#include <ossimAlphaSensorHRI.h>
| ossimAlphaSensorHRI () | |
| ossimAlphaSensorHRI (const ossimAlphaSensorHRI &src) | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| virtual void | initAdjustableParameters () |
| virtual bool | initialize (const ossimAlphaSensorSupportData &supData) |
| Initializes model from support data and calls update Model on success. More... | |
Public Member Functions inherited from ossimAlphaSensor | |
| ossimAlphaSensor () | |
| ossimAlphaSensor (const ossimAlphaSensor &src) | |
| virtual void | lineSampToWorld (const ossimDpt &image_point, ossimGpt &worldPoint) const |
| void | setFov (const double fov) |
| void | setRollBias (const double rollBias) |
| void | setPitchBias (const double pitchBias) |
| void | setHeadingBias (const double headingBias) |
| void | setSlitRot (const double slitRot) |
| void | setRollPoly (const std::vector< ossim_float64 > rollPoly) |
| void | setPitchPoly (const std::vector< ossim_float64 > pitchPoly) |
| void | setHeadingPoly (const std::vector< ossim_float64 > headingPoly) |
| void | setLonPoly (const std::vector< ossim_float64 > lonPoly) |
| void | setLatPoly (const std::vector< ossim_float64 > latPoly) |
| void | setAltPoly (const std::vector< ossim_float64 > altPoly) |
| void | setScanPoly (const std::vector< ossim_float64 > scanPoly) |
| void | getPositionOrientation (const ossim_float64 &line, ossimEcefPoint &pos, NEWMAT::Matrix &cam2EcfRot) const |
| ossimEcefPoint | getCameraPosition (const ossim_float64 &line) const |
| NEWMAT::Matrix | getPlatform2LocalRot (const ossim_float64 &line) const |
| ossim_float64 | evalPoly (const std::vector< ossim_float64 > &polyCoef, const ossim_float64 &line) const |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Protected Member Functions inherited from ossimAlphaSensor | |
| NEWMAT::Matrix | formHPRmat (const ossim_float64 &roll, const ossim_float64 &pitch, const ossim_float64 &heading) const |
| NEWMAT::Matrix | formLLAmat (const ossim_float64 &lat, const ossim_float64 &lon, const ossim_float64 &az) const |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Protected Attributes inherited from ossimAlphaSensor | |
| ossim_float64 | m_rollBias |
| ossim_float64 | m_pitchBias |
| ossim_float64 | m_headingBias |
| ossim_float64 | m_fov |
| ossim_float64 | m_slitRot |
| ossim_float64 | m_focalLength |
| std::vector< ossim_float64 > | m_rollPoly |
| std::vector< ossim_float64 > | m_pitchPoly |
| std::vector< ossim_float64 > | m_headingPoly |
| std::vector< ossim_float64 > | m_lonPoly |
| std::vector< ossim_float64 > | m_latPoly |
| std::vector< ossim_float64 > | m_altPoly |
| std::vector< ossim_float64 > | m_scanPoly |
| NEWMAT::Matrix | m_cam2Platform |
| ossim_float64 | m_adjustedFocalLength |
Protected Attributes inherited from ossimSensorModel | |
| ossimIpt | theImageSize |
| ossimDpt | theSubImageOffset |
| ossimString | theImageID |
| ossimString | theSensorID |
| ossimDpt | theGSD |
| ossim_float64 | theMeanGSD |
| ossimGpt | theRefGndPt |
| ossimDpt | theRefImgPt |
| ossimPolygon | theBoundGndPolygon |
| ossimDrect | theImageClipRect |
| ossim_float64 | theRelPosError |
| ossim_float64 | theNominalPosError |
| ossimDpt | theParWRTx |
| Partials for current point. More... | |
| ossimDpt | theParWRTy |
| ossimDpt | theParWRTz |
| ossimDpt | theObs |
| Observations & residuals for current point. More... | |
| ossimDpt | theResid |
| ossimRefPtr< ossimProjection > | theSeedFunction |
| Used as an initial guess for iterative solutions and a guess for points outside the support bounds. More... | |
| bool | theExtrapolateImageFlag |
| bool | theExtrapolateGroundFlag |
Definition at line 17 of file ossimAlphaSensorHRI.h.
| ossimAlphaSensorHRI::ossimAlphaSensorHRI | ( | ) |
Definition at line 27 of file ossimAlphaSensorHRI.cpp.
Referenced by dup().
| ossimAlphaSensorHRI::ossimAlphaSensorHRI | ( | const ossimAlphaSensorHRI & | src | ) |
Definition at line 38 of file ossimAlphaSensorHRI.cpp.
Reimplemented from ossimAlphaSensor.
Definition at line 44 of file ossimAlphaSensorHRI.cpp.
References ossimAlphaSensorHRI().
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Reimplemented from ossimSensorModel.
Definition at line 49 of file ossimAlphaSensorHRI.cpp.
References ossimAlphaSensor::getPositionOrientation(), ossimAlphaSensor::m_adjustedFocalLength, ossimEcefRay::setDirection(), ossimEcefRay::setOrigin(), ossimSensorModel::theImageSize, ossimColumnVector3d::unit(), ossimIpt::x, ossimDpt::x, and ossimDpt::y.
Definition at line 186 of file ossimAlphaSensorHRI.cpp.
| supData |
Definition at line 226 of file ossimAlphaSensorHRI.cpp.
References ossimAlphaSensorSupportData::getAltPoly(), ossimAlphaSensorSupportData::getFov(), ossimAlphaSensorSupportData::getHeadingBias(), ossimAlphaSensorSupportData::getHeadingPoly(), ossimAlphaSensorSupportData::getImageSize(), ossimAlphaSensorSupportData::getLatPoly(), ossimAlphaSensorSupportData::getLonPoly(), ossimAlphaSensorSupportData::getPitchBias(), ossimAlphaSensorSupportData::getPitchPoly(), ossimAlphaSensorSupportData::getRollBias(), ossimAlphaSensorSupportData::getRollPoly(), ossimAlphaSensorSupportData::getScanPoly(), ossimAlphaSensorSupportData::getSlitRot(), ossimSensorModel::imageSize(), ossimAlphaSensor::setAltPoly(), ossimAlphaSensor::setFov(), ossimAlphaSensor::setHeadingBias(), ossimAlphaSensor::setHeadingPoly(), ossimSensorModel::setImageRect(), ossimSensorModel::setImageSize(), ossimAlphaSensor::setLatPoly(), ossimAlphaSensor::setLonPoly(), ossimAlphaSensor::setPitchBias(), ossimAlphaSensor::setPitchPoly(), ossimSensorModel::setRefImgPt(), ossimAlphaSensor::setRollBias(), ossimAlphaSensor::setRollPoly(), ossimAlphaSensor::setScanPoly(), ossimAlphaSensor::setSlitRot(), updateModel(), ossimDpt::x, and ossimDpt::y.
Definition at line 194 of file ossimAlphaSensorHRI.cpp.
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Definition at line 219 of file ossimAlphaSensorHRI.cpp.
References ossimAlphaSensor::saveState().
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 142 of file ossimAlphaSensorHRI.cpp.
Referenced by initialize().
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 90 of file ossimAlphaSensorHRI.cpp.
References ossimEcefPoint::data(), ossimAlphaSensor::getPositionOrientation(), ossimAlphaSensor::m_adjustedFocalLength, ossimSensorModel::theImageSize, ossimIpt::x, and ossimIpt::y.
