This class allows for direct localisation and indirect localisation using the geometric model of SAR sensors. More...
#include <ossimGeometricSarSensorModel.h>
| ossimGeometricSarSensorModel () | |
| ossimGeometricSarSensorModel (const ossimGeometricSarSensorModel &rhs) | |
| copy constructor More... | |
| virtual | ~ossimGeometricSarSensorModel () |
| Destructor. More... | |
| virtual double | getSlantRangeFromGeoreferenced (double col) const =0 |
| This function associates an image column number to a slant range when the image is georeferenced (ground projected) More... | |
| virtual double | getSlantRange (double col) const |
| This function associates an image column number to a slant range. More... | |
| virtual JSDDateTime | getTime (double line) const |
| This function associates an image line number to an azimuth time. More... | |
| virtual bool | getPlatformPositionAtLine (double line, vector< double > &position, vector< double > &speed) |
| This function associates an image line number to a platform position and speed. More... | |
| This function is able to convert image coordinates into world coordinates the geometric model of SAR sensors. More... | |
| virtual bool | optimizeModel (const std::list< ossimGpt > &groundCoordinates, const std::list< ossimDpt > &imageCoordinates) |
| This function optimizes the model according to a list of Ground Control Points. More... | |
| virtual void | clearGCPlist () |
| Clears _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes Updates the optimisation factors and bias. More... | |
| virtual void | getGCPlist (std::list< ossimGpt > &groundCoordinates, std::list< ossimDpt > &imageCoordinates) |
| Returns _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes. More... | |
| Method to save object state to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
| double | get_optimizationFactorX () const |
| Accessors to the optimization parameters. More... | |
| double | get_optimizationFactorY () const |
| double | get_optimizationBiasX () const |
| double | get_optimizationBiasY () const |
| ossimRefPtr< ossimCoarseGridModel > | getReplacementOcgModel () |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| void | set_platformPosition (PlatformPosition *platformPosition) |
| Accessors to the plateform, sensor parameters and reference point. More... | |
| void | set_sensorParams (SensorParams *sensorParams) |
| void | set_refPoint (RefPoint *refPoint) |
| PlatformPosition * | get_platformPosition () const |
| SensorParams * | get_sensorParams () const |
| RefPoint * | get_refPoint () const |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| virtual ossimObject * | dup () const =0 |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| virtual void | initAdjustableParameters () |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Static Public Attributes | |
| static const char * | CREATE_OCG_PREF_KW = "geometric_sar_sensor_model.create_ocg" |
| bool | createReplacementOCG () |
| Creates replacement coarse grid model if user requested via ossim preferences keyword "geometric_sar_sensor_model.create_ocg: <bool>". More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Private Member Functions | |
| virtual bool | InitPlatformPosition (const ossimKeywordlist &kwl, const char *prefix)=0 |
| Initializes the Platform Position from a projection keywordlist. More... | |
| virtual bool | InitSensorParams (const ossimKeywordlist &kwl, const char *prefix)=0 |
| Initializes the Sensor Params from a projection keywordlist. More... | |
| virtual bool | InitRefPoint (const ossimKeywordlist &kwl, const char *prefix)=0 |
| Initializes the Reference Point from a projection keywordlist. More... | |
| virtual bool | InitSRGR (const ossimKeywordlist &kwl, const char *prefix)=0 |
| Initializes the Slant Range to/for each Ground Range data sets from a projection keywordlist. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
This class must be specified for each sensor.
Definition at line 36 of file ossimGeometricSarSensorModel.h.
| ossimplugins::ossimGeometricSarSensorModel::ossimGeometricSarSensorModel | ( | ) |
default constructor
Definition at line 42 of file ossimGeometricSarSensorModel.cpp.
| ossimplugins::ossimGeometricSarSensorModel::ossimGeometricSarSensorModel | ( | const ossimGeometricSarSensorModel & | rhs | ) |
copy constructor
Definition at line 57 of file ossimGeometricSarSensorModel.cpp.
