Pure virtual base class for image file writers. More...
#include <ossimImageFileWriter.h>
| ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
| The writer will own the sequencer. More... | |
| virtual | ~ossimImageFileWriter () |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const =0 |
| void getImageTypeList(std::vector<ossimString>& imageTypeList)const More... | |
| virtual ossimString | getExtension () const |
| Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
| virtual bool | getOutputHasInternalOverviews (void) const |
| Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
| virtual bool | hasImageType (const ossimString &imageType) const |
| bool hasImageType(const ossimString& imageType) const More... | |
| virtual void | setTileSize (const ossimIpt &tileSize) |
| Sets the output image tiling size if supported by the writer. More... | |
| virtual bool | writeEnviHeaderFile () |
| Will write an envi header file. More... | |
| virtual bool | writeErsHeaderFile () |
| Will write an ER Mapper header file. More... | |
| virtual bool | writeExternalGeometryFile () |
| Will write an external geometry file. More... | |
| virtual bool | writeFgdcFile () |
| Will write an fgdc file. More... | |
| virtual bool | writeHistogramFile () |
| Returns true on success, false on error. More... | |
| virtual bool | writeJpegWorldFile () |
| Will write a jpeg world file. More... | |
| virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
| Write out an ossim overview file from the source_file. More... | |
| virtual bool | writeReadmeFile () |
| Will write a readme file. More... | |
| virtual bool | writeTiffWorldFile () |
| Will write a world file. More... | |
| virtual bool | writeWorldFile () |
| virtual bool | writeMetaDataFiles () |
| Convenience method that calls meta data write methods that are flagged to be called. More... | |
| virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
| virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
| Sets the sequencer and connects it to the input of this. More... | |
| virtual ossimImageSourceSequencer * | getSequencer () |
| Initialize method. More... | |
| virtual bool | execute () |
| Calls: writeFile() writeMetaDataFiles() More... | |
| virtual bool | writeStream () |
| Method to write the image to a stream. More... | |
| virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
| Sets the output stream to write to. More... | |
| virtual bool | setOutputStream (std::ostream &str) |
| tmp drb More... | |
| virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
| Method to return the stream attached to output. More... | |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setOutputImageType (ossim_int32 type) |
| virtual void | setOutputImageType (const ossimString &type) |
| virtual ossim_int32 | getOutputImageType () const |
| virtual ossimString | getOutputImageTypeString () const |
| virtual void | setOutputName (const ossimString &outputName) |
| virtual void | setFilename (const ossimFilename &file) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | getWriteImageFlag () const |
| Control flags... More... | |
| virtual bool | getWriteHistogramFlag () const |
| virtual bool | getWriteOverviewFlag () const |
| virtual bool | getScaleToEightBitFlag () const |
| virtual bool | getWriteEnviHeaderFlag () const |
| virtual bool | getWriteErsHeaderFlag () const |
| virtual bool | getWriteExternalGeometryFlag () const |
| virtual bool | getWriteFgdcFlag () const |
| virtual bool | getWriteJpegWorldFileFlag () const |
| virtual bool | getWriteReadmeFlag () const |
| virtual bool | getWriteTiffWorldFileFlag () const |
| virtual bool | getWriteWorldFileFlag () const |
| virtual void | setWriteImageFlag (bool flag) |
| virtual void | setWriteOverviewFlag (bool flag) |
| virtual void | setWriteHistogramFlag (bool flag) |
| virtual void | setScaleToEightBitFlag (bool flag) |
| virtual void | setWriteEnviHeaderFlag (bool flag) |
| virtual void | setWriteErsHeaderFlag (bool flag) |
| virtual void | setWriteExternalGeometryFlag (bool flag) |
| virtual void | setWriteFgdcFlag (bool flag) |
| virtual void | setWriteJpegWorldFile (bool flag) |
| virtual void | setWriteReadme (bool flag) |
| virtual void | setWriteTiffWorldFile (bool flag) |
| virtual void | setWriteWorldFile (bool flag) |
| virtual ossim_uint16 | getOverviewCompressType () const |
| virtual ossim_int32 | getOverviewJpegCompressQuality () const |
| virtual void | setOverviewCompressType (ossim_uint16 type) |
| virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
| Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
| Overrides base "removeListener". More... | |
| virtual void | setPixelType (ossimPixelType type) |
| If "point" the coordinate tie points are relative to the center of the pixel. More... | |
| virtual void | setPixelType (const ossimString &type) |
| virtual ossimPixelType | getPixelType () const |
| virtual void | getPixelTypeString (ossimString &type) const |
Public Member Functions inherited from ossimImageWriter | |
| ossimImageWriter (ossimObject *owner=NULL) | |
| ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
| virtual | ~ossimImageWriter () |
| virtual bool | setViewingRect (const ossimIrect &aRect) |
| virtual ossimIrect | getAreaOfInterest () const |
Public Member Functions inherited from ossimOutputSource | |
| ossimOutputSource (ossimObject *owner=NULL) | |
| ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
| virtual | ~ossimOutputSource () |
| virtual bool | isOpen () const =0 |
| virtual bool | open ()=0 |
| virtual bool | open (const ossimString &outputName) |
| virtual const ossimString & | getOutputName () |
| virtual void | close ()=0 |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| bool | writeWorldFile (const ossimFilename &file) |
| Common world file writer method. More... | |
| virtual bool | writeFile ()=0 |
| Write out the file. More... | |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
There is normally one subclass of this class for each format supported for writing. This class roughly corresponds to the ImageHandler class used for reading images. Format specific ossimImageWriter's are normally instantiated by the ossimImageWriterFactory::createWriterInstance() method. ossimImageWriters should not be directly instantiated by application code.
