This class is able to direct localisation and indirect localisation using the ErsSar sensor model. More...
#include <ossimErsSarModel.h>
| ossimErsSarModel () | |
| Constructor. More... | |
| virtual | ~ossimErsSarModel () |
| Destructor. More... | |
| Method to return the class name. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| virtual double | getSlantRangeFromGeoreferenced (double col) const |
| This function associates an image column number to a slant range when the image is georeferenced (ground projected) More... | |
| bool | open (const ossimFilename &file) |
| Method to instantiate model from the leader file. More... | |
| Method to save object state to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
Public Member Functions inherited from ossimplugins::ossimGeometricSarSensorModel | |
| ossimGeometricSarSensorModel () | |
| ossimGeometricSarSensorModel (const ossimGeometricSarSensorModel &rhs) | |
| copy constructor More... | |
| virtual | ~ossimGeometricSarSensorModel () |
| virtual double | getSlantRange (double col) const |
| This function associates an image column number to a slant range. More... | |
| virtual JSDDateTime | getTime (double line) const |
| This function associates an image line number to an azimuth time. More... | |
| virtual bool | getPlatformPositionAtLine (double line, vector< double > &position, vector< double > &speed) |
| This function associates an image line number to a platform position and speed. More... | |
| This function is able to convert image coordinates into world coordinates the geometric model of SAR sensors. More... | |
| virtual bool | optimizeModel (const std::list< ossimGpt > &groundCoordinates, const std::list< ossimDpt > &imageCoordinates) |
| This function optimizes the model according to a list of Ground Control Points. More... | |
| virtual void | clearGCPlist () |
| Clears _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes Updates the optimisation factors and bias. More... | |
| virtual void | getGCPlist (std::list< ossimGpt > &groundCoordinates, std::list< ossimDpt > &imageCoordinates) |
| Returns _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes. More... | |
| double | get_optimizationFactorX () const |
| Accessors to the optimization parameters. More... | |
| double | get_optimizationFactorY () const |
| double | get_optimizationBiasX () const |
| double | get_optimizationBiasY () const |
| ossimRefPtr< ossimCoarseGridModel > | getReplacementOcgModel () |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| void | set_platformPosition (PlatformPosition *platformPosition) |
| Accessors to the plateform, sensor parameters and reference point. More... | |
| void | set_sensorParams (SensorParams *sensorParams) |
| void | set_refPoint (RefPoint *refPoint) |
| PlatformPosition * | get_platformPosition () const |
| SensorParams * | get_sensorParams () const |
| RefPoint * | get_refPoint () const |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| virtual void | initAdjustableParameters () |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| virtual bool | InitPlatformPosition (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Platform Position from a projection keywordlist. More... | |
| virtual bool | InitSensorParams (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Sensor Params from a projection keywordlist. More... | |
| virtual bool | InitRefPoint (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Reference Point from a projection keywordlist. More... | |
| virtual bool | InitSRGR (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Slant Range for each Ground Range data sets : theNumberSRGR,theSRGRCoeffset,_srgr_update,thePixelSpacing,_isProductGeoreferenced. More... | |
Protected Member Functions inherited from ossimplugins::ossimGeometricSarSensorModel | |
| bool | createReplacementOCG () |
| Creates replacement coarse grid model if user requested via ossim preferences keyword "geometric_sar_sensor_model.create_ocg: <bool>". More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Private Member Functions | |
| virtual bool | isErsLeader (const ossimFilename &file) const |
| virtual ossimFilename | findErsLeader (const ossimFilename &file) const |
Private Attributes | |
| int | theNumberSRGR |
| Slant Range for each Ground Range (SRGR) number of coefficients sets. More... | |
| double | theSRGRCoeffset [1][3] |
| SRGR coefficient sets. More... | |
| double | thePixelSpacing |
| Pixel spacing. More... | |
| ErsSarLeader * | theErsSarleader |
| List of metadata contained in the Leader file. More... | |
Definition at line 37 of file ossimErsSarModel.h.
| ossimplugins::ossimErsSarModel::ossimErsSarModel | ( | ) |
Constructor.
Definition at line 40 of file ossimErsSarModel.cpp.
References theSRGRCoeffset.
Referenced by dup().
Destructor.
Definition at line 50 of file ossimErsSarModel.cpp.
References theErsSarleader.
Implements ossimProjection.
Definition at line 64 of file ossimErsSarModel.cpp.
