ossimLandSatModel.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // AUTHOR: Oscar Kramer ([email protected])
6 //
7 // DESCRIPTION:
8 //
9 // SOFTWARE HISTORY:
10 // 01AUG2002 O. Kramer, ImageLinks
11 // Initial coding.
12 // 21NOV2002 O. Kramer, ImageLinks
13 // Fixed use of map projection to use forward/inverse instead of
14 // worldTLinesample/lineSampleToWorld methods.
15 //
16 //*****************************************************************************
17
18 #include <cstdlib>
20
21 RTTI_DEF1(ossimLandSatModel, "ossimLandSatModel", ossimSensorModel);
22
31 #include <ossim/base/ossimLsrRay.h>
33 #include <stdio.h>
34 #include <fstream>
35
36 //***
37 // Define Trace flags for use within this file:
38 //***
39 #include <ossim/base/ossimTrace.h>
40 static ossimTrace traceExec ("ossimLandSatModel:exec");
41 static ossimTrace traceDebug ("ossimLandSatModel:debug");
42
43 static const char* PROJECTION_TYPE_KW = "theProjectionType";
44 static const char* MAP_ZONE_KW = "theMapZone";
45 static const char* MAP_OFFSET_X_KW = "theMapOffset.x";
46 static const char* MAP_OFFSET_Y_KW = "theMapOffset.y";
47 static const char* WRS_PATH_NUMBER_KW = "theWrsPathNumber";
48 static const char* ROW_NUMBER_KW = "theWrsRowNumber";
49 static const char* ILLUM_AZIMUTH_KW = "theIllumAzimuth";
50 static const char* ILLUM_ELEVATION_KW = "theIllumElevation";
51 static const char* MERIDIANAL_ANGLE_KW = "theMeridianalAngle";
52 static const char* ORBIT_ALTITUDE_KW = "theOrbitAltitude";
53 static const char* ORBIT_INCLINATION_KW = "theOrbitInclination";
54 static const char* MAP_AZIM_ANGLE_KW = "theMapAzimAngle";
55 static const char* MAP_2Ic_ROT_ANGLE_KW = "theMap2IcRotAngle";
56 static const char* INTRACK_OFFSET_KW = "theIntrackOffset";
57 static const char* CRTRACK_OFFSET_KW = "theCrtrackOffset";
58 static const char* LINE_GSD_CORR_KW = "theLineGsdCorr";
59 static const char* SAMP_GSD_CORR_KW = "theSampGsdCorr";
60 static const char* ROLL_OFFSET_KW = "theRollOffset";
61 static const char* YAW_OFFSET_KW = "theYawOffset";
62 static const char* YAW_RATE_KW = "theYawRate";
63 static const char* MAP_ROTATION_KW = "theMapRotation";
64
65
66 static const double GEODETIC_2_GEOCENTRIC_FACTOR = 1.00674;
67 static const double L7_ORBIT_ALTITUDE = 705300.0;
68 static const double L7_ORBIT_INCLINATION = 98.22;
69 static const double L7_NOMINAL_POS_ERROR = 200.0;
70
71 static const double L5_ORBIT_ALTITUDE = 705300.0;
72 static const double L5_ORBIT_INCLINATION = 98.22;
73 static const double L5_NOMINAL_POS_ERROR = 12000.0; //arbitrary : to be fixed
74
75
76 static const char* PARAM_NAMES[] ={"intrack_offset",
77  "crtrack_offset",
78  "line_gsd_corr",
79  "samp_gsd_corr",
80  "roll_offset",
81  "yaw_offset",
82  "yaw_rate",
83  "map_rotation"};
84
85 static const char* PARAM_UNITS[] ={"meters",
86  "meters",
87  "meters",
88  "meters",
89  "degrees",
90  "degrees",
91  "seconds",
92  "degrees"};
93
94 static const char* PROJ_TYPE[] = { "UNKNOWN_PROJECTION",
95  "UTM_MAP",
96  "UTM_ORBIT",
97  "SOM_MAP",
98  "SOM_ORBIT" };
99
100 //*****************************************************************************
101 // DEFAULT CONSTRUCTOR: ossimLandSatModel()
102 //
103 //*****************************************************************************
105  :
107  theIntrackOffset (0.0),
108  theCrtrackOffset (0.0),
109  theLineGsdCorr (0.0),
110  theSampGsdCorr (0.0),
111  theRollOffset (0.0),
112  theYawOffset (0.0),
113  theYawRate (0.0),
114  theMapRotation (0.0)
115
116 {
117  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel: entering..." << std::endl;
118
120
121  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel: returning..." << std::endl;
122 }
123
124 //*****************************************************************************
125 // COPY CONSTRUCTOR: ossimLandSatModel(ossimLandSatModel)
126 //
127 //*****************************************************************************
129  :
131  theIntrackOffset (0.0),
132  theCrtrackOffset (0.0),
133  theLineGsdCorr (0.0),
134  theSampGsdCorr (0.0),
135  theRollOffset (0.0),
136  theYawOffset (0.0),
137  theYawRate (0.0),
138  theMapRotation (0.0)
139 {
140  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel(head): entering..." << std::endl;
141
142  initFromHeader(head);
143
144  if (traceDebug()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel(head): Exited..." << std::endl;
145 }
146
147
148 //*****************************************************************************
149 // CONSTRUCTOR: ossimLandSatModel(filename)
150 //
151 // Constructs model from a filename. The file can be either a FF header file
152 // or a KWL file.
