ossimMetadataFileWriter More...
#include <ossimMetadataFileWriter.h>
| ossimMetadataFileWriter () | |
| virtual bool | execute () |
| virtual void | setPercentComplete (double percentComplete) |
| virtual void | setFilename (const ossimFilename &file) |
| const ossimFilename & | getFilename () const |
| Load state method: More... | |
| virtual void | setPixelType (ossimPixelType pixelType) |
| Ossim uses a concept of "pixel is point" internally. More... | |
| virtual ossimPixelType | getPixelType () const |
| virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
| Sets the area of interest to write the meta data for. More... | |
| virtual ossimIrect | getAreaOfInterest () const |
| virtual void | getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const =0 |
| void getMetadatatypeList(std::vector<ossimString>& metadatatypeList)const More... | |
| virtual bool | hasMetadataType (const ossimString &metadataType) const =0 |
| bool hasMetadataType(const ossimString& metadataType) const More... | |
| ossimObject () | |
| ossimListenerManager () | |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimMetadataFileWriter () |
| virtual bool | writeFile ()=0 |
| Write out the file. More... | |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Typical usage something like this:
ossimObject* obj = ossimImageMetaDataWriterRegistry::instance()-> createObject(ossimString("ossimReadmeFileWriter")); if (!obj) { return; } ossimMetadataFileWriter* mw = PTR_CAST(ossimMetadataFileWriter, obj); if (!mw) { return; }
mw->setFilename(xmlFile); mw->loadState(kwl); mw->connectMyInputTo(ih.get()); mw->execute(); delete mw;
Definition at line 50 of file ossimMetadataFileWriter.h.
| ossimMetadataFileWriter::ossimMetadataFileWriter | ( | ) |
Definition at line 32 of file ossimMetadataFileWriter.cpp.
References ossimListenerManager::addListener(), ossimIrect::makeNan(), and theAreaOfInterest.
protectedvirtual |
Definition at line 45 of file ossimMetadataFileWriter.cpp.
References ossimListenerManager::removeListener().
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 220 of file ossimMetadataFileWriter.cpp.
References PTR_CAST.
Reimplemented from ossimConnectableObjectListener.
Definition at line 101 of file ossimMetadataFileWriter.cpp.
References initialize().
Definition at line 96 of file ossimMetadataFileWriter.cpp.
Implements ossimProcessInterface.
Definition at line 131 of file ossimMetadataFileWriter.cpp.
References initialize(), and theInputConnection.
Referenced by ossimImageFileWriter::writeEnviHeaderFile(), ossimImageFileWriter::writeErsHeaderFile(), ossimImageFileWriter::writeExternalGeometryFile(), ossimImageFileWriter::writeFgdcFile(), ossimImageFileWriter::writeReadmeFile(), and ossimImageFileWriter::writeWorldFile().
Definition at line 236 of file ossimMetadataFileWriter.cpp.
References theAreaOfInterest.
| const ossimFilename & ossimMetadataFileWriter::getFilename | ( | ) | const |
Definition at line 215 of file ossimMetadataFileWriter.cpp.
References theFilename.
pure virtual |
pure virtual
Appends the writers metadata types to the "metadatatypeList".
This is the actual image type name. So for example, ossimTiffWorldFileWriter has tiff_world_file type.
| metadatatypeList | stl::vector<ossimString> list to append to. |
Implemented in ossimFgdcFileWriter, ossimEnviHeaderFileWriter, ossimWorldFileWriter, ossimERSFileWriter, ossimReadmeFileWriter, and ossimGeomFileWriter.
Referenced by ossimImageMetaDataWriterFactory::getMetadatatypeList().
Definition at line 121 of file ossimMetadataFileWriter.cpp.
Definition at line 126 of file ossimMetadataFileWriter.cpp.
Definition at line 116 of file ossimMetadataFileWriter.cpp.
References thePixelType.
Reimplemented from ossimConnectableObject.
Definition at line 257 of file ossimMetadataFileWriter.cpp.
References ossimKeywordNames::FILENAME_KW, ossimConnectableObject::getProperty(), ossimFilenameProperty::ossimFilenamePropertyIoType_OUTPUT, ossimFilenameProperty::setIoType(), and theFilename.
Definition at line 273 of file ossimMetadataFileWriter.cpp.
References ossimKeywordNames::FILENAME_KW, and ossimConnectableObject::getPropertyNames().
pure virtual |
| imageType | string representing image type. |
Referenced by ossimImageMetaDataWriterFactory::createWriter().
