#include <ossimAlphaSensor.h>
| ossimAlphaSensor () | |
| ossimAlphaSensor (const ossimAlphaSensor &src) | |
| virtual void | lineSampToWorld (const ossimDpt &image_point, ossimGpt &worldPoint) const |
| virtual void | initAdjustableParameters () |
| void | setFov (const double fov) |
| void | setRollBias (const double rollBias) |
| void | setPitchBias (const double pitchBias) |
| void | setHeadingBias (const double headingBias) |
| void | setSlitRot (const double slitRot) |
| void | setRollPoly (const std::vector< ossim_float64 > rollPoly) |
| void | setPitchPoly (const std::vector< ossim_float64 > pitchPoly) |
| void | setHeadingPoly (const std::vector< ossim_float64 > headingPoly) |
| void | setLonPoly (const std::vector< ossim_float64 > lonPoly) |
| void | setLatPoly (const std::vector< ossim_float64 > latPoly) |
| void | setAltPoly (const std::vector< ossim_float64 > altPoly) |
| void | setScanPoly (const std::vector< ossim_float64 > scanPoly) |
| void | getPositionOrientation (const ossim_float64 &line, ossimEcefPoint &pos, NEWMAT::Matrix &cam2EcfRot) const |
| ossimEcefPoint | getCameraPosition (const ossim_float64 &line) const |
| NEWMAT::Matrix | getPlatform2LocalRot (const ossim_float64 &line) const |
| ossim_float64 | evalPoly (const std::vector< ossim_float64 > &polyCoef, const ossim_float64 &line) const |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| NEWMAT::Matrix | formHPRmat (const ossim_float64 &roll, const ossim_float64 &pitch, const ossim_float64 &heading) const |
| NEWMAT::Matrix | formLLAmat (const ossim_float64 &lat, const ossim_float64 &lon, const ossim_float64 &az) const |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimSensorModel | |
| static void | writeGeomTemplate (ostream &os) |
Definition at line 15 of file ossimAlphaSensor.h.
| ossimAlphaSensor::ossimAlphaSensor | ( | ) |
Definition at line 40 of file ossimAlphaSensor.cpp.
Referenced by dup().
| ossimAlphaSensor::ossimAlphaSensor | ( | const ossimAlphaSensor & | src | ) |
Definition at line 62 of file ossimAlphaSensor.cpp.
Implements ossimProjection.
Reimplemented in ossimAlphaSensorHRI, and ossimAlphaSensorHSI.
Definition at line 83 of file ossimAlphaSensor.cpp.
References ossimAlphaSensor().
| ossim_float64 ossimAlphaSensor::evalPoly | ( | const std::vector< ossim_float64 > & | polyCoef, |
| const ossim_float64 & | line | ||
| ) | const |
Definition at line 231 of file ossimAlphaSensor.cpp.
Referenced by getCameraPosition(), getPlatform2LocalRot(), and ossimAlphaSensorHSI::getScanAngle().
protected |
Definition at line 657 of file ossimAlphaSensor.cpp.
References ossimMatrix3x3::create().
Referenced by getPlatform2LocalRot().
protected |
| ossimEcefPoint ossimAlphaSensor::getCameraPosition | ( | const ossim_float64 & | line | ) | const |
Definition at line 195 of file ossimAlphaSensor.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), evalPoly(), ossimGpt::height(), ossimGpt::latd(), ossimGpt::lond(), m_altPoly, m_latPoly, m_lonPoly, ossimGpt::metersPerDegree(), PARAM_ADJ_ALTITUDE_OFFSET, PARAM_ADJ_LAT_OFFSET, PARAM_ADJ_LON_OFFSET, ossimDpt::x, and ossimDpt::y.
Referenced by getPositionOrientation().
| NEWMAT::Matrix ossimAlphaSensor::getPlatform2LocalRot | ( | const ossim_float64 & | line | ) | const |
Definition at line 218 of file ossimAlphaSensor.cpp.
References evalPoly(), formHPRmat(), m_headingPoly, m_pitchPoly, and m_rollPoly.
| void ossimAlphaSensor::getPositionOrientation | ( | const ossim_float64 & | line, |
| ossimEcefPoint & | pos, | ||
| NEWMAT::Matrix & | cam2EcfRot | ||
| ) | const |
Definition at line 177 of file ossimAlphaSensor.cpp.
References formLLAmat(), getCameraPosition(), getPlatform2LocalRot(), ossimGpt::latr(), ossimGpt::lonr(), and m_cam2Platform.
Referenced by ossimAlphaSensorHRI::imagingRay(), ossimAlphaSensorHSI::imagingRay(), ossimAlphaSensorHSI::worldToLineSample(), and ossimAlphaSensorHRI::worldToLineSample().
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 268 of file ossimAlphaSensor.cpp.
METHOD: lineSampleHeightToWorld This is the pure virtual that performs the actual work of projecting the image point to the given elevation above Ellipsoid.
Implements ossimSensorModel.
Definition at line 96 of file ossimAlphaSensor.cpp.
References ossimSensorModel::imagingRay(), and ossimEcefRay::intersectAboveEarthEllipsoid().
Definition at line 88 of file ossimAlphaSensor.cpp.
References ossimSensorModel::imagingRay(), ossimElevManager::instance(), and ossimElevSource::intersectRay().
Reimplemented from ossimSensorModel.
Definition at line 310 of file ossimAlphaSensor.cpp.
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files.