Definition at line 34 of file ossimImageFileWriter.h.
| ossimImageFileWriter::ossimImageFileWriter | ( | const ossimFilename & | filename = ossimFilename(), |
| ossimImageSource * | inputSource = 0, |
| ossimObject * | owner = 0 |
Definition at line 65 of file ossimImageFileWriter.cpp.
Definition at line 122 of file ossimImageFileWriter.cpp.
References removeListener(), theInputConnection, and theProgressListener.
If overview building is enabled, the listener will be passed to the overview builder::addListener, and subsequently removed from the overview builder after the build overview call is complete. This it transparent to the caller of this method.
| listener | The listener to add. |
Reimplemented from ossimListenerManager.
Definition at line 1523 of file ossimImageFileWriter.cpp.
References ossimListenerManager::addListener(), and theProgressListener.
Referenced by ossimChipProcTool::execute(), main(), and ossimIgen::writeToFile().
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 1227 of file ossimImageFileWriter.cpp.
References PTR_CAST.
This does not set the area of interest. Note stored as an ossimRefPtr.
| sequencer | Pointer to a sequencer. |
Definition at line 160 of file ossimImageFileWriter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::getInput(), and theInputConnection.
Referenced by ossimIgen::outputProduct().
Reimplemented from ossimConnectableObjectListener.
Definition at line 824 of file ossimImageFileWriter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::getInput(), initialize(), PTR_CAST, theInputConnection, and theViewController.
Definition at line 813 of file ossimImageFileWriter.cpp.
References ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), initialize(), PTR_CAST, theInputConnection, and theViewController.
Implements ossimProcessInterface.
Definition at line 1016 of file ossimImageFileWriter.cpp.
References theInputConnection.
Referenced by ossimDemTool::doOMG(), ossimPointCloudTool::execute(), ossimChipProcTool::execute(), ossimKmlSuperOverlayWriter::generateTile(), main(), ATP::AtpAnnotatedImage::write(), writeRaster(), and ossimHlzTool::writeSlopeImage().
| imageType | string representing image type. |
Reimplemented in ossimTiffWriter, ossimKakaduNitfWriter, ossimNitfWriterBase, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimKakaduJp2Writer, ossimJpegWriter, ossimGpkgWriter, ossimPdfWriter, ossimWriter, ossimArcInfoGridWriter, ossimGeneralRasterWriter, ossimGdalWriter, and ossimPngWriter.
Definition at line 1491 of file ossimImageFileWriter.cpp.
Definition at line 1222 of file ossimImageFileWriter.cpp.
References theFilename.
pure virtual |
pure virtual
Appends the writers image types to the "imageTypeList".
This is the actual image type name. So for example, ossimTiffWriter has several image types. Some of these include TIFF_TILED, TIFF_TILED_BAND_SEPARATE ... etc. The ossimGdalWriter may include GDAL_IMAGINE_HFA, GDAL_RGB_NITF, GDAL_JPEG20000, ... etc.
| imageTypeList | stl::vector<ossimString> list to append to. |
Implemented in ossimGpkgWriter, ossimPdfWriter, ossimWriter, ossimPngWriter, ossimTiffWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimNitfWriter, ossimKakaduNitfWriter, ossimNitf20Writer, ossimKakaduJp2Writer, ossimGeneralRasterWriter, ossimGdalWriter, and ossimJpegWriter.
Referenced by ossimImageWriterFactory::getImageTypeList(), ossimKmlSuperOverlayWriterFactory::getImageTypeList(), getProperty(), hasImageType(), and ossimImageWriterFactoryRegistry::printWriterProps().
Definition at line 982 of file ossimImageFileWriter.cpp.
Definition at line 987 of file ossimImageFileWriter.cpp.
Reimplemented in ossimKakaduNitfWriter, ossimOpjJp2Writer, and ossimKakaduJp2Writer.
Definition at line 1497 of file ossimImageFileWriter.cpp.
Definition at line 855 of file ossimImageFileWriter.cpp.
References ossimLookUpTable::getEntryNumber(), and theOutputImageType.
Definition at line 849 of file ossimImageFileWriter.cpp.
References theOutputImageType.
This implementation in this class does nothing and returns an empty ossimRefPtr<ossimOStream>. Derived classed should implement as needed.
Definition at line 1175 of file ossimImageFileWriter.cpp.
Definition at line 1235 of file ossimImageFileWriter.cpp.
References theOverviewCompressType.
Definition at line 1240 of file ossimImageFileWriter.cpp.
References theOverviewJpegCompressQuality.
Definition at line 1557 of file ossimImageFileWriter.cpp.
References thePixelType.
