#include <ossimSensorModel.h>
Public Types | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightEllipsoid, ossimGpt &worldPt) const =0 |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| virtual ossimObject * | dup () const =0 |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
| virtual bool | useForward () const =0 |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| virtual void | initAdjustableParameters () |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| static void | writeGeomTemplate (ostream &os) |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Protected Attributes | |
| ossimIpt | theImageSize |
| ossimDpt | theSubImageOffset |
| ossimString | theImageID |
| ossimString | theSensorID |
| ossimDpt | theGSD |
| ossim_float64 | theMeanGSD |
| ossimGpt | theRefGndPt |
| ossimDpt | theRefImgPt |
| ossimPolygon | theBoundGndPolygon |
| ossimDrect | theImageClipRect |
| ossim_float64 | theRelPosError |
| ossim_float64 | theNominalPosError |
| ossimDpt | theParWRTx |
| Partials for current point. More... | |
| ossimDpt | theParWRTy |
| ossimDpt | theParWRTz |
| ossimDpt | theObs |
| Observations & residuals for current point. More... | |
| ossimDpt | theResid |
| ossimRefPtr< ossimProjection > | theSeedFunction |
| Used as an initial guess for iterative solutions and a guess for points outside the support bounds. More... | |
| bool | theExtrapolateImageFlag |
| bool | theExtrapolateGroundFlag |
| Enumerator | |
| COV_INVALID | |
| COV_PARTIAL | |
| COV_FULL | |
Definition at line 60 of file ossimSensorModel.h.
| Enumerator | |
| OBS_INIT | |
| EVALUATE | |
| P_WRT_X | |
| P_WRT_Y | |
| P_WRT_Z | |
Definition at line 67 of file ossimSensorModel.h.
| ossimSensorModel::ossimSensorModel | ( | ) |
CONSTRUCTORS:
Definition at line 97 of file ossimSensorModel.cpp.
| ossimSensorModel::ossimSensorModel | ( | const ossimSensorModel & | copy_this | ) |
Definition at line 133 of file ossimSensorModel.cpp.
| ossimSensorModel::ossimSensorModel | ( | const ossimKeywordlist & | geom_kwl | ) |
Definition at line 180 of file ossimSensorModel.cpp.
protectedvirtual |
Definition at line 255 of file ossimSensorModel.cpp.
inlinevirtual |
This is from the adjustable parameter interface. It is called when a paraemter adjustment is made.
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 172 of file ossimSensorModel.h.
References ossimAdjustableParameterInterface::updateModel().
protected |
METHOD: buildNormalEquation builds linearized system (LMS equivalent) A*dp = projResidue
A: symetric matrix = tJ*J dp: system parameter shift that we want to estimate projResidue = tJ * residue
t: transposition operator J = jacobian of transform relative to parameters p, transform can be forward() or inverse() jacobian is obtained via finite differences residue can be image (2D) or ground residue(3D)
TODO: use image/ground points covariance matrices
Definition at line 1549 of file ossimSensorModel.cpp.
References A, ossimProjection::forward(), getForwardDeriv(), getInverseDeriv(), ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), ossimTieGptSet::getTiePoints(), ossimGpt::hgt, ossimProjection::inverse(), ossimGpt::lat, ossimGpt::lon, M_PI, ossimTieGptSet::size(), ossimOptimizableProjection::useForward(), ossimDpt::x, and ossimDpt::y.
Referenced by optimizeFit().
| void ossimSensorModel::computeGsd | ( | ) |
Definition at line 1204 of file ossimSensorModel.cpp.
References ossimGpt::distanceTo(), ossimIpt::hasNans(), ossimDpt::hasNans(), ossimGpt::hasNans(), ossimDrect::hasNans(), ossimDrect::height(), ossimGpt::hgt, lineSampleHeightToWorld(), lineSampleToWorld(), ossimDrect::midPoint(), ossimNotify(), ossimNotifyLevel_DEBUG, theGSD, theImageClipRect, theImageSize, theMeanGSD, theRefImgPt, ossimDrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by ossimQuickbirdRpcModel::finishConstruction(), ossimplugins::ossimPleiadesModel::finishConstruction(), ossimplugins::ossimSpot6Model::finishConstruction(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), ossimApplanixEcefModel::ossimApplanixEcefModel(), ossimRpcModel::setAttributes(), ossimIpodSensor::updateModel(), ossimSkyBoxLearSensor::updateModel(), and ossimSonomaSensor::updateModel().
optimizableProjection implementation
Implements ossimOptimizableProjection.
Definition at line 1405 of file ossimSensorModel.cpp.
References ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), and ossimAdjustableParameterInterface::isParameterLocked().
METHOD: extrapolate() Extrapolates solutions for points outside of the image. The second version accepts a height value – if left at the default, the elevation will be looked up via theElevation object.
Reimplemented in ossimH5GridModel.
Definition at line 1048 of file ossimSensorModel.cpp.
Referenced by ossimSonomaSensor::lineSampleHeightToWorld(), ossimSpot5Model::lineSampleHeightToWorld(), and worldToLineSample().
protectedvirtual |
Reimplemented in ossimCoarseGridModel.
Definition at line 951 of file ossimSensorModel.cpp.
References theExtrapolateImageFlag.
Implements ossimAdjustableParameterInterface.
Definition at line 262 of file ossimSensorModel.cpp.
Definition at line 267 of file ossimSensorModel.cpp.
METHOD: getForwardDeriv() gives forward() partial derivative regarding parameter parmIdx (>=0) default implementation is centered finite difference -should be reimplemented with formal derivative in child class
Reimplemented in ossimRpcModel, and ossimSarModel.
Definition at line 1682 of file ossimSensorModel.cpp.
References ossimProjection::forward(), ossimAdjustableParameterInterface::getAdjustableParameter(), and ossimAdjustableParameterInterface::setAdjustableParameter().
Referenced by buildNormalEquation(), ossimSarModel::getForwardDeriv(), and ossimRpcModel::getForwardDeriv().
inline |
Definition at line 224 of file ossimSensorModel.h.
inlinevirtual |
| key | non-ossim-based input ossimString |
| value | non-ossim-based input ossimString |
| geomKwl | The keyword list to fill in. |
Definition at line 282 of file ossimSensorModel.h.
inline |
METHOD: getInverseDeriv() gives inverse() partial derivative regarding parameter parmIdx (>=0) default implementation is centered finite difference -should be reimplemented with formal derivative in child class
Definition at line 1657 of file ossimSensorModel.cpp.
References ossimAdjustableParameterInterface::getAdjustableParameter(), ossimGpt::hgt, ossimProjection::inverse(), ossimGpt::lat, ossimGpt::lon, M_PI, and ossimAdjustableParameterInterface::setAdjustableParameter().
Referenced by buildNormalEquation().
inlinevirtual |
ACCESS METHODS:
Implements ossimProjection.
Reimplemented in ossimAdjMapModel.
Definition at line 93 of file ossimSensorModel.h.
inlinevirtual |
Definition at line 97 of file ossimSensorModel.h.
Referenced by ATP::ossimCorrelationSource::initialize(), and ATP::ossimDescriptorSource::initialize().
METHOD: getObsCovMat()
Definition at line 1162 of file ossimSensorModel.cpp.
inlinevirtual |
Definition at line 100 of file ossimSensorModel.h.
protected |
METHOD: getResidue() returns ground opr image residue
Definition at line 1704 of file ossimSensorModel.cpp.
References ossimProjection::forward(), ossimTieGptSet::getTiePoints(), ossimGpt::hgt, ossimProjection::inverse(), ossimGpt::lat, ossimGpt::lon, M_PI, ossimTieGptSet::size(), ossimOptimizableProjection::useForward(), ossimDpt::x, and ossimDpt::y.
inline |
METHOD: imageSize() Returns the maximum line/sample rigorously defined by this model.
Definition at line 166 of file ossimSensorModel.h.
Referenced by ossimCoarseGridModel::buildGrid(), ossimAlphaSensorHRI::initialize(), ossimAlphaSensorHSI::initialize(), and ossimEnviCgModel::loadEnviGeocFile().
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Reimplemented in ossimRpcModel, ossimFcsiModel, ossimSarModel, ossimLandSatModel, ossimplugins::ossimFormosatModel, ossimCoarseGridModel, ossimSpot5Model, ossimRS1SarModel, ossimSonomaSensor, ossimRsmModel, ossimIpodSensor, ossimSkyBoxLearSensor, ossimApplanixEcefModel, ossimAlphaSensorHRI, ossimAlphaSensorHSI, ossimPpjFrameSensor, ossimSpectraboticsRedEdgeModel, and ossimApplanixUtmModel.
Definition at line 1134 of file ossimSensorModel.cpp.
Referenced by ossimCoarseGridModel::imagingRay(), ossimAlphaSensor::lineSampleHeightToWorld(), and ossimAlphaSensor::lineSampToWorld().
inlinevirtual |
METHOD: insideImage(image_point) Returns true if the image_point lies inside the image rectangle.
