virtual class enabling projection optimization (can be used for outlier rejection - RANSAC) More...
#include <ossimOptimizableProjection.h>
| ossimOptimizableProjection () | |
| ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
| virtual bool | setupOptimizer (const ossimString &setup) |
| setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More... | |
| virtual bool | useForward () const =0 |
| virtual ossim_uint32 | degreesOfFreedom () const =0 |
| needsInitialState() More... | |
| virtual double | optimizeFit (const ossimTieGptSet &tieSet, double *targetVariance=0)=0 |
Definition at line 20 of file ossimOptimizableProjection.h.
| ossimOptimizableProjection::ossimOptimizableProjection | ( | ) |
| ossimOptimizableProjection::ossimOptimizableProjection | ( | const ossimOptimizableProjection & | source | ) |
Definition at line 8 of file ossimOptimizableProjection.cpp.
Definition at line 14 of file ossimOptimizableProjection.cpp.
pure virtual |
degreesOfFreedom() number of degrees of freedom (eg: 8 for bilinear, 6 for affine, 2 for translation) especially useful when not inheriting from AdjustableParameterInterface
Implemented in ossimSensorModel, ossimRpcProjection, ossimBilinearProjection, and ossimPolynomProjection.
Reimplemented in ossimSensorModel.
Definition at line 33 of file ossimOptimizableProjection.cpp.
Definition at line 17 of file ossimOptimizableProjection.cpp.
Referenced by ossimRpcProjection::operator=(), and ossimSensorModel::operator=().
pure virtual |
optimizeFit() adjusts projection to GLOBALLY fit best to ALL tie points (no outlier rejection) can select an optional threshold for accuracy
RETURNS : resulting image error variance of fitted model, or negative value for error
IMPORTANT : the unit for *targetVariance and the returned value is : meters^2 when useForward() is true OR pixel^2 if useForward() is false
Reimplemented in ossimRpcModel, ossimLandSatModel, ossimRpcProjection, ossimplugins::ossimFormosatModel, ossimSpot5Model, ossimApplanixEcefModel, ossimBilinearProjection, ossimSpectraboticsRedEdgeModel, ossimPolynomProjection, and ossimApplanixUtmModel.
Definition at line 27 of file ossimOptimizableProjection.cpp.
pure virtual |
useForward() return true when it's better (more accurate / fast) to use forward (from ground to image) than inverse(from image to ground)
Implemented in ossimFcsiModel, ossimRpcModel, ossimplugins::ossimGeometricSarSensorModel, ossimSarModel, ossimRpcProjection, ossimLandSatModel, ossimAdjMapModel, ossimSonomaSensor, ossimplugins::ossimTileMapModel, ossimCoarseGridModel, ossimplugins::ossimFormosatModel, ossimSpot5Model, ossimRS1SarModel, ossimSkyBoxLearSensor, ossimApplanixEcefModel, ossimBilinearProjection, ossimIpodSensor, ossimSpectraboticsRedEdgeModel, ossimNitfMapModel, ossimRsmModel, ossimPolynomProjection, ossimApplanixUtmModel, ossimPpjFrameSensor, and ossimAlphaSensor.
Referenced by ossimSensorModel::buildNormalEquation(), and ossimSensorModel::getResidue().