Definition at line 50 of file ossimMetadataFileWriter.cpp.
References ossimConnectableObject::getInput(), and theInputConnection.
Referenced by connectInputEvent(), disconnectInputEvent(), execute(), propertyEvent(), ossimImageFileWriter::writeEnviHeaderFile(), ossimImageFileWriter::writeErsHeaderFile(), ossimImageFileWriter::writeExternalGeometryFile(), ossimImageFileWriter::writeFgdcFile(), ossimImageFileWriter::writeReadmeFile(), and ossimImageFileWriter::writeWorldFile().
Load state method:
This method call base class ossimConnectableObject::loadState then looks for its keywords.
| kwl | Keyword list to initialize from. |
| prefix | Usually something like: "object1." |
Keywords picked up by loadState:
filename: foo.tfw
(pixel_type should be area or point)
pixel_type: area
Reimplemented in ossimFgdcFileWriter, ossimEnviHeaderFileWriter, ossimWorldFileWriter, and ossimERSFileWriter.
Definition at line 55 of file ossimMetadataFileWriter.cpp.
References ossimString::contains(), ossimString::downcase(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimConnectableObject::loadState(), OSSIM_PIXEL_IS_AREA, OSSIM_PIXEL_IS_POINT, ossimKeywordNames::PIXEL_TYPE_KW, setFilename(), ossimConnectableObject::theInputListIsFixedFlag, ossimConnectableObject::theInputObjectList, ossimConnectableObject::theOutputListIsFixedFlag, and thePixelType.
Referenced by ossimERSFileWriter::loadState(), ossimEnviHeaderFileWriter::loadState(), and ossimFgdcFileWriter::loadState().
Definition at line 106 of file ossimMetadataFileWriter.cpp.
| areaOfInterest | Sets theAreaOfInterest. |
Definition at line 230 of file ossimMetadataFileWriter.cpp.
Definition at line 210 of file ossimMetadataFileWriter.cpp.
Referenced by loadState(), setProperty(), ossimImageFileWriter::writeEnviHeaderFile(), ossimImageFileWriter::writeErsHeaderFile(), ossimImageFileWriter::writeExternalGeometryFile(), ossimImageFileWriter::writeFgdcFile(), ossimImageFileWriter::writeReadmeFile(), and ossimImageFileWriter::writeWorldFile().
Reimplemented from ossimProcessInterface.
Definition at line 202 of file ossimMetadataFileWriter.cpp.
References ossimListenerManager::fireEvent(), and ossimProcessInterface::setPercentComplete().
This means that if you say a tie point is 30.0N -81.0W, the center of the pixel at the tie point is 30.0N -81.0W.
Definition at line 111 of file ossimMetadataFileWriter.cpp.
property interface
Definition at line 241 of file ossimMetadataFileWriter.cpp.
References ossimKeywordNames::FILENAME_KW, setFilename(), ossimConnectableObject::setProperty(), ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
protectedpure virtual |
Write out the file.
Implemented in ossimFgdcFileWriter, ossimWorldFileWriter, ossimEnviHeaderFileWriter, ossimERSFileWriter, ossimGeomFileWriter, and ossimReadmeFileWriter.
protected |
Definition at line 171 of file ossimMetadataFileWriter.h.
Referenced by getAreaOfInterest(), ossimMetadataFileWriter(), setAreaOfInterest(), ossimGeomFileWriter::writeFile(), ossimERSFileWriter::writeFile(), and ossimEnviHeaderFileWriter::writeFile().
protected |
Definition at line 169 of file ossimMetadataFileWriter.h.
Referenced by getFilename(), getProperty(), setFilename(), ossimERSFileWriter::writeFile(), ossimEnviHeaderFileWriter::writeFile(), and ossimFgdcFileWriter::writeFile().
protected |
Definition at line 168 of file ossimMetadataFileWriter.h.
Referenced by execute(), initialize(), ossimGeomFileWriter::writeFile(), ossimReadmeFileWriter::writeFile(), ossimERSFileWriter::writeFile(), ossimEnviHeaderFileWriter::writeFile(), and ossimFgdcFileWriter::writeFile().
protected |
Definition at line 170 of file ossimMetadataFileWriter.h.
Referenced by getPixelType(), loadState(), setPixelType(), and ossimERSFileWriter::writeFile().
