#include <ossimH5GridModel.h>
| ossimH5GridModel () | |
| default constructor. More... | |
| virtual | ~ossimH5GridModel () |
| bool | setGridNodes (H5::DataSet *latDataSet, H5::DataSet *lonDataSet, const ossimIrect &validRect) |
| Initializes the latitude and longitude ossimDblGrids from file. More... | |
| saveState Saves state of object to a keyword list. More... | |
| loadState Loads state of object from a keyword list. More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| METHOD: extrapolate() Extrapolates solutions for points outside of the image. More... | |
Public Member Functions inherited from ossimCoarseGridModel | |
| ossimCoarseGridModel () | |
| ossimCoarseGridModel (const ossimCoarseGridModel ©_this) | |
| ossimCoarseGridModel (const ossimFilename &geom_file) | |
| Accepts name of geometry file. More... | |
| ossimCoarseGridModel (const ossimKeywordlist &geom_kwl) | |
| Accepts OSSIM keywordlist geometry file. More... | |
| ~ossimCoarseGridModel () | |
| virtual void | buildGrid (const ossimDrect &imageBounds, ossimProjection *proj, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true) |
| This method will build a grid from any projector. More... | |
| virtual void | buildGrid (const ossimDrect &imageBounds, ossimImageGeometry *geom, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true) |
| Assigns the grid data given a geometry. More... | |
| Extends base-class implementation. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| bool | saveCoarseGrid (const ossimFilename &cgFileName) const |
| Saves the coarse grid to the specified file. More... | |
| bool | loadCoarseGrid (const ossimFilename &cgFileName) |
| Loads the coarse grid from the specified file. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &world_pt) const |
| This is the virtual that performs the actual work of projecting the image point to the earth at some specified elevation. More... | |
| virtual void | initAdjustableParameters () |
| image to ground faster More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| void | initializeModelParams (ossimIrect imageBounds) |
| Initializes base class data members after grids have been assigned. More... | |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
Protected Member Functions inherited from ossimCoarseGridModel | |
| void | reallocateGrid (const ossimIpt &size) |
| Deletes existing allocated memory and reallocates new space. More... | |
| void | initializeModelParams (ossimIrect irect) |
| virtual ossimGpt | extrapolate (const ossimDpt &imgPt, const double &height=ossim::nan()) const |
| Implements its own extrapolation since this can be handled by ossimDblGrid. More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Private Member Functions | |
| bool | getWktFootprint (std::string &s) const |
| void | debugDump () |
Private Attributes | |
| bool | m_crossesDateline |
| ossimPolygon | m_boundGndPolygon |
Definition at line 42 of file ossimH5GridModel.h.
| ossimH5GridModel::ossimH5GridModel | ( | ) |
Definition at line 43 of file ossimH5GridModel.cpp.
References ossimDblGrid::SAWTOOTH_90, ossimDblGrid::setDomainType(), and ossimCoarseGridModel::theLatGrid.
private |
Definition at line 1013 of file ossimH5GridModel.cpp.
References ossimSensorModel::theImageSize, ossimCoarseGridModel::theLatGrid, ossimCoarseGridModel::theLonGrid, ossimIpt::u, ossimDpt::u, ossimIpt::v, ossimDpt::v, and ossimIpt::y.
Overrides base class method to handle date line cross.
Reimplemented from ossimSensorModel.
Definition at line 760 of file ossimH5GridModel.cpp.
private |
Definition at line 868 of file ossimH5GridModel.cpp.
References ossim::isnan(), ossimIrect::lr(), status, STEP, ossimSensorModel::theImageSize, ossimCoarseGridModel::theLatGrid, ossimCoarseGridModel::theLonGrid, ossimIrect::ur(), ossimIpt::x, x, ossimIpt::y, and y.
protected |
Definition at line 695 of file ossimH5GridModel.cpp.