153 //
154 //*****************************************************************************
156
157 {
158  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel(init_file): entering..." << std::endl;
159
160  setupOptimizer(init_file);
161
162  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel(init_file): Exited..." << std::endl;
163 }
164
165
166
167 //*****************************************************************************
168 // CONSTRUCTOR: ossimLandSatModel(kwl)
169 //
170 // Constructs model from keywordlist geometry file
171 //
172 //*****************************************************************************
174  :
176  theIntrackOffset (0.0),
177  theCrtrackOffset (0.0),
178  theLineGsdCorr (0.0),
179  theSampGsdCorr (0.0),
180  theRollOffset (0.0),
181  theYawOffset (0.0),
182  theYawRate (0.0),
183  theMapRotation (0.0)
184 {
185  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel(geom_kwl): entering..." << std::endl;
186
188
189  //***
190  // Parse keywordlist for geometry:
191  //***
192  loadState(geom_kwl);
193
194  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel(geom_kwl): Exited..." << std::endl;
195 }
196
197 //*****************************************************************************
198 // COPY CONSTRUCTOR:
199 //*****************************************************************************
201  :
202  ossimSensorModel (rhs),
203  theIllumAzimuth (rhs.theIllumAzimuth),
204  theIllumElevation (rhs.theIllumElevation),
205  theOrbitAltitude (rhs.theOrbitAltitude),
206  theOrbitInclination(rhs.theOrbitInclination),
207  theMapZone (rhs.theMapZone),
208  theMapOffset (rhs.theMapOffset),
209  theWrsPathNumber (rhs.theWrsPathNumber),
210  theWrsRowNumber (rhs.theWrsRowNumber),
211  theMeridianalAngle (rhs.theMeridianalAngle),
212  thePositionError (rhs.thePositionError),
213  theProjectionType (rhs.theProjectionType),
214  theMapProjection (rhs.theMapProjection.valid()?
215  (ossimMapProjection*)rhs.theMapProjection->dup():
216  (ossimMapProjection*)0),
217  theMapAzimAngle (rhs.theMapAzimAngle),
218  theMapAzimCos (rhs.theMapAzimCos),
219  theMapAzimSin (rhs.theMapAzimSin),
220  theMap2IcRotAngle (rhs.theMap2IcRotAngle),
221  theMap2IcRotCos (rhs.theMap2IcRotCos),
222  theMap2IcRotSin (rhs.theMap2IcRotSin),
223  theIntrackOffset (rhs.theIntrackOffset),
224  theCrtrackOffset (rhs.theCrtrackOffset),
225  theLineGsdCorr (rhs.theLineGsdCorr),
226  theSampGsdCorr (rhs.theSampGsdCorr),
227  theRollOffset (rhs.theRollOffset),
228  theYawOffset (rhs.theYawOffset),
229  theYawRate (rhs.theYawRate),
230  theMapRotation (rhs.theMapRotation),
231  theRollRotMat (rhs.theRollRotMat)
232 {
233  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel(rhs): entering..." << std::endl;
234
236
237  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::ossimLandSatModel(rhs): returning..." << std::endl;
238 }
240 {
241  return new ossimLandSatModel(*this);
242 }
243 //*****************************************************************************
244 // DESTRUCTOR: ~ossimLandSatModel()
245 //
246 //*****************************************************************************
248 {
249  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::~ossimLandSatModel: entering..." << std::endl;
250
251  theMapProjection = 0;
252
253  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::~ossimLandSatModel: returning..." << std::endl;
254 }
255
256 //*****************************************************************************
257 // METHOD: ossimLandSatModel::initFromHeader()
258 //
259 //*****************************************************************************
261 {
262  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::initFromHeader: entering..." << std::endl;
263
264  //***
265  // Initialize base-class data members:
266  //***
267  theRefGndPt = head.theCenterGP;
273  theGSD.samp = head.theGsd;
274  theGSD.line = head.theGsd;
277  theMapZone = head.theUsgsMapZone;
281  theMeanGSD = head.theGsd;
282
283  //satellite orbit and accuracy
284  ossimString satname(head.theSatName);
285  if (satname.contains("7"))
286  {
287  theOrbitAltitude = L7_ORBIT_ALTITUDE;
288  theOrbitInclination = L7_ORBIT_INCLINATION;
289  theNominalPosError = L7_NOMINAL_POS_ERROR;
290  } else if (satname.contains("5"))
291  {
292  theOrbitAltitude = L5_ORBIT_ALTITUDE;
293  theOrbitInclination = L5_ORBIT_INCLINATION;
294  theNominalPosError = L5_NOMINAL_POS_ERROR;
295  } else {
296  theErrorStatus = 1; //MODEL_ERROR
297  if(traceDebug())
298  {
299  ossimNotify(ossimNotifyLevel_WARN) << "WARNING ossimLandSatModel::initFromHeader: " << "Unknown satellite name : " << satname << std::endl;
300  }
301  }
302
303
304  //***
305  // Assign the meridianal angle. The Meridianal angle is
306  // the angle between true north and the vehicles ground track. The
307  // orientation angle is the rotation of the raster image from north (this
308  // will be 0 for map-oriented imagery).
309  //
310  // Compute meridianal angle between the along-track direction
311  // and the meridian going through the scene center excluding earth rotation
312  // effects. The spherical triangle equation is Napier's rule for right-angle
313  // spherical triangles. This angle is a negative number from -8.2 to -90
314  // depending on scene latitude:
315  //***
316  double phi_c = ossim::atand(ossim::tand(theRefGndPt.lat)/
317  GEODETIC_2_GEOCENTRIC_FACTOR);
318  double cos_phi_c = ossim::cosd(phi_c);
321
322  //***
323  // Fetch the corner points from the header:
324  //***
325  ossimDpt v[4]; // temporarily holds vertices for ground polygon
326  v[0] = head.theUL_Corner;
327  v[1] = head.theUR_Corner;
328  v[2] = head.theLR_Corner;
329  v[3] = head.theLL_Corner;
331
332  //***
333  // Initialize map projection parameters:
334  // Determine the projection/orientation type:
335  //***
336  ossimString orient_type = head.theProductType;
337  ossimString proj_type = head.theMapProjectionName;
338  if (proj_type.contains("SOM"))
339  {
340  //***
341  // Inverse the line direction GSD for SOM, since projection "intrack"
342  // axis (x) is descending:
343  //***
344  if (orient_type.contains("ORBIT"))
346  else
348
349  // this is a hack. After testing two it is consistently off
350  // by 90 degrees.