Definition at line 597 of file ossimAlphaSensor.cpp.
References ossimKeywordlist::add(), m_altPoly, m_fov, m_headingBias, m_headingPoly, m_latPoly, m_lonPoly, m_pitchBias, m_pitchPoly, m_rollBias, m_rollPoly, m_scanPoly, m_slitRot, ossimSensorModel::saveState(), ossimSensorModel::theImageSize, ossimIpt::toString(), and ossimString::toString().
Referenced by ossimAlphaSensorHRI::saveState(), and ossimAlphaSensorHSI::saveState().
| void ossimAlphaSensor::setAltPoly | ( | const std::vector< ossim_float64 > | altPoly | ) |
Definition at line 167 of file ossimAlphaSensor.cpp.
References m_altPoly.
Referenced by ossimAlphaSensorHRI::initialize(), and ossimAlphaSensorHSI::initialize().
| void ossimAlphaSensor::setFov | ( | const double | fov | ) |
Definition at line 116 of file ossimAlphaSensor.cpp.
References DEG_PER_RAD, m_focalLength, m_fov, ossimSensorModel::theImageSize, and ossimIpt::x.
| void ossimAlphaSensor::setHeadingBias | ( | const double | headingBias | ) |
Definition at line 132 of file ossimAlphaSensor.cpp.
References m_headingBias.
| void ossimAlphaSensor::setHeadingPoly | ( | const std::vector< ossim_float64 > | headingPoly | ) |
Definition at line 152 of file ossimAlphaSensor.cpp.
References m_headingPoly.
| void ossimAlphaSensor::setLatPoly | ( | const std::vector< ossim_float64 > | latPoly | ) |
Definition at line 162 of file ossimAlphaSensor.cpp.
References m_latPoly.
| void ossimAlphaSensor::setLonPoly | ( | const std::vector< ossim_float64 > | lonPoly | ) |
Definition at line 157 of file ossimAlphaSensor.cpp.
References m_lonPoly.
| void ossimAlphaSensor::setPitchBias | ( | const double | pitchBias | ) |
Definition at line 127 of file ossimAlphaSensor.cpp.
References m_pitchBias.
| void ossimAlphaSensor::setPitchPoly | ( | const std::vector< ossim_float64 > | pitchPoly | ) |
Definition at line 147 of file ossimAlphaSensor.cpp.
References m_pitchPoly.
| void ossimAlphaSensor::setRollBias | ( | const double | rollBias | ) |
Definition at line 122 of file ossimAlphaSensor.cpp.
References m_rollBias.
| void ossimAlphaSensor::setRollPoly | ( | const std::vector< ossim_float64 > | rollPoly | ) |
Definition at line 142 of file ossimAlphaSensor.cpp.
References m_rollPoly.
| void ossimAlphaSensor::setScanPoly | ( | const std::vector< ossim_float64 > | scanPoly | ) |
Definition at line 172 of file ossimAlphaSensor.cpp.
References m_scanPoly.
| void ossimAlphaSensor::setSlitRot | ( | const double | slitRot | ) |
Definition at line 137 of file ossimAlphaSensor.cpp.
References m_slitRot.
VIRTUAL METHOD: updateModel() Following a change to the adjustable parameter set, this virtual is called to permit instances to compute derived quantities after parameter change.
Definition at line 247 of file ossimAlphaSensor.cpp.
inlinevirtual |
useForward() return true when it's better (more accurate / fast) to use forward (from ground to image) than inverse(from image to ground)
Implements ossimOptimizableProjection.
Definition at line 34 of file ossimAlphaSensor.h.
protected |
Definition at line 93 of file ossimAlphaSensor.h.
protected |
Definition at line 87 of file ossimAlphaSensor.h.
Referenced by getCameraPosition(), saveState(), and setAltPoly().
protected |
Definition at line 91 of file ossimAlphaSensor.h.
protected |
Definition at line 80 of file ossimAlphaSensor.h.
Referenced by setFov().
protected |
Definition at line 77 of file ossimAlphaSensor.h.
Referenced by saveState(), and setFov().
protected |
Definition at line 76 of file ossimAlphaSensor.h.
Referenced by saveState(), and setHeadingBias().
protected |
Definition at line 84 of file ossimAlphaSensor.h.
Referenced by getPlatform2LocalRot(), saveState(), and setHeadingPoly().
protected |
Definition at line 86 of file ossimAlphaSensor.h.
Referenced by getCameraPosition(), saveState(), and setLatPoly().
protected |
Definition at line 85 of file ossimAlphaSensor.h.
Referenced by getCameraPosition(), saveState(), and setLonPoly().
protected |
Definition at line 75 of file ossimAlphaSensor.h.
Referenced by saveState(), and setPitchBias().
protected |
Definition at line 83 of file ossimAlphaSensor.h.
Referenced by getPlatform2LocalRot(), saveState(), and setPitchPoly().
protected |
Definition at line 74 of file ossimAlphaSensor.h.
Referenced by saveState(), and setRollBias().
protected |
Definition at line 82 of file ossimAlphaSensor.h.
Referenced by getPlatform2LocalRot(), saveState(), and setRollPoly().
protected |
Definition at line 88 of file ossimAlphaSensor.h.
Referenced by ossimAlphaSensorHSI::getScanAngle(), saveState(), and setScanPoly().
protected |
Definition at line 78 of file ossimAlphaSensor.h.
Referenced by saveState(), and setSlitRot().