Referenced by ossimKakaduJp2Writer::writeGeotiffBox().
| type | ossimString to initialize which will either be "point" or "area". |
Definition at line 1562 of file ossimImageFileWriter.cpp.
References OSSIM_PIXEL_IS_POINT, and thePixelType.
Reimplemented in ossimWriter, ossimPdfWriter, ossimTiffWriter, ossimGpkgWriter, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimJpegWriter, ossimGdalWriter, ossimNitfWriterBase, ossimNitfWriter, and ossimNitf20Writer.
Definition at line 1343 of file ossimImageFileWriter.cpp.
References ossimKeywordNames::FILENAME_KW, getImageTypeList(), ossimKeywordNames::IMAGE_TYPE_KW, ossimFilenameProperty::ossimFilenamePropertyIoType_OUTPUT, ossimProperty::ossimPropertyChangeType_AFFECTS_OTHERS, ossimProperty::setChangeType(), ossimStringProperty::setConstraints(), ossimFilenameProperty::setIoType(), ossimProperty::setReadOnlyFlag(), theFilename, and theOutputImageType.
Referenced by ossimNitf20Writer::getProperty(), ossimJpegWriter::getProperty(), ossimKakaduJp2Writer::getProperty(), ossimKmlSuperOverlayWriter::getProperty(), ossimGpkgWriter::getProperty(), ossimTiffWriter::getProperty(), ossimPdfWriter::getProperty(), and ossimImageWriterFactoryRegistry::printWriterProps().
Definition at line 1468 of file ossimImageFileWriter.cpp.
References ossimKeywordNames::CREATE_EXTERNAL_GEOMETRY_KW, ossimKeywordNames::CREATE_HISTOGRAM_KW, ossimKeywordNames::CREATE_IMAGE_KW, ossimKeywordNames::CREATE_OVERVIEW_KW, ossimKeywordNames::FILENAME_KW, and ossimSource::getPropertyNames().
Referenced by ossimNitf20Writer::getPropertyNames(), ossimNitfWriterBase::getPropertyNames(), ossimJpegWriter::getPropertyNames(), ossimKakaduJp2Writer::getPropertyNames(), ossimKmlSuperOverlayWriter::getPropertyNames(), ossimTiffWriter::getPropertyNames(), ossimPdfWriter::getPropertyNames(), and ossimImageWriterFactoryRegistry::printWriterProps().
Definition at line 877 of file ossimImageFileWriter.cpp.
References theScaleToEightBitFlag.
Definition at line 1011 of file ossimImageFileWriter.cpp.
References ossimRefPtr< T >::get(), and theInputConnection.
Referenced by ossimGeneralRasterWriter::writeFile().
Definition at line 882 of file ossimImageFileWriter.cpp.
References theWriteEnviHeaderFlag.
Definition at line 887 of file ossimImageFileWriter.cpp.
References theWriteErsHeaderFlag.
Definition at line 892 of file ossimImageFileWriter.cpp.
References theWriteExternalGeometryFlag.
Definition at line 867 of file ossimImageFileWriter.cpp.
References theWriteHistogramFlag.
Control flags...
Definition at line 862 of file ossimImageFileWriter.cpp.
References theWriteImageFlag.
Definition at line 902 of file ossimImageFileWriter.cpp.
References theWriteJpegWorldFileFlag.
Definition at line 872 of file ossimImageFileWriter.cpp.
References theWriteOverviewFlag.
Definition at line 907 of file ossimImageFileWriter.cpp.
References theWriteReadmeFlag.
Definition at line 912 of file ossimImageFileWriter.cpp.
References theWriteTiffWorldFileFlag.
Definition at line 917 of file ossimImageFileWriter.cpp.
References theWriteWorldFileFlag.
Reimplemented in ossimTiffWriter, ossimPdfWriter, ossimOpjJp2Writer, ossimGpkgWriter, ossimKmlSuperOverlayWriter, ossimKakaduJp2Writer, ossimPngWriter, ossimJpegWriter, ossimKakaduNitfWriter, ossimWriter, and ossimGdalWriter.
Definition at line 1504 of file ossimImageFileWriter.cpp.
References getImageTypeList().
Referenced by ossimGdalImageWriterFactory::createWriter(), ossimImageWriterFactory::createWriter(), ossimSqliteWriterFactory::createWriter(), ossimPngWriterFactory::createWriter(), ossimOpjWriterFactory::createWriter(), ossimKakaduWriterFactory::createWriter(), ossimGdalWriter::hasImageType(), ossimJpegWriter::hasImageType(), and ossimTiffWriter::hasImageType().
Initialize method.
Calls theInputConnection->initialize() then syncs area of interest(AOI) with ossimImageWriter::theAreaOfInterest taking precedence over ossimImageSourceSequencer::theAreaOfInterest.
Definition at line 129 of file ossimImageFileWriter.cpp.
References ossimImageSourceSequencer::getBoundingRect(), ossimIrect::hasNans(), ossimImageSourceSequencer::initialize(), ossimImageSourceSequencer::setAreaOfInterest(), ossimImageWriter::theAreaOfInterest, theInputConnection, and ossimRefPtr< T >::valid().
Referenced by connectInputEvent(), disconnectInputEvent(), ossimIgen::outputProduct(), propertyEvent(), and ATP::AtpAnnotatedImage::write().
