This class is able to direct localisation and indirect localisation using the RadarSat sensor model. More...
#include <ossimRadarSatModel.h>
| ossimRadarSatModel () | |
| Constructor. More... | |
| ossimRadarSatModel (const ossimRadarSatModel &rhs) | |
| copy constructor More... | |
| virtual | ~ossimRadarSatModel () |
| Destructor. More... | |
| Method to return the class name. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| virtual double | getSlantRangeFromGeoreferenced (double col) const |
| This function associates an image column number to a slant range when the image is georeferenced (ground projected) More... | |
| bool | open (const ossimFilename &file) |
| Method to intantial model from a file. More... | |
| Method to save object state to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
Public Member Functions inherited from ossimplugins::ossimGeometricSarSensorModel | |
| ossimGeometricSarSensorModel () | |
| ossimGeometricSarSensorModel (const ossimGeometricSarSensorModel &rhs) | |
| virtual | ~ossimGeometricSarSensorModel () |
| virtual double | getSlantRange (double col) const |
| This function associates an image column number to a slant range. More... | |
| virtual JSDDateTime | getTime (double line) const |
| This function associates an image line number to an azimuth time. More... | |
| virtual bool | getPlatformPositionAtLine (double line, vector< double > &position, vector< double > &speed) |
| This function associates an image line number to a platform position and speed. More... | |
| This function is able to convert image coordinates into world coordinates the geometric model of SAR sensors. More... | |
| virtual bool | optimizeModel (const std::list< ossimGpt > &groundCoordinates, const std::list< ossimDpt > &imageCoordinates) |
| This function optimizes the model according to a list of Ground Control Points. More... | |
| virtual void | clearGCPlist () |
| Clears _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes Updates the optimisation factors and bias. More... | |
| virtual void | getGCPlist (std::list< ossimGpt > &groundCoordinates, std::list< ossimDpt > &imageCoordinates) |
| Returns _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes. More... | |
| double | get_optimizationFactorX () const |
| Accessors to the optimization parameters. More... | |
| double | get_optimizationFactorY () const |
| double | get_optimizationBiasX () const |
| double | get_optimizationBiasY () const |
| ossimRefPtr< ossimCoarseGridModel > | getReplacementOcgModel () |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| void | set_platformPosition (PlatformPosition *platformPosition) |
| Accessors to the plateform, sensor parameters and reference point. More... | |
| void | set_sensorParams (SensorParams *sensorParams) |
| void | set_refPoint (RefPoint *refPoint) |
| PlatformPosition * | get_platformPosition () const |
| SensorParams * | get_sensorParams () const |
| RefPoint * | get_refPoint () const |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| virtual void | initAdjustableParameters () |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Private Member Functions | |
| virtual bool | InitPlatformPosition (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Platform Position from a projection keywordlist. More... | |
| virtual bool | InitSensorParams (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Sensor Params from a projection keywordlist. More... | |
| virtual bool | InitRefPoint (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Reference Point from a projection keywordlist. More... | |
| virtual bool | InitSRGR (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Slant Range for each Ground Range data sets : _n_srgr,_srgr_coefset,_srgr_update,_pixel_spacing,_isProductGeoreferenced. More... | |
| virtual bool | internalSaveState (ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual bool | internalLoadState (const ossimKeywordlist &kwl, const char *prefix=0) |
| int | FindSRGRSetNumber (JSDDateTime date) const |
| Finds the SRGR data set which update time is the closest to the center scene time. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Static Public Attributes inherited from ossimplugins::ossimGeometricSarSensorModel | |
| static const char * | CREATE_OCG_PREF_KW = "geometric_sar_sensor_model.create_ocg" |
Protected Member Functions inherited from ossimplugins::ossimGeometricSarSensorModel | |
| bool | createReplacementOCG () |
| Creates replacement coarse grid model if user requested via ossim preferences keyword "geometric_sar_sensor_model.create_ocg: <bool>". More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 40 of file ossimRadarSatModel.h.
| ossimplugins::ossimRadarSatModel::ossimRadarSatModel | ( | ) |
Constructor.
Definition at line 48 of file ossimRadarSatModel.cpp.
Referenced by dup().
| ossimplugins::ossimRadarSatModel::ossimRadarSatModel | ( | const ossimRadarSatModel & | rhs | ) |
copy constructor
Definition at line 59 of file ossimRadarSatModel.cpp.
Destructor.
Definition at line 70 of file ossimRadarSatModel.cpp.
References _data, _leader, _trailer, and _volumeDir.
Implements ossimProjection.
Definition at line 93 of file ossimRadarSatModel.cpp.
References ossimRadarSatModel().
private |
Definition at line 1210 of file ossimRadarSatModel.cpp.
References _n_srgr, _srgr_update, ossimplugins::JSDDateTime::get_decimal(), and ossimplugins::JSDDateTime::get_second().
Referenced by getSlantRangeFromGeoreferenced().
Definition at line 98 of file ossimRadarSatModel.cpp.
Referenced by loadState().
| col | Column coordinate of the image point |
Implements ossimplugins::ossimGeometricSarSensorModel.
Definition at line 103 of file ossimRadarSatModel.cpp.
