#include <ossimSonomaSensor.h>
Classes | |
| class | ossimPlane |
| ossimSonomaSensor () | |
| ossimSonomaSensor (const ossimSonomaSensor &src) | |
| void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| void | setRollPitchHeading (double r, double p, double y) |
| void | setFocalLength (double value) |
| void | setPlatformPosition (const ossimGpt &value) |
| void | setPrincipalPoint (const ossimDpt &value) |
| void | setPixelSize (const ossimDpt &value) |
| virtual void | initAdjustableParameters () |
| ground to image faster (you don't need DEM) //TBC More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| bool | intersectRay (const ossimMapProjection &proj, ossimDpt3d &result, ossimDpt3d &origin, ossimDpt3d &dir) const |
| bool | intersectRayWithHeight (const ossimMapProjection &proj, ossimDpt3d &result, ossimDpt3d &origin, ossimDpt3d &dir, double h) const |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Definition at line 52 of file ossimSonomaSensor.h.
| ossimSonomaSensor::ossimSonomaSensor | ( | ) |
Definition at line 30 of file ossimSonomaSensor.cpp.
References ossimMatrix4x4::createIdentity(), initAdjustableParameters(), m_mount, m_mountInverse, m_utmProjection, and ossimSensorModel::theSensorID.
inline |
Definition at line 56 of file ossimSonomaSensor.h.
inlinevirtual |
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Reimplemented from ossimSensorModel.
Definition at line 39 of file ossimSonomaSensor.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), m_compositeMatrix, m_ecefPlatformPosition, m_focalLength, m_mount, m_pixelSize, m_pixelToCamera, m_principalPoint, ossimEcefVector::magnitude(), ossimEcefVector::normalize(), ossimSensorModel::theRefImgPt, ossimDpt::x, and ossimDpt::y.
Referenced by lineSampleToWorld().
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 324 of file ossimSonomaSensor.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray(), ossimAdjustableParameterInterface::setAdjustableParameter(), ossimAdjustableParameterInterface::setParameterDescription(), ossimAdjustableParameterInterface::setParameterSigma(), and ossimAdjustableParameterInterface::setParameterUnit().
Referenced by loadState(), and ossimSonomaSensor().
protected |
Definition at line 522 of file ossimSonomaSensor.cpp.
References distance(), ossimElevManager::getHeightAboveEllipsoid(), ossimDpt3d::hasNans(), ossimGpt::height(), ossimElevManager::instance(), ossimSonomaSensor::ossimPlane::intersect(), ossimMapProjection::inverse(), ossim::isnan(), ossimDpt3d::makeNan(), ossimSensorModel::origin(), ossimSonomaSensor::ossimPlane::setOffset(), ossimDpt3d::x, ossimDpt3d::y, and ossimDpt3d::z.
protected |
Definition at line 592 of file ossimSonomaSensor.cpp.
References ossimSonomaSensor::ossimPlane::intersect(), and ossimSensorModel::origin().
Referenced by lineSampleHeightToWorld().
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 76 of file ossimSonomaSensor.cpp.
References ossimSensorModel::extrapolate(), ossimRefPtr< T >::get(), ossimGpt::height(), ossimSensorModel::insideImage(), intersectRayWithHeight(), ossimUtmProjection::inverse(), ossim::isnan(), ossimDpt3d::length(), m_compositeMatrix, m_mountInverse, m_pixelToCamera, m_utmProjection, ossimGpt::makeNan(), ossimSensorModel::origin(), ossimDpt3d::x, ossimDpt::x, ossimDpt3d::y, ossimDpt::y, and ossimDpt3d::z.
Implementation of base-class pure virtual projection methods. These methods may be overriden by derived classes if those have more efficient schemes. The implementations here are iterative (relatively slow). Both depend on calls to the pure virtual lineSampleHeightToWorld() method.
Definition at line 116 of file ossimSonomaSensor.cpp.
References ossimRefPtr< T >::get(), ossimDpt::hasNans(), ossimGpt::height(), imagingRay(), ossimElevManager::instance(), ossimElevSource::intersectRay(), intersectRay(), ossimUtmProjection::inverse(), ossimDpt3d::length(), m_compositeMatrix, m_mountInverse, m_pixelToCamera, m_utmProjection, ossimGpt::makeNan(), ossimSensorModel::origin(), ossimDpt3d::x, ossimDpt::x, ossimDpt3d::y, ossimDpt::y, and ossimDpt3d::z.
Referenced by updateModel().
Definition at line 366 of file ossimSonomaSensor.cpp.
