimAnnotationSource &rhs) | |
Public Types inherited from ossimAnnotationSource | |
| typedef std::vector< ossimRefPtr< ossimAnnotationObject > > | AnnotationObjectListType |
Definition at line 35 of file ossimGdalOgrVectorAnnotation.h.
| ossimGdalOgrVectorAnnotation::ossimGdalOgrVectorAnnotation | ( | ossimImageSource * | inputSource = 0 | ) |
Definition at line 197 of file ossimGdalOgrVectorAnnotation.cpp.
References getDefaults(), ossimDrect::makeNan(), ossimAnnotationSource::setNumberOfBands(), theImageBound, and ossimViewInterface::theObject.
Definition at line 229 of file ossimGdalOgrVectorAnnotation.cpp.
References close(), and ossimViewInterface::theObject.
Definition at line 235 of file ossimGdalOgrVectorAnnotation.cpp.
References deleteTables(), theDataSource, theImageGeometry, and ossimRefPtr< T >::valid().
Referenced by ossimOgrGdalTileSource::close(), and ~ossimGdalOgrVectorAnnotation().
Reimplemented from ossimAnnotationSource.
Definition at line 726 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimDrect::combine(), ossimAnnotationObject::getBoundingRect(), ossimDrect::hasNans(), ossimDrect::makeNan(), PTR_CAST, ossimDrect::stretchOut(), theFeatureCacheTable, and theImageBound.
Referenced by transformObjectsFromView().
protected |
Definition at line 683 of file ossimGdalOgrVectorAnnotation.cpp.
References ossim::cosd(), isOpen(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimEquDistCylProjection::setOrigin(), ossimMapProjection::setUlGpt(), theBoundingExtent, theImageGeometry, and ossimRefPtr< T >::valid().
protected |
Definition at line 1555 of file ossimGdalOgrVectorAnnotation.cpp.
protected |
Definition at line 1520 of file ossimGdalOgrVectorAnnotation.cpp.
References theFeatureCacheTable, theLayerTable, and ossimReferenced::unref().
Referenced by close(), and loadState().
Definition at line 760 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimGeoAnnotationPolyObject::draw(), ossimObject::dup(), ossimRefPtr< T >::get(), ossimRgbVector::getB(), getFeature(), getFeatures(), ossimRgbVector::getG(), ossimImageData::getImageRectangle(), ossimRgbVector::getR(), initializeTables(), m_needPenColor, PTR_CAST, ossimGeoAnnotationPolyObject::setColor(), ossimRgbImage::setCurrentImageData(), ossimGeoAnnotationPolyObject::setFillFlag(), ossimGeoAnnotationPolyObject::setThickness(), theFeatureCacheTable, theFillFlag, theImageGeometry, thePenColor, theThickness, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Will return the bounding rectangle.
Definition at line 721 of file ossimGdalOgrVectorAnnotation.cpp.
References theImageBound.
Referenced by ossimOgrGdalTileSource::getImageRectangle(), ossimOgrGdalTileSource::getNumberOfLines(), and ossimOgrGdalTileSource::getNumberOfSamples().
Definition at line 2095 of file ossimGdalOgrVectorAnnotation.cpp.
References theBrushColor.
protected |
Keyword example: shapefile_normalized_rgb_pen_color: 0.004 1.0 0.004 shapefile_normalized_rgb_brush_color: 0.004 1.0 0.004
Definition at line 2374 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimPreferences::instance().
Referenced by ossimGdalOgrVectorAnnotation().
protected |
Definition at line 1543 of file ossimGdalOgrVectorAnnotation.cpp.
References theFeatureCacheTable.
Referenced by drawAnnotations().
protected |
Definition at line 1221 of file ossimGdalOgrVectorAnnotation.cpp.