Reimplemented in ossimApplanixEcefModel, and ossimSpectraboticsRedEdgeModel.
Definition at line 199 of file ossimSensorModel.h.
Referenced by ossimIpodSensor::lineSampleHeightToWorld(), ossimSonomaSensor::lineSampleHeightToWorld(), and ossimCoarseGridModel::lineSampleToWorld().
protected |
Definition at line 1770 of file ossimSensorModel.cpp.
References SVD().
Referenced by solveLeastSquares().
inlinevirtual |
Implementation of pure virtual ossimProjection::isAffectedByElevation method.
Definition at line 263 of file ossimSensorModel.h.
pure virtual |
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implemented in ossimRpcModel, ossimFcsiModel, ossimplugins::ossimRadarSat2RPCModel, ossimCoarseGridModel, ossimLandSatModel, ossimSarModel, ossimplugins::ossimFormosatModel, ossimplugins::ossimTileMapModel, ossimSpot5Model, ossimplugins::ossimGeometricSarSensorModel, ossimSonomaSensor, ossimAdjMapModel, ossimRS1SarModel, ossimNitfMapModel, ossimNitfRpcModel, ossimSkyBoxLearSensor, ossimRsmModel, ossimIpodSensor, ossimApplanixEcefModel, ossimSpectraboticsRedEdgeModel, ossimPpjFrameSensor, ossimApplanixUtmModel, and ossimAlphaSensor.
Referenced by computeGsd(), and worldToLineSample().
Implementation of base-class pure virtual projection methods. These methods may be overriden by derived classes if those have more efficient schemes. The implementations here are iterative (relatively slow). Both depend on calls to the pure virtual lineSampleHeightToWorld() method.
Reimplemented in ossimplugins::ossimGeometricSarSensorModel, ossimRpcModel, ossimCoarseGridModel, ossimSarModel, ossimplugins::ossimTileMapModel, ossimSonomaSensor, ossimAdjMapModel, ossimRsmModel, ossimApplanixEcefModel, ossimPpjFrameSensor, ossimSpectraboticsRedEdgeModel, and ossimApplanixUtmModel.
Definition at line 280 of file ossimSensorModel.cpp.
Referenced by computeGsd(), ossimCoarseGridModel::lineSampleToWorld(), ossimIpodSensor::updateModel(), and ossimSkyBoxLearSensor::updateModel().
Reimplemented from ossimProjection.
Reimplemented in ossimplugins::ossimGeometricSarSensorModel, ossimRpcModel, ossimFcsiModel, ossimSonomaSensor, ossimplugins::ossimRadarSat2Model, ossimplugins::ossimTerraSarModel, ossimplugins::ossimRadarSat2RPCModel, ossimplugins::ossimAlosPalsarModel, ossimRsmModel, ossimplugins::ossimRadarSatModel, ossimplugins::ossimEnvisatAsarModel, ossimplugins::ossimErsSarModel, ossimLandSatModel, ossimSkyBoxLearSensor, ossimIpodSensor, ossimH5GridModel, ossimCoarseGridModel, ossimplugins::ossimFormosatModel, ossimplugins::ossimPleiadesModel, ossimplugins::ossimSpot6Model, ossimplugins::ossimTileMapModel, ossimSpot5Model, ossimRS1SarModel, ossimApplanixEcefModel, ossimAdjMapModel, ossimNitfRpcModel, ossimSpectraboticsRedEdgeModel, ossimSarModel, ossimNitfMapModel, ossimNitfRsmModel, ossimPpjFrameSensor, ossimIkonosRpcModel, ossimApplanixUtmModel, ossimQuickbirdRpcModel, ossimAlphaSensor, ossimAlphaSensorHRI, and ossimAlphaSensorHSI.
Definition at line 719 of file ossimSensorModel.cpp.
Referenced by ossimSarModel::loadState(), ossimSpot5Model::loadState(), ossimplugins::ossimTileMapModel::loadState(), ossimplugins::ossimFormosatModel::loadState(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), and ossimplugins::ossimGeometricSarSensorModel::loadState().
inlinevirtual |
Reimplemented from ossimOptimizableProjection.
Definition at line 230 of file ossimSensorModel.h.
| const ossimSensorModel & ossimSensorModel::operator= | ( | const ossimSensorModel & | rhs | ) |
assignment operator
Definition at line 221 of file ossimSensorModel.cpp.
