#include <ossimEnviCgModel.h>
| ossimEnviCgModel () | |
| ossimEnviCgModel (const ossimFilename &geoc_file) | |
| bool | loadEnviGeocFile (const ossimFilename &geoc_file) |
| bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
| Fulfills ossimObject base-class pure virtuals. More... | |
Public Member Functions inherited from ossimCoarseGridModel | |
| ossimCoarseGridModel () | |
| ossimCoarseGridModel (const ossimCoarseGridModel ©_this) | |
| ossimCoarseGridModel (const ossimFilename &geom_file) | |
| Accepts name of geometry file. More... | |
| ossimCoarseGridModel (const ossimKeywordlist &geom_kwl) | |
| Accepts OSSIM keywordlist geometry file. More... | |
| ~ossimCoarseGridModel () | |
| virtual void | buildGrid (const ossimDrect &imageBounds, ossimProjection *proj, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true) |
| This method will build a grid from any projector. More... | |
| virtual void | buildGrid (const ossimDrect &imageBounds, ossimImageGeometry *geom, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true) |
| Assigns the grid data given a geometry. More... | |
| Extends base-class implementation. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| bool | saveCoarseGrid (const ossimFilename &cgFileName) const |
| Saves the coarse grid to the specified file. More... | |
| bool | loadCoarseGrid (const ossimFilename &cgFileName) |
| Loads the coarse grid from the specified file. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &world_pt) const |
| This is the virtual that performs the actual work of projecting the image point to the earth at some specified elevation. More... | |
| virtual void | initAdjustableParameters () |
| image to ground faster More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Private Member Functions | |
| double | readValue (ifstream &s, bool bigEndian) const |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimCoarseGridModel | |
| static void | setInterpolationError (double error=.1) |
| This is used when building a grid from a projector. More... | |
| static void | setMinGridSpacing (ossim_int32 minSpacing=100) |
| static void | writeGeomTemplate (ostream &os) |
| Writes a template of geometry keywords processed by loadState and saveState to output stream. More... | |
Static Public Member Functions inherited from ossimSensorModel | |
Protected Member Functions inherited from ossimCoarseGridModel | |
| void | reallocateGrid (const ossimIpt &size) |
| Deletes existing allocated memory and reallocates new space. More... | |
| void | initializeModelParams (ossimIrect irect) |
| Initializes base class data members after grids have been assigned. More... | |
| virtual ossimGpt | extrapolate (const ossimDpt &imgPt, const double &height=ossim::nan()) const |
| Implements its own extrapolation since this can be handled by ossimDblGrid. More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Protected Attributes inherited from ossimCoarseGridModel | |
| ossimFilename | theGridFilename |
| ossimDblGrid | theLatGrid |
| ossimDblGrid | theLonGrid |
| ossimDblGrid | theDlatDhGrid |
| ossimDblGrid | theDlonDhGrid |
| ossimDblGrid * | theDlatDparamGrid |
| ossimDblGrid * | theDlonDparamGrid |
| ossimAdjustmentInfo | theInitialAdjustment |
| bool | theHeightEnabledFlag |
Protected Attributes inherited from ossimSensorModel | |
| ossimIpt | theImageSize |
| ossimDpt | theSubImageOffset |
| ossimString | theImageID |
| ossimString | theSensorID |
| ossimDpt | theGSD |
| ossim_float64 | theMeanGSD |
| ossimGpt | theRefGndPt |
| ossimDpt | theRefImgPt |
| ossimPolygon | theBoundGndPolygon |
| ossimDrect | theImageClipRect |
| ossim_float64 | theRelPosError |
| ossim_float64 | theNominalPosError |
| ossimDpt | theParWRTx |
| Partials for current point. More... | |
| ossimDpt | theParWRTy |
| ossimDpt | theParWRTz |
| ossimDpt | theObs |
| Observations & residuals for current point. More... | |
| ossimDpt | theResid |
| ossimRefPtr< ossimProjection > | theSeedFunction |
| Used as an initial guess for iterative solutions and a guess for points outside the support bounds. More... | |
| bool | theExtrapolateImageFlag |
| bool | theExtrapolateGroundFlag |
Static Protected Attributes inherited from ossimCoarseGridModel | |
| static double | theInterpolationError = .1 |
| static ossim_int32 | theMinGridSpacing = 100 |
Definition at line 13 of file ossimEnviCgModel.h.
| ossimEnviCgModel::ossimEnviCgModel | ( | ) |
Definition at line 32 of file ossimEnviCgModel.cpp.
| ossimEnviCgModel::ossimEnviCgModel | ( | const ossimFilename & | geoc_file | ) |
Definition at line 37 of file ossimEnviCgModel.cpp.
References loadEnviGeocFile().
| bool ossimEnviCgModel::loadEnviGeocFile | ( | const ossimFilename & | geoc_file | ) |
Definition at line 45 of file ossimEnviCgModel.cpp.
References ossimString::after(), ossimString::c_str(), ossimString::contains(), ossimDblGrid::fill(), ossimSensorModel::imageSize(), ossimDblGrid::initialize(), ossimCoarseGridModel::initializeModelParams(), readValue(), ossimDblGrid::SAWTOOTH_90, ossimDblGrid::setDomainType(), ossimErrorStatusInterface::setErrorStatus(), ossimDblGrid::setNode(), ossimCoarseGridModel::theDlatDhGrid, ossimCoarseGridModel::theDlonDhGrid, ossimCoarseGridModel::theHeightEnabledFlag, ossimCoarseGridModel::theLatGrid, ossimCoarseGridModel::theLonGrid, ossimString::toInt(), ossimString::trim(), ossimDblGrid::WRAP_180, ossimDpt::x, x, ossimDpt::y, and y.
Referenced by ossimEnviCgModel().
private |
Saves geometry KWL files.
Reimplemented from ossimCoarseGridModel.
Definition at line 127 of file ossimEnviCgModel.cpp.
References ossimKeywordlist::add(), ossimCoarseGridModel::saveState(), and status.