References isOpen(), ossimGpt::latd(), ossimIrect::ll(), ossimImageGeometry::localToWorld(), ossimGpt::lond(), ossimIrect::lr(), max, min, theImageGeometry, theLayersToRenderFlagList, theLayerTable, ossimIrect::ul(), ossimIrect::ur(), and ossimRefPtr< T >::valid().
| std::multimap< long, ossimAnnotationObject * > ossimGdalOgrVectorAnnotation::getFeatureTable | ( | ) |
Definition at line 2527 of file ossimGdalOgrVectorAnnotation.cpp.
References initializeTables(), and theFeatureCacheTable.
Referenced by ossimOgrGdalTileSource::getFeatureTable().
Definition at line 248 of file ossimGdalOgrVectorAnnotation.cpp.
References theFilename.
Definition at line 2110 of file ossimGdalOgrVectorAnnotation.cpp.
References theFillFlag.
The geometry contains full-to-local image transform as well as projection (image-to-world)
Definition at line 678 of file ossimGdalOgrVectorAnnotation.cpp.
References theImageGeometry.
Referenced by ossimOgrGdalTileSource::getInternalImageGeometry().
Definition at line 2090 of file ossimGdalOgrVectorAnnotation.cpp.
References thePenColor.
Definition at line 2100 of file ossimGdalOgrVectorAnnotation.cpp.
References thePointWidthHeight, and ossimDpt::x.
Definition at line 910 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimKeywordNames::BORDER_SIZE_KW, ossimKeywordNames::BRUSH_COLOR_KW, ossimKeywordNames::FILL_FLAG_KW, ossimImageSourceFilter::getProperty(), getThickness(), ossimNumericProperty::ossimNumericPropertyType_INT, ossimKeywordNames::PEN_COLOR_KW, ossimKeywordNames::POINT_WIDTH_HEIGHT_KW, ossimProperty::setCacheRefreshBit(), ossimProperty::setFullRefreshBit(), ossimNumericProperty::setNumericType(), theBrushColor, theFillFlag, thePenColor, thePointWidthHeight, ossimKeywordNames::THICKNESS_KW, ossimString::toString(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimOgrGdalTileSource::getProperty().
Definition at line 962 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimKeywordNames::BORDER_SIZE_KW, ossimKeywordNames::BRUSH_COLOR_KW, ossimKeywordNames::FILL_FLAG_KW, ossimKeywordNames::PEN_COLOR_KW, ossimKeywordNames::POINT_WIDTH_HEIGHT_KW, and ossimKeywordNames::THICKNESS_KW.
Referenced by ossimOgrGdalTileSource::getPropertyNames().
Definition at line 2136 of file ossimGdalOgrVectorAnnotation.cpp.
References theThickness.
Referenced by getProperty(), and saveState().
Implements ossimViewInterface.
Definition at line 671 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimRefPtr< T >::get(), and theImageGeometry.
Referenced by ossimOgrGdalTileSource::getView().
Definition at line 2075 of file ossimGdalOgrVectorAnnotation.cpp.
| void ossimGdalOgrVectorAnnotation::initializeBoundingRec | ( | vector< ossimGpt > | points | ) |
Definition at line 597 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimDrect::makeNan(), theBoundingExtent, theImageBound, theImageGeometry, ossimRefPtr< T >::valid(), and ossimImageGeometry::worldToLocal().
protected |
Definition at line 1265 of file ossimGdalOgrVectorAnnotation.cpp.
Referenced by drawAnnotations(), getFeatureTable(), loadState(), and transformObjectsFromView().
Definition at line 2070 of file ossimGdalOgrVectorAnnotation.cpp.
References theDataSource.
Referenced by computeDefaultView(), getFeatures(), and ossimOgrGdalTileSource::isOpen().
protected |
Also sets theIsExternalGeomFlag.
