#include <ossimPleiadesModel.h>
| ossimPleiadesModel () | |
| ossimPleiadesModel (const ossimPleiadesModel &rhs) | |
| copy constructor More... | |
| virtual | ~ossimPleiadesModel () |
| Destructor. More... | |
| bool | open (const ossimFilename &file) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| loadState Fulfills ossimObject base-class pure virtuals. More... | |
| void | setSupportData (ossimPleiadesDimapSupportData *supportData) |
| ossimPleiadesDimapSupportData * | getSupportData () |
| const ossimPleiadesDimapSupportData * | getSupportData () const |
Public Member Functions inherited from ossimRpcModel | |
| ossimRpcModel () | |
| ossimRpcModel (const ossimRpcModel ©_this) | |
| copy construtor More... | |
| void | setAttributes (ossim_float64 theSampleOffset, ossim_float64 theLineOffset, ossim_float64 theSampleScale, ossim_float64 theLineScale, ossim_float64 theLatOffset, ossim_float64 theLonOffset, ossim_float64 theHeightOffset, ossim_float64 theLatScale, ossim_float64 theLonScale, ossim_float64 theHeightScale, const std::vector< double > &xNumeratorCoeffs, const std::vector< double > &xDenominatorCoeffs, const std::vector< double > &yNumeratorCoeffs, const std::vector< double > &yDenominatorCoeffs, PolynomialType polyType=B, bool computeGsdFlag=true) |
| void | setMetersPerPixel (const ossimDpt &metersPerPixel) |
| void | setPositionError (const ossim_float64 &biasError, const ossim_float64 &randomError, bool initNominalPostionErrorFlag) |
| Sets data member theBiasError, theRandError. More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| worldToLineSample() Overrides base class implementation. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| imagingRay() Overrides base class pure virtual. More... | |
| virtual void | initAdjustableParameters () |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| uses file path to init model More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double h) |
| Compute partials of samp/line WRT ground point. More... | |
| double | getBiasError () const |
| Returns Error - Bias. More... | |
| double | getRandError () const |
| Returns Error - Random. More... | |
| void | getRpcParameters (ossimRpcModel::rpcModelStruct &model) const |
| Returns RPC parameter set in structure. More... | |
| void | setImageOffset (const ossimDpt &offset_to_chip_ul) |
| Allows setting an offset to a subimage while using the coefficients of a full-image model. More... | |
| bool | toJSON (std::ostream &json) const |
| Serializes RPC to JSON format. More... | |
| bool | toRPB (std::ostream &out) const |
| Serialize to WorldView-style .RPB file to the stream provided. More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| bool | parseMetaData (const ossimFilename &file) |
| bool | parseRpcData (const ossimFilename &file) |
| void | finishConstruction () |
| Collects common code among all parsers. More... | |
Protected Member Functions inherited from ossimRpcModel | |
| virtual | ~ossimRpcModel () |
| double | polynomial (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLat (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLon (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dHgt (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Public Types inherited from ossimRpcModel | |
| enum | PolynomialType { A ='A', B ='B' } |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimRpcModel | |
| static void | writeGeomTemplate (ostream &os) |
| STATIC METHOD: writeGeomTemplate(ostream) Writes a template of geom keywords processed by loadState and saveState to output stream. More... | |
Static Public Member Functions inherited from ossimSensorModel | |
Protected Types inherited from ossimRpcModel | |
| enum | AdjustParamIndex { INTRACK_OFFSET = 0, CRTRACK_OFFSET, INTRACK_SCALE, CRTRACK_SCALE, MAP_ROTATION, NUM_ADJUSTABLE_PARAMS } |
Definition at line 43 of file ossimPleiadesModel.h.
| ossimplugins::ossimPleiadesModel::ossimPleiadesModel | ( | ) |
default constructor
CONSTRUCTORS:
Definition at line 61 of file ossimPleiadesModel.cpp.
References ossimRpcModel::theLineDenCoef, ossimRpcModel::theLineNumCoef, ossimRpcModel::theSampDenCoef, and ossimRpcModel::theSampNumCoef.
