| | ossimTileMapModel () |
| | ossimTileMapModel (const ossimKeywordlist &geom_kwl) |
| | ossimTileMapModel (const ossimTileMapModel &rhs) |
| virtual | ~ossimTileMapModel () |
| bool | open (const ossimFilename &file) |
| virtual void | worldToLineSample (const ossimGpt &ground_point, ossimDpt &img_pt) const |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &worldPoint) const |
| void | setDepth (unsigned int depth) |
| unsigned int | getDepth () |
| | ossimSensorModel () |
| | ossimSensorModel (const ossimSensorModel ©_this) |
| | ossimSensorModel (const ossimKeywordlist &geom_kwl) |
| | assignment operator More...
| | Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More...
| | Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More...
| | Assigns the absolute image position error uncertainty (abs CE90) More...
| | Assigns the relative image position error uncertainty (rel CE90) More...
| | Sets the center line sampe of the image. More...
| | Sets the center latitude, longitude, height of the image. More...
| | Access methods: More...
| | needsInitialState() More...
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| | Gives 2X2 covariance matrix of observations. More...
| | Implementation of pure virtual ossimProjection::isAffectedByElevation method. More...
| void | computeGsd () |
| | This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More...
| | Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More...
| | ossimProjection () |
| | ossimObject () |
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
| | ossimErrorStatusInterface () |
| bool | hasError () const |
| | ossimOptimizableProjection () |
| | ossimOptimizableProjection (const ossimOptimizableProjection &source) |
| virtual bool | setupOptimizer (const ossimString &setup) |
| | setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More...
| | ossimAdjustableParameterInterface () |
| | ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) |
| | Returns adjustmentDescription of specific adjustmentInfo. More...
| | Sets the current adjustment to the adjustment with a matching description. More...
| virtual void | initAdjustableParameters () |
| | Saves the current active adjustment to the KWL file. More...
| | Save all adjustments to the KWL file. More...
| | Dumps the currently active adjustment to ostream. More...
