This class is able to direct localisation and indirect localisation using the EnvisatAsar sensor model. More...
#include <ossimEnvisatAsarModel.h>
| ossimEnvisatAsarModel () | |
| Constructor. More... | |
| virtual | ~ossimEnvisatAsarModel () |
| Destructor. More... | |
| Method to return the class name. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| virtual double | getSlantRangeFromGeoreferenced (double col) const |
| This function associates an image column number to a slant range when the image is georeferenced (ground projected) More... | |
| bool | open (const ossimFilename &file) |
| Method to intantial model from a file. More... | |
| Method to save object state to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
Public Member Functions inherited from ossimplugins::ossimGeometricSarSensorModel | |
| ossimGeometricSarSensorModel () | |
| ossimGeometricSarSensorModel (const ossimGeometricSarSensorModel &rhs) | |
| copy constructor More... | |
| virtual | ~ossimGeometricSarSensorModel () |
| virtual double | getSlantRange (double col) const |
| This function associates an image column number to a slant range. More... | |
| virtual JSDDateTime | getTime (double line) const |
| This function associates an image line number to an azimuth time. More... | |
| virtual bool | getPlatformPositionAtLine (double line, vector< double > &position, vector< double > &speed) |
| This function associates an image line number to a platform position and speed. More... | |
| This function is able to convert image coordinates into world coordinates the geometric model of SAR sensors. More... | |
| virtual bool | optimizeModel (const std::list< ossimGpt > &groundCoordinates, const std::list< ossimDpt > &imageCoordinates) |
| This function optimizes the model according to a list of Ground Control Points. More... | |
| virtual void | clearGCPlist () |
| Clears _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes Updates the optimisation factors and bias. More... | |
| virtual void | getGCPlist (std::list< ossimGpt > &groundCoordinates, std::list< ossimDpt > &imageCoordinates) |
| Returns _optimizationGCPsGroundCoordinates and _optimizationGCPsImageCoordinates attributes. More... | |
| double | get_optimizationFactorX () const |
| Accessors to the optimization parameters. More... | |
| double | get_optimizationFactorY () const |
| double | get_optimizationBiasX () const |
| double | get_optimizationBiasY () const |
| ossimRefPtr< ossimCoarseGridModel > | getReplacementOcgModel () |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| void | set_platformPosition (PlatformPosition *platformPosition) |
| Accessors to the plateform, sensor parameters and reference point. More... | |
| void | set_sensorParams (SensorParams *sensorParams) |
| void | set_refPoint (RefPoint *refPoint) |
| PlatformPosition * | get_platformPosition () const |
| SensorParams * | get_sensorParams () const |
| RefPoint * | get_refPoint () const |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| virtual void | initAdjustableParameters () |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Private Member Functions | |
| virtual bool | InitPlatformPosition (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Platform Position from a projection keywordlist. More... | |
| virtual bool | InitSensorParams (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Sensor Params from a projection keywordlist. More... | |
| virtual bool | InitRefPoint (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Reference Point from a projection keywordlist. More... | |
| virtual bool | InitSRGR (const ossimKeywordlist &kwl, const char *prefix) |
| Initializes the Slant Range for each Ground Range data sets : _n_srgr,_srgr_coefset,_srgr_update,_pixel_spacing,_isProductGeoreferenced. More... | |
| std::vector< double > | FindSRGRSetNumber (JSDDateTime date) const |
| Finds the SRGR data set which update time is the closest to the center scene time. More... | |
Private Attributes | |
| TYPE_DATA EnvisatAsarData * | _EnvisatAsarData |
| List of metadata contained in the Data file. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Static Public Attributes inherited from ossimplugins::ossimGeometricSarSensorModel | |
| static const char * | CREATE_OCG_PREF_KW = "geometric_sar_sensor_model.create_ocg" |
Protected Member Functions inherited from ossimplugins::ossimGeometricSarSensorModel | |
| bool | createReplacementOCG () |
| Creates replacement coarse grid model if user requested via ossim preferences keyword "geometric_sar_sensor_model.create_ocg: <bool>". More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 37 of file ossimEnvisatAsarModel.h.
| ossimplugins::ossimEnvisatAsarModel::ossimEnvisatAsarModel | ( | ) |
Constructor.
Definition at line 40 of file ossimEnvisatAsarModel.cpp.
Referenced by dup().
Destructor.
Definition at line 49 of file ossimEnvisatAsarModel.cpp.
References _EnvisatAsarData.
Implements ossimProjection.
Definition at line 62 of file ossimEnvisatAsarModel.cpp.
References ossimEnvisatAsarModel().
private |
Definition at line 652 of file ossimEnvisatAsarModel.cpp.