References ossimOptimizableProjection::operator=(), ossimAdjustableParameterInterface::operator=(), theBoundGndPolygon, theExtrapolateGroundFlag, theExtrapolateImageFlag, theGSD, theImageClipRect, theImageID, theImageSize, theMeanGSD, theNominalPosError, theObs, theParWRTx, theParWRTy, theParWRTz, theRefGndPt, theRefImgPt, theRelPosError, theResid, theSensorID, and theSubImageOffset.
Referenced by ossimRsmModel::operator=().
inlinevirtual |
OPERATORS:
Definition at line 379 of file ossimSensorModel.h.
References theImageID, theSensorID, and theSubImageOffset.
optimizeFit() adjusts projection to GLOBALLY fit best to ALL tie points (no outlier rejection) can select an optional threshold for accuracy
RETURNS : resulting image error variance of fitted model, or negative value for error
IMPORTANT : the unit for *targetVariance and the returned value is : meters^2 when useForward() is true OR pixel^2 if useForward() is false
Definition at line 1422 of file ossimSensorModel.cpp.
References A, buildNormalEquation(), ossimAdjustableParameterInterface::getAdjustment(), ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), ossimAdjustmentInfo::getParameterList(), getResidue(), max, n, ossimAdjustableParameterInterface::setAdjustableParameter(), ossimTieGptSet::size(), solveLeastSquares(), and updateModel().
inlinevirtual |
ACCESS METHODS:
Definition at line 92 of file ossimSensorModel.h.
Referenced by ossimSonomaSensor::intersectRay(), ossimSonomaSensor::intersectRayWithHeight(), ossimSonomaSensor::lineSampleHeightToWorld(), and ossimSonomaSensor::lineSampleToWorld().
METHOD: print() Fulfills base-class pure virtual. Dumps contents of object to ostream.
Reimplemented in ossimplugins::ossimGeometricSarSensorModel, ossimRpcModel, ossimFcsiModel, ossimplugins::ossimRadarSat2Model, ossimplugins::ossimTerraSarModel, ossimplugins::ossimRadarSat2RPCModel, ossimplugins::ossimEnvisatAsarModel, ossimSarModel, ossimLandSatModel, ossimRsmModel, ossimCoarseGridModel, ossimplugins::ossimFormosatModel, ossimplugins::ossimPleiadesModel, ossimplugins::ossimSpot6Model, ossimSpot5Model, ossimAdjMapModel, ossimplugins::ossimTileMapModel, and ossimNitfMapModel.
Definition at line 501 of file ossimSensorModel.cpp.
References ossimProjection::print(), theBoundGndPolygon, theGSD, theImageClipRect, theImageID, theImageSize, theMeanGSD, theNominalPosError, theRefGndPt, theRefImgPt, theRelPosError, theSensorID, and theSubImageOffset.
Referenced by ossimNitfMapModel::print(), ossimplugins::ossimTileMapModel::print(), ossimAdjMapModel::print(), ossimSpot5Model::print(), ossimplugins::ossimFormosatModel::print(), ossimSarModel::print(), and ossimFcsiModel::print().
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Reimplemented in ossimplugins::ossimGeometricSarSensorModel, ossimRpcModel, ossimFcsiModel, ossimSonomaSensor, ossimplugins::ossimRadarSat2Model, ossimplugins::ossimTerraSarModel, ossimplugins::ossimRadarSat2RPCModel, ossimSkyBoxLearSensor, ossimplugins::ossimAlosPalsarModel, ossimLandSatModel, ossimRsmModel, ossimplugins::ossimRadarSatModel, ossimIpodSensor, ossimplugins::ossimEnvisatAsarModel, ossimplugins::ossimErsSarModel, ossimplugins::ossimFormosatModel, ossimplugins::ossimPleiadesModel, ossimplugins::ossimSpot6Model, ossimCoarseGridModel, ossimplugins::ossimTileMapModel, ossimH5GridModel, ossimSpot5Model, ossimSarModel, ossimAdjMapModel, ossimApplanixEcefModel, ossimRS1SarModel, ossimNitfRpcModel, ossimSpectraboticsRedEdgeModel, ossimPpjFrameSensor, ossimNitfMapModel, ossimHdf5GridModel, ossimApplanixUtmModel, ossimQuickbirdRpcModel, ossimNitfRsmModel, ossimIkonosRpcModel, ossimAlphaSensor, ossimAlphaSensorHRI, ossimAlphaSensorHSI, and ossimEnviCgModel.
Definition at line 561 of file ossimSensorModel.cpp.
