#include <ossimImageSourceFactory.h>
| virtual | ~ossimImageSourceFactory () |
| virtual ossimObject * | createObject (const ossimString &name) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimImageSourceFactoryBase | |
| virtual ossimImageSource * | createImageSource (const ossimString &name) const |
| virtual ossimImageSource * | createImageSource (const ossimKeywordlist &kwl, const char *prefix=0) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimImageSourceFactory * | instance () |
| ossimImageSourceFactory () | |
| ossimImageSourceFactory (const ossimImageSourceFactory &) | |
| const ossimImageSourceFactory & | operator= (ossimImageSourceFactory &) |
Protected Member Functions inherited from ossimImageSourceFactoryBase | |
| ossimImageSourceFactoryBase () | |
| ossimImageSourceFactoryBase (const ossimImageSourceFactoryBase &) | |
| const ossimImageSourceFactoryBase & | operator= (const ossimImageSourceFactoryBase &) |
Static Protected Attributes | |
| static ossimImageSourceFactory * | theInstance =NULL |
Definition at line 13 of file ossimImageSourceFactory.h.
Definition at line 111 of file ossimImageSourceFactory.cpp.
References ossimObjectFactoryRegistry::instance(), theInstance, and ossimFactoryListInterface< T, NativeType >::unregisterFactory().
protected |
Definition at line 614 of file ossimImageSourceFactory.cpp.
Referenced by instance().
protected |
Definition at line 618 of file ossimImageSourceFactory.cpp.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 126 of file ossimImageSourceFactory.cpp.
References STATIC_TYPE_NAME.
Creates and object given a keyword list.
Definition at line 474 of file ossimImageSourceFactory.cpp.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 524 of file ossimImageSourceFactory.cpp.
static |
Definition at line 116 of file ossimImageSourceFactory.cpp.
References ossimImageSourceFactory(), and theInstance.
Referenced by ossimImageSourceFactoryRegistry::instance(), and ossimImageSourceFactoryRegistry::~ossimImageSourceFactoryRegistry().
protected |
Definition at line 622 of file ossimImageSourceFactory.cpp.
staticprotected |
Definition at line 29 of file ossimImageSourceFactory.h.
Referenced by instance(), and ~ossimImageSourceFactory().