References _n_srgr, _pixel_spacing, ossimplugins::ossimGeometricSarSensorModel::_refPoint, ossimplugins::ossimGeometricSarSensorModel::_sensor, _srgr_coefset, FindSRGRSetNumber(), ossimplugins::SensorParams::get_col_direction(), ossimplugins::RefPoint::get_distance(), ossimplugins::RefPoint::get_ephemeris(), and ossimplugins::RefPoint::get_pix_col().
privatevirtual |
Definition at line 799 of file ossimRadarSatModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_platformPosition, ossimplugins::GMSTDateTime::AN2000, ossimplugins::CivilDateTime::AsGMSTDateTime(), ossimplugins::JSDDateTime::AsGMSTDateTime(), ossimKeywordlist::find(), ossimplugins::JSDDateTime::get_second(), ossimplugins::GMSTDateTime::get_tms(), ossimplugins::JSDDateTime::NormDate(), ossimplugins::CivilDateTime::set_day(), ossimplugins::CivilDateTime::set_decimal(), ossimplugins::CivilDateTime::set_month(), ossimplugins::GMSTDateTime::set_origine(), ossimplugins::JSDDateTime::set_second(), ossimplugins::CivilDateTime::set_second(), ossimplugins::CivilDateTime::set_year(), and ossimplugins::GalileanEphemeris::ToGeographic().
Referenced by internalLoadState().
privatevirtual |
Definition at line 930 of file ossimRadarSatModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_isProductGeoreferenced, _pixel_spacing, ossimplugins::ossimGeometricSarSensorModel::_platformPosition, ossimplugins::ossimGeometricSarSensorModel::_refPoint, ossimplugins::ossimGeometricSarSensorModel::_sensor, distance(), ossimKeywordlist::find(), ossimplugins::SensorParams::get_nRangeLook(), ossimplugins::RefPoint::get_pix_col(), ossimplugins::SensorParams::get_prf(), ossimplugins::SensorParams::get_sf(), ossimplugins::PlatformPosition::Interpolate(), min, ossimplugins::ossimGeometricSarSensorModel::optimizeModel(), ossimplugins::RefPoint::set_distance(), ossimplugins::RefPoint::set_ephemeris(), ossimplugins::SensorParams::set_nAzimuthLook(), ossimplugins::RefPoint::set_pix_col(), ossimplugins::RefPoint::set_pix_line(), ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimIpt::x, and ossimIpt::y.
privatevirtual |
Definition at line 718 of file ossimRadarSatModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_sensor, ossimKeywordlist::find(), ossimplugins::SensorParams::Left, ossimplugins::SensorParams::Right, ossimplugins::SensorParams::set_col_direction(), ossimplugins::SensorParams::set_lin_direction(), ossimplugins::SensorParams::set_nAzimuthLook(), ossimplugins::SensorParams::set_nRangeLook(), ossimplugins::SensorParams::set_prf(), ossimplugins::SensorParams::set_rwl(), ossimplugins::SensorParams::set_semiMajorAxis(), ossimplugins::SensorParams::set_semiMinorAxis(), ossimplugins::SensorParams::set_sf(), ossimplugins::SensorParams::set_sightDirection(), and ossimString::trim().
privatevirtual |
Definition at line 1121 of file ossimRadarSatModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_isProductGeoreferenced, _n_srgr, _pixel_spacing, _srgr_coefset, _srgr_update, ossimKeywordlist::find(), and min.
privatevirtual |
Definition at line 659 of file ossimRadarSatModel.cpp.
References InitPlatformPosition(), InitRefPoint(), InitSensorParams(), InitSRGR(), ossimNotify(), and ossimNotifyLevel_DEBUG.
Referenced by loadState(), and open().
privatevirtual |
| kwl | Keyword list to save to. |
| prefix | added to keys when saved. |
Definition at line 430 of file ossimRadarSatModel.cpp.