References _n_srgr, _srgr_coefset, _srgr_update, ossimplugins::JSDDateTime::get_decimal(), and ossimplugins::JSDDateTime::get_second().
Referenced by getSlantRangeFromGeoreferenced().
Definition at line 57 of file ossimEnvisatAsarModel.cpp.
| col | Column coordinate of the image point |
Implements ossimplugins::ossimGeometricSarSensorModel.
Definition at line 67 of file ossimEnvisatAsarModel.cpp.
References _n_srgr, _pixel_spacing, ossimplugins::ossimGeometricSarSensorModel::_refPoint, ossimplugins::ossimGeometricSarSensorModel::_sensor, FindSRGRSetNumber(), ossimplugins::SensorParams::get_col_direction(), and ossimplugins::RefPoint::get_ephemeris().
privatevirtual |
Definition at line 430 of file ossimEnvisatAsarModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_platformPosition, and ossimKeywordlist::find().
Referenced by loadState().
privatevirtual |
Definition at line 502 of file ossimEnvisatAsarModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_platformPosition, ossimplugins::ossimGeometricSarSensorModel::_refPoint, distance(), ossimKeywordlist::find(), ossimplugins::PlatformPosition::Interpolate(), ossimplugins::ossimGeometricSarSensorModel::optimizeModel(), ossimplugins::RefPoint::set_distance(), ossimplugins::RefPoint::set_ephemeris(), ossimplugins::RefPoint::set_pix_col(), ossimplugins::RefPoint::set_pix_line(), ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimIpt::x, and ossimIpt::y.
privatevirtual |
Definition at line 372 of file ossimEnvisatAsarModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_isProductGeoreferenced, ossimplugins::ossimGeometricSarSensorModel::_sensor, ossimKeywordlist::find(), ossimplugins::SensorParams::set_col_direction(), ossimplugins::SensorParams::set_lin_direction(), ossimplugins::SensorParams::set_prf(), ossimplugins::SensorParams::set_rwl(), and ossimplugins::SensorParams::set_sf().
privatevirtual |
Definition at line 597 of file ossimEnvisatAsarModel.cpp.
References ossimplugins::ossimGeometricSarSensorModel::_isProductGeoreferenced, _n_srgr, _pixel_spacing, _srgr_coefset, _srgr_update, and ossimKeywordlist::find().
Reimplemented from ossimplugins::ossimGeometricSarSensorModel.
Definition at line 343 of file ossimEnvisatAsarModel.cpp.
References InitPlatformPosition(), InitRefPoint(), InitSensorParams(), and InitSRGR().
| bool ossimplugins::ossimEnvisatAsarModel::open | ( | const ossimFilename & | file | ) |
| file |
Definition at line 91 of file ossimEnvisatAsarModel.cpp.
References _EnvisatAsarData, ossimString::c_str(), ossimNotify(), and ossimNotifyLevel_DEBUG.
METHOD: print() Fulfills base-class pure virtual. Dumps contents of object to ostream.
Definition at line 353 of file ossimEnvisatAsarModel.cpp.
References _n_srgr, _pixel_spacing, and ossimplugins::ossimGeometricSarSensorModel::print().
| kwl | Keyword list to save to. |
| prefix | added to keys when saved. |
Definition at line 160 of file ossimEnvisatAsarModel.cpp.
References _EnvisatAsarData, ossimKeywordlist::add(), ossimplugins::MainProcessingParameters::get_avg_scene_height_ellpsoid(), ossimplugins::GeolocationGrid::get_first_zero_doppler_time_day(), ossimplugins::SRGRConversionParameters::get_first_zero_doppler_time_day(), ossimplugins::GeolocationGrid::get_first_zero_doppler_time_microsec(), ossimplugins::SRGRConversionParameters::get_first_zero_doppler_time_microsec(), ossimplugins::GeolocationGrid::get_first_zero_doppler_time_sec(), ossimplugins::SRGRConversionParameters::get_first_zero_doppler_time_sec(), ossimplugins::EnvisatAsarData::get_GeolocationGrid(), ossimplugins::SRGRConversionParameters::get_ground_range_origin(), ossimplugins::GeolocationGrid::get_lats(), ossimplugins::GeolocationGrid::get_line_num(), ossimplugins::sph::get_line_time_interval(), ossimplugins::GeolocationGrid::get_longs(), ossimplugins::EnvisatAsarData::get_MainProcessingParameters(), ossimplugins::EnvisatAsarData::get_num_ds(), ossimplugins::MainProcessingParameters::get_num_output_lines(), ossimplugins::MainProcessingParameters::get_num_samples_per_line(), ossimplugins::MainProcessingParameters::get_prf(), ossimplugins::MainProcessingParameters::get_radar_freq(), ossimplugins::MainProcessingParameters::get_range_samp_rate(), ossimplugins::sph::get_range_spacing(), ossimplugins::GeolocationGrid::get_samp_numbers(), ossimplugins::GeolocationGrid::get_slant_range_times(), ossimplugins::EnvisatAsarData::get_sph(), ossimplugins::SRGRConversionParameters::get_srgr_coef(), ossimplugins::MainProcessingParameters::get_srgr_flag(), ossimplugins::EnvisatAsarData::get_SRGRConversionParameters(), ossimplugins::MainProcessingParameters::get_state_vector_time_1_day(), ossimplugins::MainProcessingParameters::get_state_vector_time_1_microsec(), ossimplugins::MainProcessingParameters::get_state_vector_time_1_sec(), ossimplugins::MainProcessingParameters::get_state_vector_time_2_day(), ossimplugins::MainProcessingParameters::get_state_vector_time_2_microsec(), ossimplugins::MainProcessingParameters::get_state_vector_time_2_sec(), ossimplugins::MainProcessingParameters::get_state_vector_time_3_day(), ossimplugins::MainProcessingParameters::get_state_vector_time_3_microsec(), ossimplugins::MainProcessingParameters::get_state_vector_time_3_sec(), ossimplugins::MainProcessingParameters::get_state_vector_time_4_day(), ossimplugins::MainProcessingParameters::get_state_vector_time_4_microsec(), ossimplugins::MainProcessingParameters::get_state_vector_time_4_sec(), ossimplugins::MainProcessingParameters::get_state_vector_time_5_day(), ossimplugins::MainProcessingParameters::get_state_vector_time_5_microsec(), ossimplugins::MainProcessingParameters::get_state_vector_time_5_sec(), ossimplugins::MainProcessingParameters::get_x_pos_1(), ossimplugins::MainProcessingParameters::get_x_pos_2(), ossimplugins::MainProcessingParameters::get_x_pos_3(), ossimplugins::MainProcessingParameters::get_x_pos_4(), ossimplugins::MainProcessingParameters::get_x_pos_5(), ossimplugins::MainProcessingParameters::get_x_vel_1(), ossimplugins::MainProcessingParameters::get_x_vel_2(), ossimplugins::MainProcessingParameters::get_x_vel_3(), ossimplugins::MainProcessingParameters::get_x_vel_4(), ossimplugins::MainProcessingParameters::get_x_vel_5(), ossimplugins::MainProcessingParameters::get_y_pos_1(), ossimplugins::MainProcessingParameters::get_y_pos_2(), ossimplugins::MainProcessingParameters::get_y_pos_3(), ossimplugins::MainProcessingParameters::get_y_pos_4(), ossimplugins::MainProcessingParameters::get_y_pos_5(), ossimplugins::MainProcessingParameters::get_y_vel_1(), ossimplugins::MainProcessingParameters::get_y_vel_2(), ossimplugins::MainProcessingParameters::get_y_vel_3(), ossimplugins::MainProcessingParameters::get_y_vel_4(), ossimplugins::MainProcessingParameters::get_y_vel_5(), ossimplugins::MainProcessingParameters::get_z_pos_1(), ossimplugins::MainProcessingParameters::get_z_pos_2(), ossimplugins::MainProcessingParameters::get_z_pos_3(), ossimplugins::MainProcessingParameters::get_z_pos_4(), ossimplugins::MainProcessingParameters::get_z_pos_5(), ossimplugins::MainProcessingParameters::get_z_vel_1(), ossimplugins::MainProcessingParameters::get_z_vel_2(), ossimplugins::MainProcessingParameters::get_z_vel_3(), ossimplugins::MainProcessingParameters::get_z_vel_4(), ossimplugins::MainProcessingParameters::get_z_vel_5(), true, and ossimKeywordNames::TYPE_KW.
private |
Definition at line 134 of file ossimEnvisatAsarModel.h.
Referenced by open(), saveState(), and ~ossimEnvisatAsarModel().
protected |
Slant Range to Ground Range (SRGR) number of coefficients sets.
Definition at line 103 of file ossimEnvisatAsarModel.h.
Referenced by FindSRGRSetNumber(), getSlantRangeFromGeoreferenced(), InitSRGR(), and print().
protected |
Pixel spacing.
Definition at line 115 of file ossimEnvisatAsarModel.h.
Referenced by getSlantRangeFromGeoreferenced(), InitSRGR(), and print().
protected |
SRGR coefficient sets.
Definition at line 107 of file ossimEnvisatAsarModel.h.
Referenced by FindSRGRSetNumber(), and InitSRGR().
protected |
SRGR coefficient sets update times.
Definition at line 111 of file ossimEnvisatAsarModel.h.