Reimplemented from ossimImageWriter.
Reimplemented in ossimWriter, ossimPdfWriter, ossimTiffWriter, ossimNitfWriterBase, ossimGpkgWriter, ossimNitfWriter, ossimNitf20Writer, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimGeneralRasterWriter, ossimGdalWriter, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimJpegWriter, and ossimArcInfoGridWriter.
Definition at line 288 of file ossimImageFileWriter.cpp.
References ossimKeywordNames::CREATE_EXTERNAL_GEOMETRY_KW, ossimKeywordNames::CREATE_HISTOGRAM_KW, ossimKeywordNames::CREATE_IMAGE_KW, ossimKeywordNames::CREATE_OVERVIEW_KW, ossimKeywordNames::FILENAME_KW, ossimKeywordNames::FILEPATH_KW, ossimKeywordlist::find(), ossimUnitTypeLut::instance(), ossimSource::loadState(), OSSIM_FEET, OSSIM_METERS, OSSIM_PIXEL_IS_AREA, OSSIM_PIXEL_IS_POINT, OSSIM_US_SURVEY_FEET, ossimKeywordNames::PIXEL_TYPE_KW, setFilename(), theLinearUnits, thePixelType, theScaleToEightBitFlag, theWriteEnviHeaderFlag, theWriteErsHeaderFlag, theWriteExternalGeometryFlag, theWriteFgdcFlag, theWriteHistogramFlag, theWriteImageFlag, theWriteJpegWorldFileFlag, theWriteOverviewFlag, theWriteReadmeFlag, theWriteTiffWorldFileFlag, theWriteWorldFileFlag, and ossimString::toBool().
Referenced by ossimGdalImageWriterFactory::createWriter(), ossimImageWriterFactory::createWriter(), ossimSqliteWriterFactory::createWriter(), ossimOpjWriterFactory::createWriter(), ossimPngWriterFactory::createWriter(), ossimKakaduWriterFactory::createWriter(), ossimKmlSuperOverlayWriterFactory::createWriter(), ossimArcInfoGridWriter::loadState(), ossimJpegWriter::loadState(), ossimKakaduJp2Writer::loadState(), ossimGdalWriter::loadState(), ossimGeneralRasterWriter::loadState(), ossimKmlSuperOverlayWriter::loadState(), ossimGpkgWriter::loadState(), ossimPdfWriter::loadState(), and ossimWriter::loadState().
Definition at line 833 of file ossimImageFileWriter.cpp.
References initialize().
Calls base "removeListener which will find and removes the listener. If "theProgressListener" pointer matches listener "theProgressListener" will be set to NULL.
| listener | The listener to remove. |
Definition at line 1529 of file ossimImageFileWriter.cpp.
References ossimListenerManager::removeListener(), and theProgressListener.
Referenced by ossimChipProcTool::execute(), main(), and ~ossimImageFileWriter().
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Reimplemented in ossimWriter, ossimPdfWriter, ossimTiffWriter, ossimGpkgWriter, ossimNitfWriterBase, ossimNitfWriter, ossimNitf20Writer, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimGeneralRasterWriter, ossimGdalWriter, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimJpegWriter, and ossimArcInfoGridWriter.
Definition at line 169 of file ossimImageFileWriter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordNames::CREATE_EXTERNAL_GEOMETRY_KW, ossimKeywordNames::CREATE_HISTOGRAM_KW, ossimKeywordNames::CREATE_IMAGE_KW, ossimKeywordNames::CREATE_OVERVIEW_KW, ossimKeywordNames::FILENAME_KW, ossimObject::getClassName(), theFilename, theScaleToEightBitFlag, theWriteEnviHeaderFlag, theWriteErsHeaderFlag, theWriteExternalGeometryFlag, theWriteFgdcFlag, theWriteHistogramFlag, theWriteImageFlag, theWriteJpegWorldFileFlag, theWriteOverviewFlag, theWriteReadmeFlag, theWriteTiffWorldFileFlag, theWriteWorldFileFlag, and ossimKeywordNames::TYPE_KW.
Referenced by ossimArcInfoGridWriter::saveState(), ossimJpegWriter::saveState(), ossimKakaduJp2Writer::saveState(), ossimGeneralRasterWriter::saveState(), ossimKmlSuperOverlayWriter::saveState(), ossimGpkgWriter::saveState(), ossimPdfWriter::saveState(), and ossimWriter::saveState().
Definition at line 992 of file ossimImageFileWriter.cpp.
References ossimImageSourceSequencer::getBoundingRect(), ossimImageWriter::setAreaOfInterest(), ossimImageSourceSequencer::setAreaOfInterest(), ossimImageWriter::theAreaOfInterest, theInputConnection, and ossimRefPtr< T >::valid().
Referenced by ossimChipProcTool::execute(), ossimKmlSuperOverlayWriter::generateTile(), ossimIgen::outputProduct(), ATP::AtpAnnotatedImage::write(), and ossimHlzTool::writeSlopeImage().
Definition at line 1217 of file ossimImageFileWriter.cpp.
