#include <ossimSpectraboticsRedEdgeModel.h>
| ossimSpectraboticsRedEdgeModel () | |
| ossimSpectraboticsRedEdgeModel (const ossimDrect &imageRect, const ossimGpt &platformPosition, double roll, double pitch, double heading, const ossimDpt &principalPoint, double focalLength, const ossimDpt &pixelSize) | |
| ossimSpectraboticsRedEdgeModel (const ossimSpectraboticsRedEdgeModel &src) | |
| void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| void | setPrincipalPoint (ossimDpt principalPoint) |
| void | setRollPitchHeading (double roll, double pitch, double heading) |
| void | setPixelSize (const ossimDpt &pixelSize) |
| void | setImageRect (const ossimDrect &rect) |
| void | setFocalLength (double focalLength) |
| void | setPlatformPosition (const ossimGpt &gpt) |
| virtual void | initAdjustableParameters () |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| ground to image faster (you don't need DEM) More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 9 of file ossimSpectraboticsRedEdgeModel.h.
| ossimSpectraboticsRedEdgeModel::ossimSpectraboticsRedEdgeModel | ( | ) |
Definition at line 29 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimMatrix4x4::createIdentity(), initAdjustableParameters(), m_adjEcefPlatformPosition, m_compositeMatrix, m_compositeMatrixInverse, m_ecefPlatformPosition, m_focalLength, m_fov, m_heading, m_lensDistortion, m_pitch, m_pixelSize, m_roll, ossimSensorModel::theGSD, ossimSensorModel::theMeanGSD, ossimDpt::x, and ossimDpt::y.
Referenced by dup().
| ossimSpectraboticsRedEdgeModel::ossimSpectraboticsRedEdgeModel | ( | const ossimDrect & | imageRect, |
| const ossimGpt & | platformPosition, | ||
| double | roll, | ||
| double | pitch, | ||
| double | heading, | ||
| const ossimDpt & | principalPoint, | ||
| double | focalLength, | ||
| const ossimDpt & | pixelSize | ||
Definition at line 56 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimMatrix4x4::createIdentity(), initAdjustableParameters(), m_adjEcefPlatformPosition, m_compositeMatrix, m_compositeMatrixInverse, m_ecefPlatformPosition, m_focalLength, m_heading, m_lensDistortion, m_pitch, m_pixelSize, m_roll, ossimDrect::midPoint(), ossimNotify(), ossimNotifyLevel_WARN, ossimSensorModel::theImageClipRect, ossimSensorModel::theRefImgPt, updateModel(), and ossimException::what().
| ossimSpectraboticsRedEdgeModel::ossimSpectraboticsRedEdgeModel | ( | const ossimSpectraboticsRedEdgeModel & | src | ) |
Definition at line 102 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimRefPtr< T >::get(), initAdjustableParameters(), m_lensDistortion, and ossimRefPtr< T >::valid().
Implements ossimProjection.
Definition at line 117 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimSpectraboticsRedEdgeModel().
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Reimplemented from ossimSensorModel.
Definition at line 122 of file ossimSpectraboticsRedEdgeModel.cpp.
Referenced by lineSampleHeightToWorld().
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 298 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray(), ossimAdjustableParameterInterface::setAdjustableParameter(), ossimAdjustableParameterInterface::setParameterDescription(), ossimAdjustableParameterInterface::setParameterSigma(), and ossimAdjustableParameterInterface::setParameterUnit().
Referenced by ossimSpectraboticsRedEdgeModel().
inlinevirtual |
METHOD: insideImage(image_point) Returns true if the image_point lies inside the image rectangle.
Definition at line 41 of file ossimSpectraboticsRedEdgeModel.h.
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 191 of file ossimSpectraboticsRedEdgeModel.cpp.
References imagingRay(), and ossimEcefRay::intersectAboveEarthEllipsoid().
Implementation of base-class pure virtual projection methods. These methods may be overriden by derived classes if those have more efficient schemes. The implementations here are iterative (relatively slow). Both depend on calls to the pure virtual lineSampleHeightToWorld() method.
Definition at line 152 of file ossimSpectraboticsRedEdgeModel.cpp.
Referenced by updateModel().
Definition at line 408 of file ossimSpectraboticsRedEdgeModel.cpp.
Referenced by setupOptimizer().
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Definition at line 376 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimKeywordlist::add(), m_calibratedCenter, m_ecefPlatformPosition, m_focalLength, m_focalX, m_focalY, m_fov, m_heading, m_lensDistortion, m_pitch, m_pixelSize, m_principalPoint, m_roll, ossimTangentialRadialLensDistortion::saveState(), ossimSensorModel::saveState(), ossimString::toString(), ossimRefPtr< T >::valid(), ossimEcefPoint::x(), ossimDpt::x, ossimEcefPoint::y(), ossimDpt::y, and ossimEcefPoint::z().
| void ossimSpectraboticsRedEdgeModel::setFocalLength | ( | double | focalLength | ) |
Definition at line 363 of file ossimSpectraboticsRedEdgeModel.cpp.
