#include <ossimQuickbirdRpcModel.h>
| ossimQuickbirdRpcModel () | |
| ossimQuickbirdRpcModel (const ossimQuickbirdRpcModel &rhs) | |
| ossimQuickbirdRpcModel (const ossimQbTileFilesHandler *handler) | |
| Initializes. More... | |
| ~ossimQuickbirdRpcModel () | |
| dup() Returns pointer to a new instance, copy of this. More... | |
| saveState Fulfills ossimObject base-class pure virtuals. More... | |
| loadState Fulfills ossimObject base-class pure virtuals. More... | |
| virtual bool | parseFile (const ossimFilename &file) |
| Public method for parsing generic image file. More... | |
| void | setSupportData (ossimQuickbirdMetaData *supportData) |
| ossimQuickbirdMetaData * | getSupportData () |
| const ossimQuickbirdMetaData * | getSupportData () const |
Public Member Functions inherited from ossimRpcModel | |
| ossimRpcModel () | |
| ossimRpcModel (const ossimRpcModel ©_this) | |
| copy construtor More... | |
| void | setAttributes (ossim_float64 theSampleOffset, ossim_float64 theLineOffset, ossim_float64 theSampleScale, ossim_float64 theLineScale, ossim_float64 theLatOffset, ossim_float64 theLonOffset, ossim_float64 theHeightOffset, ossim_float64 theLatScale, ossim_float64 theLonScale, ossim_float64 theHeightScale, const std::vector< double > &xNumeratorCoeffs, const std::vector< double > &xDenominatorCoeffs, const std::vector< double > &yNumeratorCoeffs, const std::vector< double > &yDenominatorCoeffs, PolynomialType polyType=B, bool computeGsdFlag=true) |
| void | setMetersPerPixel (const ossimDpt &metersPerPixel) |
| void | setPositionError (const ossim_float64 &biasError, const ossim_float64 &randomError, bool initNominalPostionErrorFlag) |
| Sets data member theBiasError, theRandError. More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| worldToLineSample() Overrides base class implementation. More... | |
| print() Extends base-class implementation. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| imagingRay() Overrides base class pure virtual. More... | |
| virtual void | initAdjustableParameters () |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| uses file path to init model More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double h) |
| Compute partials of samp/line WRT ground point. More... | |
| double | getBiasError () const |
| Returns Error - Bias. More... | |
| double | getRandError () const |
| Returns Error - Random. More... | |
| void | getRpcParameters (ossimRpcModel::rpcModelStruct &model) const |
| Returns RPC parameter set in structure. More... | |
| void | setImageOffset (const ossimDpt &offset_to_chip_ul) |
| Allows setting an offset to a subimage while using the coefficients of a full-image model. More... | |
| bool | toJSON (std::ostream &json) const |
| Serializes RPC to JSON format. More... | |
| bool | toRPB (std::ostream &out) const |
| Serialize to WorldView-style .RPB file to the stream provided. More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| bool | parseNitfFile (const ossimFilename &file) |
| Parses a NITF image file for RPC info. Returns TRUE if successful. More... | |
| bool | parseTiffFile (const ossimFilename &file) |
| Parses a tagged TIFF image file for RPC info. Returns TRUE if successful. More... | |
| bool | parseMetaData (const ossimFilename &file) |
| Initializes the support data member with metadata file info. Returns TRUE if successful. More... | |
| bool | parseRpcData (const ossimFilename &file) |
| Given some base name for the image data, parses the associated RPC data file. More... | |
| bool | parseTileData (const ossimFilename &file) |
| Reads the TIL file for pertinent info. Returns TRUE if successful. More... | |
| bool | findSupportFile (ossimFilename &file) const |
| Given an initial filename with case-agnostic extension, this method searches first for an image-specific instance of that file (i.e., with _R*C* in the filename) before considering the mosaic-global support file (_R*C* removed). More... | |
| void | finishConstruction () |
| Collects common code among all parsers. More... | |
Protected Member Functions inherited from ossimRpcModel | |
| virtual | ~ossimRpcModel () |
| double | polynomial (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLat (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLon (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dHgt (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Public Types inherited from ossimRpcModel | |
| enum | PolynomialType { A ='A', B ='B' } |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimRpcModel | |
| static void | writeGeomTemplate (ostream &os) |
| STATIC METHOD: writeGeomTemplate(ostream) Writes a template of geom keywords processed by loadState and saveState to output stream. More... | |
Static Public Member Functions inherited from ossimSensorModel | |
Protected Types inherited from ossimRpcModel | |
| enum | AdjustParamIndex { INTRACK_OFFSET = 0, CRTRACK_OFFSET, INTRACK_SCALE, CRTRACK_SCALE, MAP_ROTATION, NUM_ADJUSTABLE_PARAMS } |
| ossimQuickbirdRpcModel::ossimQuickbirdRpcModel | ( | ) |
Definition at line 43 of file ossimQuickbirdRpcModel.cpp.