Referenced by ossimImageWriterFactoryRegistry::createWriter(), ossimKmlSuperOverlayWriter::generateTile(), ossimGeneralRasterWriter::loadState(), loadState(), main(), ossimIgen::outputProduct(), setOutputName(), ATP::AtpAnnotatedImage::write(), writeRaster(), and ossimHlzTool::writeSlopeImage().
Definition at line 843 of file ossimImageFileWriter.cpp.
References ossimLookUpTable::getEntryString(), and theOutputImageType.
Referenced by ossimImageWriterFactory::createFromMimeType(), ossimImageWriterFactory::createWriter(), ossimImageWriterFactory::createWriterFromExtension(), ossimGeneralRasterWriter::ossimGeneralRasterWriter(), ossimKmlSuperOverlayWriter::ossimKmlSuperOverlayWriter(), and ossimGdalWriter::setOutputImageType().
Reimplemented in ossimGdalWriter.
Definition at line 838 of file ossimImageFileWriter.cpp.
This is a generic interface to allow one to set the output name of the writer. If its a Visual display this could be used to set the title. If this is a file output then this could be a directory or a file name.
Reimplemented from ossimOutputSource.
Definition at line 1211 of file ossimImageFileWriter.cpp.
References setFilename(), and ossimOutputSource::setOutputName().
This implementation in this class does nothing and returns false. Derived classed should implement as needed.
| stream | The stream to write to. |
Definition at line 1184 of file ossimImageFileWriter.cpp.
tmp drb
Reimplemented in ossimPngWriter, ossimPdfWriter, ossimOpjJp2Writer, ossimKakaduJp2Writer, ossimKakaduNitfWriter, ossimWriter, and ossimGeneralRasterWriter.
Definition at line 1194 of file ossimImageFileWriter.cpp.
Definition at line 1245 of file ossimImageFileWriter.cpp.
Definition at line 1250 of file ossimImageFileWriter.cpp.
Reimplemented from ossimProcessInterface.
Definition at line 1204 of file ossimImageFileWriter.cpp.
References ossimListenerManager::fireEvent(), and ossimProcessInterface::setPercentComplete().
Referenced by while(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), and ossimNitfWriter::writeBlockBandSequential().
If "area" the coordinate tie points are relative to the upper left corner of the pixel.
For image types that are keyed, tiff for instance, this will set the geotiff key: GTRasterTypeGeoKey
If meta data writers are enabled, world file writers for instance, this will also be propagated to them.
Default in this writer is: OSSIM_PIXEL_IS_POINT
| type | OSSIM_PIXEL_IS_POINT = center of pixel OSSIM_PIXEL_IS_AREA = upper left corner of pixel |
Definition at line 1538 of file ossimImageFileWriter.cpp.
Referenced by setPixelType().
| type | "point" = center of pixel "area" = upper left corner of pixel |
Definition at line 1543 of file ossimImageFileWriter.cpp.
References ossimString::downcase(), OSSIM_PIXEL_IS_AREA, OSSIM_PIXEL_IS_POINT, and setPixelType().
Reimplemented in ossimWriter, ossimPdfWriter, ossimTiffWriter, ossimGpkgWriter, ossimPngWriter, ossimKmlSuperOverlayWriter, ossimOpjJp2Writer, ossimKakaduNitfWriter, ossimGdalWriter, ossimKakaduJp2Writer, ossimJpegWriter, ossimNitfWriter, ossimNitfWriterBase, and ossimNitf20Writer.
Definition at line 1255 of file ossimImageFileWriter.cpp.
References ossimKeywordNames::CREATE_EXTERNAL_GEOMETRY_KW, ossimKeywordNames::CREATE_HISTOGRAM_KW, ossimKeywordNames::CREATE_IMAGE_KW, ossimKeywordNames::CREATE_OVERVIEW_KW, ossimKeywordNames::FILENAME_KW, ossimProperty::getName(), theFilename, theScaleToEightBitFlag, theWriteEnviHeaderFlag, theWriteErsHeaderFlag, theWriteExternalGeometryFlag, theWriteFgdcFlag, theWriteHistogramFlag, theWriteImageFlag, theWriteJpegWorldFileFlag, theWriteOverviewFlag, theWriteReadmeFlag, theWriteTiffWorldFileFlag, and theWriteWorldFileFlag.
Referenced by ossimNitf20Writer::setProperty(), ossimJpegWriter::setProperty(), ossimKakaduJp2Writer::setProperty(), ossimGdalWriter::setProperty(), ossimKmlSuperOverlayWriter::setProperty(), ossimTiffWriter::setProperty(), and ossimPdfWriter::setProperty().
Definition at line 937 of file ossimImageFileWriter.cpp.
If not supported this simply sets the sequencer(input) tile size.
Reimplemented in ossimWriter, ossimNitfWriter, and ossimTiffWriter.
Definition at line 1574 of file ossimImageFileWriter.cpp.
References ossimImageSourceSequencer::setTileSize(), theInputConnection, and ossimRefPtr< T >::valid().
Definition at line 942 of file ossimImageFileWriter.cpp.
Definition at line 947 of file ossimImageFileWriter.cpp.
Definition at line 952 of file ossimImageFileWriter.cpp.
Referenced by ossimGeneralRasterWriter::ossimGeneralRasterWriter(), and ossimNitf20Writer::ossimNitf20Writer().
