#include <ossimImageHistogramSource.h>
| ossimImageHistogramSource (ossimObject *owner=0) | |
| void | setAreaOfInterest (const ossimIrect &rect) |
| ossimIrect | getAreaOfInterest () const |
| void | getAreaOfInterest (ossimIrect &rect) const |
| virtual ossim_uint32 | getMaxNumberOfRLevels () const |
| virtual void | setMaxNumberOfRLevels (ossim_uint32 number) |
| virtual ossimRefPtr< ossimMultiResLevelHistogram > | getHistogram (const ossimIrect &rect) |
| virtual ossimRefPtr< ossimMultiResLevelHistogram > | getHistogram () |
| virtual bool | execute () |
| virtual bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const |
| void | setNumberOfBinsOverride (ossim_int32 numberOfBinsOverride) |
| void | setMinValueOverride (ossim_float32 minValueOverride) |
| void | setMaxValueOverride (ossim_float32 maxValueOverride) |
| void | setNumberOfTiles (ossim_uint32 numberOfTiles) |
| ossimHistogramMode | getComputationMode () const |
| void | setComputationMode (ossimHistogramMode mode) |
Public Member Functions inherited from ossimHistogramSource | |
| virtual | ~ossimHistogramSource () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| virtual void | disconnectInputEvent (ossimConnectionEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual void | setPercentComplete (double percentComplete) |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| virtual | ~ossimImageHistogramSource () |
| void | getBinInformation (ossim_uint32 &numberOfBins, ossim_float64 &minValue, ossim_float64 &maxValue, ossim_uint32 band) const |
| virtual void | computeNormalModeHistogram () |
| virtual void | computeFastModeHistogram () |
Protected Member Functions inherited from ossimHistogramSource | |
| ossimHistogramSource (ossimObject *owner=NULL, ossim_uint32 numberOfInputs=0, ossim_uint32 numberOfOutputs=0, bool inputListFixedFlag=true, bool outputListFixedFlag=true) | |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
This source expects as input an ossimImageSource. it will slice up the requested region into tiles and compute the histogram of the passed in rectangle.
Definition at line 23 of file ossimImageHistogramSource.h.
| ossimImageHistogramSource::ossimImageHistogramSource | ( | ossimObject * | owner = 0 | ) |
Definition at line 22 of file ossimImageHistogramSource.cpp.
References ossimListenerManager::addListener(), ossimIrect::makeNan(), ossim::nan(), theAreaOfInterest, theMaxValueOverride, theMinValueOverride, and theNumberOfBinsOverride.
protectedvirtual |
Definition at line 41 of file ossimImageHistogramSource.cpp.
References ossimListenerManager::removeListener().
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 149 of file ossimImageHistogramSource.cpp.
References PTR_CAST.
protectedvirtual |
Definition at line 434 of file ossimImageHistogramSource.cpp.
References ossimMultiBandHistogram::create(), ossimMultiResLevelHistogram::create(), getBinInformation(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimConnectableObject::getInput(), ossimMultiResLevelHistogram::getMultiBandHistogram(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getTile(), ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), ossimIrect::height(), ossim::max(), ossim::min(), ossimProcessInterface::needsAborting(), OSSIM_EMPTY, ossimImageData::populateHistogram(), PTR_CAST, ossimProcessInterface::setPercentComplete(), ossimIrect::stretchToTileBoundary(), theAreaOfInterest, ossimHistogramSource::theHistogram, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimIrect::width(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by execute().
protectedvirtual |
Definition at line 321 of file ossimImageHistogramSource.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimMultiBandHistogram::create(), ossimMultiResLevelHistogram::create(), ossimConnectableObject::disconnect(), getBinInformation(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getDecimationFactors(), ossimConnectableObject::getInput(), ossimMultiResLevelHistogram::getMultiBandHistogram(), ossimImageSourceSequencer::getNextTile(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::initialize(), ossim::min(), ossimProcessInterface::needsAborting(), OSSIM_EMPTY, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::populateHistogram(), PTR_CAST, ossimImageSourceSequencer::setAreaOfInterest(), ossimProcessInterface::setPercentComplete(), ossimImageSourceSequencer::setToStartOfSequence(), theAreaOfInterest, ossimHistogramSource::theHistogram, theMaxNumberOfResLevels, and ossimRefPtr< T >::valid().
Reimplemented from ossimConnectableObjectListener.
Definition at line 185 of file ossimImageHistogramSource.cpp.
References theHistogramRecomputeFlag.
Implements ossimProcessInterface.
Definition at line 101 of file ossimImageHistogramSource.cpp.
References computeFastModeHistogram(), computeNormalModeHistogram(), ossimConnectableObject::getInput(), ossimIrect::hasNans(), ossimSource::isSourceEnabled(), ossimProcessInterface::needsAborting(), OSSIM_HISTO_MODE_FAST, OSSIM_HISTO_MODE_NORMAL, ossimProcessInterface::PROCESS_STATUS_ABORTED, ossimProcessInterface::PROCESS_STATUS_EXECUTING, ossimProcessInterface::PROCESS_STATUS_NOT_EXECUTING, PTR_CAST, ossimProcessInterface::setProcessStatus(), theAreaOfInterest, theComputationMode, ossimHistogramSource::theHistogram, theHistogramRecomputeFlag, and ossimRefPtr< T >::valid().
Referenced by getHistogram(), and ossimKMeansFilter::initialize().
| ossimIrect ossimImageHistogramSource::getAreaOfInterest | ( | ) | const |
Definition at line 65 of file ossimImageHistogramSource.cpp.