Referenced by ossim::Image::saveJSON(), ossimAlphaSensor::saveState(), ossimApplanixUtmModel::saveState(), ossimPpjFrameSensor::saveState(), ossimSpectraboticsRedEdgeModel::saveState(), ossimApplanixEcefModel::saveState(), ossimAdjMapModel::saveState(), ossimSpot5Model::saveState(), ossimplugins::ossimTileMapModel::saveState(), ossimplugins::ossimFormosatModel::saveState(), ossimIpodSensor::saveState(), ossimSkyBoxLearSensor::saveState(), ossimSonomaSensor::saveState(), and ossimplugins::ossimGeometricSarSensorModel::saveState().
| void ossimSensorModel::setGroundRect | ( | const ossimGpt & | ul, |
| const ossimGpt & | ur, | ||
| const ossimGpt & | lr, | ||
| const ossimGpt & | ll | ||
Definition at line 542 of file ossimSensorModel.cpp.
References ossimPolygon::addPoint(), ossimPolygon::clear(), and theBoundGndPolygon.
Referenced by ossimplugins::ossimRadarSatModel::open(), ossimplugins::ossimRadarSat2RPCModel::open(), and ossimplugins::ossimRadarSat2Model::open().
| void ossimSensorModel::setImageRect | ( | const ossimDrect & | imageRect | ) |
Definition at line 536 of file ossimSensorModel.cpp.
References ossimDrect::midPoint(), ossimDrect::size(), theImageClipRect, theImageSize, and theRefImgPt.
Referenced by ossimAlphaSensorHRI::initialize(), and ossimAlphaSensorHSI::initialize().
inline |
Definition at line 167 of file ossimSensorModel.h.
References size.
inlinevirtual |
Definition at line 103 of file ossimSensorModel.h.
| void ossimSensorModel::setRefGndPt | ( | const ossimGpt & | pt | ) |
| pt | Image center point. |
Definition at line 531 of file ossimSensorModel.cpp.
References theRefGndPt.
| void ossimSensorModel::setRefImgPt | ( | const ossimDpt & | pt | ) |
| pt | Image center point (x = sample, y = line). |
Definition at line 526 of file ossimSensorModel.cpp.
References theRefImgPt.
inlinevirtual |
Definition at line 106 of file ossimSensorModel.h.
protected |
solves Ax = r , with A symmetric positive definite A can be rank deficient size of A is typically between 10 and 100 rows
Definition at line 1760 of file ossimSensorModel.cpp.
References A, invert(), and x.
inlinevirtual |
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Reimplemented in ossimRpcModel, ossimFcsiModel, ossimSarModel, ossimLandSatModel, ossimplugins::ossimFormosatModel, ossimSpot5Model, ossimAdjMapModel, ossimSonomaSensor, ossimRsmModel, ossimSkyBoxLearSensor, ossimIpodSensor, ossimApplanixEcefModel, ossimPpjFrameSensor, ossimSpectraboticsRedEdgeModel, ossimApplanixUtmModel, ossimAlphaSensor, ossimAlphaSensorHRI, and ossimAlphaSensorHSI.
Definition at line 182 of file ossimSensorModel.h.
Referenced by ossimplugins::ossimTileMapModel::loadState(), and optimizeFit().
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Reimplemented in ossimFcsiModel, ossimRpcModel, ossimplugins::ossimRadarSat2RPCModel, ossimSarModel, ossimH5GridModel, ossimAdjMapModel, ossimplugins::ossimTileMapModel, ossimNitfRpcModel, ossimApplanixEcefModel, ossimRsmModel, ossimPpjFrameSensor, ossimSpectraboticsRedEdgeModel, ossimApplanixUtmModel, ossimAlphaSensorHRI, and ossimAlphaSensorHSI.
Definition at line 325 of file ossimSensorModel.cpp.
References ossim::almostEqual(), DBL_EPSILON, extrapolate(), ossimPolygon::getNumberOfVertices(), ossimPolygon::hasNans(), ossimGpt::hgt, ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossim::isnan(), ossimGpt::lat, lineSampleHeightToWorld(), ossimGpt::lon, ossimDpt::makeNan(), ossimPolygon::pointWithin(), theBoundGndPolygon, theExtrapolateGroundFlag, theRefImgPt, theSeedFunction, theSubImageOffset, ossimDpt::u, ossimDpt::v, ossimRefPtr< T >::valid(), and ossimProjection::worldToLineSample().
Referenced by ossimplugins::ossimGeometricSarSensorModel::optimizeModel().
static |
STATIC METHOD: writeGeomTemplate(ostream) Writes a template of keywords processed by loadState and saveState to output stream.
Definition at line 1364 of file ossimSensorModel.cpp.
Referenced by ossimAdjMapModel::writeGeomTemplate().
protected |
Definition at line 348 of file ossimSensorModel.h.