References m_focalLength.
| void ossimSpectraboticsRedEdgeModel::setImageRect | ( | const ossimDrect & | rect | ) |
Definition at line 357 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimDrect::midPoint(), ossimSensorModel::theImageClipRect, and ossimSensorModel::theRefImgPt.
| void ossimSpectraboticsRedEdgeModel::setPixelSize | ( | const ossimDpt & | pixelSize | ) |
Definition at line 352 of file ossimSpectraboticsRedEdgeModel.cpp.
References m_pixelSize.
| void ossimSpectraboticsRedEdgeModel::setPlatformPosition | ( | const ossimGpt & | gpt | ) |
Definition at line 368 of file ossimSpectraboticsRedEdgeModel.cpp.
References m_ecefPlatformPosition, ossimSensorModel::theRefGndPt, and updateModel().
| void ossimSpectraboticsRedEdgeModel::setPrincipalPoint | ( | ossimDpt | principalPoint | ) |
Definition at line 336 of file ossimSpectraboticsRedEdgeModel.cpp.
References m_principalPoint.
| void ossimSpectraboticsRedEdgeModel::setRollPitchHeading | ( | double | roll, |
| double | heading | ||
Definition at line 341 of file ossimSpectraboticsRedEdgeModel.cpp.
References m_heading, m_pitch, m_roll, and updateModel().
Reimplemented from ossimOptimizableProjection.
Definition at line 782 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), and loadState().
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 256 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossimMatrix4x4::createRotationXMatrix(), ossimMatrix4x4::createRotationYMatrix(), ossimMatrix4x4::createRotationZMatrix(), ossimGpt::height(), ossimGpt::latd(), lineSampleToWorld(), ossimDrect::ll(), ossimGpt::lond(), ossimDrect::lr(), ossimLsrSpace::lsrToEcefRotMatrix(), m_adjEcefPlatformPosition, m_compositeMatrix, m_compositeMatrixInverse, m_ecefPlatformPosition, m_heading, m_pitch, m_roll, ossimGpt::metersPerDegree(), OSSIM_LEFT_HANDED, OSSIM_RIGHT_HANDED, ossimPolygon::resize(), ossimSensorModel::theBoundGndPolygon, ossimSensorModel::theExtrapolateGroundFlag, ossimSensorModel::theExtrapolateImageFlag, ossimSensorModel::theImageClipRect, ossimSensorModel::theMeanGSD, ossimDrect::ul(), ossimDrect::ur(), and ossimDpt::x.
Referenced by ossimSpectraboticsRedEdgeModel(), setPlatformPosition(), and setRollPitchHeading().
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 73 of file ossimSpectraboticsRedEdgeModel.h.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 212 of file ossimSpectraboticsRedEdgeModel.cpp.
References ossimEcefVector::data(), ossimLensDistortion::distort(), ossimPolygon::getNumberOfVertices(), ossimPolygon::hasNans(), m_adjEcefPlatformPosition, m_calibratedCenter, m_compositeMatrixInverse, m_focalLength, m_lensDistortion, m_norm, m_pixelSize, ossimPolygon::pointWithin(), ossimSensorModel::theBoundGndPolygon, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 95 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by ossimSpectraboticsRedEdgeModel(), updateModel(), and worldToLineSample().
protected |
Definition at line 85 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by saveState(), and worldToLineSample().
protected |
uses file path to init model
Definition at line 78 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by ossimSpectraboticsRedEdgeModel(), and updateModel().
protected |
Definition at line 79 of file ossimSpectraboticsRedEdgeModel.h.
protected |
Definition at line 91 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by ossimSpectraboticsRedEdgeModel(), saveState(), setPlatformPosition(), and updateModel().
protected |
Definition at line 87 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by ossimSpectraboticsRedEdgeModel(), saveState(), setFocalLength(), and worldToLineSample().
protected |
Definition at line 89 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by saveState().
protected |
Definition at line 90 of file ossimSpectraboticsRedEdgeModel.h.
protected |
Definition at line 83 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by ossimSpectraboticsRedEdgeModel(), and saveState().
protected |
Definition at line 82 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by ossimSpectraboticsRedEdgeModel(), saveState(), setRollPitchHeading(), and updateModel().
protected |
Definition at line 92 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by ossimSpectraboticsRedEdgeModel(), saveState(), and worldToLineSample().
protected |
Definition at line 88 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by worldToLineSample().
protected |
Definition at line 81 of file ossimSpectraboticsRedEdgeModel.h.
protected |
Definition at line 86 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by ossimSpectraboticsRedEdgeModel(), saveState(), setPixelSize(), and worldToLineSample().
protected |
Definition at line 84 of file ossimSpectraboticsRedEdgeModel.h.
Referenced by saveState(), and setPrincipalPoint().
protected |
Definition at line 80 of file ossimSpectraboticsRedEdgeModel.h.
