This class allows for direct localisation and indirect localisation using the RadarSat2 sensor model. More...
#include <ossimRadarSat2RPCModel.h>
| ossimRadarSat2RPCModel () | |
| ossimRadarSat2RPCModel (const ossimRadarSat2RPCModel &rhs) | |
| copy constructor More... | |
| ossimRadarSat2RPCModel (const ossimFilename &RS2File) | |
| virtual | ~ossimRadarSat2RPCModel () |
| Destructor. More... | |
| Method to return the class name. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| bool | open (const ossimFilename &file) |
Method to parse an nitf file and initialize model. More... | |
| Method to save object state to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| worldToLineSample() Calls ossimRpcModel::worldToLineSample(), then applies (if needed) decimation. More... | |
| lineSampleHeightToWorld() Backs out decimation of image_point (if needed) then calls: ossimRpcModel::lineSampleHeightToWorld This is a temp work around for decimation RPC NITFs. More... | |
Public Member Functions inherited from ossimRpcModel | |
| ossimRpcModel () | |
| ossimRpcModel (const ossimRpcModel ©_this) | |
| copy construtor More... | |
| void | setAttributes (ossim_float64 theSampleOffset, ossim_float64 theLineOffset, ossim_float64 theSampleScale, ossim_float64 theLineScale, ossim_float64 theLatOffset, ossim_float64 theLonOffset, ossim_float64 theHeightOffset, ossim_float64 theLatScale, ossim_float64 theLonScale, ossim_float64 theHeightScale, const std::vector< double > &xNumeratorCoeffs, const std::vector< double > &xDenominatorCoeffs, const std::vector< double > &yNumeratorCoeffs, const std::vector< double > &yDenominatorCoeffs, PolynomialType polyType=B, bool computeGsdFlag=true) |
| void | setMetersPerPixel (const ossimDpt &metersPerPixel) |
| void | setPositionError (const ossim_float64 &biasError, const ossim_float64 &randomError, bool initNominalPostionErrorFlag) |
| Sets data member theBiasError, theRandError. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| imagingRay() Overrides base class pure virtual. More... | |
| virtual void | initAdjustableParameters () |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| uses file path to init model More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double h) |
| Compute partials of samp/line WRT ground point. More... | |
| double | getBiasError () const |
| Returns Error - Bias. More... | |
| double | getRandError () const |
| Returns Error - Random. More... | |
| void | getRpcParameters (ossimRpcModel::rpcModelStruct &model) const |
| Returns RPC parameter set in structure. More... | |
| void | setImageOffset (const ossimDpt &offset_to_chip_ul) |
| Allows setting an offset to a subimage while using the coefficients of a full-image model. More... | |
| bool | toJSON (std::ostream &json) const |
| Serializes RPC to JSON format. More... | |
| bool | toRPB (std::ostream &out) const |
| Serialize to WorldView-style .RPB file to the stream provided. More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Private Member Functions | |
| bool | InitSensorParams (const ossimKeywordlist &kwl, const char *prefix) |
| bool | initSensorParams (const ossimXmlDocument *xdoc, const ossimRadarSat2ProductDoc &rsDoc) |
Private Attributes | |
| ossim_float64 | theDecimation |
| Stored from header field "IMAG". More... | |
| SensorParams * | _sensor |
| ossimFilename | theProductXmlFile |
Public Types inherited from ossimRpcModel | |
| enum | PolynomialType { A ='A', B ='B' } |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimRpcModel | |
| static void | writeGeomTemplate (ostream &os) |
| STATIC METHOD: writeGeomTemplate(ostream) Writes a template of geom keywords processed by loadState and saveState to output stream. More... | |
Static Public Member Functions inherited from ossimSensorModel | |
Protected Types inherited from ossimRpcModel | |
| enum | AdjustParamIndex { INTRACK_OFFSET = 0, CRTRACK_OFFSET, INTRACK_SCALE, CRTRACK_SCALE, MAP_ROTATION, NUM_ADJUSTABLE_PARAMS } |
Protected Member Functions inherited from ossimRpcModel | |
| virtual | ~ossimRpcModel () |