Referenced by dup().
| ossimQuickbirdRpcModel::ossimQuickbirdRpcModel | ( | const ossimQuickbirdRpcModel & | rhs | ) |
Definition at line 52 of file ossimQuickbirdRpcModel.cpp.
| ossimQuickbirdRpcModel::ossimQuickbirdRpcModel | ( | const ossimQbTileFilesHandler * | handler | ) |
Initializes.
Constructor for multiple tile-files sharing common RPC model initializes given pointer to multi-tile-files handler.
Definition at line 62 of file ossimQuickbirdRpcModel.cpp.
References ossimErrorStatusInterface::clearErrorStatus(), finishConstruction(), ossimImageHandler::getFilename(), ossimTiledImageHandler::getImageRectangle(), ossimDpt::makeNan(), parseRpcData(), ossimErrorStatusInterface::setErrorStatus(), ossimSensorModel::theGSD, and ossimSensorModel::theImageClipRect.
| ossimQuickbirdRpcModel::~ossimQuickbirdRpcModel | ( | ) |
Definition at line 87 of file ossimQuickbirdRpcModel.cpp.
References theSupportData.
Reimplemented from ossimRpcModel.
Definition at line 95 of file ossimQuickbirdRpcModel.cpp.
References ossimQuickbirdRpcModel().
protected |
If a file is found, the argument is modified to match the actual filename and TRUE is returned. Otherwise, argument filename is left unchanged and FALSE is returned.
Definition at line 489 of file ossimQuickbirdRpcModel.cpp.
References ossimString::downcase(), ossimFilename::exists(), ossimFilename::ext(), ossimString::replaceAllThatMatch(), ossimFilename::setExtension(), and ossimString::upcase().
Referenced by parseMetaData(), parseRpcData(), and parseTileData().
protected |
Definition at line 413 of file ossimQuickbirdRpcModel.cpp.
References ossimSensorModel::computeGsd(), ossimDpt::hasNans(), ossimDrect::height(), ossimGpt::hgt, ossimGpt::lat, ossimIpt::line, ossimDpt::line, ossimRpcModel::lineSampleHeightToWorld(), ossimDrect::ll(), ossimGpt::lon, ossimDrect::lr(), ossimDrect::midPoint(), ossimNotify(), ossimNotifyLevel_WARN, ossimIpt::samp, ossimDpt::samp, ossimSensorModel::theBoundGndPolygon, ossimSensorModel::theGSD, ossimRpcModel::theHgtOffset, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimRpcModel::theLatOffset, ossimRpcModel::theLonOffset, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimDrect::ul(), ossimRpcModel::updateModel(), ossimDrect::ur(), ossimException::what(), ossimDrect::width(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimQuickbirdRpcModel(), and parseTiffFile().
inline |
Definition at line 56 of file ossimQuickbirdRpcModel.h.
References ossimRefPtr< T >::get(), and theSupportData.
inline |
Definition at line 60 of file ossimQuickbirdRpcModel.h.
Loads and saves geometry KWL files. Returns true if successful.
Definition at line 470 of file ossimQuickbirdRpcModel.cpp.
References ossimQuickbirdMetaData::loadState(), ossimRpcModel::loadState(), theSupportData, and ossimRefPtr< T >::valid().
Definition at line 103 of file ossimQuickbirdRpcModel.cpp.
References parseNitfFile(), and parseTiffFile().
Referenced by ossimQuickbirdTiffTileSource::getImageGeometry().
protected |
Definition at line 336 of file ossimQuickbirdRpcModel.cpp.
