#include <ossimElevManager.h>
Classes | |
| class | ConnectionStringVisitor |
Public Types | |
| typedef std::vector< ossimRefPtr< ossimElevationDatabase > > | ElevationDatabaseListType |
| virtual | ~ossimElevManager () |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &gpt) |
| virtual double | getHeightAboveMSL (const ossimGpt &gpt) |
| Height access methods: More... | |
| virtual bool | pointHasCoverage (const ossimGpt &) const |
| METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt: More... | |
| virtual double | getMeanSpacingMeters () const |
| Returns the mean post spacing (in meters) for the highest resolution DEM in the list or NaN if no DEMs have been loaded. More... | |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const |
| ossim_uint32 | getNumberOfElevationDatabases () const |
| ossimElevationDatabase * | getElevationDatabase (ossim_uint32 idx) |
| const ossimElevationDatabase * | getElevationDatabase (ossim_uint32 idx) const |
| void | addDatabase (ossimElevationDatabase *database, bool set_as_first=false) |
| Adds a new elevation database to the collection. More... | |
| bool | loadElevationPath (const ossimFilename &path, bool set_as_first=false) |
| Adds a new elevation file (or multiple files if path is a directory) to the collection. More... | |
| void | setDefaultHeightAboveEllipsoid (double meters) |
| void | setElevationOffset (double meters) |
| double | getElevationOffset () const |
| void | getOpenCellList (std::vector< ossimFilename > &list) const |
| void | getCellsForBounds (const std::string &connectionString, const ossim_float64 &minLat, const ossim_float64 &minLon, const ossim_float64 &maxLat, const ossim_float64 &maxLon, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0) |
| Gets a list of elevation cells needed to cover bounding box. More... | |
| void | getCellsForBounds (const ossim_float64 &minLat, const ossim_float64 &minLon, const ossim_float64 &maxLat, const ossim_float64 &maxLon, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0) |
| void | getCellsForBounds (const ossimGrect &bounds, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0) |
| void | setUseGeoidIfNullFlag (bool flag) |
| bool | getUseGeoidIfNullFlag () const |
| void | setRoundRobinMaxSize (ossim_uint32 size) |
| void | clear () |
Public Member Functions inherited from ossimElevSource | |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| static ossimElevManager * | instance () |
| METHOD: instance() Implements singelton pattern. More... | |
| ossimElevManager () | |
| void | loadStandardElevationPaths () |
| ElevationDatabaseListType & | getNextElevDbList () const |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
Definition at line 30 of file ossimElevManager.h.
| typedef std::vector<ossimRefPtr<ossimElevationDatabase> > ossimElevManager::ElevationDatabaseListType |
Definition at line 33 of file ossimElevManager.h.
Definition at line 96 of file ossimElevManager.cpp.
References clear().
protected |
Definition at line 79 of file ossimElevManager.cpp.
We will add a visitor interface for all connectable objects.
Reimplemented from ossimConnectableObject.
Definition at line 359 of file ossimElevManager.cpp.
References m_dbRoundRobin, and ossimVisitor::stopTraversal().
Referenced by getCellsForBounds().
| void ossimElevManager::addDatabase | ( | ossimElevationDatabase * | database, |
| bool | set_as_first = false |
Normally pushed on to the tail of the list, unless set_as_first=true, in which case this database will receive the first requests.
Definition at line 600 of file ossimElevManager.cpp.
References ossimElevSource::dup(), and m_dbRoundRobin.
Referenced by ossimPointCloudTool::loadDem(), and loadElevationPath().
| void ossimElevManager::clear | ( | ) |
Definition at line 349 of file ossimElevManager.cpp.
References m_dbRoundRobin.
Referenced by ossimPointCloudTool::loadDem(), and ~ossimElevManager().
inlineprotectedvirtual |
Implements ossimElevSource.
Definition at line 169 of file ossimElevManager.h.
Definition at line 384 of file ossimElevManager.cpp.
References getNextElevDbList().
Referenced by ossimHgtRef::getSurfaceCovMatrix().
| void ossimElevManager::getCellsForBounds | ( | const std::string & | connectionString, |
| const ossim_float64 & | minLat, | ||
| const ossim_float64 & | minLon, | ||
| const ossim_float64 & | maxLat, | ||
| const ossim_float64 & | maxLon, | ||
| std::vector< ossimFilename > & | cells, | ||
| ossim_uint32 | maxNumberOfCells = 0 |
| connectionString | Typically elevation repository, e.g.: "/data1/elevation/srtm/1arc" |
| minLat | Minimum latitude of bounding box. |
| minLon | Minimum longitude of bounding box. |
| maxLat | Maximum latitude of bounding box. |
| maxLon | Maximum longitude of bounding box. |
| cells | Initialized by this. |
| maxNumberOfCells | Value of 0 indicates return as many as you can. Any positive number will only return that number of cells. |
Definition at line 262 of file ossimElevManager.cpp.
