#include <ossimAtbController.h>
| ossimAtbController () | |
| ossimAtbController (ossimImageCombiner *combiner, ossimGridRemapEngine *engine=0) | |
| ossimAtbController (ossimGridRemapEngine *engine) | |
| ~ossimAtbController () | |
| void | initializeWithCombiner (ossimImageCombiner *combiner, ossimGridRemapEngine *engine=0) |
| bool | enableImage (unsigned int index) |
| bool | disableImage (unsigned int index) |
| bool | lockImage (unsigned int index) |
| bool | unlockImage (unsigned int index) |
| virtual bool | execute () |
| virtual void | abort () |
| void | setKernelSize (int side_size) |
| void | setGridSpacing (const ossimIpt &spacing) |
| void | setGridRemapEngine (ossimGridRemapEngine *engine) |
| virtual bool | saveState (ossimKeywordlist &kwl) const |
| virtual bool | loadState (const ossimKeywordlist &kwl) |
| virtual bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const |
| ossimObject () | |
| ossimListenerManager () | |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual void | setPercentComplete (double percentComplete) |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| void | initializeRemappers () |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Definition at line 37 of file ossimAtbController.h.
| ossimAtbController::ossimAtbController | ( | ) |
default Constructor initializes the member combiner pointer to NULL.
Definition at line 43 of file ossimAtbController.cpp.
| ossimAtbController::ossimAtbController | ( | ossimImageCombiner * | combiner, |
| ossimGridRemapEngine * | engine = 0 |
Constructor with Combiner reference. This combiner is used for the ATB.
Definition at line 66 of file ossimAtbController.cpp.
| ossimAtbController::ossimAtbController | ( | ossimGridRemapEngine * | engine | ) |
Constructor with a specified remap engine.
Definition at line 86 of file ossimAtbController.cpp.
| ossimAtbController::~ossimAtbController | ( | ) |
Definition at line 120 of file ossimAtbController.cpp.
References theContainer, and theGridRemapEngine.
Implementation of ossimConnectableObject pure virtual.
Implements ossimConnectableObject.
Definition at line 564 of file ossimAtbController.cpp.
References PTR_CAST.
| bool ossimAtbController::disableImage | ( | unsigned int | index | ) |
Disnable an image in the mosaic from the tonal balancing process
Definition at line 239 of file ossimAtbController.cpp.
References ossimSource::disableSource(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), and PTR_CAST.
| bool ossimAtbController::enableImage | ( | unsigned int | index | ) |
Enable an image in the mosaic for the tonal balancing process
Definition at line 220 of file ossimAtbController.cpp.
References ossimSource::enableSource(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), and PTR_CAST.
Implementation of ossimProcessInterface pure virtual method.
Implements ossimProcessInterface.
Definition at line 297 of file ossimAtbController.cpp.
inlinevirtual |
Definition at line 60 of file ossimAtbController.h.
inlinevirtual |
Definition at line 64 of file ossimAtbController.h.
protected |
Definition at line 467 of file ossimAtbController.cpp.
| void ossimAtbController::initializeWithCombiner | ( | ossimImageCombiner * | combiner, |
Provide alternate means of initialization in case default constructor used.
Definition at line 130 of file ossimAtbController.cpp.
Definition at line 430 of file ossimAtbController.cpp.
| bool ossimAtbController::lockImage | ( | unsigned int | index | ) |
Locks a particular source for adjustment. A locked image effectively defines the target values for all overlapping imagery.
Definition at line 259 of file ossimAtbController.cpp.
References ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimGridRemapSource::lock(), and PTR_CAST.
Implementations of ossimStateInterface pure virtuals
Definition at line 415 of file ossimAtbController.cpp.
| void ossimAtbController::setGridRemapEngine | ( | ossimGridRemapEngine * | engine | ) |
Sets the ATB remap engine. This object implements the specific tonal balancing algorithm. The dependency on number of bands and color space, is limited only to this engine. This facilitates the implementation of various grid-based image matching schemes.
Definition at line 529 of file ossimAtbController.cpp.
| void ossimAtbController::setGridSpacing | ( | const ossimIpt & | spacing | ) |
Sets the grid spacing used in gridding the mosaic's bounding rectangle.
| void ossimAtbController::setKernelSize | ( | int | side_size | ) |
Hook to set the size of the kernel used by all point sources in computing their mean pixel value. The kernels will be resized to NxN.
Definition at line 449 of file ossimAtbController.cpp.
| bool ossimAtbController::unlockImage | ( | unsigned int | index | ) |
Unlock a particular source for adjustment.
Definition at line 279 of file ossimAtbController.cpp.
protected |
Definition at line 137 of file ossimAtbController.h.
protected |
Definition at line 138 of file ossimAtbController.h.
Referenced by ~ossimAtbController().
protected |
Definition at line 139 of file ossimAtbController.h.
protected |
Definition at line 141 of file ossimAtbController.h.
protected |
Definition at line 140 of file ossimAtbController.h.