Definition at line 932 of file ossimImageFileWriter.cpp.
Definition at line 962 of file ossimImageFileWriter.cpp.
Definition at line 922 of file ossimImageFileWriter.cpp.
Definition at line 967 of file ossimImageFileWriter.cpp.
Definition at line 972 of file ossimImageFileWriter.cpp.
Definition at line 977 of file ossimImageFileWriter.cpp.
If "theFilename" is "foo.tif" then this will write out "foo.hdr".
Definition at line 500 of file ossimImageFileWriter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimMetadataFileWriter::execute(), ossimRefPtr< T >::get(), ossimIrect::hasNans(), ossimMetadataFileWriter::initialize(), ossimMetadataFileWriter::setAreaOfInterest(), ossimFilename::setExtension(), ossimMetadataFileWriter::setFilename(), ossimMetadataFileWriter::setPixelType(), ossimImageWriter::theAreaOfInterest, theFilename, theInputConnection, and thePixelType.
Referenced by writeMetaDataFiles().
Definition at line 527 of file ossimImageFileWriter.cpp.
If "theFilename" is "foo.tif" then this will write out "foo.geom".
Definition at line 554 of file ossimImageFileWriter.cpp.
If "theFilename" is "foo.tif" then this will write out "foo.xml".
Definition at line 581 of file ossimImageFileWriter.cpp.
protectedpure virtual |
Write out the file.
Implemented in ossimGpkgWriter, ossimPngWriter, ossimPdfWriter, ossimOpjJp2Writer, ossimWriter, ossimTiffWriter, ossimNitfWriter, ossimKakaduNitfWriter, ossimKakaduJp2Writer, ossimKmlSuperOverlayWriter, ossimJpegWriter, ossimGeneralRasterWriter, ossimNitf20Writer, ossimGdalWriter, and ossimArcInfoGridWriter.
Definition at line 780 of file ossimImageFileWriter.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimSource::enableSource(), ossimHistogramWriter::execute(), ossimRefPtr< T >::get(), ossimImageHandlerRegistry::instance(), ossimProcessInterface::needsAborting(), ossimOutputSource::open(), ossimFilename::setExtension(), ossimHistogramWriter::setFilename(), ossimImageHistogramSource::setMaxNumberOfRLevels(), theFilename, and theStdOutProgress.
If "theFilename" is "foo.tif" then this will write out "foo.jpw".
Definition at line 607 of file ossimImageFileWriter.cpp.
References ossimFilename::setExtension(), theFilename, and writeWorldFile().
Attempts to write all files flagged to be written even if one file writer returns false.
Currently calls these methods if flagged: writeEnviHeaderFile writeExternalGeometryFile writeFgdcFile writeJpegWorldFile writeReadmeFile writeTiffWorldFile writeOverviewFile writeHistogramFile
Definition at line 663 of file ossimImageFileWriter.cpp.
References ossimProcessInterface::needsAborting(), ossimNotify(), ossimNotifyLevel_WARN, status, theWriteEnviHeaderFlag, theWriteErsHeaderFlag, theWriteExternalGeometryFlag, writeEnviHeaderFile(), writeErsHeaderFile(), and writeExternalGeometryFile().
If source file is "foo.tif", this will create a "foo.ovr" in the same directory.
| source_file | The file to create overview from. |
| tiff_compress_type | valid types:
| jpeg_compress_quality | Compression quality. Only valid with COMPRESSION_JPEG. Range 1 to 100 with 100 being the best. default = 75 |
Definition at line 455 of file ossimImageFileWriter.cpp.
References ossimListenerManager::addListener(), ossimTiffOverviewBuilder::execute(), ossimRefPtr< T >::get(), ossimImageHandlerRegistry::instance(), ossimImageHandlerRegistry::open(), ossimListenerManager::removeListener(), ossimTiffOverviewBuilder::setCompressionType(), ossimTiffOverviewBuilder::setCopyAllFlag(), ossimFilename::setExtension(), ossimTiffOverviewBuilder::setInputSource(), ossimTiffOverviewBuilder::setJpegCompressionQuality(), ossimTiffOverviewBuilder::setOutputFile(), theFilename, theProgressListener, and ossimRefPtr< T >::valid().
If "theFilename" is "foo.tif" then this will write out "foo_readme.txt".
Definition at line 621 of file ossimImageFileWriter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimMetadataFileWriter::execute(), ossimRefPtr< T >::get(), ossimIrect::hasNans(), ossimMetadataFileWriter::initialize(), ossimFilename::noExtension(), ossimMetadataFileWriter::setAreaOfInterest(), ossimMetadataFileWriter::setFilename(), ossimMetadataFileWriter::setPixelType(), ossimImageWriter::theAreaOfInterest, theFilename, theInputConnection, and thePixelType.
This implementation does nothing and returns false. Derived classed should implement as needed.
Reimplemented in ossimPngWriter, ossimPdfWriter, ossimOpjJp2Writer, ossimKmlSuperOverlayWriter, ossimKakaduJp2Writer, ossimKakaduNitfWriter, ossimWriter, and ossimGeneralRasterWriter.
Definition at line 1166 of file ossimImageFileWriter.cpp.
If "theFilename" is "foo.tif" then this will write out "foo.tfw".
