#include <ossimImageMpiSWriterSequenceConnection.h>
| ossimImageMpiSWriterSequenceConnection (ossimObject *owner=NULL, long numberOfTilesToBuffer=2) | |
| ossimImageMpiSWriterSequenceConnection (ossimImageSource *inputSource, ossimObject *owner=NULL, long numberOfTilesToBuffer=2) | |
| virtual | ~ossimImageMpiSWriterSequenceConnection () |
| virtual bool | isMaster () const |
| virtual void | setToStartOfSequence () |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 resLevel=0) |
| virtual void | slaveProcessTiles () |
Public Member Functions inherited from ossimImageSourceSequencer | |
| ossimImageSourceSequencer (ossimImageSource *inputSource=NULL, ossimObject *owner=NULL) | |
| virtual | ~ossimImageSourceSequencer () |
| ossim_int64 | getNumberOfTiles () const |
| ossim_int64 | getNumberOfTilesHorizontal () const |
| ossim_int64 | getNumberOfTilesVertical () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| const ossimIrect & | getAreaOfInterest () const |
| virtual bool | getNextTileStream (std::ostream &bos) |
| virtual bool | getTileOrigin (ossim_int64 id, ossimIpt &origin) const |
| bool | getTileRect (ossim_int64 tile_id, ossimIrect &rect) const |
| Establishes a tile rect given tile ID. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (ossim_int64 id, ossim_uint32 resLevel=0) |
| virtual ossimIpt | getTileSize () const |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| virtual void | setTileSize (ossim_int32 width, ossim_int32 height) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| void | setCreateHistogram (bool create_histogram) |
| bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
| void | getBinInformation (ossim_uint32 &numberOfBins, ossim_float64 &minValue, ossim_float64 &maxValue, ossimScalarType stype) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | deleteOutputTiles () |
Protected Member Functions inherited from ossimImageSourceSequencer | |
| virtual void | updateTileDimensions () |
Definition at line 16 of file ossimImageMpiSWriterSequenceConnection.h.
| ossimImageMpiSWriterSequenceConnection::ossimImageMpiSWriterSequenceConnection | ( | ossimObject * | owner = NULL, |
| long | numberOfTilesToBuffer = 2 |
Definition at line 29 of file ossimImageMpiSWriterSequenceConnection.cpp.
| ossimImageMpiSWriterSequenceConnection::ossimImageMpiSWriterSequenceConnection | ( | ossimImageSource * | inputSource, |
Definition at line 57 of file ossimImageMpiSWriterSequenceConnection.cpp.
References ossimImageSourceSequencer::theCurrentTileNumber, theNumberOfProcessors, theNumberOfTilesToBuffer, and theRank.
Definition at line 82 of file ossimImageMpiSWriterSequenceConnection.cpp.
References deleteOutputTiles().
protected |
Definition at line 87 of file ossimImageMpiSWriterSequenceConnection.cpp.
References theOutputTile.
Referenced by initialize(), and ~ossimImageMpiSWriterSequenceConnection().
Will allow you to get the next tile in the sequence.
Reimplemented from ossimImageSourceSequencer.
Definition at line 342 of file ossimImageMpiSWriterSequenceConnection.cpp.
References ossimNotify(), and ossimNotifyLevel_FATAL.
This must be called. We can only initialize this object completely if we know all connections are valid. Some other object drives this and so the connection's initialize will be called after. The job of this connection is to set up the sequence. It will default to the bounding rect. The area of interest can be set to some other rectagle (use setAreaOfInterest).
Definition at line 96 of file ossimImageMpiSWriterSequenceConnection.cpp.
References ossimImageDataFactory::create(), deleteOutputTiles(), ossimImageSourceSequencer::initialize(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceSequencer::theCurrentTileNumber, ossimImageSourceSequencer::theInputConnection, theNumberOfTilesToBuffer, theOutputTile, and theRank.
inlinevirtual |
Definition at line 27 of file ossimImageMpiSWriterSequenceConnection.h.
Will set the internal pointers to the upperleft tile number. To go to the next tile in the sequence just call getNextTile.
Definition at line 119 of file ossimImageMpiSWriterSequenceConnection.cpp.
References ossimImageSourceSequencer::setToStartOfSequence(), ossimImageSourceSequencer::theCurrentTileNumber, and theRank.
Definition at line 136 of file ossimImageMpiSWriterSequenceConnection.cpp.
References ossimImageSourceSequencer::getNumberOfTiles(), and theNumberOfTilesToBuffer.
protected |
Definition at line 42 of file ossimImageMpiSWriterSequenceConnection.h.
Referenced by ossimImageMpiSWriterSequenceConnection().
protected |
Definition at line 44 of file ossimImageMpiSWriterSequenceConnection.h.
Referenced by initialize(), ossimImageMpiSWriterSequenceConnection(), and slaveProcessTiles().
protected |
Definition at line 46 of file ossimImageMpiSWriterSequenceConnection.h.
Referenced by deleteOutputTiles(), and initialize().
protected |
Definition at line 43 of file ossimImageMpiSWriterSequenceConnection.h.
Referenced by initialize(), ossimImageMpiSWriterSequenceConnection(), and setToStartOfSequence().