References _data, _leader, _trailer, ossimKeywordlist::add(), ossimplugins::ProcessedDataRecord::get_acq_msec(), ossimplugins::DataSetSummary::get_alt_dopcen(), ossimplugins::DataSetSummary::get_asc_des(), ossimplugins::DataSetSummary::get_bnd_azi(), ossimplugins::DataSetSummary::get_bnd_azilok(), ossimplugins::DataSetSummary::get_bnd_rng(), ossimplugins::DataSetSummary::get_bnd_rnglok(), ossimplugins::DataSetSummary::get_crt_dopcen(), ossimplugins::PlatformPositionData::get_data_int(), ossimplugins::Trailer::get_DataSetSummary(), ossimplugins::Leader::get_DataSetSummary(), ossimplugins::PlatformPositionData::get_day(), ossimplugins::DataSetSummary::get_ellip_des(), ossimplugins::DataSetSummary::get_ellip_maj(), ossimplugins::DataSetSummary::get_ellip_min(), ossimplugins::DataSetSummary::get_fa(), ossimplugins::FileDescriptor::get_file_name(), ossimplugins::Leader::get_FileDescriptor(), ossimplugins::Data::get_FirstProcessedDataRecord(), ossimplugins::DataSetSummary::get_fr(), ossimplugins::PlatformPositionData::get_gmt_sec(), ossimplugins::PlatformPositionData::get_hr_angle(), ossimplugins::Data::get_ImageOptionsFileDescriptor(), ossimplugins::DataSetSummary::get_inp_sctim(), ossimplugins::Data::get_LastProcessedDataRecord(), ossimplugins::ProcessedDataRecord::get_lat_first(), ossimplugins::ProcessedDataRecord::get_lat_last(), ossimplugins::DataSetSummary::get_line_spacing(), ossimplugins::ProcessedDataRecord::get_lon_first(), ossimplugins::ProcessedDataRecord::get_lon_last(), ossimplugins::PlatformPositionData::get_month(), ossimplugins::DataSetSummary::get_n_azilok(), ossimplugins::DataSetSummary::get_n_rnglok(), ossimplugins::ProcessingParameters::get_n_srgr(), ossimplugins::PlatformPositionData::get_ndata(), ossimplugins::ImageOptionsFileDescriptor::get_ngrp(), ossimplugins::ImageOptionsFileDescriptor::get_nlin(), ossimplugins::ProcessingParameters::get_pixel_spacing(), ossimplugins::DataSetSummary::get_plat_head(), ossimplugins::DataSetSummary::get_plat_lat(), ossimplugins::DataSetSummary::get_plat_long(), ossimplugins::Leader::get_PlatformPositionData(), ossimplugins::PlatformPositionData::get_pos_vect(), ossimplugins::DataSetSummary::get_pro_head(), ossimplugins::DataSetSummary::get_pro_lat(), ossimplugins::DataSetSummary::get_pro_long(), ossimplugins::Trailer::get_ProcessingParameters(), ossimplugins::Leader::get_ProcessingParameters(), ossimplugins::DataSetSummary::get_rng_gate(), ossimplugins::DataSetSummary::get_sc_lin(), ossimplugins::DataSetSummary::get_sc_pix(), ossimplugins::ProcessingParameters::get_sens_orient(), ossimplugins::ProcessingParameters::get_srgr_coefset(), ossimplugins::DataSetSummary::get_terrain_h(), ossimplugins::DataSetSummary::get_time_dir_lin(), ossimplugins::DataSetSummary::get_time_dir_pix(), ossimplugins::DataSetSummary::get_wave_length(), ossimplugins::PlatformPositionData::get_year(), ossimNotify(), ossimNotifyLevel_DEBUG, and ossimKeywordNames::TYPE_KW.
Referenced by open(), and saveState().
Reimplemented from ossimplugins::ossimGeometricSarSensorModel.
Definition at line 680 of file ossimRadarSatModel.cpp.
References ossimKeywordlist::find(), getClassName(), internalLoadState(), ossimNotify(), ossimNotifyLevel_DEBUG, and ossimKeywordNames::TYPE_KW.
| bool ossimplugins::ossimRadarSatModel::open | ( | const ossimFilename & | file | ) |
| file |
Definition at line 127 of file ossimRadarSatModel.cpp.
References _data, _leader, _trailer, _volumeDir, ossimString::c_str(), ossimFilename::exists(), ossimString::find(), ossimplugins::RadarSatRecordFactory::Instanciate(), internalLoadState(), internalSaveState(), ossimplugins::ossimGeometricSarSensorModel::lineSampleToWorld(), ossimDrect::ll(), ossimDrect::lr(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimplugins::RadarSatRecord::Read(), ossimSensorModel::setGroundRect(), ossimSensorModel::theImageClipRect, ossimDrect::ul(), and ossimDrect::ur().
Definition at line 646 of file ossimRadarSatModel.cpp.
References internalSaveState(), and ossimplugins::ossimGeometricSarSensorModel::saveState().
protected |
List of metadata contained in the Data file.
Definition at line 116 of file ossimRadarSatModel.h.
Referenced by internalSaveState(), open(), and ~ossimRadarSatModel().
protected |
List of metadata contained in the Leader file.
Definition at line 121 of file ossimRadarSatModel.h.
protected |
Slant Range for each Ground Range (SRGR) number of coefficients sets.
Definition at line 99 of file ossimRadarSatModel.h.
Referenced by FindSRGRSetNumber(), getSlantRangeFromGeoreferenced(), and InitSRGR().
protected |
Pixel spacing.
Definition at line 111 of file ossimRadarSatModel.h.
Referenced by getSlantRangeFromGeoreferenced(), InitRefPoint(), and InitSRGR().
protected |
SRGR coefficient sets.
Definition at line 103 of file ossimRadarSatModel.h.
Referenced by getSlantRangeFromGeoreferenced(), and InitSRGR().
protected |
SRGR coefficient sets update times.
Definition at line 107 of file ossimRadarSatModel.h.
Referenced by FindSRGRSetNumber(), and InitSRGR().
protected |
List of metadata contained in the Trailer file.
Definition at line 126 of file ossimRadarSatModel.h.
protected |
List of metadata contained in the Volume Directory file.
Definition at line 131 of file ossimRadarSatModel.h.
Referenced by open(), and ~ossimRadarSatModel().
