The is a factory list interface that allows registries to be accessed in a common way. More...
#include <ossimFactoryListInterface.h>
Public Types | |
| typedef std::vector< T * > | FactoryListType |
| typedef T | FactoryType |
| typedef NativeType | NativeReturnType |
| ossimFactoryListInterface () | |
| void | addFactory (T *factory) |
| This is for backward compatability and calls registerFactory for simple adds. More... | |
| bool | isFactoryRegistered (T *factory) const |
| Public access method to determine if a factory is already registered to this list. More... | |
| void | registerFactory (T *factory, bool pushToFrontFlag=false) |
| Will register a factory to the factory list. More... | |
| void | unregisterFactory (T *factory) |
| Will remove the factory from the registry. More... | |
| void | unregisterFactory (const ossimString &factoryTypeName) |
| Will remove the factory from the registry by name. More... | |
| void | unregisterAllFactories () |
| Will remove all factories from the registry. More... | |
| void | registerFactoryToFront (T *factory) |
| Inserts the factory to the front of the list. More... | |
| void | registerFactoryBefore (T *factory, T *beforeThisFactory) |
| Will insert the factory before the beforeThisFactory. More... | |
| void | getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const |
| Will add all object types the factories can allocate. More... | |
| ossimObject * | createObjectFromRegistry (const ossimString &typeName) const |
| This is the base object return for all objects in the system. More... | |
| ossimObject * | createObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| NativeType * | createNativeObjectFromRegistry (const ossimString &typeName) const |
| This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More... | |
| NativeType * | createNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| bool | findFactory (T *factory) const |
| Utility to find a factory in the list. More... | |
Protected Attributes | |
| std::mutex | m_factoryListMutex |
| FactoryListType | m_factoryList |
This is typically used by the Registries. The registries derive from this interface so that it will have the ability to give access to others to add to it's registry:
Pseudo Code:
Definition at line 33 of file ossimFactoryListInterface.h.
| typedef std::vector<T*> ossimFactoryListInterface< T, NativeType >::FactoryListType |
Definition at line 36 of file ossimFactoryListInterface.h.
| typedef T ossimFactoryListInterface< T, NativeType >::FactoryType |
Definition at line 37 of file ossimFactoryListInterface.h.
| typedef NativeType ossimFactoryListInterface< T, NativeType >::NativeReturnType |
Definition at line 38 of file ossimFactoryListInterface.h.
inline |
Definition at line 40 of file ossimFactoryListInterface.h.
inline |
Definition at line 45 of file ossimFactoryListInterface.h.
Referenced by ossimInit::initializeDefaultFactories().
| NativeType * ossimFactoryListInterface< T, NativeType >::createNativeObjectFromRegistry | ( | const ossimString & | typeName | ) | const |
Definition at line 261 of file ossimFactoryListInterface.h.
Referenced by ossimProjectionFactoryRegistry::createProjection(), and ossim2dTo2dTransformRegistry::createTransform().
| NativeType * ossimFactoryListInterface< T, NativeType >::createNativeObjectFromRegistry | ( | const ossimKeywordlist & | kwl, |
| const char * | prefix = 0 |
| ) | const |
| kwl | is a state keywordlist allowing one to instantiate an object defined by a set of name value pairs. It will use the type keyword to create an object of the defined type and then load the state. |
Definition at line 278 of file ossimFactoryListInterface.h.
| ossimObject * ossimFactoryListInterface< T, NativeType >::createObjectFromRegistry | ( | const ossimString & | typeName | ) | const |
This is used for backward compatability.
Definition at line 234 of file ossimFactoryListInterface.h.
Referenced by ossimWebRequestFactoryRegistry::createObject(), ossimObjectFactoryRegistry::createObject(), ossim2dTo2dTransformRegistry::createObject(), and ossimProjectionFactoryRegistry::createObject().
| ossimObject * ossimFactoryListInterface< T, NativeType >::createObjectFromRegistry | ( | const ossimKeywordlist & | kwl, |
| ) | const |
Definition at line 247 of file ossimFactoryListInterface.h.
inlineprotected |
Definition at line 205 of file ossimFactoryListInterface.h.
Referenced by ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::isFactoryRegistered(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactory(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactoryBefore(), and ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactoryToFront().
| void ossimFactoryListInterface< T, NativeType >::getAllTypeNamesFromRegistry | ( | std::vector< ossimString > & | typeList | ) | const |
Typically a list of classnames are returned
Definition at line 224 of file ossimFactoryListInterface.h.
Referenced by ossimElevationDatabaseRegistry::getTypeNameList(), ossimObjectFactoryRegistry::getTypeNameList(), ossimWebRequestFactoryRegistry::getTypeNameList(), ossimImageGeometryRegistry::getTypeNameList(), ossimProjectionFactoryRegistry::getTypeNameList(), and ossim2dTo2dTransformRegistry::getTypeNameList().
inline |
Definition at line 54 of file ossimFactoryListInterface.h.
inline |
Will append the passed in factory if not already registered to the list.
Definition at line 66 of file ossimFactoryListInterface.h.
Referenced by ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::addFactory(), ossimInit::initializeDefaultFactories(), ossimCodecFactoryRegistry::instance(), ossimElevationDatabaseRegistry::instance(), ossimImageGeometryRegistry::instance(), ossimImageWriterFactory::instance(), ossim2dTo2dTransformRegistry::instance(), ossimImageWriterFactoryRegistry::instance(), ossimOverviewBuilderFactoryRegistry::instance(), ossimImageHandlerRegistry::ossimImageHandlerRegistry(), ossimImageMetaDataWriterRegistry::ossimImageMetaDataWriterRegistry(), ossimProjectionFactoryRegistry::ossimProjectionFactoryRegistry(), and ossimSharedLibraryInitialize().
inline |
If not found it will do a simple append.
Definition at line 146 of file ossimFactoryListInterface.h.
inline |
Definition at line 133 of file ossimFactoryListInterface.h.
Referenced by ossimSharedLibraryInitialize().
inline |
Definition at line 124 of file ossimFactoryListInterface.h.
inline |
Definition at line 85 of file ossimFactoryListInterface.h.
Referenced by ossimSharedLibraryFinalize(), ATP::ossimAtpToolFactory::~ossimAtpToolFactory(), ossimDemToolFactory::~ossimDemToolFactory(), ossimImageMetaDataWriterRegistry::~ossimImageMetaDataWriterRegistry(), ossimImageSourceFactory::~ossimImageSourceFactory(), ossimPotraceToolFactory::~ossimPotraceToolFactory(), ossimRegToolFactory::~ossimRegToolFactory(), and ossimToolFactory::~ossimToolFactory().
inline |
| factoryTypeName | The class name of the factory, (e.g. "ossimCsmProjectionFactory") |
Definition at line 103 of file ossimFactoryListInterface.h.
protected |
Definition at line 220 of file ossimFactoryListInterface.h.
Referenced by ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::findFactory(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactory(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactoryBefore(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactoryToFront(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::unregisterAllFactories(), and ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::unregisterFactory().
mutableprotected |
Definition at line 219 of file ossimFactoryListInterface.h.
Referenced by ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::isFactoryRegistered(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactory(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactoryBefore(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactoryToFront(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::unregisterAllFactories(), and ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::unregisterFactory().