References _platformPosition, _sarSensor, and _sensor.
Destructor.
Definition at line 75 of file ossimGeometricSarSensorModel.cpp.
References _platformPosition, _refPoint, _sarSensor, and _sensor.
Definition at line 185 of file ossimGeometricSarSensorModel.cpp.
References _optimizationGCPsGroundCoordinates, _optimizationGCPsImageCoordinates, and optimizeModel().
protected |
Definition at line 606 of file ossimGeometricSarSensorModel.cpp.
References ossimPreferences::instance(), ossimCoarseGridModel::setInterpolationError(), and ossimString::toBool().
Referenced by ossimplugins::ossimRadarSat2Model::open().
inline |
Definition at line 161 of file ossimGeometricSarSensorModel.h.
inline |
Definition at line 162 of file ossimGeometricSarSensorModel.h.
inline |
Definition at line 159 of file ossimGeometricSarSensorModel.h.
inline |
Definition at line 160 of file ossimGeometricSarSensorModel.h.
| PlatformPosition * ossimplugins::ossimGeometricSarSensorModel::get_platformPosition | ( | ) | const |
Definition at line 791 of file ossimGeometricSarSensorModel.cpp.
| RefPoint * ossimplugins::ossimGeometricSarSensorModel::get_refPoint | ( | ) | const |
Definition at line 803 of file ossimGeometricSarSensorModel.cpp.
| SensorParams * ossimplugins::ossimGeometricSarSensorModel::get_sensorParams | ( | ) | const |
Definition at line 797 of file ossimGeometricSarSensorModel.cpp.
| groundCoordinates | : GCP ground coordinates |
| imageCoordinates | : actual image coordinates corresponding to groundCoordinates |
Definition at line 193 of file ossimGeometricSarSensorModel.cpp.
References _optimizationGCPsGroundCoordinates, and _optimizationGCPsImageCoordinates.
| line | Line coordinate of the image point |
| position | Position of the sensor at line line |
| speed | Speed of the sensor at line line |
Definition at line 122 of file ossimGeometricSarSensorModel.cpp.
References _platformPosition, ossimplugins::PlatformPosition::getPlatformPositionAtTime(), and getTime().
inline |
Definition at line 164 of file ossimGeometricSarSensorModel.h.
| col | Column coordinate of the image point |
Definition at line 102 of file ossimGeometricSarSensorModel.cpp.
References _refPoint, _sensor, ossimplugins::SensorParams::get_col_direction(), ossimplugins::RefPoint::get_distance(), ossimplugins::SensorParams::get_nRangeLook(), ossimplugins::RefPoint::get_pix_col(), and ossimplugins::SensorParams::get_sf().
Referenced by lineSampleHeightToWorld().
pure virtual |
Implemented in ossimplugins::ossimRadarSat2Model, ossimplugins::ossimAlosPalsarModel, ossimplugins::ossimTerraSarModel, ossimplugins::ossimRadarSatModel, ossimplugins::ossimEnvisatAsarModel, ossimplugins::ossimErsSarModel, and ossimplugins::ossimCosmoSkymedModel.
Definition at line 112 of file ossimGeometricSarSensorModel.cpp.
References _refPoint, _sensor, ossimplugins::Ephemeris::get_date(), ossimplugins::RefPoint::get_ephemeris(), ossimplugins::SensorParams::get_lin_direction(), ossimplugins::SensorParams::get_nAzimuthLook(), ossimplugins::RefPoint::get_pix_line(), ossimplugins::SensorParams::get_prf(), ossimplugins::JSDDateTime::get_second(), ossimplugins::JSDDateTime::NormDate(), and ossimplugins::JSDDateTime::set_second().
Referenced by getPlatformPositionAtLine(), and lineSampleHeightToWorld().
privatepure virtual |
Implemented in ossimplugins::ossimRadarSatModel, ossimplugins::ossimEnvisatAsarModel, ossimplugins::ossimTerraSarModel, ossimplugins::ossimRadarSat2Model, ossimplugins::ossimAlosPalsarModel, ossimplugins::ossimErsSarModel, and ossimplugins::ossimCosmoSkymedModel.