References ossimSensorModel::computeGsd(), ossimMatrix3x3::createIdentity(), ossimMatrix4x4::createIdentity(), ossimString::empty(), ossimKeywordlist::find(), ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), ossimDpt::hasNans(), ossimGpt::height(), ossimDrect::height(), initAdjustableParameters(), ossimGeoidManager::instance(), ossimDpt::isNan(), ossim::isnan(), ossimSensorModel::loadState(), m_focalLength, m_heading, m_mount, m_mountInverse, m_pitch, m_pixelSize, m_platformPosition, m_platformPositionEllipsoid, m_principalPoint, m_roll, ossimDpt::makeNan(), ossimDrect::midPoint(), ossimGeoidManager::offsetFromEllipsoid(), ossimString::split(), ossimSensorModel::theGSD, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimSensorModel::theRefImgPt, ossimString::toDouble(), ossimDpt::toPoint(), ossimGpt::toPoint(), ossimString::trim(), updateModel(), and ossimDrect::width().
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Definition at line 493 of file ossimSonomaSensor.cpp.
References ossimKeywordlist::add(), m_focalLength, m_heading, m_mount, m_pitch, m_pixelSize, m_platformPosition, m_principalPoint, m_roll, ossimSensorModel::saveState(), ossimDpt::toString(), ossimGpt::toString(), ossimString::toString(), and ossimString::trim().
inline |
Definition at line 97 of file ossimSonomaSensor.h.
inline |
Definition at line 111 of file ossimSonomaSensor.h.
inline |
Definition at line 101 of file ossimSonomaSensor.h.
inline |
Definition at line 107 of file ossimSonomaSensor.h.
inline |
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 159 of file ossimSonomaSensor.cpp.
References ossimSensorModel::computeGsd(), ossimUtmProjection::computeZone(), ossimMatrix3x3::create(), ossimMatrix4x4::createIdentity(), ossimMatrix4x4::createRotationXMatrix(), ossimMatrix4x4::createRotationZMatrix(), ossimMatrix4x4::createTranslationMatrix(), ossim::degreesToRadians(), ossimLsrSpace::ecefToLsrRotMatrix(), ossimUtmProjection::forward(), ossimMatrix4x4::getData(), ossimGpt::height(), ossimDrect::height(), ossimGpt::latd(), lineSampleToWorld(), ossimDrect::ll(), ossimDrect::lr(), m_compositeMatrix, m_compositeMatrixInverse, m_ecefPlatformPosition, m_focalLength, m_heading, m_pitch, m_pixelSize, m_pixelToCamera, m_platformPositionEllipsoid, m_roll, m_utmProjection, ossimEcefVector::normalize(), ossimPolygon::resize(), ossimUtmProjection::setHemisphere(), ossimUtmProjection::setZone(), ossimSensorModel::theBoundGndPolygon, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimDrect::ul(), ossimDrect::ur(), ossimDrect::width(), ossimEcefPoint::x(), ossimIpt::x, ossimDpt::x, ossimEcefPoint::y(), ossimIpt::y, ossimDpt::y, y, and ossimEcefPoint::z().
Referenced by loadState().
inlinevirtual |
useForward() return true when it's better (more accurate / fast) to use forward (from ground to image) than inverse(from image to ground)
Implements ossimOptimizableProjection.
Definition at line 115 of file ossimSonomaSensor.h.
protected |
Definition at line 170 of file ossimSonomaSensor.h.
Referenced by imagingRay(), lineSampleHeightToWorld(), lineSampleToWorld(), and updateModel().
protected |
Definition at line 171 of file ossimSonomaSensor.h.
protected |
Definition at line 181 of file ossimSonomaSensor.h.
Referenced by imagingRay(), and updateModel().
protected |
Definition at line 180 of file ossimSonomaSensor.h.
Referenced by imagingRay(), loadState(), saveState(), and updateModel().
protected |
Definition at line 177 of file ossimSonomaSensor.h.
Referenced by loadState(), saveState(), and updateModel().
protected |
Definition at line 173 of file ossimSonomaSensor.h.
Referenced by imagingRay(), loadState(), ossimSonomaSensor(), and saveState().
protected |
Definition at line 174 of file ossimSonomaSensor.h.
Referenced by lineSampleHeightToWorld(), lineSampleToWorld(), loadState(), and ossimSonomaSensor().
protected |
Definition at line 176 of file ossimSonomaSensor.h.
protected |
Definition at line 179 of file ossimSonomaSensor.h.
protected |
Definition at line 172 of file ossimSonomaSensor.h.
protected |
Definition at line 182 of file ossimSonomaSensor.h.
Referenced by loadState(), and saveState().
protected |
Definition at line 183 of file ossimSonomaSensor.h.
Referenced by loadState(), and updateModel().
protected |
Definition at line 178 of file ossimSonomaSensor.h.
Referenced by imagingRay(), loadState(), and saveState().
protected |
Definition at line 175 of file ossimSonomaSensor.h.
protected |
Definition at line 169 of file ossimSonomaSensor.h.
Referenced by lineSampleHeightToWorld(), lineSampleToWorld(), ossimSonomaSensor(), and updateModel().
