#include <ossimIkonosRpcModel.h>
| ossimIkonosRpcModel () | |
| ossimIkonosRpcModel (const ossimFilename &geom_file) | |
| ossimIkonosRpcModel (const ossimFilename &metadata, const ossimFilename &rpcdata) | |
| saveState Fulfills ossimObject base-class pure virtuals. More... | |
| loadState Fulfills ossimObject base-class pure virtuals. More... | |
| virtual bool | parseFile (const ossimFilename &file) |
Public Member Functions inherited from ossimRpcModel | |
| ossimRpcModel () | |
| ossimRpcModel (const ossimRpcModel ©_this) | |
| copy construtor More... | |
| void | setAttributes (ossim_float64 theSampleOffset, ossim_float64 theLineOffset, ossim_float64 theSampleScale, ossim_float64 theLineScale, ossim_float64 theLatOffset, ossim_float64 theLonOffset, ossim_float64 theHeightOffset, ossim_float64 theLatScale, ossim_float64 theLonScale, ossim_float64 theHeightScale, const std::vector< double > &xNumeratorCoeffs, const std::vector< double > &xDenominatorCoeffs, const std::vector< double > &yNumeratorCoeffs, const std::vector< double > &yDenominatorCoeffs, PolynomialType polyType=B, bool computeGsdFlag=true) |
| void | setMetersPerPixel (const ossimDpt &metersPerPixel) |
| void | setPositionError (const ossim_float64 &biasError, const ossim_float64 &randomError, bool initNominalPostionErrorFlag) |
| Sets data member theBiasError, theRandError. More... | |
| virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
| worldToLineSample() Overrides base class implementation. More... | |
| print() Extends base-class implementation. More... | |
| virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
| imagingRay() Overrides base class pure virtual. More... | |
| virtual void | initAdjustableParameters () |
| dup() Returns pointer to a new instance, copy of this. More... | |
| virtual bool | setupOptimizer (const ossimString &init_file) |
| uses file path to init model More... | |
| virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double h) |
| Compute partials of samp/line WRT ground point. More... | |
| double | getBiasError () const |
| Returns Error - Bias. More... | |
| double | getRandError () const |
| Returns Error - Random. More... | |
| void | getRpcParameters (ossimRpcModel::rpcModelStruct &model) const |
| Returns RPC parameter set in structure. More... | |
| void | setImageOffset (const ossimDpt &offset_to_chip_ul) |
| Allows setting an offset to a subimage while using the coefficients of a full-image model. More... | |
| bool | toJSON (std::ostream &json) const |
| Serializes RPC to JSON format. More... | |
| bool | toRPB (std::ostream &out) const |
| Serialize to WorldView-style .RPB file to the stream provided. More... | |
Public Member Functions inherited from ossimSensorModel | |
| ossimSensorModel () | |
| ossimSensorModel (const ossimSensorModel ©_this) | |
| ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
| assignment operator More... | |
| Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
| Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
| Assigns the absolute image position error uncertainty (abs CE90) More... | |
| Assigns the relative image position error uncertainty (rel CE90) More... | |
| Sets the center line sampe of the image. More... | |
| Sets the center latitude, longitude, height of the image. More... | |
| Access methods: More... | |
| needsInitialState() More... | |
| Gives 2X2 covariance matrix of observations. More... | |
| void | computeGsd () |
| This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
| Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Public Member Functions inherited from ossimOptimizableProjection | |
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
Public Member Functions inherited from ossimAdjustableParameterInterface | |
| ossimAdjustableParameterInterface () | |
| ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
| Returns adjustmentDescription of specific adjustmentInfo. More... | |
| Sets the current adjustment to the adjustment with a matching description. More... | |
| Saves the current active adjustment to the KWL file. More... | |
| Save all adjustments to the KWL file. More... | |
| Dumps the currently active adjustment to ostream. More... | |