Implemented in ossimplugins::ossimRadarSatModel, ossimplugins::ossimRadarSat2Model, ossimplugins::ossimEnvisatAsarModel, ossimplugins::ossimTerraSarModel, ossimplugins::ossimAlosPalsarModel, ossimplugins::ossimErsSarModel, and ossimplugins::ossimCosmoSkymedModel.
| image_point | Coordinates of the image point |
| heightEllipsoid | Altitude of the world point |
| worldPoint | Coordinates of the world point (OUT) |
Implements ossimSensorModel.
Definition at line 128 of file ossimGeometricSarSensorModel.cpp.
References _isProductGeoreferenced, _optimizationBiasX, _optimizationBiasY, _optimizationFactorX, _optimizationFactorY, _platformPosition, _sarSensor, _sensor, getSlantRange(), getSlantRangeFromGeoreferenced(), getTime(), ossimGpt::hgt, ossimplugins::SarSensor::ImageToWorld(), ossimGpt::lat, ossimGpt::lon, ossimNotify(), ossimNotifyLevel_DEBUG, ossimDpt::x, and ossimDpt::y.
Implementation of base-class pure virtual projection methods. These methods may be overriden by derived classes if those have more efficient schemes. The implementations here are iterative (relatively slow). Both depend on calls to the pure virtual lineSampleHeightToWorld() method.
Reimplemented from ossimSensorModel.
Definition at line 637 of file ossimGeometricSarSensorModel.cpp.
Referenced by ossimplugins::ossimRadarSatModel::open(), and ossimplugins::ossimRadarSat2Model::open().
Reimplemented in ossimplugins::ossimRadarSat2Model, ossimplugins::ossimTerraSarModel, ossimplugins::ossimAlosPalsarModel, ossimplugins::ossimRadarSatModel, ossimplugins::ossimEnvisatAsarModel, and ossimplugins::ossimErsSarModel.
Definition at line 350 of file ossimGeometricSarSensorModel.cpp.
References _isProductGeoreferenced, _optimizationBiasX, _optimizationBiasY, _optimizationFactorX, _optimizationFactorY, _platformPosition, _refPoint, _sarSensor, _sensor, ossimKeywordlist::find(), ossimplugins::RefPoint::loadState(), ossimplugins::PlatformPosition::loadState(), ossimSensorModel::loadState(), ossimplugins::SensorParams::loadState(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimNotifyLevel_WARN, ossimString::toBool(), and ossimString::toDouble().
Referenced by ossimplugins::ossimTerraSarModel::loadState(), and ossimplugins::ossimRadarSat2Model::loadState().
The input list of GCPs is appended to the one present in memory. An inverse localization of each ground GCP is performed. The error between localized GCPs and actual image coordinates is then computed and modeled by a linear model on each dimension. The time and range estimations are updated accordingly.
| groundCoordinates | : input GCP ground coordinates |
| imageCoordinates | : actual image coordinates corresponding to input groundCoordinates |
Definition at line 198 of file ossimGeometricSarSensorModel.cpp.
References _optimizationBiasX, _optimizationBiasY, _optimizationFactorX, _optimizationFactorY, _optimizationGCPsGroundCoordinates, _optimizationGCPsImageCoordinates, FLT_EPSILON, true, and ossimSensorModel::worldToLineSample().
Referenced by clearGCPlist(), ossimplugins::ossimCosmoSkymedModel::InitRefPoint(), ossimplugins::ossimErsSarModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::InitRefPoint(), ossimplugins::ossimEnvisatAsarModel::InitRefPoint(), ossimplugins::ossimRadarSatModel::InitRefPoint(), and ossimplugins::ossimRadarSat2Model::initRefPoint().
METHOD: print() Fulfills base-class pure virtual. Dumps contents of object to ostream.
Reimplemented in ossimplugins::ossimRadarSat2Model, ossimplugins::ossimTerraSarModel, and ossimplugins::ossimEnvisatAsarModel.
