#include <ossimApplanixUtmModel.h>
| ossimApplanixUtmModel () | |
| ossimApplanixUtmModel (const ossimApplanixUtmModel &src) | |
| void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| void | setPrincipalPoint (ossimDpt principalPoint) |
| void | setPixelSize (const ossimDpt &pixelSize) |
| void | setImageRect (const ossimDrect &rect) |
| void | setFocalLength (double focalLength) |
| void | setPlatformPosition (const ossimGpt &gpt) |
| virtual void | initAdjustableParameters () |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| ground to image faster (you don't need DEM) //TBC More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 16 of file ossimApplanixUtmModel.h.
| ossimApplanixUtmModel::ossimApplanixUtmModel | ( | ) |
Definition at line 32 of file ossimApplanixUtmModel.cpp.
References ossimMatrix4x4::createIdentity(), initAdjustableParameters(), theCompositeMatrix, theCompositeMatrixInverse, theEcefPlatformPosition, theFocalLength, ossimSensorModel::theGSD, theLensDistortion, ossimSensorModel::theMeanGSD, thePixelSize, ossimDpt::x, and ossimDpt::y.
Referenced by dup().
| ossimApplanixUtmModel::ossimApplanixUtmModel | ( | const ossimApplanixUtmModel & | src | ) |
Definition at line 61 of file ossimApplanixUtmModel.cpp.
References ossimRefPtr< T >::get(), theLensDistortion, and ossimRefPtr< T >::valid().
Implements ossimProjection.
Definition at line 90 of file ossimApplanixUtmModel.cpp.
References ossimApplanixUtmModel().
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Reimplemented from ossimSensorModel.
Definition at line 95 of file ossimApplanixUtmModel.cpp.
References ossimEcefVector::magnitude(), ossimEcefRay::setDirection(), ossimEcefRay::setOrigin(), theAdjEcefPlatformPosition, theCompositeMatrix, theFocalLength, theLensDistortion, thePixelSize, thePrincipalPoint, ossimSensorModel::theRefImgPt, ossimMeanRadialLensDistortion::undistort(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by lineSampleHeightToWorld().
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 320 of file ossimApplanixUtmModel.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray(), ossimAdjustableParameterInterface::setAdjustableParameter(), ossimAdjustableParameterInterface::setParameterDescription(), ossimAdjustableParameterInterface::setParameterSigma(), and ossimAdjustableParameterInterface::setParameterUnit().
Referenced by ossimApplanixUtmModel().
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 173 of file ossimApplanixUtmModel.cpp.
References imagingRay(), and ossimEcefRay::intersectAboveEarthEllipsoid().
Implementation of base-class pure virtual projection methods. These methods may be overriden by derived classes if those have more efficient schemes. The implementations here are iterative (relatively slow). Both depend on calls to the pure virtual lineSampleHeightToWorld() method.
Definition at line 134 of file ossimApplanixUtmModel.cpp.
Referenced by updateModel().
Definition at line 443 of file ossimApplanixUtmModel.cpp.
Referenced by setupOptimizer().
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Definition at line 387 of file ossimApplanixUtmModel.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimDatum::code(), ossimGpt::datum(), ossimGpt::height(), ossimGpt::latd(), ossimGpt::lond(), ossimMeanRadialLensDistortion::saveState(), ossimSensorModel::saveState(), theBoreSightTx, theBoreSightTy, theBoreSightTz, theEcefPlatformPosition, theFocalLength, theKappa, theLensDistortion, theOmega, thePhi, thePixelSize, thePlatformPosition, thePrincipalPoint, theShiftValues, theUtmHemisphere, theUtmPlatformPosition, theUtmZone, ossimString::toString(), ossimRefPtr< T >::valid(), ossimEcefPoint::x(), ossimEcefVector::x(), ossimDpt3d::x, ossimDpt::x, ossimEcefPoint::y(), ossimEcefVector::y(), ossimDpt3d::y, ossimDpt::y, ossimEcefPoint::z(), ossimEcefVector::z(), and ossimDpt3d::z.
| void ossimApplanixUtmModel::setFocalLength | ( | double | focalLength | ) |
| void ossimApplanixUtmModel::setImageRect | ( | const ossimDrect & | rect | ) |
Definition at line 368 of file ossimApplanixUtmModel.cpp.
References ossimDrect::midPoint(), ossimSensorModel::theImageClipRect, and ossimSensorModel::theRefImgPt.
| void ossimApplanixUtmModel::setPixelSize | ( | const ossimDpt & | pixelSize | ) |
| void ossimApplanixUtmModel::setPlatformPosition | ( | const ossimGpt & | gpt | ) |
Definition at line 379 of file ossimApplanixUtmModel.cpp.