References ossimErsSarModel().
privatevirtual |
Definition at line 665 of file ossimErsSarModel.cpp.
References ossimFilename::exists(), ossimFilename::fileNoExtension(), and ossimFilename::setFile().
Referenced by open().
Definition at line 59 of file ossimErsSarModel.cpp.
Referenced by loadState().
| col | Column coordinate of the image point |
Implements ossimplugins::ossimGeometricSarSensorModel.
Definition at line 69 of file ossimErsSarModel.cpp.
protectedvirtual |
Definition at line 334 of file ossimErsSarModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_platformPosition, ossimKeywordlist::find(), ossimplugins::JSDDateTime::get_second(), ossimplugins::JSDDateTime::NormDate(), ossimplugins::CivilDateTime::set_day(), ossimplugins::CivilDateTime::set_decimal(), ossimplugins::CivilDateTime::set_month(), ossimplugins::JSDDateTime::set_second(), ossimplugins::CivilDateTime::set_second(), and ossimplugins::CivilDateTime::set_year().
protectedvirtual |
Definition at line 439 of file ossimErsSarModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_platformPosition, ossimplugins::ossimGeometricSarSensorModel::_refPoint, ossimplugins::ossimGeometricSarSensorModel::_sensor, distance(), ossimKeywordlist::find(), ossimplugins::SensorParams::get_nRangeLook(), ossimplugins::SensorParams::get_sf(), ossimplugins::PlatformPosition::Interpolate(), min, ossimplugins::ossimGeometricSarSensorModel::optimizeModel(), ossimplugins::RefPoint::set_distance(), ossimplugins::RefPoint::set_ephemeris(), ossimplugins::RefPoint::set_pix_col(), ossimplugins::RefPoint::set_pix_line(), ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Definition at line 76 of file ossimErsSarModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_sensor, ossimString::c_str(), ossimKeywordlist::find(), ossimplugins::SensorParams::Right, ossimplugins::SensorParams::set_col_direction(), ossimplugins::SensorParams::set_lin_direction(), ossimplugins::SensorParams::set_nAzimuthLook(), ossimplugins::SensorParams::set_nRangeLook(), ossimplugins::SensorParams::set_prf(), ossimplugins::SensorParams::set_rwl(), ossimplugins::SensorParams::set_semiMajorAxis(), ossimplugins::SensorParams::set_semiMinorAxis(), ossimplugins::SensorParams::set_sf(), ossimplugins::SensorParams::set_sightDirection(), and ossimString::upcase().
protectedvirtual |
Definition at line 596 of file ossimErsSarModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_isProductGeoreferenced, ossimKeywordlist::find(), ossimString::find(), theNumberSRGR, theSRGRCoeffset, and ossimString::upcase().
privatevirtual |
Definition at line 633 of file ossimErsSarModel.cpp.
References ossimString::c_str(), and ossimString::find().
Reimplemented from ossimplugins::ossimGeometricSarSensorModel.
Definition at line 252 of file ossimErsSarModel.cpp.
References ossimKeywordlist::find(), getClassName(), InitPlatformPosition(), InitRefPoint(), InitSensorParams(), InitSRGR(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimNotifyLevel_WARN, and ossimKeywordNames::TYPE_KW.
| bool ossimplugins::ossimErsSarModel::open | ( | const ossimFilename & | file | ) |
| file |
Definition at line 140 of file ossimErsSarModel.cpp.
References ossimString::c_str(), ossimFilename::exists(), findErsLeader(), isErsLeader(), loadState(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimplugins::ossimGeometricSarSensorModel::print(), saveState(), and theErsSarleader.
| kwl | Keyword list to save to. |
| prefix | added to keys when saved. |
Definition at line 220 of file ossimErsSarModel.cpp.
References ossimNotify(), ossimNotifyLevel_DEBUG, ossimplugins::ErsSarLeader::saveState(), and theErsSarleader.
private |
Definition at line 116 of file ossimErsSarModel.h.
Referenced by open(), saveState(), and ~ossimErsSarModel().
private |
Definition at line 103 of file ossimErsSarModel.h.
Referenced by InitSRGR().
private |
Pixel spacing.
Definition at line 111 of file ossimErsSarModel.h.
private |
Definition at line 107 of file ossimErsSarModel.h.
Referenced by getSlantRangeFromGeoreferenced(), InitSRGR(), and ossimErsSarModel().
