#include <ossimNitfMapModel.h>
| ossimNitfMapModel () | |
| ossimNitfMapModel (const ossimFilename &init_file) | |
| ossimNitfMapModel (const ossimKeywordlist &geom_kwl) | |
| virtual | ~ossimNitfMapModel () |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| virtual void | initAdjustableParameters () |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| static void | writeGeomTemplate (ostream &os) |
Static Public Member Functions inherited from ossimSensorModel | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Protected Attributes inherited from ossimSensorModel | |
| ossimIpt | theImageSize |
| ossimDpt | theSubImageOffset |
| ossimString | theImageID |
| ossimString | theSensorID |
| ossimDpt | theGSD |
| ossim_float64 | theMeanGSD |
| ossimGpt | theRefGndPt |
| ossimDpt | theRefImgPt |
| ossimPolygon | theBoundGndPolygon |
| ossimDrect | theImageClipRect |
| ossim_float64 | theRelPosError |
| ossim_float64 | theNominalPosError |
| ossimDpt | theParWRTx |
| Partials for current point. More... | |
| ossimDpt | theParWRTy |
| ossimDpt | theParWRTz |
| ossimDpt | theObs |
| Observations & residuals for current point. More... | |
| ossimDpt | theResid |
| ossimRefPtr< ossimProjection > | theSeedFunction |
| Used as an initial guess for iterative solutions and a guess for points outside the support bounds. More... | |
| bool | theExtrapolateImageFlag |
| bool | theExtrapolateGroundFlag |
Definition at line 24 of file ossimNitfMapModel.h.
| ossimNitfMapModel::ossimNitfMapModel | ( | ) |
CONSTRUCTORS:
Definition at line 37 of file ossimNitfMapModel.cpp.
| ossimNitfMapModel::ossimNitfMapModel | ( | const ossimFilename & | init_file | ) |
Definition at line 52 of file ossimNitfMapModel.cpp.
| ossimNitfMapModel::ossimNitfMapModel | ( | const ossimKeywordlist & | geom_kwl | ) |
Definition at line 388 of file ossimNitfMapModel.cpp.
Definition at line 405 of file ossimNitfMapModel.cpp.
inlinevirtual |
Returns pointer to a new instance, copy of this.
Implements ossimProjection.
Definition at line 39 of file ossimNitfMapModel.h.
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 418 of file ossimNitfMapModel.cpp.
Reimplemented from ossimSensorModel.
Definition at line 601 of file ossimNitfMapModel.cpp.
Extends base-class implementation. Dumps contents of object to ostream.
Definition at line 433 of file ossimNitfMapModel.cpp.
References ossimSensorModel::print().
Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files. Returns true if successful.
Definition at line 447 of file ossimNitfMapModel.cpp.
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 71 of file ossimNitfMapModel.h.
static |
Writes a template of geom keywords processed by loadState and saveState to output stream.
Definition at line 652 of file ossimNitfMapModel.cpp.
