#include <ossimFormosatModel.h>
Public Types | |
| enum | AdjustParamIndex { ROLL_OFFSET = 0, PITCH_OFFSET, YAW_OFFSET, ROLL_RATE, PITCH_RATE, YAW_RATE, FOCAL_LEN_OFFSET, NUM_ADJUSTABLE_PARAMS } |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
| ossimFormosatModel () | |
| ossimFormosatModel (ossimFormosatDimapSupportData *sd) | |
| ossimFormosatModel (const ossimFilename &init_file) | |
| ossimFormosatModel (const ossimKeywordlist &geom_kwl) | |
| ossimFormosatModel (const ossimFormosatModel &rhs) | |
| virtual | ~ossimFormosatModel () |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual void | lineSampleHeightToWorld (const ossimDpt &image_point, const ossim_float64 &heightEllipsoid, ossimGpt &worldPoint) const |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| image to ground faster More... | |
| bool | initFromMetadata (ossimFormosatDimapSupportData *sd) |
| uses file path to init model More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| static void | writeGeomTemplate (ostream &os) |
Static Public Member Functions inherited from ossimSensorModel | |
| void | initAdjustableParameters () |
| void | loadGeometry (FILE *) |
| void | loadSupportData () |
| void | computeSatToOrbRotation (NEWMAT::Matrix &result, ossim_float64 t) const |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 34 of file ossimFormosatModel.h.
| Enumerator | |
| ROLL_OFFSET | |
| PITCH_OFFSET | |
| YAW_OFFSET | |
| ROLL_RATE | |
| PITCH_RATE | |
| YAW_RATE | |
| FOCAL_LEN_OFFSET | |
| NUM_ADJUSTABLE_PARAMS | |
Definition at line 48 of file ossimFormosatModel.h.
| ossimplugins::ossimFormosatModel::ossimFormosatModel | ( | ) |
CONSTRUCTORS:
Definition at line 70 of file ossimFormosatModel.cpp.
References initAdjustableParameters().
| ossimplugins::ossimFormosatModel::ossimFormosatModel | ( | ossimFormosatDimapSupportData * | sd | ) |
Definition at line 95 of file ossimFormosatModel.cpp.
References ossimErrorStatusInterface::getErrorStatus(), initAdjustableParameters(), loadSupportData(), ossimErrorCodes::OSSIM_OK, ossimNotify(), ossimNotifyLevel_DEBUG, and updateModel().
| ossimplugins::ossimFormosatModel::ossimFormosatModel | ( | const ossimFilename & | init_file | ) |
| ossimplugins::ossimFormosatModel::ossimFormosatModel | ( | const ossimKeywordlist & | geom_kwl | ) |
| ossimplugins::ossimFormosatModel::ossimFormosatModel | ( | const ossimFormosatModel & | rhs | ) |
Definition at line 152 of file ossimFormosatModel.cpp.
References ossimFormosatDimapSupportData::dup(), loadSupportData(), theSupportData, updateModel(), and ossimRefPtr< T >::valid().
Definition at line 143 of file ossimFormosatModel.cpp.
References ossimNotify(), and ossimNotifyLevel_DEBUG.
protected |
Definition at line 164 of file ossimFormosatModel.cpp.
References ossimNotify(), ossimNotifyLevel_DEBUG, ossimDpt3d::x, ossimDpt3d::y, and ossimDpt3d::z.
Returns pointer to a new instance, copy of this. Not implemented yet! Returns NULL...
Implements ossimProjection.
Definition at line 451 of file ossimFormosatModel.cpp.
Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target.
Reimplemented from ossimSensorModel.
Definition at line 536 of file ossimFormosatModel.cpp.
References ossimColumnVector3d::cross(), ossimDpt::line, ossimNotify(), ossimNotifyLevel_DEBUG, ossimDpt::samp, ossimColumnVector3d::unit(), ossimEcefPoint::x(), ossimEcefPoint::y(), and ossimEcefPoint::z().
protectedvirtual |
Sets adjustables to default values.
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 315 of file ossimFormosatModel.cpp.
Referenced by ossimFormosatModel().
| bool ossimplugins::ossimFormosatModel::initFromMetadata | ( | ossimFormosatDimapSupportData * | sd | ) |
Definition at line 760 of file ossimFormosatModel.cpp.
References ossimErrorCodes::OSSIM_OK, ossimNotify(), and ossimNotifyLevel_DEBUG.
Given an image point and height, initializes worldPoint.
Implements ossimSensorModel.
Definition at line 652 of file ossimFormosatModel.cpp.
References ossimEcefRay::intersectAboveEarthEllipsoid(), ossimNotify(), and ossimNotifyLevel_DEBUG.
protected |
Definition at line 508 of file ossimFormosatModel.cpp.
References ossimSensorModel::loadState(), and ossimErrorCodes::OSSIM_OK.
protected |
Definition at line 340 of file ossimFormosatModel.cpp.
References ossimErrorCodes::OSSIM_OK, ossimNotify(), ossimNotifyLevel_DEBUG, and ossimNotifyLevel_FATAL.
Extends base-class implementation. Dumps contents of object to ostream.
Definition at line 456 of file ossimFormosatModel.cpp.
References ossimSensorModel::print().
Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files. Returns true if successful.
Definition at line 492 of file ossimFormosatModel.cpp.
References ossimSensorModel::saveState().
Reimplemented from ossimOptimizableProjection.
Definition at line 709 of file ossimFormosatModel.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), ossimFilename::dirCat(), ossimFilename::exists(), ossimRefPtr< T >::get(), ossimFormosatDimapSupportData::loadXmlFile(), ossimFilename::path(), and ossimFilename::setExtension().
Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 264 of file ossimFormosatModel.cpp.
References ossimErrorCodes::OSSIM_ERROR, ossimNotify(), and ossimNotifyLevel_DEBUG.
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 111 of file ossimFormosatModel.h.
static |
Writes a template of geom keywords processed by loadState and saveState to output stream.
protected |
Definition at line 160 of file ossimFormosatModel.h.
protected |
Definition at line 137 of file ossimFormosatModel.h.
protected |
Definition at line 138 of file ossimFormosatModel.h.
protected |
Definition at line 146 of file ossimFormosatModel.h.
protected |
Definition at line 136 of file ossimFormosatModel.h.
protected |
Definition at line 155 of file ossimFormosatModel.h.
protected |
Definition at line 158 of file ossimFormosatModel.h.
protected |
Definition at line 140 of file ossimFormosatModel.h.
protected |
Definition at line 141 of file ossimFormosatModel.h.
protected |
relative to full image
Definition at line 144 of file ossimFormosatModel.h.
protected |
Definition at line 154 of file ossimFormosatModel.h.
protected |
Definition at line 157 of file ossimFormosatModel.h.
protected |
Definition at line 139 of file ossimFormosatModel.h.
protected |
Definition at line 147 of file ossimFormosatModel.h.
protected |
Definition at line 131 of file ossimFormosatModel.h.
protected |
Definition at line 156 of file ossimFormosatModel.h.
protected |
Definition at line 159 of file ossimFormosatModel.h.
