#include <ossimNitfRsmModel.h>
| ossimNitfRsmModel () | |
| ossimNitfRsmModel (const ossimNitfRsmModel &obj) | |
| copy constructor More... | |
| const ossimNitfRsmModel & | operator= (const ossimNitfRsmModel &rhs) |
| assignment operator More... | |
| virtual bool | parseFile (const ossimFilename &nitfFile, ossim_uint32 entryIndex=0) |
| virtual bool | parseImageHeader (const ossimNitfImageHeader *ih) |
| bool | getRsmData (const ossimNitfImageHeader *ih) |
| saveState Fulfills ossimObject base-class pure virtuals. More... | |
| loadState Fulfills ossimObject base-class pure virtuals. More... | |
| dup() Returns pointer to a new instance, copy of this. More... | |
| bool | initializeModel (const ossimNitfRsmecaTag *rsmecaTag) |
| Initializes model from RSMECA tag. More... | |
Public Member Functions inherited from ossimRsmModel | |
| ossimRsmModel () | |
| ossimRsmModel (const ossimRsmModel &obj) | |
| const ossimRsmModel & | operator= (const ossimRsmModel &rhs) |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| worldToLineSample() Overrides base class implementation. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| lineSampleToWorld() Overrides base class pure virtual. More... | |
| lineSampleHeightToWorld() Overrides base class pure virtual. More... | |
| imagingRay() Overrides base class pure virtual. More... | |
| virtual void | initAdjustableParameters () |
| print() Extends base-class implementation. More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| virtual | ~ossimNitfRsmModel () |
Protected Member Functions inherited from ossimRsmModel | |
| ossim_uint32 | getPcaIndex (const double &x, const double &y, const double &z) const |
| Gets index into RSM Polynomial Coefficients(rsmpca) container array for a given ground point. More... | |
| ossim_uint32 | getPcaIndex (const ossimDpt &ipt, bool shiftPoint) const |
| Gets index into RSM Polynomial Coefficients(rsmpca) container array for a given image point. More... | |
| void | lowOrderPolynomial (const double &x, const double &y, const double &z, ossimDpt &ipt) const |
| double | polynomial (const double &x, const double &y, const double &z, const ossim_uint32 &maxx, const ossim_uint32 &maxy, const ossim_uint32 &maxz, std::vector< double > pcf) const |
| double | dPoly_dLat (const double &x, const double &y, const double &z, const ossim_uint32 &maxx, const ossim_uint32 &maxy, const ossim_uint32 &maxz, std::vector< double > pcf) const |
| double | dPoly_dLon (const double &x, const double &y, const double &z, const ossim_uint32 &maxx, const ossim_uint32 &maxy, const ossim_uint32 &maxz, std::vector< double > pcf) const |
| double | dPoly_dHgt (const double &x, const double &y, const double &z, const ossim_uint32 &maxx, const ossim_uint32 &maxy, const ossim_uint32 &maxz, std::vector< double > pcf) const |
| bool | validate () const |
| Performs sanity check on key/required rsm data. More... | |
| virtual | ~ossimRsmModel () |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 18 of file ossimNitfRsmModel.h.
| ossimNitfRsmModel::ossimNitfRsmModel | ( | ) |
| ossimNitfRsmModel::ossimNitfRsmModel | ( | const ossimNitfRsmModel & | obj | ) |
protectedvirtual |
Reimplemented from ossimRsmModel.
Definition at line 332 of file ossimNitfRsmModel.cpp.
References ossimNitfRsmModel().
| bool ossimNitfRsmModel::getRsmData | ( | const ossimNitfImageHeader * | ih | ) |
Definition at line 193 of file ossimNitfRsmModel.cpp.
| bool ossimNitfRsmModel::initializeModel | ( | const ossimNitfRsmecaTag * | rsmecaTag | ) |
| rsmecaTag |
Definition at line 318 of file ossimNitfRsmModel.cpp.
References status.
Loads and saves geometry KWL files. Returns true if successful.
Definition at line 363 of file ossimNitfRsmModel.cpp.
| const ossimNitfRsmModel & ossimNitfRsmModel::operator= | ( | const ossimNitfRsmModel & | rhs | ) |
assignment operator
Definition at line 48 of file ossimNitfRsmModel.cpp.
References ossimRsmModel::operator=().
Definition at line 61 of file ossimNitfRsmModel.cpp.
References ossimFilename::exists(), ossimRefPtr< T >::get(), ossimNitfFile::getNewImageHeader(), ossimNitfFile::parseFile(), parseImageHeader(), ossimErrorStatusInterface::setErrorStatus(), status, and ossimRefPtr< T >::valid().
Definition at line 87 of file ossimNitfRsmModel.cpp.
Referenced by parseFile().
Definition at line 337 of file ossimNitfRsmModel.cpp.