References accept(), ossimRefPtr< T >::get(), ossimElevationCellDatabase::getCellsForBounds(), ossimElevManager::ConnectionStringVisitor::getElevationDatabase(), ossimElevationDatabaseRegistry::instance(), ossimElevationDatabaseRegistry::open(), and ossimRefPtr< T >::valid().
Referenced by getCellsForBounds(), ossimSlopeTool::initProcessingChain(), and ossimChipProcTool::mosaicDemSources().
| void ossimElevManager::getCellsForBounds | ( | const ossim_float64 & | minLat, |
This implementation sorts elevation repositories by resolution, best first, then searches cells for bounds. Search is stopped on the first repository that has cells.
Definition at line 302 of file ossimElevManager.cpp.
References getHeightAboveMSL(), getOpenCellList(), ossimGpt::lat, and ossimGpt::lon.
| void ossimElevManager::getCellsForBounds | ( | const ossimGrect & | bounds, |
Definition at line 342 of file ossimElevManager.cpp.
References getCellsForBounds(), ossimGpt::lat, ossimGpt::lon, ossimGrect::lr(), and ossimGrect::ul().
inline |
Definition at line 74 of file ossimElevManager.h.
inline |
Definition at line 78 of file ossimElevManager.h.
inline |
Definition at line 98 of file ossimElevManager.h.
Reimplemented from ossimElevSource.
Definition at line 101 of file ossimElevManager.cpp.
References getNextElevDbList(), ossimGeoidManager::instance(), ossim::isnan(), ossimSource::isSourceEnabled(), m_defaultHeightAboveEllipsoid, m_elevationOffset, m_useGeoidIfNullFlag, ossim::nan(), and ossimGeoidManager::offsetFromEllipsoid().
Referenced by ATP::AtpTileSource::computeParallax(), ossimHgtRef::getLocalTerrainNormal(), ossimHgtRef::getRefHeight(), ossimPointCloudUtilityFilter::getTile(), ATP::AtpGenerator::initialize(), ossimViewshedTool::initializeProjectionGsd(), ossimViewshedTool::initProcessingChain(), ossimSonomaSensor::intersectRay(), ossimQuadProjection::lineSampleHeightToWorld(), ossimMapProjection::lineSampleHeightToWorld(), ossimEquDistCylProjection::lineSampleHeightToWorld(), ossimLlxyProjection::lineSampleToWorld(), ossimInfo::outputHeight(), and ossimImageGeometry::worldToLocal().
Definition at line 136 of file ossimElevManager.cpp.
Referenced by getCellsForBounds(), and ossimInfo::outputHeight().
Recommended to perform a getHeight() call for a central ground pt first to load the relevant cells before calling this method.
Definition at line 630 of file ossimElevManager.cpp.
References ossim::isnan(), m_dbRoundRobin, and ossim::nan().
Referenced by ossimViewshedTool::initializeProjectionGsd().
inlineprotected |
Definition at line 571 of file ossimElevManager.cpp.
References ossimElevSource::dup(), m_currentDatabaseIdx, m_dbRoundRobin, m_maxRoundRobinSize, and m_mutex.
Referenced by getAccuracyInfo(), getHeightAboveEllipsoid(), and getHeightAboveMSL().
inline |
Definition at line 70 of file ossimElevManager.h.
| void ossimElevManager::getOpenCellList | ( | std::vector< ossimFilename > & | list | ) | const |
Definition at line 244 of file ossimElevManager.cpp.
References ossimElevationCellDatabase::getOpenCellList(), m_dbRoundRobin, and ossimRefPtr< T >::valid().
inline |
Definition at line 148 of file ossimElevManager.h.
static |
Definition at line 73 of file ossimElevManager.cpp.
