#include <ossimLandSatModel.h>
Public Types | |
| enum | ProjectionType { UNKNOWN_PROJECTION = 0, UTM_MAP, UTM_ORBIT, SOM_MAP, SOM_ORBIT } |
| enum | AdjustParamIndex { INTRACK_OFFSET = 0, CRTRACK_OFFSET, LINE_GSD_CORR, SAMP_GSD_CORR, ROLL_OFFSET, YAW_OFFSET, YAW_RATE, MAP_ROTATION, NUM_ADJUSTABLE_PARAMS } |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
| ossimLandSatModel () | |
| ossimLandSatModel (const ossimFfL7 &head) | |
| ossimLandSatModel (const ossimFilename &init_file) | |
| ossimLandSatModel (const ossimKeywordlist &geom_kwl) | |
| ossimLandSatModel (const ossimLandSatModel &rhs) | |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| image to ground faster More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| static void | writeGeomTemplate (ostream &os) |
Static Public Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimLandSatModel () |
| uses file path to init model More... | |
| void | initFromHeader (const ossimFfL7 &head) |
| virtual void | initAdjustableParameters () |
| void | initMapProjection () |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 39 of file ossimLandSatModel.h.
| Enumerator | |
| INTRACK_OFFSET | |
| CRTRACK_OFFSET | |
| LINE_GSD_CORR | |
| SAMP_GSD_CORR | |
| ROLL_OFFSET | |
| YAW_OFFSET | |
| YAW_RATE | |
| MAP_ROTATION | |
| NUM_ADJUSTABLE_PARAMS | |
Definition at line 61 of file ossimLandSatModel.h.
| Enumerator | |
| UNKNOWN_PROJECTION | |
| UTM_MAP | |
| UTM_ORBIT | |
| SOM_MAP | |
| SOM_ORBIT | |
Definition at line 52 of file ossimLandSatModel.h.
| ossimLandSatModel::ossimLandSatModel | ( | ) |
CONSTRUCTORS:
Definition at line 104 of file ossimLandSatModel.cpp.
Referenced by dup().
| ossimLandSatModel::ossimLandSatModel | ( | const ossimFfL7 & | head | ) |
Definition at line 128 of file ossimLandSatModel.cpp.
| ossimLandSatModel::ossimLandSatModel | ( | const ossimFilename & | init_file | ) |
Definition at line 155 of file ossimLandSatModel.cpp.
| ossimLandSatModel::ossimLandSatModel | ( | const ossimKeywordlist & | geom_kwl | ) |
Definition at line 173 of file ossimLandSatModel.cpp.
| ossimLandSatModel::ossimLandSatModel | ( | const ossimLandSatModel & | rhs | ) |
Definition at line 200 of file ossimLandSatModel.cpp.
protectedvirtual |
Definition at line 247 of file ossimLandSatModel.cpp.
Implements ossimProjection.
Definition at line 239 of file ossimLandSatModel.cpp.
References ossimLandSatModel().
Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target.
Reimplemented from ossimSensorModel.
Definition at line 459 of file ossimLandSatModel.cpp.
protectedvirtual |
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 1107 of file ossimLandSatModel.cpp.
protected |
Initializes the model given a fast format header.
Definition at line 260 of file ossimLandSatModel.cpp.
protected |
Definition at line 1012 of file ossimLandSatModel.cpp.
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 409 of file ossimLandSatModel.cpp.
Definition at line 718 of file ossimLandSatModel.cpp.
Extends base-class implementation. Dumps contents of object to ostream.
Definition at line 626 of file ossimLandSatModel.cpp.
References ossimString::chars(), ossimDpt::line, ossimDpt::samp, ossimSensorModel::theGSD, ossimSensorModel::theImageID, ossimSensorModel::theImageSize, ossimSensorModel::theRefGndPt, and ossimSensorModel::theRefImgPt.
Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files. Returns true if successful.
Definition at line 669 of file ossimLandSatModel.cpp.
Reimplemented from ossimOptimizableProjection.
Definition at line 1140 of file ossimLandSatModel.cpp.
Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 1054 of file ossimLandSatModel.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossim::cosd(), ossimMatrix3x3::create(), CRTRACK_OFFSET, INTRACK_OFFSET, LINE_GSD_CORR, MAP_ROTATION, ROLL_OFFSET, SAMP_GSD_CORR, ossim::sind(), theCrtrackOffset, theIntrackOffset, theLineGsdCorr, theMapAzimAngle, theMapAzimCos, theMapAzimSin, theMapRotation, theProjectionType, theRollOffset, theRollRotMat, theSampGsdCorr, theYawOffset, theYawRate, UTM_ORBIT, YAW_OFFSET, and YAW_RATE.
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 120 of file ossimLandSatModel.h.
static |
Writes a template of geom keywords processed by loadState and saveState to output stream.
Definition at line 964 of file ossimLandSatModel.cpp.
protected |
Definition at line 162 of file ossimLandSatModel.h.
Referenced by updateModel().
protected |
Definition at line 137 of file ossimLandSatModel.h.
protected |
Definition at line 138 of file ossimLandSatModel.h.
protected |
Definition at line 161 of file ossimLandSatModel.h.
protected |
Definition at line 163 of file ossimLandSatModel.h.
protected |
Definition at line 154 of file ossimLandSatModel.h.
protected |
Definition at line 155 of file ossimLandSatModel.h.
protected |
Definition at line 156 of file ossimLandSatModel.h.
protected |
Definition at line 151 of file ossimLandSatModel.h.
protected |
Definition at line 152 of file ossimLandSatModel.h.
protected |
Definition at line 153 of file ossimLandSatModel.h.
protected |
Definition at line 142 of file ossimLandSatModel.h.
protected |
Definition at line 149 of file ossimLandSatModel.h.
protected |
Definition at line 168 of file ossimLandSatModel.h.
protected |
Definition at line 141 of file ossimLandSatModel.h.
protected |
Definition at line 145 of file ossimLandSatModel.h.
protected |
Definition at line 139 of file ossimLandSatModel.h.
protected |
Definition at line 140 of file ossimLandSatModel.h.
protected |
Definition at line 146 of file ossimLandSatModel.h.
protected |
Definition at line 148 of file ossimLandSatModel.h.
protected |
Definition at line 165 of file ossimLandSatModel.h.
protected |
Definition at line 173 of file ossimLandSatModel.h.
protected |
Definition at line 164 of file ossimLandSatModel.h.
protected |
Definition at line 143 of file ossimLandSatModel.h.
protected |
Definition at line 144 of file ossimLandSatModel.h.
protected |
Definition at line 166 of file ossimLandSatModel.h.
protected |
Definition at line 167 of file ossimLandSatModel.h.