Referenced by dup().
| ossimplugins::ossimPleiadesModel::ossimPleiadesModel | ( | const ossimPleiadesModel & | rhs | ) |
copy constructor
Definition at line 77 of file ossimPleiadesModel.cpp.
Destructor.
Definition at line 86 of file ossimPleiadesModel.cpp.
References ossimNotify(), ossimNotifyLevel_DEBUG, and theSupportData.
Returns pointer to a new instance, copy of this. Not implemented yet! Returns NULL...
Reimplemented from ossimRpcModel.
Definition at line 97 of file ossimPleiadesModel.cpp.
References ossimPleiadesModel().
protected |
Definition at line 355 of file ossimPleiadesModel.cpp.
References ossimSensorModel::computeGsd(), ossimDpt::hasNans(), ossimDrect::height(), ossimGpt::hgt, ossimGpt::lat, ossimIpt::line, ossimDpt::line, ossimRpcModel::lineSampleHeightToWorld(), ossimDrect::ll(), ossimGpt::lon, ossimDrect::lr(), ossimDrect::midPoint(), ossimNotify(), ossimNotifyLevel_WARN, ossimIpt::samp, ossimDpt::samp, ossimSensorModel::theBoundGndPolygon, ossimSensorModel::theGSD, ossimRpcModel::theHgtOffset, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimRpcModel::theLatOffset, ossimRpcModel::theLonOffset, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimDrect::ul(), ossimRpcModel::updateModel(), ossimDrect::ur(), ossimException::what(), ossimDrect::width(), ossimDpt::x, and ossimDpt::y.
Referenced by open().
inline |
Definition at line 85 of file ossimPleiadesModel.h.
inline |
Definition at line 89 of file ossimPleiadesModel.h.
Loads and saves geometry KWL files. Returns true if successful.
Definition at line 159 of file ossimPleiadesModel.cpp.
References ossimRpcModel::loadState(), and theSupportData.
| bool ossimplugins::ossimPleiadesModel::open | ( | const ossimFilename & | file | ) |
Definition at line 186 of file ossimPleiadesModel.cpp.
References _productXmlFile, ossimSupportFilesList::add(), ossimRpcModel::B, ossimErrorStatusInterface::clearErrorStatus(), ossimFilename::dirCat(), ossimString::downcase(), ossimFilename::exists(), ossimFilename::ext(), ossimFilename::file(), finishConstruction(), ossimSupportFilesList::instance(), ossimDpt::makeNan(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimNotifyLevel_WARN, ossimFilename::path(), ossimString::replaceStrThatMatch(), ossimFilename::setExtension(), ossimFilename::setFile(), ossimSensorModel::theGSD, ossimRpcModel::theHgtOffset, ossimRpcModel::theHgtScale, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageID, ossimSensorModel::theImageSize, ossimRpcModel::theLatOffset, ossimRpcModel::theLatScale, ossimRpcModel::theLineDenCoef, ossimRpcModel::theLineNumCoef, ossimRpcModel::theLineOffset, ossimRpcModel::theLineScale, ossimRpcModel::theLonOffset, ossimRpcModel::theLonScale, ossimRpcModel::thePolyType, ossimRpcModel::theSampDenCoef, ossimRpcModel::theSampNumCoef, ossimRpcModel::theSampOffset, ossimRpcModel::theSampScale, ossimSensorModel::theSensorID, and theSupportData.
protected |
protected |
Extends base-class implementation. Dumps contents of object to ostream.
Definition at line 105 of file ossimPleiadesModel.cpp.
References ossimRpcModel::print(), ossimSensorModel::theImageID, ossimSensorModel::theImageSize, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, and theSupportData.
Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files. Returns true if successful.
Definition at line 133 of file ossimPleiadesModel.cpp.
References ossimKeywordlist::add(), ossimRpcModel::saveState(), ossimSensorModel::theSensorID, and theSupportData.
inline |
Definition at line 81 of file ossimPleiadesModel.h.
protected |
Definition at line 107 of file ossimPleiadesModel.h.
protected |
Definition at line 105 of file ossimPleiadesModel.h.
Referenced by loadState(), open(), print(), saveState(), and ~ossimPleiadesModel().
