#include <ossimPpjFrameSensor.h>
| ossimPpjFrameSensor () | |
| ossimPpjFrameSensor (const ossimPpjFrameSensor &src) | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| void | setFocalLength (double focX, double focY) |
| void | setCameraPosition (const ossimGpt &value) |
| void | setPrincipalPoint (const ossimDpt &value) |
| void | setecef2CamMatrix (const NEWMAT::Matrix &value) |
| void | setAveragePrjectedHeight (double averageProjectedHeight) |
| virtual void | initAdjustableParameters () |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 15 of file ossimPpjFrameSensor.h.
| ossimPpjFrameSensor::ossimPpjFrameSensor | ( | ) |
Definition at line 40 of file ossimPpjFrameSensor.cpp.
Referenced by dup().
| ossimPpjFrameSensor::ossimPpjFrameSensor | ( | const ossimPpjFrameSensor & | src | ) |
Definition at line 78 of file ossimPpjFrameSensor.cpp.
Implements ossimProjection.
Definition at line 99 of file ossimPpjFrameSensor.cpp.
References ossimPpjFrameSensor().
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Reimplemented from ossimSensorModel.
Definition at line 133 of file ossimPpjFrameSensor.cpp.
References m_adjustedCameraPosition, m_adjustedFocalLength, m_ecef2CamInverse, m_principalPoint, ossimEcefRay::setDirection(), ossimEcefRay::setOrigin(), ossimDpt::x, and ossimDpt::y.
Referenced by lineSampleHeightToWorld(), and lineSampleToWorld().
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 269 of file ossimPpjFrameSensor.cpp.
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 167 of file ossimPpjFrameSensor.cpp.
References ossim::almostEqual(), imagingRay(), ossimEcefRay::intersectAboveEarthEllipsoid(), ossim::isnan(), and m_averageProjectedHeight.
Implementation of base-class pure virtual projection methods. These methods may be overriden by derived classes if those have more efficient schemes. The implementations here are iterative (relatively slow). Both depend on calls to the pure virtual lineSampleHeightToWorld() method.
Definition at line 159 of file ossimPpjFrameSensor.cpp.
References imagingRay(), ossimElevManager::instance(), ossimElevSource::intersectRay(), and m_averageProjectedHeight.
Definition at line 312 of file ossimPpjFrameSensor.cpp.
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Definition at line 448 of file ossimPpjFrameSensor.cpp.
References ossimKeywordlist::add(), m_averageProjectedHeight, m_ecef2Cam, m_ecefCameraPosition, m_focalLengthX, m_focalLengthY, m_principalPoint, ossimSensorModel::saveState(), ossimSensorModel::theGSD, ossimSensorModel::theImageSize, ossimIpt::toString(), ossimDpt::toString(), ossimEcefPoint::toString(), and ossimString::toString().
| void ossimPpjFrameSensor::setAveragePrjectedHeight | ( | double | averageProjectedHeight | ) |
Definition at line 128 of file ossimPpjFrameSensor.cpp.
References m_averageProjectedHeight.
| void ossimPpjFrameSensor::setCameraPosition | ( | const ossimGpt & | value | ) |
Definition at line 111 of file ossimPpjFrameSensor.cpp.
References m_cameraPositionEllipsoid, and m_ecefCameraPosition.
| void ossimPpjFrameSensor::setecef2CamMatrix | ( | const NEWMAT::Matrix & | value | ) |
Definition at line 122 of file ossimPpjFrameSensor.cpp.
References m_ecef2Cam, and m_ecef2CamInverse.
| void ossimPpjFrameSensor::setFocalLength | ( | double | focX, |
| double | focY | ||
Definition at line 104 of file ossimPpjFrameSensor.cpp.
References m_focalLength, m_focalLengthX, and m_focalLengthY.
| void ossimPpjFrameSensor::setPrincipalPoint | ( | const ossimDpt & | value | ) |
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 208 of file ossimPpjFrameSensor.cpp.
inlinevirtual |
useForward() return true when it's better (more accurate / fast) to use forward (from ground to image) than inverse(from image to ground)
Implements ossimOptimizableProjection.
Definition at line 48 of file ossimPpjFrameSensor.h.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 187 of file ossimPpjFrameSensor.cpp.
References ossimEcefVector::data(), ossimGpt::height(), ossimGpt::isHgtNan(), m_adjustedCameraPosition, m_adjustedFocalLength, m_averageProjectedHeight, m_ecef2Cam, m_principalPoint, ossimDpt::x, x, ossimDpt::y, and y.
protected |
Definition at line 70 of file ossimPpjFrameSensor.h.
Referenced by imagingRay(), and worldToLineSample().
protected |
Definition at line 71 of file ossimPpjFrameSensor.h.
protected |
Definition at line 72 of file ossimPpjFrameSensor.h.
Referenced by lineSampleHeightToWorld(), lineSampleToWorld(), saveState(), setAveragePrjectedHeight(), and worldToLineSample().
protected |
Definition at line 62 of file ossimPpjFrameSensor.h.
Referenced by setCameraPosition().
protected |
Definition at line 55 of file ossimPpjFrameSensor.h.
Referenced by saveState(), setecef2CamMatrix(), and worldToLineSample().
protected |
Definition at line 56 of file ossimPpjFrameSensor.h.
Referenced by imagingRay(), and setecef2CamMatrix().
protected |
Definition at line 61 of file ossimPpjFrameSensor.h.
Referenced by saveState(), and setCameraPosition().
protected |
Definition at line 60 of file ossimPpjFrameSensor.h.
Referenced by setFocalLength().
protected |
Definition at line 58 of file ossimPpjFrameSensor.h.
Referenced by saveState(), and setFocalLength().
protected |
Definition at line 59 of file ossimPpjFrameSensor.h.
protected |
Definition at line 57 of file ossimPpjFrameSensor.h.
Referenced by imagingRay(), saveState(), setPrincipalPoint(), and worldToLineSample().
protected |
Definition at line 65 of file ossimPpjFrameSensor.h.
protected |
Definition at line 66 of file ossimPpjFrameSensor.h.
protected |
Definition at line 67 of file ossimPpjFrameSensor.h.
protected |
Definition at line 68 of file ossimPpjFrameSensor.h.
