Special "sensor model" that provides a conventional map projection but with. More...
#include <ossimAdjMapModel.h>
Public Types | |
| enum | AdjParamIndex { OFFSET_X = 0, OFFSET_Y, ROTATION, SCALE_X, SCALE_Y, NUM_ADJ_PARAMS } |
| Enumeration for adjustable parameter positions in theAdjParams vector. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
| ossimAdjMapModel () | |
| Constructs to uninitialized state (needed by factory). More... | |
| ossimAdjMapModel (ossimMapProjection *map_proj, const ossimIpt &image_size) | |
| Constructs with map projection and image rectangle size. More... | |
| ossimAdjMapModel (const ossimAdjMapModel ©_this) | |
| Copy constructor. More... | |
| ossimAdjMapModel (const ossimKeywordlist &kwl, const char *prefix) | |
| Constructs given geom KWL. More... | |
| ossimAdjMapModel (const ossimFilename &geom_filename) | |
| Constructs given geom filename. More... | |
| bool | initializeFromMap () |
| Initializes base class data members after map model established. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| Extends base-class implementation. Dumps contents of object to ostream. More... | |
| Fulfills ossimObject base-class pure virtuals. More... | |
| Overrides base class pure virtual. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &worldPoint) const |
| Overrides base class virtual. More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Rigorous inverse transform implented, overrides base-class' iterative. More... | |
| Following a change to the adjustable parameter set, this virtual is. More... | |
| virtual void | initAdjustableParameters () |
| Initializes adjustable parameters to their default values. More... | |
| Fetches the GSD from the internal map projection. More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| static void | writeGeomTemplate (ostream &os) |
| Writes a template of geom keywords processed by loadState and saveState. More... | |
Static Public Member Functions inherited from ossimSensorModel | |
Private Member Functions | |
| virtual | ~ossimAdjMapModel () |
| ground to image faster (you don't need DEM) More... | |
Private Attributes | |
| ColumnVector | theAdjParams |
| This is the vector of UNNORMALIZED, BIASED parameters as used in the model. More... | |
| ossimRefPtr< ossimMapProjection > | theMapProjection |
| double | theCosTheta |
| double | theSinTheta |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Protected Attributes inherited from ossimSensorModel | |
| ossimIpt | theImageSize |
| ossimDpt | theSubImageOffset |
| ossimString | theImageID |
| ossimString | theSensorID |
| ossimDpt | theGSD |
| ossim_float64 | theMeanGSD |
| ossimGpt | theRefGndPt |
| ossimDpt | theRefImgPt |
| ossimPolygon | theBoundGndPolygon |
| ossimDrect | theImageClipRect |
| ossim_float64 | theRelPosError |
| ossim_float64 | theNominalPosError |
| ossimDpt | theParWRTx |
| Partials for current point. More... | |
| ossimDpt | theParWRTy |
| ossimDpt | theParWRTz |
| ossimDpt | theObs |
| Observations & residuals for current point. More... | |
| ossimDpt | theResid |
| ossimRefPtr< ossimProjection > | theSeedFunction |
| Used as an initial guess for iterative solutions and a guess for points outside the support bounds. More... | |
| bool | theExtrapolateImageFlag |
| bool | theExtrapolateGroundFlag |
capability for adjusting the map x,y coordinates with offset, scale, and
Definition at line 39 of file ossimAdjMapModel.h.
| Enumerator | |
| OFFSET_X | |
| OFFSET_Y | |
| ROTATION | |
| SCALE_X | |
| SCALE_Y | |
| NUM_ADJ_PARAMS | |
Definition at line 104 of file ossimAdjMapModel.h.
| ossimAdjMapModel::ossimAdjMapModel | ( | ) |
Definition at line 41 of file ossimAdjMapModel.cpp.
References initAdjustableParameters(), ossimErrorStatusInterface::theErrorStatus, and ossimSensorModel::theImageSize.
Referenced by dup().
| ossimAdjMapModel::ossimAdjMapModel | ( | ossimMapProjection * | map_proj, |
| const ossimIpt & | image_size | ||
Definition at line 58 of file ossimAdjMapModel.cpp.
References initAdjustableParameters(), initializeFromMap(), and ossimSensorModel::theImageSize.
| ossimAdjMapModel::ossimAdjMapModel | ( | const ossimAdjMapModel & | copy_this | ) |
Copy constructor.
Definition at line 76 of file ossimAdjMapModel.cpp.
References theAdjParams.
| ossimAdjMapModel::ossimAdjMapModel | ( | const ossimKeywordlist & | kwl, |
| const char * | prefix | ||
Constructs from Geom KWL.
Definition at line 90 of file ossimAdjMapModel.cpp.
References initAdjustableParameters(), and loadState().
| ossimAdjMapModel::ossimAdjMapModel | ( | const ossimFilename & | geom_filename | ) |
Definition at line 108 of file ossimAdjMapModel.cpp.
privatevirtual |
Destructor.
Destructor only deletes the map projection.