Referenced by ossimQuickbirdRpcModel::finishConstruction(), ossimplugins::ossimPleiadesModel::finishConstruction(), ossimplugins::ossimSpot6Model::finishConstruction(), ossimH5GridModel::initializeModelParams(), ossimCoarseGridModel::initializeModelParams(), ossimplugins::ossimRadarSat2RPCModel::loadState(), ossimplugins::ossimRadarSat2Model::loadState(), ossimplugins::ossimRadarSat2RPCModel::open(), operator=(), ossimCoarseGridModel::print(), print(), setGroundRect(), ossimApplanixUtmModel::updateModel(), ossimSpectraboticsRedEdgeModel::updateModel(), ossimApplanixEcefModel::updateModel(), ossimIpodSensor::updateModel(), ossimSkyBoxLearSensor::updateModel(), ossimSonomaSensor::updateModel(), ossimApplanixUtmModel::worldToLineSample(), ossimSpectraboticsRedEdgeModel::worldToLineSample(), ossimApplanixEcefModel::worldToLineSample(), and worldToLineSample().
mutableprotected |
Definition at line 369 of file ossimSensorModel.h.
Referenced by operator=(), ossimSpectraboticsRedEdgeModel::updateModel(), ossimApplanixEcefModel::updateModel(), and worldToLineSample().
mutableprotected |
Definition at line 368 of file ossimSensorModel.h.
Referenced by extrapolate(), operator=(), ossimSpectraboticsRedEdgeModel::updateModel(), and ossimApplanixEcefModel::updateModel().
protected |
Definition at line 344 of file ossimSensorModel.h.
Referenced by computeGsd(), ossimQuickbirdRpcModel::finishConstruction(), ossimplugins::ossimPleiadesModel::finishConstruction(), ossimplugins::ossimSpot6Model::finishConstruction(), ossimNitfRpcModel::getGsd(), ossimplugins::ossimRadarSat2Model::getSlantRangeFromGeoreferenced(), ossimAdjMapModel::initializeFromMap(), ossimH5GridModel::initializeModelParams(), ossimCoarseGridModel::initializeModelParams(), ossimplugins::ossimRadarSat2Model::InitRefPoint(), ossimplugins::ossimRadarSat2Model::initRefPoint(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), ossimplugins::ossimPleiadesModel::open(), ossimplugins::ossimSpot6Model::open(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimplugins::ossimRadarSat2Model::open(), operator=(), ossimApplanixEcefModel::ossimApplanixEcefModel(), ossimApplanixUtmModel::ossimApplanixUtmModel(), ossimQuickbirdRpcModel::ossimQuickbirdRpcModel(), ossimSpectraboticsRedEdgeModel::ossimSpectraboticsRedEdgeModel(), ossimQuickbirdRpcModel::parseNitfFile(), ossimQuickbirdRpcModel::parseTiffFile(), ossimplugins::ossimTileMapModel::print(), ossimCoarseGridModel::print(), ossimLandSatModel::print(), print(), ossimPpjFrameSensor::saveState(), and ossimRpcModel::setMetersPerPixel().
protected |
Definition at line 349 of file ossimSensorModel.h.
Referenced by computeGsd(), ossimQuickbirdRpcModel::finishConstruction(), ossimplugins::ossimPleiadesModel::finishConstruction(), ossimplugins::ossimSpot6Model::finishConstruction(), ossimH5GridModel::initializeModelParams(), ossimCoarseGridModel::initializeModelParams(), ossimplugins::ossimCosmoSkymedModel::InitRefPoint(), ossimplugins::ossimErsSarModel::InitRefPoint(), ossimplugins::ossimAlosPalsarModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::InitRefPoint(), ossimplugins::ossimEnvisatAsarModel::InitRefPoint(), ossimplugins::ossimRadarSatModel::InitRefPoint(), ossimSpot5Model::lineSampleHeightToWorld(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), ossimplugins::ossimSpot6Model::open(), ossimplugins::ossimPleiadesModel::open(), ossimplugins::ossimRadarSatModel::open(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimplugins::ossimRadarSat2Model::open(), operator=(), ossimApplanixEcefModel::ossimApplanixEcefModel(), ossimQuickbirdRpcModel::ossimQuickbirdRpcModel(), ossimSpectraboticsRedEdgeModel::ossimSpectraboticsRedEdgeModel(), ossimQuickbirdRpcModel::parseNitfFile(), ossimQuickbirdRpcModel::parseTiffFile(), print(), ossimRpcModel::setImageOffset(), ossimApplanixUtmModel::setImageRect(), ossimSpectraboticsRedEdgeModel::setImageRect(), ossimApplanixEcefModel::setImageRect(), setImageRect(), ossimApplanixUtmModel::updateModel(), ossimSpectraboticsRedEdgeModel::updateModel(), ossimApplanixEcefModel::updateModel(), ossimIpodSensor::updateModel(), ossimSkyBoxLearSensor::updateModel(), and ossimSonomaSensor::updateModel().
protected |
Definition at line 342 of file ossimSensorModel.h.