Definition at line 561 of file ossimGeometricSarSensorModel.cpp.
References ossimKeywordlist::add().
Referenced by ossimplugins::ossimErsSarModel::open(), ossimplugins::ossimAlosPalsarModel::open(), ossimplugins::ossimEnvisatAsarModel::print(), and ossimplugins::ossimRadarSat2Model::print().
| kwl | Keyword list to save to. |
| prefix | added to keys when saved. |
Definition at line 295 of file ossimGeometricSarSensorModel.cpp.
References _isProductGeoreferenced, _optimizationBiasX, _optimizationBiasY, _optimizationFactorX, _optimizationFactorY, _platformPosition, _refPoint, _sensor, ossimKeywordlist::add(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimplugins::RefPoint::saveState(), ossimplugins::PlatformPosition::saveState(), ossimSensorModel::saveState(), and ossimplugins::SensorParams::saveState().
Referenced by ossimplugins::ossimRadarSatModel::saveState(), and ossimplugins::ossimRadarSat2Model::saveState().
| void ossimplugins::ossimGeometricSarSensorModel::set_platformPosition | ( | PlatformPosition * | platformPosition | ) |
Definition at line 760 of file ossimGeometricSarSensorModel.cpp.
References ossimplugins::PlatformPosition::Clone().
| void ossimplugins::ossimGeometricSarSensorModel::set_refPoint | ( | RefPoint * | refPoint | ) |
Definition at line 780 of file ossimGeometricSarSensorModel.cpp.
References ossimplugins::RefPoint::Clone().
| void ossimplugins::ossimGeometricSarSensorModel::set_sensorParams | ( | SensorParams * | sensorParams | ) |
Definition at line 770 of file ossimGeometricSarSensorModel.cpp.
References ossimplugins::SensorParams::Clone().
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 132 of file ossimGeometricSarSensorModel.h.
protected |
Definition at line 218 of file ossimGeometricSarSensorModel.h.
protected |
True iff the product is ground range.
Definition at line 202 of file ossimGeometricSarSensorModel.h.
Referenced by ossimplugins::ossimCosmoSkymedModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::InitRefPoint(), ossimplugins::ossimRadarSatModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::initRefPoint(), ossimplugins::ossimEnvisatAsarModel::InitSensorParams(), ossimplugins::ossimCosmoSkymedModel::InitSRGR(), ossimplugins::ossimErsSarModel::InitSRGR(), ossimplugins::ossimEnvisatAsarModel::InitSRGR(), ossimplugins::ossimRadarSat2Model::InitSRGR(), ossimplugins::ossimRadarSat2Model::initSRGR(), ossimplugins::ossimRadarSatModel::InitSRGR(), lineSampleHeightToWorld(), ossimplugins::ossimAlosPalsarModel::loadState(), loadState(), and saveState().
protected |
Definition at line 215 of file ossimGeometricSarSensorModel.h.
Referenced by lineSampleHeightToWorld(), loadState(), optimizeModel(), and saveState().
protected |
Definition at line 216 of file ossimGeometricSarSensorModel.h.
protected |
Optimization result : linear error correction in both dimensions.
Definition at line 213 of file ossimGeometricSarSensorModel.h.
protected |
Definition at line 214 of file ossimGeometricSarSensorModel.h.
protected |
List Ground Control Points used by the optimization.
Definition at line 207 of file ossimGeometricSarSensorModel.h.
Referenced by clearGCPlist(), getGCPlist(), and optimizeModel().
protected |
Definition at line 208 of file ossimGeometricSarSensorModel.h.
protected |
Handle the position of the platform.
Definition at line 190 of file ossimGeometricSarSensorModel.h.