Definition at line 142 of file ossimAdjMapModel.cpp.
References ColumnVector::CleanUp(), and theAdjParams.
Implements ossimProjection.
Definition at line 426 of file ossimAdjMapModel.cpp.
References ossimAdjMapModel().
Reimplemented from ossimSensorModel.
Definition at line 416 of file ossimAdjMapModel.cpp.
References ossimMapProjection::getMetersPerPixel(), theMapProjection, and ossimRefPtr< T >::valid().
Overrides ossimAdjustableParameterInterface virtual method.
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 151 of file ossimAdjMapModel.cpp.
References ossimAdjustableParameterInterface::newAdjustment(), NUM_ADJ_PARAMS, OFFSET_X, OFFSET_Y, ossimAdjustableParameterInterface::removeAllAdjustments(), ROTATION, SCALE_X, SCALE_Y, ossimAdjustableParameterInterface::setAdjustableParameter(), ossimAdjustableParameterInterface::setAdjustmentDescription(), ossimAdjustableParameterInterface::setParameterCenter(), ossimAdjustableParameterInterface::setParameterDescription(), and updateModel().
Referenced by ossimAdjMapModel().
| bool ossimAdjMapModel::initializeFromMap | ( | ) |
Initializes base class data members after map model established. Returns TRUE if all's well.
Definition at line 124 of file ossimAdjMapModel.cpp.
References ossimMapProjection::getMetersPerPixel(), ossimMapProjection::origin(), ossimErrorStatusInterface::theErrorStatus, ossimSensorModel::theGSD, theMapProjection, ossimSensorModel::theMeanGSD, ossimSensorModel::theRefGndPt, ossimSensorModel::theSensorID, ossimDpt::x, and ossimDpt::y.
Implements ossimSensorModel.
Definition at line 198 of file ossimAdjMapModel.cpp.
References ossimGpt::height(), ossimMapProjection::lineSampleHeightToWorld(), ossim::nan(), OFFSET_X, OFFSET_Y, SCALE_X, SCALE_Y, theAdjParams, theCosTheta, theMapProjection, theSinTheta, ossimDpt::x, x, ossimDpt::y, and y.
Referenced by lineSampleToWorld().
Definition at line 226 of file ossimAdjMapModel.cpp.
References ossimGpt::hasNans(), and lineSampleHeightToWorld().
Loads geometry KWL files. Returns true if successful.
Definition at line 292 of file ossimAdjMapModel.cpp.
References ossimString::chars(), ossimMapProjectionFactory::createProjection(), ossimKeywordlist::find(), ossimMapProjectionFactory::instance(), ossimString::size(), theMapProjection, ossimKeywordNames::TYPE_KW, and TYPE_NAME.
Definition at line 403 of file ossimAdjMapModel.cpp.
References NUM_ADJ_PARAMS, and ossimSensorModel::print().
Loads and saves geometry KWL files. Returns true if successful.
Saves geometry KWL files. Returns true if successful.
Definition at line 265 of file ossimAdjMapModel.cpp.
References ossimKeywordlist::add(), ossimString::chars(), NUM_ADJ_PARAMS, ossimMapProjection::saveState(), ossimSensorModel::saveState(), ossimString::size(), theMapProjection, ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 186 of file ossimAdjMapModel.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossim::cosd(), NUM_ADJ_PARAMS, ROTATION, ossim::sind(), theAdjParams, theCosTheta, and theSinTheta.
Referenced by initAdjustableParameters().
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 117 of file ossimAdjMapModel.h.
Rigorous inverse transform implented, overrides base-class' iterative solution.
Definition at line 240 of file ossimAdjMapModel.cpp.
References ossim::nan(), OFFSET_X, OFFSET_Y, SCALE_X, SCALE_Y, theAdjParams, theCosTheta, theMapProjection, theSinTheta, ossimMapProjection::worldToLineSample(), ossimDpt::x, and ossimDpt::y.
static |
Writes a template of geom keywords processed by loadState and saveState to output stream.
Definition at line 377 of file ossimAdjMapModel.cpp.
References ossimKeywordNames::TYPE_KW, and ossimSensorModel::writeGeomTemplate().
private |
The collection of normalized, 0-biased, parameters used in registration are found in the ossimAdjustableParameterInterface and related classes. The quantities here are computed given the base class quantities.
Definition at line 128 of file ossimAdjMapModel.h.
Referenced by lineSampleHeightToWorld(), ossimAdjMapModel(), updateModel(), worldToLineSample(), and ~ossimAdjMapModel().
private |
Definition at line 131 of file ossimAdjMapModel.h.
Referenced by lineSampleHeightToWorld(), updateModel(), and worldToLineSample().
private |
Definition at line 130 of file ossimAdjMapModel.h.
Referenced by getMetersPerPixel(), initializeFromMap(), lineSampleHeightToWorld(), loadState(), saveState(), and worldToLineSample().
private |
Definition at line 132 of file ossimAdjMapModel.h.
