#include <ossimHistogramWriter.h>
| ossimHistogramWriter (ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| void | setAreaOfInterest (const ossimIrect &rect) |
| virtual bool | execute () |
| virtual bool | open () |
| virtual bool | open (const ossimFilename &filename) |
| virtual void | close () |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | processProgressEvent (ossimProcessProgressEvent &event) |
| virtual void | abort () |
| Overrides base to pass on abort to theHistogramSource. More... | |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual void | setPercentComplete (double percentComplete) |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimHistogramWriter () |
| virtual void | writeHistogram () |
Friends | |
| class | ossimHistogramWriterProcessListener |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Definition at line 29 of file ossimHistogramWriter.h.
| ossimHistogramWriter::ossimHistogramWriter | ( | ossimImageSource * | inputSource = 0, |
| ossimObject * | owner = 0 |
Definition at line 48 of file ossimHistogramWriter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimIrect::makeNan(), ossimHistogramWriterProcessListener, theAreaOfInterest, and theProcessListener.
protectedvirtual |
Definition at line 67 of file ossimHistogramWriter.cpp.
References close(), isOpen(), theHistogramSource, and theProcessListener.
Reimplemented from ossimProcessInterface.
Definition at line 285 of file ossimHistogramWriter.cpp.
References ossimProcessInterface::abort(), ossimProcessInterface::PROCESS_STATUS_ABORTED, PTR_CAST, ossimProcessInterface::setProcessStatus(), and theHistogramSource.
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 135 of file ossimHistogramWriter.cpp.
References PTR_CAST.
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 118 of file ossimHistogramWriter.cpp.
References theFileStream.
Referenced by open(), and ~ossimHistogramWriter().
Reimplemented from ossimConnectableObjectListener.
Definition at line 162 of file ossimHistogramWriter.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::getInput(), ossimEvent::getObject(), ossimConnectionEvent::getOldObject(), and PTR_CAST.
Definition at line 179 of file ossimHistogramWriter.cpp.
References ossimConnectableObject::getInput(), ossimConnectionEvent::getOldObject(), and PTR_CAST.
Implements ossimProcessInterface.
Definition at line 214 of file ossimHistogramWriter.cpp.
References writeHistogram().
Referenced by ossimImageHandler::buildHistogram(), and ossimImageFileWriter::writeHistogramFile().
Definition at line 91 of file ossimHistogramWriter.cpp.
Definition at line 143 of file ossimHistogramWriter.cpp.
Definition at line 96 of file ossimHistogramWriter.cpp.
Referenced by open(), writeHistogram(), and ~ossimHistogramWriter().
Reimplemented from ossimOutputSource.
Definition at line 198 of file ossimHistogramWriter.cpp.
References ossimConnectableObject::getNumberOfInputs(), ossimOutputSource::loadState(), and ossimConnectableObject::setNumberOfInputs().
open the histogram file for output. Note if the file was previously open then it will close it and re-opens the file.
Definition at line 101 of file ossimHistogramWriter.cpp.
References ossimString::c_str(), close(), isOpen(), theFilename, and theFileStream.
Referenced by writeHistogram().
Definition at line 113 of file ossimHistogramWriter.cpp.
References ossimOutputSource::open().
Definition at line 148 of file ossimHistogramWriter.cpp.
References ossimProcessProgressEvent::getMessage(), ossimEvent::getObject(), ossimProcessProgressEvent::getPercentComplete(), ossimProcessInterface::setCurrentMessage(), and ossimProcessInterface::setPercentComplete().
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 189 of file ossimHistogramWriter.cpp.
References ossimOutputSource::saveState().
| void ossimHistogramWriter::setAreaOfInterest | ( | const ossimIrect & | rect | ) |
Definition at line 86 of file ossimHistogramWriter.cpp.
References theAreaOfInterest.
Definition at line 130 of file ossimHistogramWriter.cpp.
References theFilename.
Referenced by ossimImageHandler::buildHistogram(), setOutputName(), and ossimImageFileWriter::writeHistogramFile().
Overrides the base class and maps the outputName to a filename.
Definition at line 124 of file ossimHistogramWriter.cpp.
References setFilename(), and ossimOutputSource::setOutputName().
protectedvirtual |
Definition at line 221 of file ossimHistogramWriter.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::connectMyInputTo(), ossimSource::enableSource(), ossimHistogramSource::getHistogram(), ossimConnectableObject::getInput(), ossimProcessInterface::isAborted(), isOpen(), open(), PTR_CAST, ossimMultiResLevelHistogram::saveState(), theHistogramSource, theProcessListener, and ossimRefPtr< T >::valid().
Referenced by execute().
friend |
Definition at line 34 of file ossimHistogramWriter.h.
Referenced by ossimHistogramWriter().
protected |
Definition at line 90 of file ossimHistogramWriter.h.
Referenced by ossimHistogramWriter(), and setAreaOfInterest().
protected |
Definition at line 91 of file ossimHistogramWriter.h.
Referenced by open(), and setFilename().
protected |
Definition at line 92 of file ossimHistogramWriter.h.
protected |
stored for abort call only.
Definition at line 96 of file ossimHistogramWriter.h.
Referenced by abort(), writeHistogram(), and ~ossimHistogramWriter().
protected |
Definition at line 93 of file ossimHistogramWriter.h.
Referenced by ossimHistogramWriter(), writeHistogram(), and ~ossimHistogramWriter().