| static void | writeGeomTemplate (ostream &os) |
Static Public Member Functions inherited from ossimRpcModel | |
| STATIC METHOD: writeGeomTemplate(ostream) Writes a template of geom keywords processed by loadState and saveState to output stream. More... | |
Static Public Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimIkonosRpcModel () |
| void | finishConstruction () |
| void | parseMetaData (const ossimFilename &metadata) |
| void | parseRpcData (const ossimFilename &rpcdata) |
| bool | isNitf (const ossimFilename &filename) |
| bool | parseTiffFile (const ossimFilename &filename) |
| bool | parseHdrData (const ossimFilename &data_file) |
Protected Member Functions inherited from ossimRpcModel | |
| virtual | ~ossimRpcModel () |
| double | polynomial (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLat (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dLon (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
| double | dPoly_dHgt (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
Protected Member Functions inherited from ossimSensorModel | |
| virtual | ~ossimSensorModel () |
| virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
| virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
| void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
| NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
| NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
| stable invert stolen from ossimRpcSolver More... | |
Protected Member Functions inherited from ossimAdjustableParameterInterface | |
| bool | paramChanged (ossim_uint32 param_idx) const |
| Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
| void | setAllChangeFlags (bool areChanged) |
| Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
| void | initChangeFlags () |
| Initializes the change flags to TRUE. More... | |
Public Types inherited from ossimRpcModel | |
| enum | PolynomialType { A ='A', B ='B' } |
Public Types inherited from ossimSensorModel | |
| enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
Protected Types inherited from ossimRpcModel | |
| enum | AdjustParamIndex { INTRACK_OFFSET = 0, CRTRACK_OFFSET, INTRACK_SCALE, CRTRACK_SCALE, MAP_ROTATION, NUM_ADJUSTABLE_PARAMS } |
| ossimIkonosRpcModel::ossimIkonosRpcModel | ( | ) |
Definition at line 57 of file ossimIkonosRpcModel.cpp.
| ossimIkonosRpcModel::ossimIkonosRpcModel | ( | const ossimFilename & | geom_file | ) |
Definition at line 70 of file ossimIkonosRpcModel.cpp.
| ossimIkonosRpcModel::ossimIkonosRpcModel | ( | const ossimFilename & | metadata, |
| const ossimFilename & | rpcdata | ||
Definition at line 164 of file ossimIkonosRpcModel.cpp.
protectedvirtual |
Definition at line 200 of file ossimIkonosRpcModel.cpp.
References theSupportData.
protected |
Definition at line 209 of file ossimIkonosRpcModel.cpp.
protected |
Definition at line 970 of file ossimIkonosRpcModel.cpp.
References ossimString::c_str().
Loads and saves geometry KWL files. Returns true if successful.
Reimplemented from ossimRpcModel.
Definition at line 868 of file ossimIkonosRpcModel.cpp.
References ossimIkonosMetaData::loadState(), ossimRpcModel::loadState(), theSupportData, and ossimRefPtr< T >::valid().
Definition at line 880 of file ossimIkonosRpcModel.cpp.
References parseTiffFile().
protected |
Definition at line 454 of file ossimIkonosRpcModel.cpp.
protected |
Definition at line 290 of file ossimIkonosRpcModel.cpp.
protected |
Definition at line 593 of file ossimIkonosRpcModel.cpp.
protected |
Definition at line 885 of file ossimIkonosRpcModel.cpp.
References ossimIkonosMetaData::open(), ossimTiffTileSource::open(), and theSupportData.
Referenced by parseFile().
Definition at line 842 of file ossimIkonosRpcModel.cpp.
References ossimIkonosMetaData::saveState(), ossimRpcModel::saveState(), theSupportData, and ossimRefPtr< T >::valid().
static |
STATIC METHOD: writeGeomTemplate(ostream) Writes a template of an ossimIkonosRpcModel geometry file.
Definition at line 820 of file ossimIkonosRpcModel.cpp.
protected |
Definition at line 71 of file ossimIkonosRpcModel.h.
Referenced by loadState(), parseTiffFile(), saveState(), and ~ossimIkonosRpcModel().
