#include <ossimIpodSensor.h>
| ossimIpodSensor () | |
| ossimIpodSensor (const ossimIpodSensor &src) | |
| void | lineSampleHeightToWorld (const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &worldPoint) const |
| void | setRollPitchYaw (double r, double p, double y) |
| void | setFocalLength (double value) |
| void | setPlatformPosition (const ossimGpt &value) |
| void | setPrincipalPoint (const ossimDpt &value) |
| void | setPixelSize (const ossimDpt &value) |
| virtual void | initAdjustableParameters () |
| ground to image faster (you don't need DEM) //TBC More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Definition at line 17 of file ossimIpodSensor.h.
| ossimIpodSensor::ossimIpodSensor | ( | ) |
Definition at line 30 of file ossimIpodSensor.cpp.
References initAdjustableParameters(), and ossimSensorModel::theSensorID.
inline |
Definition at line 21 of file ossimIpodSensor.h.
inlinevirtual |
METHOD: imagingRay(image_point, &ossimEcefRay) Given an image point, returns a ray originating at some arbitrarily high point (ideally at the sensor position) and pointing towards the target. Implemented here but should be overriden for more efficient solution.
Reimplemented from ossimSensorModel.
Definition at line 36 of file ossimIpodSensor.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), m_adjustedPlatformPosition, m_air2Ned, m_ecef2NedInverse, m_focalLength, m_pixelSize, m_principalPoint, ossimEcefRay::setDirection(), ossimEcefRay::setOrigin(), ossimSensorModel::theRefImgPt, ossimDpt::x, and ossimDpt::y.
Referenced by lineSampleHeightToWorld().
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 149 of file ossimIpodSensor.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray(), ossimAdjustableParameterInterface::setAdjustableParameter(), ossimAdjustableParameterInterface::setParameterDescription(), ossimAdjustableParameterInterface::setParameterSigma(), and ossimAdjustableParameterInterface::setParameterUnit().
Referenced by loadState(), and ossimIpodSensor().
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 61 of file ossimIpodSensor.cpp.
References imagingRay(), ossimSensorModel::insideImage(), ossimEcefRay::intersectAboveEarthEllipsoid(), and ossimGpt::makeNan().
Definition at line 191 of file ossimIpodSensor.cpp.
References ossimSensorModel::computeGsd(), ossimString::empty(), ossimKeywordlist::find(), ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), ossimDpt::hasNans(), ossimDrect::hasNans(), ossimGpt::height(), initAdjustableParameters(), ossimGeoidManager::instance(), ossimDpt::isNan(), ossim::isnan(), ossimSensorModel::loadState(), m_focalLength, m_pitch, m_pixelSize, m_platformPosition, m_platformPositionEllipsoid, m_principalPoint, m_roll, m_yaw, ossimDpt::makeNan(), ossimDrect::midPoint(), ossimGeoidManager::offsetFromEllipsoid(), ossimSensorModel::theGSD, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimSensorModel::theRefImgPt, ossimString::toDouble(), ossimIpt::toPoint(), ossimDpt::toPoint(), ossimGpt::toPoint(), updateModel(), ossimIpt::x, and ossimIpt::y.
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Definition at line 290 of file ossimIpodSensor.cpp.
References ossimKeywordlist::add(), m_focalLength, m_pitch, m_pixelSize, m_platformPosition, m_principalPoint, m_roll, m_yaw, ossimSensorModel::saveState(), ossimSensorModel::theImageSize, ossimIpt::toString(), ossimDpt::toString(), ossimGpt::toString(), and ossimString::toString().
inline |
Definition at line 61 of file ossimIpodSensor.h.
inline |
Definition at line 75 of file ossimIpodSensor.h.
inline |
Definition at line 65 of file ossimIpodSensor.h.
inline |
Definition at line 71 of file ossimIpodSensor.h.
inline |
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 83 of file ossimIpodSensor.cpp.
References ossimSensorModel::computeGsd(), ossimAdjustableParameterInterface::computeParameterOffset(), ossim::cosd(), ossimMatrix3x3::create(), ossim::degreesToRadians(), ossimGpt::height(), ossimDrect::height(), ossimGpt::latd(), ossimSensorModel::lineSampleToWorld(), ossimDrect::ll(), ossimGpt::lond(), ossimDrect::lr(), m_adjustedPlatformPosition, m_air2Ned, m_ecef2Ned, m_ecef2NedInverse, m_focalLength, m_fovCrossTrack, m_fovIntrack, m_pitch, m_platformPositionEllipsoid, m_roll, m_yaw, ossimPolygon::resize(), ossim::sind(), ossimSensorModel::theBoundGndPolygon, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimDrect::ul(), ossimDrect::ur(), ossimDrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, ossimDpt::y, and y.
Referenced by loadState().
inlinevirtual |
useForward() return true when it's better (more accurate / fast) to use forward (from ground to image) than inverse(from image to ground)
Implements ossimOptimizableProjection.
Definition at line 79 of file ossimIpodSensor.h.
protected |
Definition at line 105 of file ossimIpodSensor.h.
Referenced by imagingRay(), and updateModel().
protected |
Definition at line 86 of file ossimIpodSensor.h.
protected |
Definition at line 90 of file ossimIpodSensor.h.
protected |
Definition at line 91 of file ossimIpodSensor.h.
protected |
Definition at line 87 of file ossimIpodSensor.h.
Referenced by updateModel().
protected |
Definition at line 88 of file ossimIpodSensor.h.
protected |
Definition at line 99 of file ossimIpodSensor.h.
protected |
Definition at line 98 of file ossimIpodSensor.h.
Referenced by imagingRay(), loadState(), saveState(), and updateModel().
protected |
Definition at line 103 of file ossimIpodSensor.h.
protected |
Definition at line 102 of file ossimIpodSensor.h.
protected |
Definition at line 94 of file ossimIpodSensor.h.
Referenced by loadState(), saveState(), and updateModel().
protected |
Definition at line 97 of file ossimIpodSensor.h.
Referenced by imagingRay(), loadState(), and saveState().
protected |
Definition at line 100 of file ossimIpodSensor.h.
Referenced by loadState(), and saveState().
protected |
Definition at line 101 of file ossimIpodSensor.h.
Referenced by loadState(), and updateModel().
protected |
Definition at line 96 of file ossimIpodSensor.h.
protected |
Definition at line 93 of file ossimIpodSensor.h.
protected |
Definition at line 95 of file ossimIpodSensor.h.