| double | polynomial (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLat (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLon (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dHgt (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Protected Attributes inherited from ossimRpcModel | |
| PolynomialType | thePolyType |
| double | theLineScale |
| double | theSampScale |
| double | theLatScale |
| double | theLonScale |
| double | theHgtScale |
| double | theLineOffset |
| double | theSampOffset |
| double | theLatOffset |
| double | theLonOffset |
| double | theHgtOffset |
| double | theIntrackOffset |
| double | theCrtrackOffset |
| double | theIntrackScale |
| double | theCrtrackScale |
| double | theCosMapRot |
| double | theSinMapRot |
| double | theBiasError |
| error More... | |
| double | theRandError |
| double | theLineNumCoef [20] |
| double | theLineDenCoef [20] |
| double | theSampNumCoef [20] |
| double | theSampDenCoef [20] |
Protected Attributes inherited from ossimSensorModel | |
| ossimIpt | theImageSize |
| ossimDpt | theSubImageOffset |
| ossimString | theImageID |
| ossimString | theSensorID |
| ossimDpt | theGSD |
| ossim_float64 | theMeanGSD |
| ossimGpt | theRefGndPt |
| ossimDpt | theRefImgPt |
| ossimPolygon | theBoundGndPolygon |
| ossimDrect | theImageClipRect |
| ossim_float64 | theRelPosError |
| ossim_float64 | theNominalPosError |
| ossimDpt | theParWRTx |
| Partials for current point. More... | |
| ossimDpt | theParWRTy |
| ossimDpt | theParWRTz |
| ossimDpt | theObs |
| Observations & residuals for current point. More... | |
| ossimDpt | theResid |
| ossimRefPtr< ossimProjection > | theSeedFunction |
| Used as an initial guess for iterative solutions and a guess for points outside the support bounds. More... | |
| bool | theExtrapolateImageFlag |
| bool | theExtrapolateGroundFlag |
Definition at line 45 of file ossimRadarSat2RPCModel.h.
| ossimplugins::ossimRadarSat2RPCModel::ossimRadarSat2RPCModel | ( | ) |
default constructor
Definition at line 51 of file ossimRadarSat2RPCModel.cpp.
Referenced by dup().
| ossimplugins::ossimRadarSat2RPCModel::ossimRadarSat2RPCModel | ( | const ossimRadarSat2RPCModel & | rhs | ) |
copy constructor
Definition at line 59 of file ossimRadarSat2RPCModel.cpp.
| ossimplugins::ossimRadarSat2RPCModel::ossimRadarSat2RPCModel | ( | const ossimFilename & | RS2File | ) |
Definition at line 76 of file ossimRadarSat2RPCModel.cpp.
References open(), ossimNotify(), and ossimNotifyLevel_DEBUG.
Reimplemented from ossimRpcModel.
Definition at line 101 of file ossimRadarSat2RPCModel.cpp.
References ossimRadarSat2RPCModel().
Definition at line 94 of file ossimRadarSat2RPCModel.cpp.
Referenced by loadState().
private |
Definition at line 433 of file ossimRadarSat2RPCModel.cpp.
References _sensor, ossimKeywordlist::find(), ossimplugins::SensorParams::Left, ossimplugins::SensorParams::Right, ossimplugins::SensorParams::set_col_direction(), ossimplugins::SensorParams::set_lin_direction(), ossimplugins::SensorParams::set_nAzimuthLook(), ossimplugins::SensorParams::set_nRangeLook(), ossimplugins::SensorParams::set_prf(), ossimplugins::SensorParams::set_rwl(), ossimplugins::SensorParams::set_semiMajorAxis(), ossimplugins::SensorParams::set_semiMinorAxis(), ossimplugins::SensorParams::set_sf(), ossimplugins::SensorParams::set_sightDirection(), and ossimString::toDouble().
private |
Definition at line 522 of file ossimRadarSat2RPCModel.cpp.
References _sensor, ossimplugins::ossimRadarSat2ProductDoc::initSensorParams(), ossimNotify(), and ossimNotifyLevel_DEBUG.
Definition at line 405 of file ossimRadarSat2RPCModel.cpp.
References ossimRpcModel::lineSampleHeightToWorld(), theDecimation, ossimDpt::x, and ossimDpt::y.
Definition at line 590 of file ossimRadarSat2RPCModel.cpp.
References ossimPolygon::clear(), ossimKeywordlist::find(), getClassName(), ossimRpcModel::loadState(), open(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimSensorModel::theBoundGndPolygon, theDecimation, theProductXmlFile, ossimString::toBool(), ossimString::toFloat64(), and ossimKeywordNames::TYPE_KW.
| bool ossimplugins::ossimRadarSat2RPCModel::open | ( | const ossimFilename & | file | ) |
| entryIndex | The entry to get model for. Note the nitf's can have multiple entries; each with a different projection. |
Definition at line 106 of file ossimRadarSat2RPCModel.cpp.
