#include <ossimApplanixEcefModel.h>
| ossimApplanixEcefModel () | |
| ossimApplanixEcefModel (const ossimDrect &imageRect, const ossimGpt &platformPosition, double roll, double pitch, double heading, const ossimDpt &principalPoint, double focalLength, const ossimDpt &pixelSize) | |
| ossimApplanixEcefModel (const ossimApplanixEcefModel &src) | |
| void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| void | setPrincipalPoint (ossimDpt principalPoint) |
| void | setRollPitchHeading (double roll, double pitch, double heading) |
| void | setPixelSize (const ossimDpt &pixelSize) |
| void | setImageRect (const ossimDrect &rect) |
| void | setFocalLength (double focalLength) |
| void | setPlatformPosition (const ossimGpt &gpt) |
| virtual void | initAdjustableParameters () |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| ground to image faster (you don't need DEM) More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 16 of file ossimApplanixEcefModel.h.
| ossimApplanixEcefModel::ossimApplanixEcefModel | ( | ) |
Definition at line 34 of file ossimApplanixEcefModel.cpp.
References ossimMatrix4x4::createIdentity(), initAdjustableParameters(), theAdjEcefPlatformPosition, theCompositeMatrix, theCompositeMatrixInverse, theEcefPlatformPosition, theFocalLength, ossimSensorModel::theGSD, theHeading, theLensDistortion, ossimSensorModel::theMeanGSD, thePitch, thePixelSize, theRoll, ossimDpt::x, and ossimDpt::y.
Referenced by dup().
| ossimApplanixEcefModel::ossimApplanixEcefModel | ( | const ossimDrect & | imageRect, |
| const ossimGpt & | platformPosition, | ||
| double | roll, | ||
| double | pitch, | ||
| double | heading, | ||
| const ossimDpt & | principalPoint, | ||
| double | focalLength, | ||
| const ossimDpt & | pixelSize | ||
Definition at line 60 of file ossimApplanixEcefModel.cpp.
References ossimSensorModel::computeGsd(), ossimMatrix4x4::createIdentity(), initAdjustableParameters(), ossimDrect::midPoint(), ossimNotify(), ossimNotifyLevel_WARN, theAdjEcefPlatformPosition, theCompositeMatrix, theCompositeMatrixInverse, theEcefPlatformPosition, theFocalLength, theHeading, ossimSensorModel::theImageClipRect, theLensDistortion, thePitch, thePixelSize, ossimSensorModel::theRefImgPt, theRoll, updateModel(), and ossimException::what().
| ossimApplanixEcefModel::ossimApplanixEcefModel | ( | const ossimApplanixEcefModel & | src | ) |
Definition at line 106 of file ossimApplanixEcefModel.cpp.
References ossimRefPtr< T >::get(), initAdjustableParameters(), theLensDistortion, and ossimRefPtr< T >::valid().
Implements ossimProjection.
Definition at line 121 of file ossimApplanixEcefModel.cpp.
References ossimApplanixEcefModel().
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Reimplemented from ossimSensorModel.
Definition at line 126 of file ossimApplanixEcefModel.cpp.
References ossimEcefVector::magnitude(), ossimEcefRay::setDirection(), ossimEcefRay::setOrigin(), theAdjEcefPlatformPosition, theCompositeMatrix, theFocalLength, theLensDistortion, thePixelSize, thePrincipalPoint, ossimSensorModel::theRefImgPt, ossimMeanRadialLensDistortion::undistort(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by lineSampleHeightToWorld().
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 305 of file ossimApplanixEcefModel.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray(), ossimAdjustableParameterInterface::setAdjustableParameter(), ossimAdjustableParameterInterface::setParameterDescription(), ossimAdjustableParameterInterface::setParameterSigma(), and ossimAdjustableParameterInterface::setParameterUnit().
Referenced by ossimApplanixEcefModel().
inlinevirtual |
METHOD: insideImage(image_point) Returns true if the image_point lies inside the image rectangle.
Definition at line 48 of file ossimApplanixEcefModel.h.
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 204 of file ossimApplanixEcefModel.cpp.
References imagingRay(), and ossimEcefRay::intersectAboveEarthEllipsoid().
Implementation of base-class pure virtual projection methods. These methods may be overriden by derived classes if those have more efficient schemes. The implementations here are iterative (relatively slow). Both depend on calls to the pure virtual lineSampleHeightToWorld() method.
Definition at line 165 of file ossimApplanixEcefModel.cpp.
Referenced by updateModel().
Definition at line 411 of file ossimApplanixEcefModel.cpp.
Referenced by setupOptimizer().