References theEcefPlatformPosition, ossimSensorModel::theRefGndPt, and updateModel().
| void ossimApplanixUtmModel::setPrincipalPoint | ( | ossimDpt | principalPoint | ) |
Definition at line 358 of file ossimApplanixUtmModel.cpp.
References thePrincipalPoint.
Reimplemented from ossimOptimizableProjection.
Definition at line 973 of file ossimApplanixUtmModel.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), and loadState().
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 234 of file ossimApplanixUtmModel.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossimMatrix3x3::createRotationXMatrix(), ossimMatrix3x3::createRotationYMatrix(), ossimMatrix3x3::createRotationZMatrix(), ossimEcefVector::cross(), ossimUtmProjection::forward(), ossimGpt::height(), ossimUtmProjection::inverse(), ossimGpt::latd(), lineSampleToWorld(), ossimDrect::ll(), ossimGpt::lond(), ossimDrect::lr(), ossimLsrSpace::lsrToEcefRotMatrix(), ossimGpt::metersPerDegree(), ossimEcefVector::normalize(), OSSIM_LEFT_HANDED, ossimPolygon::resize(), ossimMapProjection::setMetersPerPixel(), ossimUtmProjection::setZone(), theAdjEcefPlatformPosition, ossimSensorModel::theBoundGndPolygon, theCompositeMatrix, theCompositeMatrixInverse, ossimSensorModel::theImageClipRect, theKappa, ossimSensorModel::theMeanGSD, theOmega, thePhi, thePlatformPosition, theUtmHemisphere, theUtmZone, ossimDrect::ul(), ossimDrect::ur(), and ossimDpt::x.
Referenced by setPlatformPosition().
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 55 of file ossimApplanixUtmModel.h.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 194 of file ossimApplanixUtmModel.cpp.
References ossimEcefVector::data(), ossimLensDistortion::distort(), ossimPolygon::getNumberOfVertices(), ossimPolygon::hasNans(), ossimDpt::makeNan(), ossimPolygon::pointWithin(), theAdjEcefPlatformPosition, ossimSensorModel::theBoundGndPolygon, theCompositeMatrixInverse, theFocalLength, theLensDistortion, thePixelSize, thePrincipalPoint, ossimSensorModel::theRefImgPt, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 78 of file ossimApplanixUtmModel.h.
Referenced by imagingRay(), updateModel(), and worldToLineSample().
protected |
Definition at line 64 of file ossimApplanixUtmModel.h.
Referenced by saveState().
protected |
Definition at line 65 of file ossimApplanixUtmModel.h.
protected |
Definition at line 66 of file ossimApplanixUtmModel.h.
protected |
uses file path to init model
Definition at line 59 of file ossimApplanixUtmModel.h.
Referenced by imagingRay(), ossimApplanixUtmModel(), and updateModel().
protected |
Definition at line 60 of file ossimApplanixUtmModel.h.
Referenced by ossimApplanixUtmModel(), updateModel(), and worldToLineSample().
protected |
Definition at line 70 of file ossimApplanixUtmModel.h.
Referenced by ossimApplanixUtmModel(), saveState(), and setPlatformPosition().
protected |
Definition at line 69 of file ossimApplanixUtmModel.h.
Referenced by imagingRay(), ossimApplanixUtmModel(), saveState(), setFocalLength(), and worldToLineSample().
protected |
Definition at line 63 of file ossimApplanixUtmModel.h.
Referenced by saveState(), and updateModel().
protected |
Definition at line 77 of file ossimApplanixUtmModel.h.
Referenced by imagingRay(), ossimApplanixUtmModel(), saveState(), and worldToLineSample().
protected |
Definition at line 61 of file ossimApplanixUtmModel.h.
protected |
Definition at line 62 of file ossimApplanixUtmModel.h.
protected |
Definition at line 68 of file ossimApplanixUtmModel.h.
Referenced by imagingRay(), ossimApplanixUtmModel(), saveState(), setPixelSize(), and worldToLineSample().
protected |
Definition at line 71 of file ossimApplanixUtmModel.h.
protected |
Definition at line 67 of file ossimApplanixUtmModel.h.
Referenced by imagingRay(), saveState(), setPrincipalPoint(), and worldToLineSample().
protected |
Definition at line 75 of file ossimApplanixUtmModel.h.
protected |
Definition at line 73 of file ossimApplanixUtmModel.h.
protected |
Definition at line 74 of file ossimApplanixUtmModel.h.
protected |
Definition at line 72 of file ossimApplanixUtmModel.h.