References ossimRpcModel::B, RPCModel::biasError, ossimFilename::dirCat(), ossimString::downcase(), ossimFilename::exists(), ossimFilename::expand(), ossimFilename::ext(), ossimplugins::ossimRadarSat2ProductDoc::getAcquisitionType(), ossimplugins::ossimRadarSat2ProductDoc::getBeamModeMnemonic(), ossimplugins::ossimRadarSat2ProductDoc::getImageId(), ossimplugins::ossimRadarSat2ProductDoc::getRpcData(), ossimplugins::ossimRadarSat2ProductDoc::getSatellite(), RPCModel::heightOffset, RPCModel::heightScale, ossimGpt::hgt, ossimplugins::ossimRadarSat2ProductDoc::initGsd(), ossimplugins::ossimRadarSat2ProductDoc::initImageSize(), ossimFilename::isFile(), ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossimplugins::ossimRadarSat2ProductDoc::isRadarSat2(), ossimGpt::lat, RPCModel::latitudeOffset, RPCModel::latitudeScale, ossimIpt::line, ossimDpt::line, RPCModel::lineDenominatorCoefficients, RPCModel::lineNumeratorCoefficients, RPCModel::lineOffset, ossimRpcModel::lineSampleHeightToWorld(), ossimRpcModel::lineSampleToWorld(), RPCModel::lineScale, ossimDrect::ll(), ossimGpt::lon, RPCModel::longitudeOffset, RPCModel::longitudeScale, ossimDrect::lr(), ossimFilename::NIL, ossimXmlDocument::openFile(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimFilename::path(), RPCModel::pixelDenominatorCoefficients, RPCModel::pixelNumeratorCoefficients, RPCModel::pixelOffset, RPCModel::pixelScale, RPCModel::randomError, ossimIpt::samp, ossimDpt::samp, ossimErrorStatusInterface::setErrorStatus(), ossimSensorModel::setGroundRect(), ossimRpcModel::theBiasError, ossimSensorModel::theBoundGndPolygon, theDecimation, ossimSensorModel::theGSD, ossimRpcModel::theHgtOffset, ossimRpcModel::theHgtScale, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageID, ossimSensorModel::theImageSize, ossimRpcModel::theLatOffset, ossimRpcModel::theLatScale, ossimRpcModel::theLineDenCoef, ossimRpcModel::theLineNumCoef, ossimRpcModel::theLineOffset, ossimRpcModel::theLineScale, ossimRpcModel::theLonOffset, ossimRpcModel::theLonScale, ossimSensorModel::theMeanGSD, ossimSensorModel::theNominalPosError, ossimRpcModel::thePolyType, theProductXmlFile, ossimRpcModel::theRandError, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimRpcModel::theSampDenCoef, ossimRpcModel::theSampNumCoef, ossimRpcModel::theSampOffset, ossimRpcModel::theSampScale, ossimSensorModel::theSensorID, ossimSensorModel::theSubImageOffset, ossimDrect::ul(), ossimRpcModel::updateModel(), ossimDrect::ur(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by loadState(), and ossimRadarSat2RPCModel().
METHOD: print() Fulfills base-class pure virtual. Dumps contents of object to ostream.
Definition at line 420 of file ossimRadarSat2RPCModel.cpp.
References ossimRpcModel::print().
| kwl | Keyword list to save to. |
| prefix | added to keys when saved. |
Definition at line 556 of file ossimRadarSat2RPCModel.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimRpcModel::saveState(), theDecimation, and theProductXmlFile.
Definition at line 394 of file ossimRadarSat2RPCModel.cpp.
References theDecimation, ossimRpcModel::worldToLineSample(), ossimDpt::x, and ossimDpt::y.
private |
Definition at line 141 of file ossimRadarSat2RPCModel.h.
Referenced by InitSensorParams(), and initSensorParams().
private |
This is a temp work around to handle decimated rpc nitf's.
Definition at line 139 of file ossimRadarSat2RPCModel.h.
Referenced by lineSampleHeightToWorld(), loadState(), open(), saveState(), and worldToLineSample().
private |
Definition at line 145 of file ossimRadarSat2RPCModel.h.
Referenced by loadState(), open(), and saveState().