351  //
352  theMapAzimAngle -= 90.0;
353  }
354  else if (proj_type.contains("UTM"))
355  {
356  if (orient_type.contains("ORBIT"))
358  else
360  }
361  else
362  {
363  theErrorStatus = 1; //MODEL_ERROR
364  if(traceDebug())
365  {
366  ossimNotify(ossimNotifyLevel_WARN) << "WARNING ossimLandSatModel::initFromHeader: "
367  << "Unknown projection/orientation type." << std::endl;
368  }
369  return;
370  }
371
372  //***
373  // Establish the map projection:
374  //***
376
377
379  if (traceDebug())
380  {
382  << "DEBUG ossimLandSatModel::initFromHeader:"
383  << "\ntheMapProjection:\n";
384
386
388  << "\nHeader upper left ground point: " << head.theUL_Corner
389  << std::endl;
390  }
391
392  //***
393  // initialize remaining data members:
394  //***
396  updateModel();
397
398  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::initFromHeader: returning..." << std::endl;
399 }
400
401 //*****************************************************************************
402 // METHOD: ossimLandSatModel::lineSampleHeightToWorld()
403 //
404 // Performs the line/sample to groundpoint projection given an elevation.
405 //
406 // 5. Intersect imaging ray with elevation surface.
407 //
408 //*****************************************************************************
410  const double& height,
411  ossimGpt& gpt) const
412 {
413  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::lineSampleHeightToWorld: entering..." << std::endl;
414
415 #if 0
416  //***
417  // Extrapolate if point is outside image:
418  //***
419  if (!insideImage(image_point))
420  {
421  gpt = extrapolate(image_point, height);
422  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::lineSampleHeightToWorld: returning..." << std::endl;
423  return;
424  }
425 #endif
426
427  //***
428  // First establish imaging ray from image point:
429  //***
430  ossimEcefRay imaging_ray;
431  imagingRay(image_point, imaging_ray);
432  ossimEcefPoint Pecf (imaging_ray.intersectAboveEarthEllipsoid(height));
433  gpt = ossimGpt(Pecf);
434 }
435
436
437 //*****************************************************************************
438 // METHOD: ossimLandSatModel::imagingRay()
439 //
440 // This model implements an affine transform with scaling to arrive at an
441 // ECF ray given an image point. This ray is intersected with a constant
442 // elevation surface to arrive at a ground point. The transform to arrive at a
443 // point on the ground [p,l,0] is implemented briefly as follows:
444 //
445 // 0. Establish the lat/lon map point given input point.
446 //
447 // 1. Determine intrack/crosstrack coordinates of image map point by rotating
448 // the input coordinates by meridianal angle.
449 //
450 // 2. Given intrack line number, compute vehicle position at time of imaging.
451 //
452 // 3. Establish imaging ray given input point ground coordinates and vehicle
453 // position.
454 //
455 // 4. Perturb imaging ray by adjustable parameters for platform attitude and
456 // position error.
457 //
458 //*****************************************************************************
460  ossimEcefRay& image_ray) const
461 {
462 #if 0
463  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "ossimLandSatModel::imagingRay: entering..." << std::endl;
464
465  bool debug_flag = false; // setable by interactive debugger
466  if (traceDebug() || debug_flag)
467  {
468  ossimNotify(ossimNotifyLevel_DEBUG) << "inImgPt = " << inImgPt << std::endl;
469  }
470 #endif
471
472  //***
473  // Get ground point for given map image point:
474  //***
475  ossimDpt rot_img_pt(-inImgPt.line*theMapAzimSin+inImgPt.samp*theMapAzimCos,
476  inImgPt.line*theMapAzimCos+inImgPt.samp*theMapAzimSin);
477  ossimDpt map_point
478  (theMapOffset.x + rot_img_pt.samp*(theGSD.samp+theSampGsdCorr),
479  theMapOffset.y - rot_img_pt.line*(theGSD.line+theLineGsdCorr));
480
481  ossimGpt inGndPt (theMapProjection->inverse(map_point));
482
483 #if 0
484  if (traceDebug() || debug_flag)
485  {
486  ossimNotify(ossimNotifyLevel_DEBUG) << "\t theMapOffset="<<theMapOffset<<endl;
487  ossimNotify(ossimNotifyLevel_DEBUG) << "\t rot_img_pt="<<rot_img_pt<<endl;
488  ossimNotify(ossimNotifyLevel_DEBUG) << "\t image point map_point="<<map_point<<endl;
489  ossimNotify(ossimNotifyLevel_DEBUG) << "\t inGndPt="<<inGndPt<<endl;
490  }
491 #endif
492  //***
493  // Rotate the image map coordinates by the map-to-IC rotation