References ossimGpt::distanceTo(), ossimDblGrid::enableExtrapolation(), ossimDblGrid::getNode(), ossimIrect::height(), ossimDpt::lat, ossimGpt::lat, ossimGpt::limitLonTo180(), ossimDpt::line, ossimGpt::lon, m_boundGndPolygon, m_crossesDateline, ossimIrect::midPoint(), ossimDpt::samp, ossimDblGrid::size(), ossimDblGrid::spacing(), ossimSensorModel::theBoundGndPolygon, ossimSensorModel::theGSD, ossimCoarseGridModel::theHeightEnabledFlag, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimCoarseGridModel::theLatGrid, ossimCoarseGridModel::theLonGrid, ossimSensorModel::theMeanGSD, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimSensorModel::theSubImageOffset, ossimIrect::width(), ossimDpt::x, and ossimDpt::y.
Referenced by setGridNodes().
| kwl | Keyword list to initialize from. |
| prefix | E.g. "image0.geometry.projection." |
Reimplemented from ossimCoarseGridModel.
Definition at line 445 of file ossimH5GridModel.cpp.
References ossimKeywordlist::findKey(), ossimProjectionFactoryRegistry::instance(), and ossimSensorModel::theSeedFunction.
| kwl | Initialized by this. |
Definition at line 401 of file ossimH5GridModel.cpp.
References ossimKeywordlist::addPair(), m_crossesDateline, ossimCoarseGridModel::saveState(), status, ossimString::string(), and ossimString::toString().
| bool ossimH5GridModel::setGridNodes | ( | H5::DataSet * | latDataSet, |
| H5::DataSet * | lonDataSet, | ||
| const ossimIrect & | validRect | ||
| latDataSet | H5::DataSet* to layer, e.g. /All_Data/VIIRS-DNB-GEO_All/Latitude |
| lonDataSet | H5::DataSet* to layer, e.g. /All_Data/VIIRS-DNB-GEO_All/Longitude |
| validRect | Valid rectangle of image. |
This can throw an ossimException on nans.
Definition at line 56 of file ossimH5GridModel.cpp.
References ossim::byteOrder(), ossim_hdf5::crossesDateline(), ossim_hdf5::getBilinearProjection(), ossim_hdf5::getByteOrder(), ossimDblGrid::getNode(), ossim_hdf5::getScalarType(), ossimIrect::height(), ossimDblGrid::initialize(), initializeModelParams(), m_crossesDateline, ossim::nan(), OSSIM_FLOAT32, ossimDblGrid::setDomainType(), ossimDblGrid::setNode(), ossimDblGrid::setNullValue(), status, ossimEndian::swap(), ossimCoarseGridModel::theLatGrid, ossimCoarseGridModel::theLonGrid, ossimSensorModel::theSeedFunction, ossimIrect::ul(), ossimIrect::width(), ossimDblGrid::WRAP_180, ossimDblGrid::WRAP_360, ossimIpt::x, x, ossimIpt::y, and y.
The second version accepts a height value – if left at the default, the elevation will be looked up via theElevation object.
Definition at line 508 of file ossimH5GridModel.cpp.
References ossim::almostEqual(), DBL_EPSILON, ossimCoarseGridModel::extrapolate(), ossimPolygon::getNumberOfVertices(), ossimPolygon::hasNans(), ossimGpt::hgt, ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossim::isnan(), ossimDpt::lat, ossimGpt::lat, ossimCoarseGridModel::lineSampleHeightToWorld(), ossimDpt::lon, ossimGpt::lon, m_boundGndPolygon, m_crossesDateline, ossimDpt::makeNan(), ossimPolygon::pointWithin(), ossimSensorModel::theRefImgPt, ossimSensorModel::theSeedFunction, ossimSensorModel::theSubImageOffset, ossimDpt::u, ossimDpt::v, ossimRefPtr< T >::valid(), ossimProjection::worldToLineSample(), and ossimDpt::x.
private |
Definition at line 122 of file ossimH5GridModel.h.
Referenced by initializeModelParams(), and worldToLineSample().
private |
Definition at line 115 of file ossimH5GridModel.h.
Referenced by initializeModelParams(), saveState(), setGridNodes(), and worldToLineSample().