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Definition at line 383 of file ossimApplanixEcefModel.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimMeanRadialLensDistortion::saveState(), ossimSensorModel::saveState(), theEcefPlatformPosition, theFocalLength, theHeading, theLensDistortion, thePitch, thePixelSize, thePrincipalPoint, theRoll, ossimString::toString(), ossimRefPtr< T >::valid(), ossimEcefPoint::x(), ossimDpt::x, ossimEcefPoint::y(), ossimDpt::y, and ossimEcefPoint::z().
| void ossimApplanixEcefModel::setFocalLength | ( | double | focalLength | ) |
| void ossimApplanixEcefModel::setImageRect | ( | const ossimDrect & | rect | ) |
Definition at line 364 of file ossimApplanixEcefModel.cpp.
References ossimDrect::midPoint(), ossimSensorModel::theImageClipRect, and ossimSensorModel::theRefImgPt.
| void ossimApplanixEcefModel::setPixelSize | ( | const ossimDpt & | pixelSize | ) |
| void ossimApplanixEcefModel::setPlatformPosition | ( | const ossimGpt & | gpt | ) |
Definition at line 375 of file ossimApplanixEcefModel.cpp.
References theEcefPlatformPosition, ossimSensorModel::theRefGndPt, and updateModel().
| void ossimApplanixEcefModel::setPrincipalPoint | ( | ossimDpt | principalPoint | ) |
Definition at line 343 of file ossimApplanixEcefModel.cpp.
References thePrincipalPoint.
| void ossimApplanixEcefModel::setRollPitchHeading | ( | double | roll, |
| double | heading | ||
Definition at line 348 of file ossimApplanixEcefModel.cpp.
References theHeading, thePitch, theRoll, and updateModel().
Reimplemented from ossimOptimizableProjection.
Definition at line 799 of file ossimApplanixEcefModel.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), and loadState().
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 265 of file ossimApplanixEcefModel.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossimMatrix4x4::createRotationXMatrix(), ossimMatrix4x4::createRotationYMatrix(), ossimGpt::height(), ossimGpt::latd(), lineSampleToWorld(), ossimDrect::ll(), ossimGpt::lond(), ossimDrect::lr(), ossimLsrSpace::lsrToEcefRotMatrix(), ossimGpt::metersPerDegree(), OSSIM_LEFT_HANDED, ossimPolygon::resize(), theAdjEcefPlatformPosition, ossimSensorModel::theBoundGndPolygon, theCompositeMatrix, theCompositeMatrixInverse, theEcefPlatformPosition, ossimSensorModel::theExtrapolateGroundFlag, ossimSensorModel::theExtrapolateImageFlag, theHeading, ossimSensorModel::theImageClipRect, ossimSensorModel::theMeanGSD, thePitch, theRoll, ossimDrect::ul(), ossimDrect::ur(), and ossimDpt::x.
Referenced by ossimApplanixEcefModel(), setPlatformPosition(), and setRollPitchHeading().
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 80 of file ossimApplanixEcefModel.h.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 225 of file ossimApplanixEcefModel.cpp.
References ossimEcefVector::data(), ossimLensDistortion::distort(), ossimPolygon::getNumberOfVertices(), ossimPolygon::hasNans(), ossimPolygon::pointWithin(), theAdjEcefPlatformPosition, ossimSensorModel::theBoundGndPolygon, theCompositeMatrixInverse, theFocalLength, theLensDistortion, thePixelSize, thePrincipalPoint, ossimSensorModel::theRefImgPt, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 97 of file ossimApplanixEcefModel.h.
Referenced by imagingRay(), ossimApplanixEcefModel(), updateModel(), and worldToLineSample().
protected |
uses file path to init model
Definition at line 85 of file ossimApplanixEcefModel.h.
Referenced by imagingRay(), ossimApplanixEcefModel(), and updateModel().
protected |
Definition at line 86 of file ossimApplanixEcefModel.h.
Referenced by ossimApplanixEcefModel(), updateModel(), and worldToLineSample().
protected |
Definition at line 93 of file ossimApplanixEcefModel.h.
Referenced by ossimApplanixEcefModel(), saveState(), setPlatformPosition(), and updateModel().
protected |
Definition at line 92 of file ossimApplanixEcefModel.h.
Referenced by imagingRay(), ossimApplanixEcefModel(), saveState(), setFocalLength(), and worldToLineSample().
protected |
Definition at line 89 of file ossimApplanixEcefModel.h.
Referenced by ossimApplanixEcefModel(), saveState(), setRollPitchHeading(), and updateModel().
protected |
Definition at line 94 of file ossimApplanixEcefModel.h.
Referenced by imagingRay(), ossimApplanixEcefModel(), saveState(), and worldToLineSample().
protected |
Definition at line 88 of file ossimApplanixEcefModel.h.
protected |
Definition at line 91 of file ossimApplanixEcefModel.h.
Referenced by imagingRay(), ossimApplanixEcefModel(), saveState(), setPixelSize(), and worldToLineSample().
protected |
Definition at line 90 of file ossimApplanixEcefModel.h.
Referenced by imagingRay(), saveState(), setPrincipalPoint(), and worldToLineSample().
protected |
Definition at line 87 of file ossimApplanixEcefModel.h.