Referenced by ossimplugins::ossimPleiadesModel::open(), ossimplugins::ossimSpot6Model::open(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimplugins::ossimRadarSat2Model::open(), operator=(), operator==(), ossimQuickbirdRpcModel::parseRpcData(), ossimplugins::ossimTileMapModel::print(), ossimSpot5Model::print(), ossimplugins::ossimPleiadesModel::print(), ossimplugins::ossimSpot6Model::print(), ossimCoarseGridModel::print(), ossimLandSatModel::print(), and print().
protected |
Definition at line 335 of file ossimSensorModel.h.
Referenced by computeGsd(), ossimH5GridModel::debugDump(), ossimQuickbirdRpcModel::finishConstruction(), ossimplugins::ossimSpot6Model::finishConstruction(), ossimplugins::ossimPleiadesModel::finishConstruction(), ossimH5GridModel::getWktFootprint(), ossimAlphaSensorHRI::imagingRay(), ossimAlphaSensorHSI::imagingRay(), ossimRS1SarModel::imagingRay(), ossimHdf5GridModel::initialize(), ossimH5GridModel::initializeModelParams(), ossimCoarseGridModel::initializeModelParams(), ossimplugins::ossimCosmoSkymedModel::InitRefPoint(), ossimplugins::ossimErsSarModel::InitRefPoint(), ossimplugins::ossimAlosPalsarModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::InitRefPoint(), ossimplugins::ossimEnvisatAsarModel::InitRefPoint(), ossimplugins::ossimRadarSatModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::initRefPoint(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), ossimplugins::ossimPleiadesModel::open(), ossimplugins::ossimSpot6Model::open(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimplugins::ossimRadarSat2Model::open(), operator=(), ossimAdjMapModel::ossimAdjMapModel(), ossimplugins::ossimTileMapModel::print(), ossimSpot5Model::print(), ossimplugins::ossimPleiadesModel::print(), ossimplugins::ossimSpot6Model::print(), ossimCoarseGridModel::print(), ossimLandSatModel::print(), print(), ossimAlphaSensor::saveState(), ossimPpjFrameSensor::saveState(), ossimIpodSensor::saveState(), ossimSkyBoxLearSensor::saveState(), ossimAlphaSensor::setFov(), ossimRpcModel::setImageOffset(), setImageRect(), ossimplugins::ossimRadarSat2Model::setModelRefPoint(), ossimIpodSensor::updateModel(), ossimSkyBoxLearSensor::updateModel(), ossimSonomaSensor::updateModel(), ossimAlphaSensorHSI::worldToLineSample(), and ossimAlphaSensorHRI::worldToLineSample().
protected |
Definition at line 345 of file ossimSensorModel.h.
Referenced by computeGsd(), ossimAdjMapModel::initializeFromMap(), ossimH5GridModel::initializeModelParams(), ossimCoarseGridModel::initializeModelParams(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimplugins::ossimRadarSat2Model::open(), operator=(), ossimApplanixEcefModel::ossimApplanixEcefModel(), ossimApplanixUtmModel::ossimApplanixUtmModel(), ossimSpectraboticsRedEdgeModel::ossimSpectraboticsRedEdgeModel(), print(), ossimRpcModel::setMetersPerPixel(), ossimApplanixUtmModel::updateModel(), ossimSpectraboticsRedEdgeModel::updateModel(), and ossimApplanixEcefModel::updateModel().
protected |
Definition at line 351 of file ossimSensorModel.h.
Referenced by ossimplugins::ossimRadarSat2RPCModel::open(), operator=(), print(), and ossimRpcModel::setPositionError().
protected |
Definition at line 359 of file ossimSensorModel.h.
Referenced by ossimSarModel::getForwardDeriv(), ossimRpcModel::getForwardDeriv(), and operator=().
protected |
Definition at line 354 of file ossimSensorModel.h.
protected |
Definition at line 355 of file ossimSensorModel.h.
protected |
Definition at line 356 of file ossimSensorModel.h.
protected |
Definition at line 346 of file ossimSensorModel.h.