494  // to arrive at intrack/crosstrack coordinate:
495  //***
496  ossimDpt offInMapPt (inImgPt - theRefImgPt);
497  ossimDpt icInPt
498  (offInMapPt.line*theMap2IcRotSin + offInMapPt.samp*theMap2IcRotCos,
499  offInMapPt.line*theMap2IcRotCos - offInMapPt.samp*theMap2IcRotSin);
500
501 #if 0
502  if (traceDebug() || debug_flag)
503  {
504  ossimNotify(ossimNotifyLevel_DEBUG) << "\t offInMapPt="<<offInMapPt<<endl;
505  ossimNotify(ossimNotifyLevel_DEBUG) << "\t icInPt="<<icInPt<<endl;
506  }
507 #endif
508
509  //***
510  // Establish an image map point at vehicle NADIR corresponding to imaging
511  // line:
512  //***
513  ossimDpt icNdrPt (0.0, icInPt.line);
514  ossimDpt offNdrMapPt
515  (-icNdrPt.line*theMap2IcRotSin + icNdrPt.samp*theMap2IcRotCos,
516  icNdrPt.line*theMap2IcRotCos + icNdrPt.samp*theMap2IcRotSin);
517  ossimDpt ndrMapPt(offNdrMapPt + theRefImgPt);
518  ossimDpt rotNdrMapPt
519  (-ndrMapPt.line*theMapAzimSin + ndrMapPt.samp*theMapAzimCos,
520  ndrMapPt.line*theMapAzimCos + ndrMapPt.samp*theMapAzimSin);
521
522 #if 0
523  if (traceDebug() || debug_flag)
524  {
525  ossimNotify(ossimNotifyLevel_DEBUG) << "\t icNdrPt="<<icNdrPt<<endl;
526  ossimNotify(ossimNotifyLevel_DEBUG) << "\t offNdrMapPt="<<offNdrMapPt<<endl;
527  ossimNotify(ossimNotifyLevel_DEBUG) << "\t ndrMapPt="<<ndrMapPt<<endl;
528  ossimNotify(ossimNotifyLevel_DEBUG) << "\t rotNdrMapPt="<<rotNdrMapPt<<endl;
529  }
530 #endif
531
532  //***
533  // Establish the vehicle position at time of line imaging:
534  //***
535  map_point.y =theMapOffset.y+rotNdrMapPt.x*(theGSD.x+theSampGsdCorr);
537  map_point.x = theMapOffset.x+rotNdrMapPt.y*(theGSD.y+theLineGsdCorr);
538  else
539  map_point.x = theMapOffset.x-rotNdrMapPt.y*(theGSD.y+theLineGsdCorr);
540
541  ossimGpt vehiclePlhPos(theMapProjection->inverse(map_point));
542  vehiclePlhPos.hgt = theOrbitAltitude;
543
544 #if 0
545  if (traceDebug() || debug_flag)
546  {
547  ossimNotify(ossimNotifyLevel_DEBUG) << "\t map_point="<<map_point<<endl;
548  ossimNotify(ossimNotifyLevel_DEBUG) << "\t vehiclePlhPos="<<vehiclePlhPos<<endl;
549  }
550 #endif
551
552  //***
553  // Establish an LSR space at the vehicle with X along the intrack direction:
554  //***
555  ossimLsrSpace icrSpace (vehiclePlhPos, theMeridianalAngle-90.0);
556
557 #if 0
558  if (traceDebug() || debug_flag)
559  {
560  ossimNotify(ossimNotifyLevel_DEBUG) << "\t icrSpace="<<icrSpace<<endl;
561  }
562 #endif
563
564  //***
565  // Now establish a ray pointing to the imaged ground point from the vehicle
566  // in ICR space:
567  //***
568  ossimLsrPoint lsrInPt (inGndPt, icrSpace);
569  ossimLsrPoint vehicleLsrPos (0.0, 0.0, 0.0, icrSpace);
570  ossimLsrRay initLsrImgRay (vehicleLsrPos, lsrInPt);
571
572 #if 0
573  if (traceDebug() || debug_flag)
574  {
575  ossimNotify(ossimNotifyLevel_DEBUG) << "\t initLsrImgRay="<<initLsrImgRay<<endl;
576  }
577 #endif
578
579  //***
580  // Establish the attitude rotation matrix considering the attitude biases
581  // and rates:
582  //***
583  double cos, sin;
584  double norm_line = inImgPt.line/theImageSize.line;
585  double yaw = theYawOffset + theYawRate*norm_line;
586  cos = ossim::cosd(yaw);
587  sin = ossim::sind(yaw);
588  NEWMAT::Matrix T_yaw = ossimMatrix3x3::create( cos,-sin, 0.0,
589  sin, cos, 0.0,
590  0.0, 0.0, 1.0);
591  NEWMAT::Matrix attRotMat = T_yaw * theRollRotMat;
592
593  //***
594  // Now apply the perturbation to the ray due to the adjustable parameters,
595  // and arrive at the ECF adjusted imaging ray:
596  //***
597  ossimLsrVector adjLsrImgRayDir (attRotMat*initLsrImgRay.direction().data(),
598  icrSpace);
599  ossimLsrPoint adjLsrImgRayOrg (theIntrackOffset,
601  0.0, // no radial adjustment of position
602  icrSpace);
603  ossimLsrRay adjLsrImgRay (adjLsrImgRayOrg, adjLsrImgRayDir);
604  image_ray = ossimEcefRay(adjLsrImgRay);
605
606 #if 0
607  if (traceDebug() || debug_flag)
608  {
609  ossimNotify(ossimNotifyLevel_DEBUG) << "\t adjLsrImgRay="<<adjLsrImgRay<<endl;
610  ossimNotify(ossimNotifyLevel_DEBUG) << "\t image_ray="<<image_ray<<endl;
611  }
612
613  if (traceExec())
614  {
615  ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::imagingRay: Returning..." << std::endl;
616  }
617 #endif
618 }
619
620 //*****************************************************************************
621 // METHOD: ossimLandSatModel::print()
622 //
623 // Formatted dump of data members.