Definition at line 2141 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimKeywordlist::addFile(), ossimFilename::exists(), ossimImageGeometry::getProjection(), ossimImageGeometry::loadState(), PTR_CAST, ossimFilename::setExtension(), theFilename, theImageGeometry, and theIsExternalGeomFlag.
protected |
Definition at line 2183 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimFilename::exists(), ossimRefPtr< T >::get(), ossimFgdcXmlDoc::getProjection(), ossimFilename::noExtension(), ossimFgdcXmlDoc::open(), ossimImageGeometry::setProjection(), theFilename, theImageGeometry, theIsExternalGeomFlag, and ossimRefPtr< T >::valid().
protected |
Definition at line 1707 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimGpt::datum(), ossimRefPtr< T >::get(), ossimRgbVector::getB(), ossimRgbVector::getG(), ossimImageGeometry::getProjection(), ossimRgbVector::getR(), ossimMapProjection::inverse(), ossimProjection::origin(), theBrushColor, theFeatureCacheTable, theFillFlag, theImageGeometry, thePenColor, theThickness, ossimGeoAnnotationPolyLineObject::transform(), and ossimRefPtr< T >::valid().
protected |
Definition at line 1765 of file ossimGdalOgrVectorAnnotation.cpp.
protected |
Definition at line 1884 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimGeoAnnotationMultiEllipseObject::addPoint(), ossimRefPtr< T >::get(), ossimRgbVector::getB(), ossimRgbVector::getG(), ossimImageGeometry::getProjection(), ossimRgbVector::getR(), ossimMapProjection::inverse(), ossimProjection::origin(), theBrushColor, theFeatureCacheTable, theFillFlag, theImageGeometry, thePenColor, thePointWidthHeight, theThickness, ossimGeoAnnotationMultiEllipseObject::transform(), and ossimRefPtr< T >::valid().
protected |
Definition at line 1943 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimGpt::datum(), ossimRefPtr< T >::get(), ossimRgbVector::getB(), ossimRgbVector::getG(), ossimImageGeometry::getProjection(), ossimRgbVector::getR(), ossimMapProjection::inverse(), ossimProjection::origin(), theBrushColor, theFeatureCacheTable, theFillFlag, theImageGeometry, thePenColor, theThickness, ossimGeoAnnotationMultiPolyObject::transform(), and ossimRefPtr< T >::valid().
protected |
Definition at line 2211 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimKeywordlist::addFile(), ossimKeywordNames::BORDER_SIZE_KW, ossimKeywordNames::BRUSH_COLOR_KW, ossimString::c_str(), ossimFilename::exists(), ossimKeywordlist::find(), ossimUnitConversionTool::getValue(), ossimUnitTypeLut::instance(), OSSIM_DEGREES, OSSIM_UNIT_UNKNOWN, ossimFilename::setExtension(), theBorderSize, theBorderSizeUnits, theBrushColor, theFilename, and ossimString::toDouble().
protected |
Definition at line 1834 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimGpt::datum(), ossimRefPtr< T >::get(), ossimRgbVector::getB(), ossimRgbVector::getG(), ossimImageGeometry::getProjection(), ossimRgbVector::getR(), ossimMapProjection::inverse(), ossimProjection::origin(), theBrushColor, theFeatureCacheTable, theFillFlag, theImageGeometry, thePenColor, thePointWidthHeight, theThickness, ossimGeoAnnotationEllipseObject::transform(), and ossimRefPtr< T >::valid().
protected |
Definition at line 1595 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimGpt::datum(), ossimRefPtr< T >::get(), ossimRgbVector::getB(), ossimRgbVector::getG(), ossimImageGeometry::getProjection(), ossimRgbVector::getR(), ossimMapProjection::inverse(), ossimProjection::origin(), ossimGeoAnnotationPolyObject::OSSIM_POLY_INTERIOR_RING, ossimGeoAnnotationPolyObject::setPolyType(), theBrushColor, theFeatureCacheTable, theFillFlag, theImageGeometry, thePenColor, theThickness, ossimGeoAnnotationObject::transform(), ossimGeoAnnotationPolyObject::transform(), and ossimRefPtr< T >::valid().
