#include <ossimCoarseGridModel.h>
| ossimCoarseGridModel () | |
| ossimCoarseGridModel (const ossimCoarseGridModel ©_this) | |
| ossimCoarseGridModel (const ossimFilename &geom_file) | |
| Accepts name of geometry file. More... | |
| ossimCoarseGridModel (const ossimKeywordlist &geom_kwl) | |
| Accepts OSSIM keywordlist geometry file. More... | |
| ~ossimCoarseGridModel () | |
| virtual void | buildGrid (const ossimDrect &imageBounds, ossimProjection *proj, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true) |
| This method will build a grid from any projector. More... | |
| virtual void | buildGrid (const ossimDrect &imageBounds, ossimImageGeometry *geom, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true) |
| Assigns the grid data given a geometry. More... | |
| Extends base-class implementation. More... | |
| Fulfills ossimObject base-class pure virtuals. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| bool | saveCoarseGrid (const ossimFilename &cgFileName) const |
| Saves the coarse grid to the specified file. More... | |
| bool | loadCoarseGrid (const ossimFilename &cgFileName) |
| Loads the coarse grid from the specified file. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &world_pt) const |
| This is the virtual that performs the actual work of projecting the image point to the earth at some specified elevation. More... | |
| virtual void | initAdjustableParameters () |
| image to ground faster More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| static void | setInterpolationError (double error=.1) |
| This is used when building a grid from a projector. More... | |
| static void | setMinGridSpacing (ossim_int32 minSpacing=100) |
| static void | writeGeomTemplate (ostream &os) |
| Writes a template of geometry keywords processed by loadState and saveState to output stream. More... | |
Static Public Member Functions inherited from ossimSensorModel | |
| void | reallocateGrid (const ossimIpt &size) |
| Deletes existing allocated memory and reallocates new space. More... | |
| void | initializeModelParams (ossimIrect irect) |
| Initializes base class data members after grids have been assigned. More... | |
| virtual ossimGpt | extrapolate (const ossimDpt &imgPt, const double &height=ossim::nan()) const |
| Implements its own extrapolation since this can be handled by ossimDblGrid. More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Static Protected Attributes | |
| static double | theInterpolationError = .1 |
| static ossim_int32 | theMinGridSpacing = 100 |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Definition at line 34 of file ossimCoarseGridModel.h.
| ossimCoarseGridModel::ossimCoarseGridModel | ( | ) |
Definition at line 58 of file ossimCoarseGridModel.cpp.
| ossimCoarseGridModel::ossimCoarseGridModel | ( | const ossimCoarseGridModel & | copy_this | ) |
Definition at line 85 of file ossimCoarseGridModel.cpp.
| ossimCoarseGridModel::ossimCoarseGridModel | ( | const ossimFilename & | geom_file | ) |
This can be either MET ECG geom file, or OSSIM keywordlist geometry file.
Definition at line 128 of file ossimCoarseGridModel.cpp.
| ossimCoarseGridModel::ossimCoarseGridModel | ( | const ossimKeywordlist & | geom_kwl | ) |
Definition at line 163 of file ossimCoarseGridModel.cpp.
| ossimCoarseGridModel::~ossimCoarseGridModel | ( | ) |
Definition at line 459 of file ossimCoarseGridModel.cpp.
Assigns the grid data given a projection (typically a rigorous sensor model)
The accuracy of the grid can be controlled by the static method setInterpolationError().
| imageBounds | Must be the image space bounds for the projection. |
| proj | The projector that will be used to approximate a bilinear grid over. |
Definition at line 184 of file ossimCoarseGridModel.cpp.
References ossimRefPtr< T >::get(), and ossimImageGeometry::setProjection().
Definition at line 199 of file ossimCoarseGridModel.cpp.
References ossimImageGeometry::getProjection(), ossimDrect::hasNans(), ossimDrect::height(), ossimSensorModel::imageSize(), ossimDatumFactory::instance(), ossimImageGeometry::localToWorld(), ossimDrect::midPoint(), ossimAdjustableParameterInterface::resizeAdjustableParameterArray(), theDlatDparamGrid, theDlonDparamGrid, theHeightEnabledFlag, ossimDrect::ul(), ossimDatumFactory::wgs84(), ossimDrect::width(), ossimIpt::x, and ossimIpt::y.
inlinevirtual |
Implements ossimProjection.
Definition at line 85 of file ossimCoarseGridModel.h.
protectedvirtual |
Reimplemented from ossimSensorModel.
Definition at line 1048 of file ossimCoarseGridModel.cpp.
References lineSampleHeightToWorld().
Referenced by lineSampleToWorld(), and ossimH5GridModel::worldToLineSample().
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Definition at line 578 of file ossimCoarseGridModel.cpp.
References ossimSensorModel::imagingRay().
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 563 of file ossimCoarseGridModel.cpp.
References ossimAdjustableParameterInterface::addAdjustment(), ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), ossimAdjustableParameterInterface::setAdjustment(), and theInitialAdjustment.
protected |
It is assumed that theImageSize and the origin image point were already set.
Definition at line 413 of file ossimCoarseGridModel.cpp.
References ossimGpt::distanceTo(), ossimDblGrid::getNode(), ossimIrect::height(), ossimDpt::lat, ossimGpt::lat, ossimDpt::line, ossimGpt::lon, ossimIrect::midPoint(), ossimDpt::samp, ossimDblGrid::size(), ossimDblGrid::spacing(), ossimSensorModel::theBoundGndPolygon, ossimSensorModel::theGSD, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, theLatGrid, theLonGrid, ossimSensorModel::theMeanGSD, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimSensorModel::theSubImageOffset, ossimIrect::ul(), ossimIrect::width(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimHdf5GridModel::initialize(), and ossimEnviCgModel::loadEnviGeocFile().