624 //
625 //*****************************************************************************
627 {
628  os << "\nDump of ossimLandSatModel object at "
629  << hex << this << ":\n"
630  << "\nLandSatModel -- Dump of all data members: "
631  << "\n theImageID: " << theImageID.chars()
632  << "\n theImageSize: " << theImageSize
633  << "\n theRefImgPt: " << theRefImgPt
634  << "\n theRefGndPt: " << theRefGndPt
635  << "\n theGSD.line: " << theGSD.line
636  << "\n theGSD.samp: " << theGSD.samp
637  << "\n theProjectionType: " << PROJ_TYPE[theProjectionType]
638  << "\n theMapZone: " << theMapZone
639  << "\n theMapOffset: " << theMapOffset
640  << "\n theWrsPathNumber: " << theWrsPathNumber
641  << "\n theWrsRowNumber: " << theWrsRowNumber
642  << "\n theIllumAzimuth: " << theIllumAzimuth
643  << "\n theIllumElevation: " << theIllumElevation
644  << "\n thePositionError: " << thePositionError
645  << "\n theMeridianalAngle: " << theMeridianalAngle
646  << "\n theOrbitAltitude: " << theOrbitAltitude
647  << "\ntheOrbitInclination: " << theOrbitInclination
648  << "\n theMapAzimAngle: " << theMapAzimAngle
649  << "\n theMap2IcRotAngle: " << theMap2IcRotAngle
650  << "\n theIntrackOffset: " << theIntrackOffset
651  << "\n theCrtrackOffset: " << theCrtrackOffset
652  << "\n theLineGsdCorr: " << theLineGsdCorr
653  << "\n theSampGsdCorr: " << theSampGsdCorr
654  << "\n theRollOffset: " << theRollOffset
655  << "\n theYawOffset: " << theYawOffset
656  << "\n theYawRate: " << theYawRate
657  << "\n theMapRotation: " << theMapRotation
658  << endl;
659
660  return ossimSensorModel::print(os);
661 }
662
663 //*****************************************************************************
664 // METHOD: ossimLandSatModel::saveState()
665 //
666 // Saves the model state to the KWL. This KWL also serves as a geometry file.
667 //
668 //*****************************************************************************
670  const char* prefix) const
671 {
672  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::saveState: entering..." << std::endl;
673
674  kwl.add(prefix, ossimKeywordNames::TYPE_KW, TYPE_NAME(this));
675
676  //***
677  // Hand off to base class for common stuff:
678  //***
679  ossimSensorModel::saveState(kwl, prefix);
680
681  //***
682  // Save off data members:
683  //***
684  kwl.add(prefix, PROJECTION_TYPE_KW, theProjectionType, true);
685  kwl.add(prefix, MAP_ZONE_KW, theMapZone, true);
686  kwl.add(prefix, MAP_OFFSET_X_KW, theMapOffset.x, true);
687  kwl.add(prefix, MAP_OFFSET_Y_KW, theMapOffset.y, true);
688  kwl.add(prefix, WRS_PATH_NUMBER_KW, theWrsPathNumber, true);
689  kwl.add(prefix, ROW_NUMBER_KW, theWrsRowNumber, true);
690  kwl.add(prefix, ILLUM_AZIMUTH_KW, theIllumAzimuth, true);
691  kwl.add(prefix, ILLUM_ELEVATION_KW, theIllumElevation, true);
692  kwl.add(prefix, MERIDIANAL_ANGLE_KW, theMeridianalAngle, true);
693  kwl.add(prefix, ORBIT_ALTITUDE_KW, theOrbitAltitude, true);
694  kwl.add(prefix, ORBIT_INCLINATION_KW, theOrbitInclination, true);
695  kwl.add(prefix, MAP_AZIM_ANGLE_KW, theMapAzimAngle, true);
696  kwl.add(prefix, MAP_2Ic_ROT_ANGLE_KW, theMap2IcRotAngle, true);
697
698 // kwl.add(prefix, INTRACK_OFFSET_KW , theIntrackOffset, true);
699 // kwl.add(prefix, CRTRACK_OFFSET_KW, theCrtrackOffset, true);
700 // kwl.add(prefix, LINE_GSD_CORR_KW, theLineGsdCorr, true);
701 // kwl.add(prefix, SAMP_GSD_CORR_KW, theSampGsdCorr, true);
702 // kwl.add(prefix, ROLL_OFFSET_KW, theRollOffset, true);
703 // kwl.add(prefix, YAW_OFFSET_KW, theYawOffset, true);
704 // kwl.add(prefix, YAW_RATE_KW, theYawRate, true);
705 // kwl.add(prefix, MAP_ROTATION_KW, theMapRotation, true);
706
707  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::saveState: returning..." << std::endl;
708  return true;
709 }
710
711 //*****************************************************************************
712 // METHOD: ossimLandSatModel::loadState()
713 //
714 // Restores the model's state from the KWL. This KWL also serves as a
715 // geometry file.