Definition at line 649 of file ossimImageFileWriter.cpp.
The extension will be derived from the image extension.
Currently handles the following image extensions:
"tif" or "tiff" -> "tfw" "jpg" of "jpeg" -> "jpw" "png" -> "pgw" "sid" -> "sdw"
If extension does not match one of the above no file will be written and false will be returned.
Definition at line 1582 of file ossimImageFileWriter.cpp.
References ossimString::downcase(), ossimFilename::ext(), ossimNotify(), ossimNotifyLevel_WARN, ossimFilename::setExtension(), ossimString::size(), and theFilename.
Referenced by writeJpegWorldFile(), and writeTiffWorldFile().
protected |
| file | The file to write like "foo.tfw" or "foo.jpw". |
Definition at line 1633 of file ossimImageFileWriter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimMetadataFileWriter::execute(), ossimRefPtr< T >::get(), ossimIrect::hasNans(), ossimMetadataFileWriter::initialize(), ossimMetadataFileWriter::setAreaOfInterest(), ossimMetadataFileWriter::setFilename(), ossimWorldFileWriter::setLinearUnits(), ossimMetadataFileWriter::setPixelType(), ossimImageWriter::theAreaOfInterest, theInputConnection, theLinearUnits, and thePixelType.
protected |
Definition at line 478 of file ossimImageFileWriter.h.
protected |
Definition at line 456 of file ossimImageFileWriter.h.
Referenced by ossimKmlSuperOverlayWriter::generateRootKml(), ossimKmlSuperOverlayWriter::getExtension(), getFilename(), getProperty(), ossimPdfWriter::getTitle(), ossimArcInfoGridWriter::isOpen(), ossimKmlSuperOverlayWriter::isOpen(), ossimArcInfoGridWriter::open(), ossimNitf20Writer::open(), ossimNitfWriter::open(), ossimJpegWriter::open(), ossimKakaduJp2Writer::open(), ossimKakaduNitfWriter::open(), ossimGeneralRasterWriter::open(), ossimKmlSuperOverlayWriter::open(), ossimPngWriter::open(), ossimWriter::open(), ossimPdfWriter::open(), ossimGpkgWriter::open(), ossimTiffWriter::openTiff(), ossimGdalWriter::postProcessOutput(), saveState(), setFilename(), setProperty(), ossimArcInfoGridWriter::writeBinaryAigBounds(), ossimArcInfoGridWriter::writeBinaryAigHeader(), ossimArcInfoGridWriter::writeBinaryAigStats(), ossimGdalWriter::writeBlockFile(), writeEnviHeaderFile(), writeErsHeaderFile(), writeExternalGeometryFile(), writeFgdcFile(), ossimArcInfoGridWriter::writeFile(), ossimJpegWriter::writeFile(), ossimKakaduJp2Writer::writeGeotiffBox(), writeHistogramFile(), writeJpegWorldFile(), writeOverviewFile(), writeReadmeFile(), writeTiffWorldFile(), and writeWorldFile().
protected |
Definition at line 453 of file ossimImageFileWriter.h.
Referenced by ossimGpkgWriter::addLevels(), ossimGdalWriter::allocateGdalDriverOptions(), ossimGdalWriter::buildGdalOverviews(), changeSequencer(), ossimGdalWriter::checkColorLut(), ossimTiffWriter::checkColorLut(), connectInputEvent(), disconnectInputEvent(), execute(), getSequencer(), ossimWriter::getTiffSampleFormat(), initialize(), ossimGdalWriter::isInputDataIndexed(), ossimWriter::needsMinMax(), ossimTiffWriter::openTiff(), ossimKmlSuperOverlayWriter::propagateViewChange(), ossimGpkgWriter::reInitializeCombiners(), ossimGpkgWriter::reInitializeCutters(), setAreaOfInterest(), setTileSize(), ossimPdfWriter::setupInputChain(), ossimGpkgWriter::setView(), while(), ossimArcInfoGridWriter::writeBinaryAigBounds(), ossimArcInfoGridWriter::writeBinaryAigHeader(), ossimArcInfoGridWriter::writeBinaryAigStats(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), ossimGdalWriter::writeBlockFile(), ossimGpkgWriter::writeEntry(), writeEnviHeaderFile(), writeErsHeaderFile(), writeExternalGeometryFile(), writeFgdcFile(), ossimArcInfoGridWriter::writeFile(), ossimNitf20Writer::writeFile(), ossimGeneralRasterWriter::writeFile(), ossimJpegWriter::writeFile(), ossimKmlSuperOverlayWriter::writeFile(), ossimKakaduJp2Writer::writeFile(), ossimKakaduNitfWriter::writeFile(), ossimNitfWriter::writeFile(), ossimWriter::writeFile(), ossimPngWriter::writeFile(), ossimNitfWriterBase::writeGeometry(), ossimKakaduJp2Writer::writeGeotiffBox(), ossimKakaduJp2Writer::writeGmlBox(), ossimWriter::writeMinMaxTiffTags(), ossimGdalWriter::writeProjectionInfo(), writeReadmeFile(), ossimPngWriter::writeSignificantBits(), ossimWriter::writeSMinSMaxTiffTags(), ossimGeneralRasterWriter::writeStream(), ossimWriter::writeStream(), ossimPngWriter::writeStream(), ossimWriter::writeTiffTags(), ossimTiffWriter::writeTiffTags(), ossimGpkgWriter::writeTiles(), writeWorldFile(), and ~ossimImageFileWriter().
protected |
If not a geographic projection this allows the user to set the linear units of the output tag to be:
meters (default) us_survey_feet feet
This will be propagated to writers that can switch types and to the associated metadata writers.