Definition at line 1055 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimKeywordNames::BORDER_SIZE_KW, ossimKeywordNames::BRUSH_COLOR_KW, ossimString::c_str(), deleteTables(), ossimKeywordNames::FILENAME_KW, ossimKeywordNames::FILL_FLAG_KW, ossimKeywordlist::find(), ossimUnitConversionTool::getValue(), initializeTables(), ossimUnitTypeLut::instance(), ossimAnnotationSource::loadState(), m_needPenColor, open(), OSSIM_DEGREES, OSSIM_UNIT_UNKNOWN, ossimKeywordNames::PEN_COLOR_KW, ossimKeywordNames::POINT_WIDTH_HEIGHT_KW, ossimKeywordNames::QUERY_KW, setQuery(), setThickness(), ossimString::split(), status, theBorderSize, theBorderSizeUnits, theBrushColor, theFillFlag, thePenColor, thePointWidthHeight, ossimKeywordNames::THICKNESS_KW, ossimString::toBool(), and ossimString::toDouble().
Referenced by ossimOgrGdalTileSource::loadState().
Definition at line 2065 of file ossimGdalOgrVectorAnnotation.cpp.
Referenced by loadState(), ossimOgrGdalTileSource::open(), setCurrentEntry(), and setQuery().
Definition at line 265 of file ossimGdalOgrVectorAnnotation.cpp.
Definition at line 1178 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimSource::print(), theLayersToRenderFlagList, and theLayerTable.
Saves the current state of this object.
Definition at line 974 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::BORDER_SIZE_KW, ossimKeywordNames::BRUSH_COLOR_KW, ossimString::c_str(), ossimString::empty(), ossimKeywordNames::FILENAME_KW, ossimKeywordNames::FILL_FLAG_KW, ossimRgbVector::getB(), ossimRgbVector::getG(), ossimRgbVector::getR(), getThickness(), ossimUnitTypeLut::instance(), m_query, ossimKeywordNames::PEN_COLOR_KW, ossimKeywordNames::POINT_WIDTH_HEIGHT_KW, ossimKeywordNames::QUERY_KW, ossimAnnotationSource::saveState(), ossimImageGeometry::saveState(), theBorderSize, theBorderSizeUnits, theBrushColor, theFilename, theFillFlag, theImageGeometry, thePenColor, thePointWidthHeight, ossimKeywordNames::THICKNESS_KW, ossimString::toString(), ossimKeywordNames::UNITS_KW, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimOgrGdalTileSource::saveState().
Definition at line 2080 of file ossimGdalOgrVectorAnnotation.cpp.
| bool ossimGdalOgrVectorAnnotation::setCurrentEntry | ( | ossim_uint32 | entryIdx | ) |
Definition at line 2536 of file ossimGdalOgrVectorAnnotation.cpp.
References m_layerName, m_layerNames, open(), and theFilename.
Referenced by ossimOgrGdalTileSource::setCurrentEntry().
Definition at line 2115 of file ossimGdalOgrVectorAnnotation.cpp.
| void ossimGdalOgrVectorAnnotation::setGeometryBuffer | ( | ossim_float64 | distance, |
| ossimUnitType | type | ||
Definition at line 259 of file ossimGdalOgrVectorAnnotation.cpp.
References distance(), m_geometryDistance, and m_geometryDistanceType.
Referenced by ossimOgrGdalTileSource::setGeometryBuffer().
Definition at line 2085 of file ossimGdalOgrVectorAnnotation.cpp.
Definition at line 2105 of file ossimGdalOgrVectorAnnotation.cpp.
References thePointWidthHeight.