716 //
717 //*****************************************************************************
719  const char* prefix)
720 {
721  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::loadState: entering..." << std::endl;
722
723  if (traceDebug())
724  {
725  ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::loadState:"
726  << "\nInput kwl: " << kwl
727  << std::endl;
728  }
729
730  const char* value = NULL;
731  const char* keyword =NULL;
732  bool success;
733
734  //***
735  // Assure this keywordlist contains correct type info:
736  //***
737  value = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
738  if (!value || (strcmp(value, TYPE_NAME(this))))
739  {
740  theErrorStatus = 1;
741  return false;
742  }
743
744  //
745  // Clear out any existing adjustable params:
746  //
748  {
750  }
751
752  //***
753  // Pass on to the base-class for parsing first:
754  //***
755  success = ossimSensorModel::loadState(kwl, prefix);
756  if (!success)
757  {
758  theErrorStatus++;
759  return false;
760  }
761
762  keyword = PROJECTION_TYPE_KW;
763  value = kwl.find(prefix, keyword);
764  if (!value)
765  {
766  theErrorStatus++;
767  return false;
768  }
769
770  theProjectionType = (ProjectionType) atoi(value);
771
772  keyword = MAP_ZONE_KW;
773  value = kwl.find(prefix, keyword);
774  if (!value)
775  {
776  theErrorStatus++;
777  return false;
778  }
779  theMapZone = atoi(value);
780
781  keyword = MAP_OFFSET_X_KW;
782  value = kwl.find(prefix, keyword);
783  if (!value)
784  {
785  theErrorStatus++;
786  return false;
787  }
788  theMapOffset.x = atof(value);
789
790  keyword = MAP_OFFSET_Y_KW;
791  value = kwl.find(prefix, keyword);
792  if (!value)
793  {
794  theErrorStatus++;
795  return false;
796  }
797  theMapOffset.y = atof(value);
798
799  keyword = WRS_PATH_NUMBER_KW;
800  value = kwl.find(prefix, keyword);
801  if (!value)
802  {
803  theErrorStatus++;
804  return false;
805  }
806  theWrsPathNumber = atoi(value);
807
808  keyword = ROW_NUMBER_KW;
809  value = kwl.find(prefix, keyword);
810  if (!value)
811  {
812  theErrorStatus++;
813  return false;
814  }
815  theWrsRowNumber = atoi(value);
816
817  keyword = ILLUM_AZIMUTH_KW;
818  value = kwl.find(prefix, keyword);
819  if (!value)
820  {
821  theErrorStatus++;
822  return false;
823  }
824  theIllumAzimuth = atof(value);
825
826  keyword = ILLUM_ELEVATION_KW;
827  value = kwl.find(prefix, keyword);
828  if (!value)
829  {
830  theErrorStatus++;
831  return false;
832  }
833  theIllumElevation = atof(value);
834
835  keyword = MERIDIANAL_ANGLE_KW;
836  value = kwl.find(prefix, keyword);
837  if (!value)
838  {
839  theErrorStatus++;
840  return false;
841  }
842  theMeridianalAngle = atof(value);
843
844  keyword = ORBIT_ALTITUDE_KW;
845  value = kwl.find(prefix, keyword);
846  if (!value)
847  {
848  theErrorStatus++;
849  return false;
850  }
851  theOrbitAltitude = atof(value);
852
853  keyword = ORBIT_INCLINATION_KW;
854  value = kwl.find(prefix, keyword);
855  if (!value)
856  {
857  theErrorStatus++;
858  return false;
859  }
860  theOrbitInclination = atof(value);
861
862  keyword = MAP_AZIM_ANGLE_KW;
863  value = kwl.find(prefix, keyword);
864  if (!value)
865  {
866  theErrorStatus++;
867  return false;
868  }
869  theMapAzimAngle = atof(value);
870
871  keyword = MAP_2Ic_ROT_ANGLE_KW;
872  value = kwl.find(prefix, keyword);
873  if (!value)
874  {
875  theErrorStatus++;
876  return false;
877  }
878  theMap2IcRotAngle = atof(value);
879
880  theIntrackOffset = 0.0;
881  theCrtrackOffset = 0.0;
882  theLineGsdCorr = 0.0;
883  theSampGsdCorr = 0.0;
884  theRollOffset = 0.0;
885  theYawOffset = 0.0;
886  theYawRate = 0.0;
887  theMapRotation = 0.0;
888
889  //***
890  // Adjustable parameters are optional keywords:
891  //***
892 // keyword = INTRACK_OFFSET_KW;
893 // value = kwl.find(prefix, keyword);
894 // if(value)
895 // theIntrackOffset = ossimString(value).toDouble();
896 // else
897 // theIntrackOffset = 0.0;
898
899 // keyword = CRTRACK_OFFSET_KW;
900 // value = kwl.find(prefix, keyword);
901 // if(value)
902 // theCrtrackOffset = ossimString(value).toDouble();
903 // else
904 // theCrtrackOffset = 0.0;
905
906 // keyword = LINE_GSD_CORR_KW;
907 // value = kwl.find(prefix, keyword);
908 // if(value)
909 // theLineGsdCorr = ossimString(value).toDouble();
910 // else
911 // theLineGsdCorr = 0.0;
912
913 // keyword = SAMP_GSD_CORR_KW;
914 // value = kwl.find(prefix, keyword);
915 // if(value)
916 // theSampGsdCorr = ossimString(value).toDouble();
917 // else
918 // theSampGsdCorr = 0.0;
919
920 // keyword = ROLL_OFFSET_KW;
921 // value = kwl.find(prefix, keyword);
922 // if(value)
923 // theRollOffset = ossimString(value).toDouble();
924 // else
925 // theRollOffset = 0.0;
926
927 // keyword = YAW_OFFSET_KW;
928 // value = kwl.find(prefix, keyword);
929 // if(value)
930 // theYawOffset = ossimString(value).toDouble();
931 // else
932 // theYawOffset = 0.0;
933
934 // keyword = YAW_RATE_KW;
935 // value = kwl.find(prefix, keyword);
936 // if(value)
937 // theYawRate = ossimString(value).toDouble();
938 // else
939 // theYawRate = 0.0;
940
941 // keyword = MAP_ROTATION_KW;
942 // value = kwl.find(prefix, keyword);
943 // if(value)
944 // theMapRotation = ossimString(value).toDouble();
945 // else
946 // theMapRotation = 0.0;
947
948  //***
949  // Initialize given parameters read:
950  //***
952  updateModel();
953
954  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::loadState: returning..." << std::endl;
955  return true;
956 }
957
958 //*****************************************************************************
959 // STATIC METHOD: ossimLandSatModel::writeGeomTemplate
960 //
961 // Writes a sample kwl to output stream.
