#include <ossimElevSource.h>
| virtual double | getHeightAboveMSL (const ossimGpt &)=0 |
| Height access methods: More... | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| virtual ossimObject * | dup () const =0 |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual bool | pointHasCoverage (const ossimGpt &) const =0 |
| METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt: More... | |
| virtual double | getMeanSpacingMeters () const =0 |
| METHOD: meanSpacingMeters() This method returns the post spacing in the region of gpt: More... | |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const =0 |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
Definition at line 31 of file ossimElevSource.h.
protectedvirtual |
Definition at line 94 of file ossimElevSource.cpp.
protected |
Definition at line 40 of file ossimElevSource.cpp.
protected |
Definition at line 83 of file ossimElevSource.cpp.
required to be overriden by derived classes
Implements ossimConnectableObject.
Reimplemented in ossimElevCellHandler.
Definition at line 245 of file ossimElevSource.cpp.
pure virtual |
Implemented in ossimElevManager, ossimDtedHandler, ossimTiledElevationDatabase, ossimGeneralRasterElevHandler, ossimImageElevationHandler, ossimSrtmHandler, ossimImageElevationDatabase, ossimDtedElevationDatabase, ossimGeneralRasterElevationDatabase, and ossimSrtmElevationDatabase.
Referenced by ossimElevManager::addDatabase(), and ossimElevManager::getNextElevDbList().
pure virtual |
METHOD: getBoundingGndRect
Definition at line 240 of file ossimElevSource.cpp.
References theGroundRect.
Referenced by ossimImageElevationDatabase::createCell(), and ossimImageElevationDatabase::getBoundingRect().
Definition at line 255 of file ossimElevSource.cpp.
References theComputeStatsFlag.
Reimplemented in ossimTiledElevationDatabase, ossimImageElevationDatabase, ossimGeneralRasterElevationDatabase, ossimElevManager, ossimDtedElevationDatabase, and ossimSrtmElevationDatabase.
Definition at line 97 of file ossimElevSource.cpp.
References ossimNotify(), ossimNotifyLevel_FATAL, and theNullHeightValue.
pure virtual |
Implemented in ossimDtedHandler, ossimGeneralRasterElevHandler, ossimTiledElevationDatabase, ossimImageElevationDatabase, ossimGeneralRasterElevationDatabase, ossimElevManager, ossimSrtmHandler, ossimDtedElevationDatabase, ossimImageElevationHandler, and ossimSrtmElevationDatabase.
Referenced by ossimSrtmElevationDatabase::getHeightAboveMSL(), ossimDtedElevationDatabase::getHeightAboveMSL(), ossimGeneralRasterElevationDatabase::getHeightAboveMSL(), ossimImageElevationDatabase::getHeightAboveMSL(), and ossimElevImageSource::getTile().
Definition at line 225 of file ossimElevSource.cpp.
References theMaxHeightAboveMSL.
Referenced by ossimElevImageSource::getMaxPixelValue(), and ossimElevImageSource::getTile().
pure virtual |
Implemented in ossimElevManager, ossimElevCellHandler, and ossimElevationDatabase.
Referenced by ossimElevLess::operator()().
Definition at line 220 of file ossimElevSource.cpp.
References theMinHeightAboveMSL.
Referenced by ossimElevImageSource::getMinPixelValue(), and ossimElevImageSource::getTile().
| double ossimElevSource::getNullHeightValue | ( | ) | const |
Definition at line 230 of file ossimElevSource.cpp.
References theNullHeightValue.
| double ossimElevSource::getSeaLevelValue | ( | ) | const |
Definition at line 251 of file ossimElevSource.cpp.
| bool ossimElevSource::intersectRay | ( | const ossimEcefRay & | ray, |
| ossimGpt & | gpt, | ||
| double | defaultElevValue = 0.0 |
Service method for intersecting a ray with the elevation surface to arrive at a ground point. The ray is expected to originate ABOVE the surface and pointing down.
NOTE: the gpt argument is expected to be initialized with the desired datum, including ellipsoid, for the proper intersection point to be computed.
LIMITATION: This release supports only single valued solutions, i.e., it is possible a ray passing through one side of a mountain and out the other will return an intersection with the far side. Eventually, a more robust algorithm will be employed.
Returns true if good intersection found.
Definition at line 122 of file ossimElevSource.cpp.
Referenced by ossimSkyBoxLearSensor::lineSampeToWorld(), ossimPpjFrameSensor::lineSampleToWorld(), ossimRsmModel::lineSampleToWorld(), ossimSonomaSensor::lineSampleToWorld(), ossimRpcModel::lineSampleToWorld(), and ossimAlphaSensor::lineSampToWorld().
pure virtual |
Implemented in ossimGeneralRasterElevHandler, ossimTiledElevationDatabase, ossimImageElevationDatabase, ossimImageElevationHandler, ossimElevCellHandler, ossimElevManager, ossimGeneralRasterElevationDatabase, ossimDtedElevationDatabase, and ossimSrtmElevationDatabase.
Reimplemented in ossimElevManager, ossimImageElevationDatabase, ossimTiledElevationDatabase, ossimElevationCellDatabase, ossimElevCellHandler, ossimElevationDatabase, ossimGeneralRasterElevationDatabase, and ossimDtedElevationDatabase.
Definition at line 265 of file ossimElevSource.cpp.
References ossimSource::print(), theGroundRect, theMaxHeightAboveMSL, theMinHeightAboveMSL, theNullHeightValue, and theSeaLevelValue.
Referenced by ossimElevManager::print().
| flag | true to enable, false to disable. |
Definition at line 260 of file ossimElevSource.cpp.
protected |
Definition at line 174 of file ossimElevSource.h.
Referenced by getComputeStatisticsFlag(), and setComputeStatisticsFlag().
protected |
Definition at line 171 of file ossimElevSource.h.
Referenced by ossimTiledElevationDatabase::close(), getBoundingGndRect(), ossimSrtmHandler::getHeightAboveMSLMemoryTemplate(), ossimTiledElevationDatabase::mapRegion(), ossimImageElevationHandler::open(), ossimSrtmHandler::open(), ossimTiledElevationDatabase::ossimTiledElevationDatabase(), ossimElevCellHandler::pointHasCoverage(), ossimTiledElevationDatabase::pointHasCoverage(), print(), and ossimGeneralRasterElevHandler::setFilename().
protected |
Definition at line 168 of file ossimElevSource.h.
Referenced by getMaxHeightAboveMSL(), and print().
protected |
Data members:
Definition at line 167 of file ossimElevSource.h.
Referenced by getMinHeightAboveMSL(), and print().
protected |
Definition at line 169 of file ossimElevSource.h.
Referenced by getHeightAboveEllipsoid(), ossimSrtmHandler::getHeightAboveMSLFileTemplate(), ossimSrtmHandler::getHeightAboveMSLMemoryTemplate(), getNullHeightValue(), ossimSrtmHandler::getPostValue(), ossimSrtmHandler::open(), print(), and ossimGeneralRasterElevHandler::setFilename().
protected |
Definition at line 170 of file ossimElevSource.h.
Referenced by getSeaLevelValue(), and print().