Definition at line 853 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimKeywordNames::BORDER_SIZE_KW, ossimKeywordNames::BRUSH_COLOR_KW, ossimKeywordNames::FILL_FLAG_KW, ossimKeywordNames::PEN_COLOR_KW, ossimKeywordNames::POINT_WIDTH_HEIGHT_KW, ossimRgbVector::setB(), ossimRgbVector::setG(), ossimImageSourceFilter::setProperty(), ossimRgbVector::setR(), setThickness(), theBrushColor, theFillFlag, thePenColor, thePointWidthHeight, ossimKeywordNames::THICKNESS_KW, ossimString::toBool(), ossimString::toInt32(), updateAnnotationSettings(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimOgrGdalTileSource::setProperty().
| void ossimGdalOgrVectorAnnotation::setQuery | ( | const ossimString & | query | ) |
Definition at line 253 of file ossimGdalOgrVectorAnnotation.cpp.
References m_query, open(), and theFilename.
Referenced by loadState(), and ossimOgrGdalTileSource::setQuery().
Definition at line 2120 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimNotify(), ossimNotifyLevel_WARN, and theThickness.
Referenced by loadState(), and setProperty().
The derived classes should overrid this method and return true or false whether it was able to cast the past in view to a view that it can interface to. So if you are a projective view you might cast to an ossimProjection. The ownsTheView specifies whether or not it owns the passed in view pointer. This will specifiy whether or not the derived classes need to re-allocate the pointer or just delete its old pointer and set it to the passed in pointer.
Definition at line 631 of file ossimGdalOgrVectorAnnotation.cpp.
References PTR_CAST, ossimImageGeometry::setProjection(), theImageGeometry, and transformObjectsFromView().
Referenced by ossimOgrGdalTileSource::setView().
protected |
Definition at line 1195 of file ossimGdalOgrVectorAnnotation.cpp.
References computeBoundingRect(), ossimRefPtr< T >::get(), initializeTables(), PTR_CAST, theFeatureCacheTable, theImageGeometry, ossimGeoAnnotationObject::transform(), and ossimRefPtr< T >::valid().
Referenced by setView().
protected |
Definition at line 811 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimRefPtr< T >::get(), ossimRgbVector::getB(), ossimRgbVector::getG(), ossimRgbVector::getR(), PTR_CAST, ossimGeoAnnotationMultiPolyObject::setFillFlag(), ossimGeoAnnotationPolyObject::setFillFlag(), ossimGeoAnnotationEllipseObject::setFillFlag(), ossimGeoAnnotationEllipseObject::setWidthHeight(), theBrushColor, theFeatureCacheTable, theFillFlag, theImageGeometry, thePenColor, thePointWidthHeight, theThickness, and ossimGeoAnnotationEllipseObject::transform().
Referenced by setProperty().
protected |
Sets to some default if nan.
Definition at line 2485 of file ossimGdalOgrVectorAnnotation.cpp.
References ossimMapProjection::getDecimalDegreesPerPixel(), ossimMapProjection::getMetersPerPixel(), ossimImageGeometry::getProjection(), ossimMapProjection::getUlGpt(), ossimDpt::hasNans(), ossimMapProjection::isGeographic(), ossimGpt::isLatNan(), ossimGpt::isLonNan(), PTR_CAST, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlGpt(), theBoundingExtent, theImageGeometry, and ossimRefPtr< T >::valid().
protected |
Definition at line 121 of file ossimGdalOgrVectorAnnotation.h.
Referenced by setGeometryBuffer().
protected |
Definition at line 122 of file ossimGdalOgrVectorAnnotation.h.
protected |
Definition at line 123 of file ossimGdalOgrVectorAnnotation.h.
Referenced by setCurrentEntry().
protected |
Definition at line 124 of file ossimGdalOgrVectorAnnotation.h.
protected |
Definition at line 120 of file ossimGdalOgrVectorAnnotation.h.
Referenced by drawAnnotations(), and loadState().
protected |
Definition at line 119 of file ossimGdalOgrVectorAnnotation.h.
Referenced by saveState(), and setQuery().
protected |
Definition at line 112 of file ossimGdalOgrVectorAnnotation.h.
Referenced by loadOmdFile(), loadState(), and saveState().
protected |
Definition at line 113 of file ossimGdalOgrVectorAnnotation.h.
protected |
Definition at line 103 of file ossimGdalOgrVectorAnnotation.h.
Referenced by computeDefaultView(), initializeBoundingRec(), and verifyViewParams().
protected |
Definition at line 108 of file ossimGdalOgrVectorAnnotation.h.
Referenced by getBrushColor(), getProperty(), loadLineString(), loadMultiLineString(), loadMultiPoint(), loadMultiPolygon(), loadOmdFile(), loadPoint(), loadPolygon(), loadState(), saveState(), setBrushColor(), setProperty(), and updateAnnotationSettings().
protected |
Definition at line 100 of file ossimGdalOgrVectorAnnotation.h.
protected |
Definition at line 101 of file ossimGdalOgrVectorAnnotation.h.
protected |
Definition at line 117 of file ossimGdalOgrVectorAnnotation.h.
Referenced by computeBoundingRect(), deleteTables(), drawAnnotations(), getFeature(), getFeatureTable(), loadLineString(), loadMultiLineString(), loadMultiPoint(), loadMultiPolygon(), loadPoint(), loadPolygon(), transformObjectsFromView(), and updateAnnotationSettings().
protected |
Definition at line 102 of file ossimGdalOgrVectorAnnotation.h.
Referenced by getFilename(), loadExternalGeometryFile(), loadExternalImageGeometryFromXml(), loadOmdFile(), open(), saveState(), setCurrentEntry(), and setQuery().
protected |
Definition at line 109 of file ossimGdalOgrVectorAnnotation.h.
Referenced by drawAnnotations(), getFillFlag(), getProperty(), loadLineString(), loadMultiLineString(), loadMultiPoint(), loadMultiPolygon(), loadPoint(), loadPolygon(), loadState(), saveState(), setFillFlag(), setProperty(), and updateAnnotationSettings().
protected |
Definition at line 114 of file ossimGdalOgrVectorAnnotation.h.
Referenced by computeBoundingRect(), getBoundingRect(), initializeBoundingRec(), and ossimGdalOgrVectorAnnotation().
protected |
Definition at line 104 of file ossimGdalOgrVectorAnnotation.h.
Referenced by close(), computeDefaultView(), drawAnnotations(), getFeatures(), getImageGeometry(), getView(), initializeBoundingRec(), loadExternalGeometryFile(), loadExternalImageGeometryFromXml(), loadLineString(), loadMultiLineString(), loadMultiPoint(), loadMultiPolygon(), loadPoint(), loadPolygon(), saveState(), setView(), transformObjectsFromView(), updateAnnotationSettings(), and verifyViewParams().
protected |
Definition at line 115 of file ossimGdalOgrVectorAnnotation.h.
Referenced by loadExternalGeometryFile(), and loadExternalImageGeometryFromXml().
protected |
Definition at line 105 of file ossimGdalOgrVectorAnnotation.h.
Referenced by getFeatures(), and print().
protected |
Definition at line 106 of file ossimGdalOgrVectorAnnotation.h.
Referenced by deleteTables(), getFeatures(), and print().
protected |
Definition at line 107 of file ossimGdalOgrVectorAnnotation.h.
Referenced by drawAnnotations(), getPenColor(), getProperty(), loadLineString(), loadMultiLineString(), loadMultiPoint(), loadMultiPolygon(), loadPoint(), loadPolygon(), loadState(), saveState(), setPenColor(), setProperty(), and updateAnnotationSettings().
protected |
Definition at line 111 of file ossimGdalOgrVectorAnnotation.h.
Referenced by getPointRadius(), getProperty(), loadMultiPoint(), loadPoint(), loadState(), saveState(), setPointRadius(), setProperty(), and updateAnnotationSettings().
protected |
Definition at line 110 of file ossimGdalOgrVectorAnnotation.h.
Referenced by drawAnnotations(), getThickness(), loadLineString(), loadMultiLineString(), loadMultiPoint(), loadMultiPolygon(), loadPoint(), loadPolygon(), setThickness(), and updateAnnotationSettings().