Referenced by ATP::AtpTileSource::computeParallax(), ossimHgtRef::getLocalTerrainNormal(), ossimHgtRef::getRefHeight(), ossimHgtRef::getSurfaceCovMatrix(), ossimPointCloudUtilityFilter::getTile(), ATP::AtpGenerator::initialize(), ossimViewshedTool::initializeProjectionGsd(), ossimSlopeTool::initProcessingChain(), ossimViewshedTool::initProcessingChain(), ossimSonomaSensor::intersectRay(), ossimSkyBoxLearSensor::lineSampeToWorld(), ossimQuadProjection::lineSampleHeightToWorld(), ossimMapProjection::lineSampleHeightToWorld(), ossimEquDistCylProjection::lineSampleHeightToWorld(), ossimPpjFrameSensor::lineSampleToWorld(), ossimRsmModel::lineSampleToWorld(), ossimLlxyProjection::lineSampleToWorld(), ossimSonomaSensor::lineSampleToWorld(), ossimRpcModel::lineSampleToWorld(), ossimAlphaSensor::lineSampToWorld(), ossimPointCloudTool::loadDem(), ossimChipProcTool::loadDemFiles(), ossimChipProcTool::mosaicDemSources(), ossimInfo::outputHeight(), and ossimImageGeometry::worldToLocal().
| bool ossimElevManager::loadElevationPath | ( | const ossimFilename & | path, |
Normally pushed on to the tail of the list, unless set_as_first=true, in which case this source will receive the first requests.
Definition at line 211 of file ossimElevManager.cpp.
References addDatabase(), ossimDirectory::getFirst(), ossimDirectory::getNext(), ossimElevationDatabaseRegistry::instance(), ossimFilename::isDir(), ossimElevationDatabaseRegistry::open(), ossimDirectory::open(), and ossimDirectory::OSSIM_DIR_DIRS.
Referenced by ossimChipProcTool::loadDemFiles(), and loadStandardElevationPaths().
protected |
Definition at line 171 of file ossimElevManager.cpp.
References ossimFilename::dirCat(), ossimString::empty(), ossimFilename::exists(), ossimEnvironmentUtility::getEnvironmentVariable(), ossimEnvironmentUtility::getInstalledOssimSupportDir(), ossimEnvironmentUtility::getUserOssimSupportDir(), ossimEnvironmentUtility::instance(), loadElevationPath(), m_useStandardPaths, and ossimString::split().
Definition at line 429 of file ossimElevManager.cpp.
Definition at line 398 of file ossimElevManager.cpp.
Definition at line 648 of file ossimElevManager.cpp.
References m_currentDatabaseIdx, m_dbRoundRobin, m_defaultHeightAboveEllipsoid, m_elevationOffset, m_useGeoidIfNullFlag, and ossimElevSource::print().
Definition at line 414 of file ossimElevManager.cpp.
References ossimKeywordlist::add(), m_defaultHeightAboveEllipsoid, m_elevationOffset, m_maxRoundRobinSize, m_useGeoidIfNullFlag, m_useStandardPaths, ossimSource::saveState(), and ossimString::toString().
inline |
Definition at line 96 of file ossimElevManager.h.
Referenced by ATP::AtpGenerator::initialize(), and ossimPointCloudTool::loadDem().
inline |
Definition at line 97 of file ossimElevManager.h.
| void ossimElevManager::setRoundRobinMaxSize | ( | ossim_uint32 | size | ) |
Definition at line 550 of file ossimElevManager.cpp.
References m_dbRoundRobin, and m_maxRoundRobinSize.
inline |
Definition at line 147 of file ossimElevManager.h.
mutableprotected |
Definition at line 186 of file ossimElevManager.h.
Referenced by getNextElevDbList(), and print().
mutableprotected |
Definition at line 177 of file ossimElevManager.h.
Referenced by accept(), addDatabase(), clear(), getMeanSpacingMeters(), getNextElevDbList(), getOpenCellList(), pointHasCoverage(), print(), and setRoundRobinMaxSize().
protected |
Definition at line 179 of file ossimElevManager.h.
Referenced by getHeightAboveEllipsoid(), getHeightAboveMSL(), print(), and saveState().
protected |
Definition at line 180 of file ossimElevManager.h.
protected |
Definition at line 178 of file ossimElevManager.h.
Referenced by getNextElevDbList(), saveState(), and setRoundRobinMaxSize().
mutableprotected |
I have tried the readwrite lock interfaces but have found it unstable.
I am using the standard Mutex and it seems to be much more stable across all platforms. More testing needs to occur for the ReadWriteMutex. For now we will use Mutex.
Definition at line 193 of file ossimElevManager.h.
Referenced by getNextElevDbList().
protected |
Definition at line 183 of file ossimElevManager.h.
protected |
Definition at line 184 of file ossimElevManager.h.
Referenced by loadStandardElevationPaths(), and saveState().