References theAreaOfInterest.
| void ossimImageHistogramSource::getAreaOfInterest | ( | ossimIrect & | rect | ) | const |
Definition at line 70 of file ossimImageHistogramSource.cpp.
protected |
Definition at line 196 of file ossimImageHistogramSource.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageSource::getOutputScalarType(), OSSIM_DEFAULT_MAX_PIX_SINT16, OSSIM_DEFAULT_MAX_PIX_UCHAR, OSSIM_DEFAULT_MAX_PIX_UINT11, OSSIM_DEFAULT_MAX_PIX_UINT12, OSSIM_DEFAULT_MAX_PIX_UINT13, OSSIM_DEFAULT_MAX_PIX_UINT14, OSSIM_DEFAULT_MAX_PIX_UINT15, OSSIM_DEFAULT_MAX_PIX_UINT16, OSSIM_DEFAULT_MIN_PIX_SINT16, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_SINT32, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, and PTR_CAST.
Referenced by computeFastModeHistogram(), and computeNormalModeHistogram().
| ossimHistogramMode ossimImageHistogramSource::getComputationMode | ( | ) | const |
Definition at line 170 of file ossimImageHistogramSource.cpp.
References theComputationMode.
The first argument is the region of interest that you wish to use for the histogram. If the region is different than what it has already computed before then the histogram is considered dirty and will be re-computed. The returned object is a multi-reslevel histogram
Definition at line 89 of file ossimImageHistogramSource.cpp.
References getHistogram(), ossimIrect::hasNans(), theAreaOfInterest, and theHistogramRecomputeFlag.
Referenced by ossimKMeansFilter::initialize().
Reimplemented from ossimHistogramSource.
Definition at line 190 of file ossimImageHistogramSource.cpp.
References execute(), and ossimHistogramSource::theHistogram.
Referenced by getHistogram().
Definition at line 75 of file ossimImageHistogramSource.cpp.
References theMaxNumberOfResLevels.
Definition at line 46 of file ossimImageHistogramSource.cpp.
Definition at line 51 of file ossimImageHistogramSource.cpp.
Definition at line 605 of file ossimImageHistogramSource.cpp.
References ossimString::downcase(), ossimString::empty(), ossimKeywordlist::find(), ossimConnectableObject::getNumberOfInputs(), ossimHistogramSource::loadState(), ossimIrect::loadState(), OSSIM_HISTO_MODE_FAST, OSSIM_HISTO_MODE_NORMAL, ossimConnectableObject::setNumberOfInputs(), theAreaOfInterest, theComputationMode, ossimConnectableObject::theInputListIsFixedFlag, and ossimConnectableObject::theOutputListIsFixedFlag.
Definition at line 180 of file ossimImageHistogramSource.cpp.
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 649 of file ossimImageHistogramSource.cpp.
References ossimHistogramSource::saveState(), ossimIrect::saveState(), and theAreaOfInterest.
| void ossimImageHistogramSource::setAreaOfInterest | ( | const ossimIrect & | rect | ) |
Definition at line 56 of file ossimImageHistogramSource.cpp.
References theAreaOfInterest, and theHistogramRecomputeFlag.
| void ossimImageHistogramSource::setComputationMode | ( | ossimHistogramMode | mode | ) |
Definition at line 175 of file ossimImageHistogramSource.cpp.
Referenced by ossimImageHandler::buildHistogram(), and ossimKMeansFilter::initialize().
Definition at line 80 of file ossimImageHistogramSource.cpp.
References theHistogramRecomputeFlag, and theMaxNumberOfResLevels.
Referenced by ossimImageHandler::buildHistogram(), ossimKMeansFilter::initialize(), and ossimImageFileWriter::writeHistogramFile().
| void ossimImageHistogramSource::setMaxValueOverride | ( | ossim_float32 | maxValueOverride | ) |
Definition at line 165 of file ossimImageHistogramSource.cpp.
References theMaxValueOverride.
| void ossimImageHistogramSource::setMinValueOverride | ( | ossim_float32 | minValueOverride | ) |
Definition at line 161 of file ossimImageHistogramSource.cpp.
References theMinValueOverride.
| void ossimImageHistogramSource::setNumberOfBinsOverride | ( | ossim_int32 | numberOfBinsOverride | ) |
Definition at line 156 of file ossimImageHistogramSource.cpp.
References theNumberOfBinsOverride.
| void ossimImageHistogramSource::setNumberOfTiles | ( | ossim_uint32 | numberOfTiles | ) |
protected |
Initialized to ossimNAN'S
Definition at line 91 of file ossimImageHistogramSource.h.
Referenced by computeFastModeHistogram(), computeNormalModeHistogram(), execute(), getAreaOfInterest(), getHistogram(), loadState(), ossimImageHistogramSource(), saveState(), and setAreaOfInterest().
protected |
Definition at line 102 of file ossimImageHistogramSource.h.
Referenced by execute(), getComputationMode(), loadState(), and setComputationMode().
protected |
Definition at line 92 of file ossimImageHistogramSource.h.
Referenced by connectInputEvent(), execute(), getHistogram(), propertyEvent(), setAreaOfInterest(), and setMaxNumberOfRLevels().
protected |
Will default to 1. This means it will use up to max number of res levels for the histogram.
Definition at line 98 of file ossimImageHistogramSource.h.
Referenced by computeNormalModeHistogram(), getMaxNumberOfRLevels(), and setMaxNumberOfRLevels().
protected |
Definition at line 100 of file ossimImageHistogramSource.h.
Referenced by ossimImageHistogramSource(), and setMaxValueOverride().
protected |
Definition at line 99 of file ossimImageHistogramSource.h.
Referenced by ossimImageHistogramSource(), and setMinValueOverride().
protected |
Definition at line 101 of file ossimImageHistogramSource.h.
Referenced by ossimImageHistogramSource(), and setNumberOfBinsOverride().
