#include <ossimHdf5GridModel.h>
| ossimHdf5GridModel () | |
| default constructor. More... | |
| virtual | ~ossimHdf5GridModel () |
| bool | initialize (ossimHdf5 *hdf5, const ossimString &projDataPath="") |
| Initializes from an open HDF5 file. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix) const |
| Makes sure that the "type" keyword entry reflects the base class, not this one. More... | |
Public Member Functions inherited from ossimCoarseGridModel | |
| ossimCoarseGridModel () | |
| ossimCoarseGridModel (const ossimCoarseGridModel ©_this) | |
| ossimCoarseGridModel (const ossimFilename &geom_file) | |
| Accepts name of geometry file. More... | |
| ossimCoarseGridModel (const ossimKeywordlist &geom_kwl) | |
| Accepts OSSIM keywordlist geometry file. More... | |
| ~ossimCoarseGridModel () | |
| virtual void | buildGrid (const ossimDrect &imageBounds, ossimProjection *proj, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true) |
| This method will build a grid from any projector. More... | |
| virtual void | buildGrid (const ossimDrect &imageBounds, ossimImageGeometry *geom, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true) |
| Assigns the grid data given a geometry. More... | |
| Extends base-class implementation. More... | |
| Fulfills ossimObject base-class pure virtuals. More... | |
| Returns pointer to a new instance, copy of this. More... | |
| bool | saveCoarseGrid (const ossimFilename &cgFileName) const |
| Saves the coarse grid to the specified file. More... | |
| bool | loadCoarseGrid (const ossimFilename &cgFileName) |
| Loads the coarse grid from the specified file. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &world_pt) const |
| This is the virtual that performs the actual work of projecting the image point to the earth at some specified elevation. More... | |
| virtual void | initAdjustableParameters () |
| image to ground faster More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11) |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| bool | initCoarseGrid (const char *datasetName, ossimDblGrid &coarseGrid) |
| bool | crossesDateline () |
Protected Member Functions inherited from ossimCoarseGridModel | |
| void | reallocateGrid (const ossimIpt &size) |
| Deletes existing allocated memory and reallocates new space. More... | |
| void | initializeModelParams (ossimIrect irect) |
| Initializes base class data members after grids have been assigned. More... | |
| virtual ossimGpt | extrapolate (const ossimDpt &imgPt, const double &height=ossim::nan()) const |
| Implements its own extrapolation since this can be handled by ossimDblGrid. More... | |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Static Public Member Functions inherited from ossimCoarseGridModel | |
| static void | setInterpolationError (double error=.1) |
| This is used when building a grid from a projector. More... | |
| static void | setMinGridSpacing (ossim_int32 minSpacing=100) |
| static void | writeGeomTemplate (ostream &os) |
| Writes a template of geometry keywords processed by loadState and saveState to output stream. More... | |
Static Public Member Functions inherited from ossimSensorModel | |
Static Protected Attributes inherited from ossimCoarseGridModel | |
| static double | theInterpolationError = .1 |
| static ossim_int32 | theMinGridSpacing = 100 |
Definition at line 35 of file ossimHdf5GridModel.h.
| ossimHdf5GridModel::ossimHdf5GridModel | ( | ) |
Definition at line 44 of file ossimHdf5GridModel.cpp.
References ossimDblGrid::SAWTOOTH_90, ossimDblGrid::setDomainType(), and ossimCoarseGridModel::theLatGrid.
protected |
Definition at line 362 of file ossimHdf5GridModel.cpp.
References ossimDblGrid::getNode(), ossimDblGrid::setDomainType(), ossimDblGrid::size(), size, ossimCoarseGridModel::theLonGrid, ossimDblGrid::WRAP_180, ossimDblGrid::WRAP_360, x, and y.
Referenced by initialize().
protected |
Definition at line 98 of file ossimHdf5GridModel.cpp.
References ossimString::chars(), ossimHdf5::findDatasetByName(), ossimHdf5::findGroupByName(), m_hdf5, m_imageSize, m_projDataPath, ossimIpt::x, and ossimIpt::y.
| bool ossimHdf5GridModel::initialize | ( | ossimHdf5 * | hdf5, |
| const ossimString & | projDataPath = "" |
Definition at line 54 of file ossimHdf5GridModel.cpp.
References crossesDateline(), initCoarseGrid(), ossimDblGrid::initialize(), ossimCoarseGridModel::initializeModelParams(), m_hdf5, m_imageSize, m_projDataPath, ossimDblGrid::maxValue(), ossimDblGrid::minValue(), ossimDblGrid::origin(), ossimNotify(), ossimNotifyLevel_FATAL, ossimDblGrid::size(), ossimDblGrid::spacing(), ossimCoarseGridModel::theDlatDhGrid, ossimCoarseGridModel::theDlonDhGrid, ossimCoarseGridModel::theHeightEnabledFlag, ossimSensorModel::theImageSize, ossimCoarseGridModel::theLatGrid, ossimCoarseGridModel::theLonGrid, ossimSensorModel::theSeedFunction, ossimIpt::u, ossimIpt::v, ossimIpt::x, x, and ossimIpt::y.
Referenced by ossimHdf5ProjectionFactory::createProjection(), and ossimViirsHandler::getImageGeometry().
Reimplemented from ossimCoarseGridModel.
Definition at line 442 of file ossimHdf5GridModel.cpp.
References ossimKeywordlist::add(), ossimCoarseGridModel::saveState(), and ossimKeywordNames::TYPE_KW.
protected |
Definition at line 60 of file ossimHdf5GridModel.h.
protected |
Definition at line 62 of file ossimHdf5GridModel.h.
Referenced by initCoarseGrid(), and initialize().
protected |
Definition at line 63 of file ossimHdf5GridModel.h.
protected |
Definition at line 64 of file ossimHdf5GridModel.h.