Definition at line 491 of file ossimImageFileWriter.h.
Referenced by ossimTiffWriter::getUnitType(), loadState(), and writeWorldFile().
protected |
Definition at line 457 of file ossimImageFileWriter.h.
Referenced by ossimGdalWriter::getExtension(), ossimWriter::getExtension(), ossimGdalWriter::getGdalOptions(), ossimGdalWriter::getGdalPropertyNames(), ossimGeneralRasterWriter::getInterleaveString(), getOutputImageType(), getOutputImageTypeString(), getProperty(), ossimTiffWriter::isTiled(), ossimWriter::isTiled(), ossimJpegWriter::loadState(), ossimGeneralRasterWriter::loadState(), ossimWriter::loadState(), ossimGdalWriter::open(), ossimWriter::open(), ossimNitf20Writer::ossimNitf20Writer(), ossimNitfWriter::ossimNitfWriter(), setOutputImageType(), ossimGdalWriter::setProperty(), ossimGeneralRasterWriter::writeFile(), ossimGeneralRasterWriter::writeStream(), ossimWriter::writeStream(), and ossimTiffWriter::writeTiffTags().
protected |
Definition at line 462 of file ossimImageFileWriter.h.
Referenced by getOverviewCompressType(), and setOverviewCompressType().
protected |
Definition at line 463 of file ossimImageFileWriter.h.
Referenced by getOverviewJpegCompressQuality(), and setOverviewJpegCompressQuality().
protected |
OSSIM_PIXEL_IS_POINT = 0, OSSIM_PIXEL_IS_AREA = 1.
Definition at line 494 of file ossimImageFileWriter.h.
Referenced by getPixelType(), getPixelTypeString(), loadState(), setPixelType(), writeEnviHeaderFile(), writeErsHeaderFile(), writeExternalGeometryFile(), writeFgdcFile(), writeReadmeFile(), and writeWorldFile().
protected |
Definition at line 455 of file ossimImageFileWriter.h.
Referenced by addListener(), removeListener(), writeOverviewFile(), and ~ossimImageFileWriter().
protected |
Definition at line 461 of file ossimImageFileWriter.h.
Referenced by getScaleToEightBitFlag(), loadState(), saveState(), setProperty(), and setScaleToEightBitFlag().
protected |
Definition at line 454 of file ossimImageFileWriter.h.
Referenced by connectInputEvent(), and disconnectInputEvent().
protected |
External meta data writer flags.
Not really part of an image writer, put here for convenience. If true the writer will do the connection work for you.
Definition at line 470 of file ossimImageFileWriter.h.
Referenced by getWriteEnviHeaderFlag(), loadState(), saveState(), setProperty(), setWriteEnviHeaderFlag(), and writeMetaDataFiles().
protected |
Definition at line 471 of file ossimImageFileWriter.h.
Referenced by getWriteErsHeaderFlag(), loadState(), saveState(), setProperty(), setWriteErsHeaderFlag(), and writeMetaDataFiles().
protected |
Definition at line 472 of file ossimImageFileWriter.h.
Referenced by getWriteExternalGeometryFlag(), loadState(), saveState(), setProperty(), setWriteExternalGeometryFlag(), and writeMetaDataFiles().
protected |
Definition at line 473 of file ossimImageFileWriter.h.
Referenced by getWriteFgdcFlag(), loadState(), saveState(), setProperty(), and setWriteFgdcFlag().
protected |
Definition at line 460 of file ossimImageFileWriter.h.
Referenced by getWriteHistogramFlag(), loadState(), saveState(), setProperty(), and setWriteHistogramFlag().
protected |
Definition at line 458 of file ossimImageFileWriter.h.
Referenced by getWriteImageFlag(), loadState(), saveState(), setProperty(), and setWriteImageFlag().
protected |
Definition at line 474 of file ossimImageFileWriter.h.
Referenced by getWriteJpegWorldFileFlag(), loadState(), saveState(), setProperty(), and setWriteJpegWorldFile().
protected |
Definition at line 459 of file ossimImageFileWriter.h.
Referenced by getWriteOverviewFlag(), loadState(), saveState(), setProperty(), and setWriteOverviewFlag().
protected |
Definition at line 475 of file ossimImageFileWriter.h.
Referenced by getWriteReadmeFlag(), loadState(), saveState(), setProperty(), and setWriteReadme().
protected |
Definition at line 476 of file ossimImageFileWriter.h.
Referenced by getWriteTiffWorldFileFlag(), loadState(), saveState(), setProperty(), and setWriteTiffWorldFile().
protected |
Definition at line 477 of file ossimImageFileWriter.h.
Referenced by getWriteWorldFileFlag(), loadState(), saveState(), setProperty(), and setWriteWorldFile().