962 //
963 //*****************************************************************************
965 {
966  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::writeGeomTemplate: entering..." << std::endl;
967
968  os <<
969  "//**************************************************************\n"
970  "// Template for LandSat model keywordlist\n"
971  "//**************************************************************\n"
972  << ossimKeywordNames::TYPE_KW << ": " << "ossimLandSatModel" << endl;
973
975
976  os << "//\n"
977  << "// Derived-class ossimLandSatModel Keywords:\n"
978  << "//\n"
979  << PROJECTION_TYPE_KW << ": <float>\n"
980  << MAP_ZONE_KW << ": <float>\n"
981  << MAP_OFFSET_X_KW << ": <float>\n"
982  << MAP_OFFSET_Y_KW << ": <float>\n"
983  << WRS_PATH_NUMBER_KW << ": <float>\n"
984  << ROW_NUMBER_KW << ": <float>\n"
985  << ILLUM_AZIMUTH_KW << ": <float>\n"
986  << ILLUM_ELEVATION_KW << ": <float>\n"
987  << MERIDIANAL_ANGLE_KW << ": <float>\n"
988  << ORBIT_ALTITUDE_KW << ": <float>\n"
989  << ORBIT_INCLINATION_KW << ": <float>\n"
990  << MAP_AZIM_ANGLE_KW << ": <float>\n"
991  << MAP_2Ic_ROT_ANGLE_KW << ": <float>\n"
992  << INTRACK_OFFSET_KW << ": <float> [optional]\n"
993  << CRTRACK_OFFSET_KW << ": <float> [optional]\n"
994  << LINE_GSD_CORR_KW << ": <float> [optional]\n"
995  << SAMP_GSD_CORR_KW << ": <float> [optional]\n"
996  << ROLL_OFFSET_KW << ": <float> [optional]\n"
997  << YAW_OFFSET_KW << ": <float> [optional]\n"
998  << YAW_RATE_KW << ": <float> [optional]\n"
999  << MAP_ROTATION_KW << ": <float> [optional]\n"
1000  << endl;
1001  os << "\n" <<endl;
1002
1003  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::writeGeomTemplate: returning..." << std::endl;
1004  return;
1005 }
1006
1007
1008 //*****************************************************************************
1009 // PROTECTED METHOD: ossimLandSatModel::initMapProjection()
1010 //
1011 //*****************************************************************************
1013 {
1014  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::writeGeomTemplate: entering... " << std::endl;
1015
1016  theMapProjection = 0;
1017  //***
1018  // Instantiate the proper map projection:
1019  //***
1021  {
1024  (double)theWrsPathNumber);
1025  }
1026  else
1027  {
1029  theMapProjection = utm;
1030  if(theRefGndPt.latd() < 0.0)
1031  {
1032  utm->setHemisphere('S');
1033  }
1034  else
1035  {
1036  utm->setHemisphere('N');
1037  }
1038  }
1039
1040  //***
1041  // Initialize angle sines/cosines used in phiLambda projection:
1042  //***
1046
1047  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::writeGeomTemplate: returning... " << std::endl;
1048  return;
1049 }
1050
1051 //*****************************************************************************
1052 // PROTECTED METHOD:
1053 //*****************************************************************************
1055 {
1056  //***
1057  // Update the geometry...
1058  // Adjusted = Initial + adj_parm[i]*adj_sigma[i]
1059  // Some parameters have a zero initial value and that term is not included.
1060  //***
1069
1070 // int numParams = getNumberOfAdjustableParameters();
1071  //***
1072  // Now the initial values have been updated, zero out the adjustment:
1073  //***
1074 // for (int i=0; i<numParams; i++)
1075 // setAdjustableParameter(i, 0.0);
1076
1077  //***
1078  // Compute image-common values dependent on adjustable parameters:
1079  //***
1081  {
1084  }
1085  else
1086  {
1089  }
1090
1091  double cos = ossim::cosd(theRollOffset);
1092  double sin = ossim::sind(theRollOffset);
1093  theRollRotMat = ossimMatrix3x3::create( 1.0, 0.0, 0.0,
1094  0.0, cos,-sin,
1095  0.0, sin, cos);
1096
1097
1098 }
1099 //*****************************************************************************
1100 // PRIVATE METHOD: ossimLandSatModel::initAdjustableParameters()
1101 //
1102 // This method initializes the base class adjustable parameter and associated
1103 // sigmas arrays with quantities specific to this model.
1104 //
1105 //
1106 //*****************************************************************************
1108 {
1109  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::initAdjustableParameters: entering..." << std::endl;
1110
1111  //
1112  // Allocate storage for adjustables and assign their names and units strings
1113  //
1115  int numParams = getNumberOfAdjustableParameters();
1116  //***
1117  // Initialize base-class adjustable parameter array:
1118  //***
1119  for (int i=0; i<numParams; i++)
1120  {
1121  setAdjustableParameter(i, 0.0);
1122  setParameterDescription(i, PARAM_NAMES[i]);
1123  setParameterUnit(i,PARAM_UNITS[i]);
1124  }
1125  //***
1126  // Initialize base-class parameter sigma array:
1127  //***
1128  setParameterSigma(INTRACK_OFFSET, 500.0); //change for Landsat 5
1129  setParameterSigma(CRTRACK_OFFSET, 500.0); //change for Landsat 5
1133  setParameterSigma(YAW_OFFSET, 0.01);
1134  setParameterSigma(YAW_RATE, 0.05);
1136  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::initAdjustableParameters: returning..." << std::endl;
1137 }
1138
1139 bool
1141 {
1142  //init model using file path
1143  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::setupOptimizer(init_file): entering..." << std::endl;
1144
1145  theMapProjection = 0;
1146  theIntrackOffset = 0.0;
1147  theCrtrackOffset = 0.0;
1148  theLineGsdCorr = 0.0;
1149  theSampGsdCorr = 0.0;
1150  theRollOffset = 0.0;
1151  theYawOffset = 0.0;
1152  theYawRate = 0.0;
1153  theMapRotation = 0.0;
1154
1155  ossimRefPtr<ossimFfL7> ff_headerp;
1156  if (ossimString::downcase(init_file).contains("header.dat"))
1157  {
1158  ossimRefPtr<ossimFfL5> h = new ossimFfL5(init_file);
1159  ff_headerp = h.get();
1160
1161  if (!ff_headerp->getErrorStatus())
1162  {
1163  double d = fabs(h->revb()->theUlEasting - h->revb()->theCenterEasting)/h->theGsd;
1164  h->theCenterImagePoint.x = static_cast<ossim_int32>(d); // d + 0.5 ???