Referenced by getPlatformPositionAtLine(), ossimplugins::ossimCosmoSkymedModel::InitPlatformPosition(), ossimplugins::ossimErsSarModel::InitPlatformPosition(), ossimplugins::ossimAlosPalsarModel::InitPlatformPosition(), ossimplugins::ossimRadarSat2Model::InitPlatformPosition(), ossimplugins::ossimEnvisatAsarModel::InitPlatformPosition(), ossimplugins::ossimRadarSatModel::InitPlatformPosition(), ossimplugins::ossimRadarSat2Model::initPlatformPosition(), ossimplugins::ossimCosmoSkymedModel::InitRefPoint(), ossimplugins::ossimErsSarModel::InitRefPoint(), ossimplugins::ossimAlosPalsarModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::InitRefPoint(), ossimplugins::ossimEnvisatAsarModel::InitRefPoint(), ossimplugins::ossimRadarSatModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::initRefPoint(), lineSampleHeightToWorld(), loadState(), ossimGeometricSarSensorModel(), saveState(), and ~ossimGeometricSarSensorModel().
protected |
Definition at line 219 of file ossimGeometricSarSensorModel.h.
Referenced by ossimplugins::ossimRadarSat2Model::InitLut(), ossimplugins::ossimRadarSat2Model::loadState(), ossimplugins::ossimRadarSat2Model::open(), and ossimplugins::ossimRadarSat2Model::saveState().
protected |
Definition at line 192 of file ossimGeometricSarSensorModel.h.
Referenced by getSlantRange(), ossimplugins::ossimCosmoSkymedModel::getSlantRangeFromGeoreferenced(), ossimplugins::ossimEnvisatAsarModel::getSlantRangeFromGeoreferenced(), ossimplugins::ossimRadarSatModel::getSlantRangeFromGeoreferenced(), ossimplugins::ossimRadarSat2Model::getSlantRangeFromGeoreferenced(), getTime(), ossimplugins::ossimCosmoSkymedModel::InitRefPoint(), ossimplugins::ossimErsSarModel::InitRefPoint(), ossimplugins::ossimAlosPalsarModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::InitRefPoint(), ossimplugins::ossimEnvisatAsarModel::InitRefPoint(), ossimplugins::ossimRadarSatModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::initRefPoint(), loadState(), saveState(), and ~ossimGeometricSarSensorModel().
protected |
Definition at line 221 of file ossimGeometricSarSensorModel.h.
mutableprotected |
Definition at line 197 of file ossimGeometricSarSensorModel.h.
Referenced by lineSampleHeightToWorld(), loadState(), ossimGeometricSarSensorModel(), and ~ossimGeometricSarSensorModel().
protected |
Definition at line 191 of file ossimGeometricSarSensorModel.h.
Referenced by getSlantRange(), ossimplugins::ossimCosmoSkymedModel::getSlantRangeFromGeoreferenced(), ossimplugins::ossimEnvisatAsarModel::getSlantRangeFromGeoreferenced(), ossimplugins::ossimRadarSatModel::getSlantRangeFromGeoreferenced(), ossimplugins::ossimRadarSat2Model::getSlantRangeFromGeoreferenced(), getTime(), ossimplugins::ossimCosmoSkymedModel::InitRefPoint(), ossimplugins::ossimErsSarModel::InitRefPoint(), ossimplugins::ossimAlosPalsarModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::InitRefPoint(), ossimplugins::ossimRadarSatModel::InitRefPoint(), ossimplugins::ossimRadarSat2Model::initRefPoint(), ossimplugins::ossimCosmoSkymedModel::InitSensorParams(), ossimplugins::ossimErsSarModel::InitSensorParams(), ossimplugins::ossimAlosPalsarModel::InitSensorParams(), ossimplugins::ossimRadarSat2Model::InitSensorParams(), ossimplugins::ossimEnvisatAsarModel::InitSensorParams(), ossimplugins::ossimRadarSatModel::InitSensorParams(), ossimplugins::ossimRadarSat2Model::initSensorParams(), lineSampleHeightToWorld(), loadState(), ossimGeometricSarSensorModel(), saveState(), and ~ossimGeometricSarSensorModel().
static |
Definition at line 39 of file ossimGeometricSarSensorModel.h.