References findSupportFile(), ossimQuickbirdMetaData::getSatID(), ossimQuickbirdMetaData::open(), ossimNotify(), ossimNotifyLevel_WARN, ossimFilename::setExtension(), ossimSensorModel::theSensorID, theSupportData, and ossimRefPtr< T >::valid().
Referenced by parseNitfFile(), and parseTiffFile().
protected |
Definition at line 116 of file ossimQuickbirdRpcModel.cpp.
References ossimNitfImageHeader::getImageRect(), ossimNitfFile::getNewImageHeader(), ossimNitfImageHeader::getTagData(), ossimDpt::line, ossim::nan(), ossimNitfFile::parseFile(), parseMetaData(), parseRpcData(), parseTileData(), ossimDpt::samp, ossimErrorStatusInterface::setErrorStatus(), ossimFilename::setExtension(), ossimSensorModel::theGSD, and ossimSensorModel::theImageClipRect.
Referenced by parseFile().
protected |
Definition at line 288 of file ossimQuickbirdRpcModel.cpp.
References ossimRpcModel::A, ossimRpcModel::B, ossimFilename::fileNoExtension(), findSupportFile(), ossimQuickbirdRpcHeader::isAPolynomial(), ossimQuickbirdRpcHeader::open(), ossimFilename::setExtension(), ossimQuickbirdRpcHeader::theHeightOffset, ossimQuickbirdRpcHeader::theHeightScale, ossimRpcModel::theHgtOffset, ossimRpcModel::theHgtScale, ossimSensorModel::theImageID, ossimQuickbirdRpcHeader::theLatOffset, ossimRpcModel::theLatOffset, ossimQuickbirdRpcHeader::theLatScale, ossimRpcModel::theLatScale, ossimRpcModel::theLineDenCoef, ossimQuickbirdRpcHeader::theLineDenCoeff, ossimRpcModel::theLineNumCoef, ossimQuickbirdRpcHeader::theLineNumCoeff, ossimQuickbirdRpcHeader::theLineOffset, ossimRpcModel::theLineOffset, ossimQuickbirdRpcHeader::theLineScale, ossimRpcModel::theLineScale, ossimQuickbirdRpcHeader::theLonOffset, ossimRpcModel::theLonOffset, ossimQuickbirdRpcHeader::theLonScale, ossimRpcModel::theLonScale, ossimRpcModel::thePolyType, ossimRpcModel::theSampDenCoef, ossimQuickbirdRpcHeader::theSampDenCoeff, ossimRpcModel::theSampNumCoef, ossimQuickbirdRpcHeader::theSampNumCoeff, ossimQuickbirdRpcHeader::theSampOffset, ossimRpcModel::theSampOffset, ossimQuickbirdRpcHeader::theSampScale, and ossimRpcModel::theSampScale.
Referenced by ossimQuickbirdRpcModel(), parseNitfFile(), and parseTiffFile().
protected |
Definition at line 253 of file ossimQuickbirdRpcModel.cpp.
References ossimErrorStatusInterface::clearErrorStatus(), finishConstruction(), ossimImageHandler::getImageRectangle(), ossimDpt::makeNan(), ossimTiffTileSource::open(), parseMetaData(), parseRpcData(), parseTileData(), ossimErrorStatusInterface::setErrorStatus(), ossimSensorModel::theGSD, and ossimSensorModel::theImageClipRect.
protected |
Definition at line 365 of file ossimQuickbirdRpcModel.cpp.
References ossimFilename::file(), findSupportFile(), ossimQuickbirdTile::getInfo(), ossimDpt::hasNans(), ossimQuickbirdTile::open(), ossimFilename::setExtension(), ossimRpcModel::setImageOffset(), ossimQuickbirdTileInfo::theUlXOffset, and ossimQuickbirdTileInfo::theUlYOffset.
Definition at line 457 of file ossimQuickbirdRpcModel.cpp.
References ossimQuickbirdMetaData::saveState(), ossimRpcModel::saveState(), theSupportData, and ossimRefPtr< T >::valid().
inline |
Definition at line 52 of file ossimQuickbirdRpcModel.h.
protected |
Definition at line 80 of file ossimQuickbirdRpcModel.h.
Referenced by getSupportData(), loadState(), parseMetaData(), saveState(), setSupportData(), and ~ossimQuickbirdRpcModel().