Referenced by ossimQuickbirdRpcModel::finishConstruction(), ossimplugins::ossimPleiadesModel::finishConstruction(), ossimplugins::ossimSpot6Model::finishConstruction(), ossimAdjMapModel::initializeFromMap(), ossimH5GridModel::initializeModelParams(), ossimCoarseGridModel::initializeModelParams(), ossimplugins::ossimRadarSat2RPCModel::open(), operator=(), ossimplugins::ossimTileMapModel::print(), ossimSpot5Model::print(), ossimplugins::ossimPleiadesModel::print(), ossimplugins::ossimSpot6Model::print(), ossimCoarseGridModel::print(), ossimLandSatModel::print(), print(), ossimplugins::ossimRadarSat2Model::setModelRefPoint(), ossimApplanixUtmModel::setPlatformPosition(), ossimSpectraboticsRedEdgeModel::setPlatformPosition(), ossimApplanixEcefModel::setPlatformPosition(), setRefGndPt(), ossimIpodSensor::updateModel(), ossimSkyBoxLearSensor::updateModel(), and ossimSonomaSensor::updateModel().
protected |
Definition at line 347 of file ossimSensorModel.h.
Referenced by computeGsd(), ossimQuickbirdRpcModel::finishConstruction(), ossimplugins::ossimPleiadesModel::finishConstruction(), ossimplugins::ossimSpot6Model::finishConstruction(), ossimApplanixUtmModel::imagingRay(), ossimApplanixEcefModel::imagingRay(), ossimIpodSensor::imagingRay(), ossimSkyBoxLearSensor::imagingRay(), ossimSonomaSensor::imagingRay(), ossimH5GridModel::initializeModelParams(), ossimCoarseGridModel::initializeModelParams(), ossimplugins::ossimRadarSat2Model::initRefPoint(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), ossimplugins::ossimRadarSat2RPCModel::open(), operator=(), ossimApplanixEcefModel::ossimApplanixEcefModel(), ossimSpectraboticsRedEdgeModel::ossimSpectraboticsRedEdgeModel(), ossimplugins::ossimTileMapModel::print(), ossimSpot5Model::print(), ossimplugins::ossimSpot6Model::print(), ossimplugins::ossimPleiadesModel::print(), ossimCoarseGridModel::print(), ossimLandSatModel::print(), print(), ossimApplanixUtmModel::setImageRect(), ossimSpectraboticsRedEdgeModel::setImageRect(), ossimApplanixEcefModel::setImageRect(), setImageRect(), ossimplugins::ossimRadarSat2Model::setModelRefPoint(), setRefImgPt(), ossimIpodSensor::updateModel(), ossimSkyBoxLearSensor::updateModel(), ossimSonomaSensor::updateModel(), ossimApplanixUtmModel::worldToLineSample(), ossimApplanixEcefModel::worldToLineSample(), ossimH5GridModel::worldToLineSample(), and worldToLineSample().
protected |
Definition at line 350 of file ossimSensorModel.h.
Referenced by operator=(), and print().
protected |
Definition at line 360 of file ossimSensorModel.h.
Referenced by operator=().
protected |
Definition at line 366 of file ossimSensorModel.h.
Referenced by ossimHdf5GridModel::initialize(), ossimSpot5Model::lineSampleHeightToWorld(), ossimH5GridModel::loadState(), ossimH5GridModel::setGridNodes(), ossimH5GridModel::worldToLineSample(), and worldToLineSample().
protected |
Definition at line 343 of file ossimSensorModel.h.
Referenced by ossimNitfRpcModel::getSensorID(), ossimAdjMapModel::initializeFromMap(), ossimplugins::ossimSpot6Model::open(), ossimplugins::ossimPleiadesModel::open(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimplugins::ossimRadarSat2Model::open(), operator=(), operator==(), ossimIpodSensor::ossimIpodSensor(), ossimSkyBoxLearSensor::ossimSkyBoxLearSensor(), ossimSonomaSensor::ossimSonomaSensor(), ossimQuickbirdRpcModel::parseMetaData(), ossimCoarseGridModel::print(), print(), ossimplugins::ossimSpot6Model::saveState(), and ossimplugins::ossimPleiadesModel::saveState().
protected |
Support sub-image of larger full image by maintaining offset to UL corner
Definition at line 340 of file ossimSensorModel.h.
Referenced by ossimH5GridModel::initializeModelParams(), ossimCoarseGridModel::initializeModelParams(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimplugins::ossimRadarSat2Model::open(), operator=(), operator==(), print(), ossimH5GridModel::worldToLineSample(), and worldToLineSample().