1165
1166  d = fabs(h->revb()->theUlNorthing - h->revb()->theCenterNorthing)/h->theGsd;
1167  h->theCenterImagePoint.y = static_cast<ossim_int32>(d); // d + 0.5 ???
1168  initFromHeader(*ff_headerp);
1169
1170  theMapOffset.x = h->revb()->theUlEasting;
1171  theMapOffset.y = h->revb()->theUlNorthing;
1172
1173  }
1174  else
1175  {
1176  ff_headerp = 0;
1177  }
1178  }
1179  else
1180  {
1181  ff_headerp=new ossimFfL7(init_file);
1182  if (!ff_headerp->getErrorStatus())
1183  {
1184  initFromHeader(*ff_headerp);
1185  }
1186  else
1187  {
1188  ff_headerp = 0;
1189  }
1190  }
1191  if(!ff_headerp.valid())
1192  {
1193  //
1194  // If not header, then check for possible KWL file. The loadState sets the
1195  // error status:
1196  //
1197  ossimFilename init_filename(init_file);
1198  ossimKeywordlist kwl(init_filename);
1199  loadState(kwl);
1200  }
1201
1202  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimLandSatModel::setupOptimizer(init_file): Exited..." << std::endl;
1203  return true;
1204 }
double theUlNorthing
Definition: ossimFfRevb.h:250
virtual void initAdjustableParameters()
void setParameterDescription(ossim_uint32 idx, const ossimString &descrption)
double asind(double x)
Definition: ossimCommon.h:265
virtual ossimObject * dup() const
#define TYPE_NAME(p)
Definition: ossimRtti.h:326
ossimGpt theUL_Corner
Definition: ossimFfL7.h:167
static void writeGeomTemplate(ostream &os)
double theUlEasting
Definition: ossimFfRevb.h:249
int theRowNumber
Definition: ossimFfL7.h:137
virtual void updateModel()
double theSunAzimuth
Definition: ossimFfL7.h:178
ossimEcefPoint intersectAboveEarthEllipsoid(const double &heightAboveEllipsoid, const ossimDatum *aDatum=ossimDatumFactory::instance() ->wgs84()) const
ossimGpt theUR_Corner
Definition: ossimFfL7.h:168
bool valid() const
Definition: ossimRefPtr.h:75
ossimString theImageID
double samp
Definition: ossimDpt.h:164
virtual void imagingRay(const ossimDpt &image_point, ossimEcefRay &image_ray) const
double y
Definition: ossimDpt.h:165
char theProductType[19]
Definition: ossimFfL7.h:143
bool contains(char aChar) const
Definition: ossimString.h:58
void initFromHeader(const ossimFfL7 &head)
ossimIpt theCenterImagePoint
Definition: ossimFfL7.h:173
double theCenterNorthing
Definition: ossimFfRevb.h:276
int theLinesPerBand
Definition: ossimFfL7.h:148
ossimColumnVector3d & data()
char theSatName[11]
Definition: ossimFfL7.h:139
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
double sind(double x)
Definition: ossimCommon.h:260
double latd() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:87
static const char * TYPE_KW
virtual ossimGpt inverse(const ossimDpt &projectedPoint) const =0
double theSunElevation
Definition: ossimFfL7.h:177
NEWMAT::Matrix theRollRotMat
ossimRefPtr< ossimFfRevb > revb()
Definition: ossimFfL5.cpp:173
double tand(double x)
Definition: ossimCommon.h:261
char theMapProjectionName[5]
Definition: ossimFfL7.h:161
double line
virtual void lineSampleHeightToWorld(const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &worldPoint) const
virtual ~ossimLandSatModel()
uses file path to init model
ossimGpt theLR_Corner
Definition: ossimFfL7.h:169
ossim_float64 theNominalPosError
virtual bool setupOptimizer(const ossimString &init_file)
image to ground faster
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
ossimPolygon theBoundGndPolygon
void setParameterUnit(ossim_uint32 idx, ossimUnitType unit)
static NEWMAT::Matrix create()
double cosd(double x)
Definition: ossimCommon.h:259
ossimGpt theCenterGP
Definition: ossimFfL7.h:171
virtual ossimDpt extrapolate(const ossimGpt &gp) const
ossimGpt theLL_Corner
Definition: ossimFfL7.h:170
virtual ossimDpt forward(const ossimGpt &worldPoint) const =0
int theUsgsMapZone
Definition: ossimFfL7.h:165
int thePathNumber
Definition: ossimFfL7.h:136
ossimDrect theImageClipRect
virtual ossimErrorCode getErrorStatus() const
virtual void setAdjustableParameter(ossim_uint32 idx, double value, bool notify=false)
ossim_int32 y
Definition: ossimIpt.h:142
double atand(double x)
Definition: ossimCommon.h:266
ProjectionType theProjectionType
double theOffNadirAngle
Definition: ossimFfL7.h:142
double x
void resizeAdjustableParameterArray(ossim_uint32 numberOfParameters)
ossim_int32 line
virtual bool insideImage(const ossimDpt &p) const
ossim_int32 x
Definition: ossimIpt.h:141
double theCenterEasting
Definition: ossimFfRevb.h:275
double theGsd
Definition: ossimFfL7.h:150
ossim_float64 lat
Definition: ossimGpt.h:265
const ossimLsrVector & direction() const
Definition: ossimLsrRay.h:70
int thePixelsPerLine
Definition: ossimFfL7.h:147
void setHemisphere(const ossimGpt &ground)
Prints data members to stream.
char theRequestNumber[21]
Definition: ossimFfL7.h:134
void setParameterSigma(ossim_uint32 idx, double value, bool notify=false)
ossim_float64 theMeanGSD
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
ossimRefPtr< ossimMapProjection > theMapProjection
double theOrientationAngle
Definition: ossimFfL7.h:176
ossimString & downcase()
Downcases this string.
Definition: ossimString.cpp:81