Overrides base ossimSensorModel::isAffectedByElevation method.
Definition at line 1055 of file ossimCoarseGridModel.cpp.
References theHeightEnabledFlag.
Implements ossimSensorModel.
Definition at line 513 of file ossimCoarseGridModel.cpp.
Referenced by extrapolate(), lineSampleToWorld(), and ossimH5GridModel::worldToLineSample().
Implementation of base-class pure virtual projection methods. These methods may be overriden by derived classes if those have more efficient schemes. The implementations here are iterative (relatively slow). Both depend on calls to the pure virtual lineSampleHeightToWorld() method.
Definition at line 483 of file ossimCoarseGridModel.cpp.
References extrapolate(), ossimSensorModel::insideImage(), lineSampleHeightToWorld(), ossimSensorModel::lineSampleToWorld(), and theHeightEnabledFlag.
| bool ossimCoarseGridModel::loadCoarseGrid | ( | const ossimFilename & | cgFileName | ) |
Definition at line 855 of file ossimCoarseGridModel.cpp.
Loads geometry KWL files.
Reimplemented in ossimH5GridModel.
Definition at line 680 of file ossimCoarseGridModel.cpp.
Dumps contents of object to ostream.
Definition at line 591 of file ossimCoarseGridModel.cpp.
References ossimDblGrid::getNode(), ossimDblGrid::size(), size, ossimDblGrid::spacing(), ossimSensorModel::theBoundGndPolygon, theDlatDhGrid, theDlonDhGrid, theGridFilename, ossimSensorModel::theGSD, ossimSensorModel::theImageID, ossimSensorModel::theImageSize, theLatGrid, theLonGrid, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimSensorModel::theSensorID, ossimIpt::x, and ossimIpt::y.
protected |
This may happen if a new grid is loaded over an existing one.
Definition at line 962 of file ossimCoarseGridModel.cpp.
| bool ossimCoarseGridModel::saveCoarseGrid | ( | const ossimFilename & | cgFileName | ) | const |
Definition at line 795 of file ossimCoarseGridModel.cpp.
Referenced by ossimHdf5Tool::execute().
Saves geometry KWL files.
Reimplemented in ossimH5GridModel, ossimHdf5GridModel, and ossimEnviCgModel.
Definition at line 647 of file ossimCoarseGridModel.cpp.
Referenced by ossimEnviCgModel::saveState(), ossimHdf5GridModel::saveState(), and ossimH5GridModel::saveState().
static |
You can set the interpolation error. The default is subpixel accuracy (within .1 of a pixel).
Definition at line 399 of file ossimCoarseGridModel.cpp.
References theInterpolationError.
Referenced by ossimplugins::ossimGeometricSarSensorModel::createReplacementOCG().
static |
Definition at line 404 of file ossimCoarseGridModel.cpp.
References theMinGridSpacing.
inlinevirtual |
Implements ossimOptimizableProjection.
Definition at line 111 of file ossimCoarseGridModel.h.
static |
Definition at line 1024 of file ossimCoarseGridModel.cpp.
protected |
Definition at line 132 of file ossimCoarseGridModel.h.
Referenced by ossimHdf5GridModel::initialize(), ossimEnviCgModel::loadEnviGeocFile(), and print().
protected |
Definition at line 134 of file ossimCoarseGridModel.h.
Referenced by buildGrid().
protected |
Definition at line 133 of file ossimCoarseGridModel.h.
protected |
Definition at line 135 of file ossimCoarseGridModel.h.
mutableprotected |
Definition at line 129 of file ossimCoarseGridModel.h.
Referenced by print().
protected |
Definition at line 140 of file ossimCoarseGridModel.h.
Referenced by buildGrid(), ossimHdf5GridModel::initialize(), ossimH5GridModel::initializeModelParams(), isAffectedByElevation(), lineSampleToWorld(), and ossimEnviCgModel::loadEnviGeocFile().
protected |
Definition at line 139 of file ossimCoarseGridModel.h.
Referenced by initAdjustableParameters().
staticprotected |
Definition at line 137 of file ossimCoarseGridModel.h.
Referenced by setInterpolationError().
protected |
Definition at line 130 of file ossimCoarseGridModel.h.
Referenced by ossimH5GridModel::debugDump(), ossimH5GridModel::getWktFootprint(), ossimHdf5GridModel::initialize(), ossimH5GridModel::initializeModelParams(), initializeModelParams(), ossimEnviCgModel::loadEnviGeocFile(), ossimH5GridModel::ossimH5GridModel(), ossimHdf5GridModel::ossimHdf5GridModel(), print(), and ossimH5GridModel::setGridNodes().
protected |
Definition at line 131 of file ossimCoarseGridModel.h.
Referenced by ossimHdf5GridModel::crossesDateline(), ossimH5GridModel::debugDump(), ossimH5GridModel::getWktFootprint(), ossimHdf5GridModel::initialize(), ossimH5GridModel::initializeModelParams(), initializeModelParams(), ossimEnviCgModel::loadEnviGeocFile(), print(), and ossimH5GridModel::setGridNodes().
staticprotected |
Definition at line 138 of file ossimCoarseGridModel.h.
Referenced by setMinGridSpacing().
